Audi A6 C7 Keyless Entry retrofit
CuturiloD
Serbia
C?ID=361908
I would like to retrofit Audi A6 C7 keyless entry.
I was buy 8K0907247 antenna in the door 2pc and 4G8927753 door sensor x 4pcs.
Also I think that I need to replace BCM2 4H0907064FN with another who have support for keyless entry.
I would be appreciate if someone have experience with this issue and provide me part number(BCM2) what I need.
Also I would like to know how to adapt my keys with new BCM2.
Here is my autoscan:
Tuesday,26,March,2019,16:23:39:48786
VCDS Version: 19.1.2.0 (x64)  HEX-V2 CB: 0.4502.4
Data version: 20190131 DS301.0
VIN: WAUZZZ4GXFN075726   License Plate: SU106US
Mileage: 138796km-86243mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 36 3B 3C 42 44 46 52
          53 55 5F 62 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4GXFN075726   Mileage: 138796km-86243miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 0A25401A234401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFEF19E952BBEFEFD-802C
   Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000000191
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002014
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 323D183574A488B76E7-8066
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A29E49604579929B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB4101B7F655DF919-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A8700E000000000000
   VCID: 7AADF015ECD4B0F7E67-802E
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 02031500110355
   Coding: 34110908250000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619FA77961C2432FC7D-8034
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001021731202
   Coding: 0105001440349FE2C1014083A0001800CF9CC3082E08020100000494E10114020040002C030000
   VCID: 71BFD739B1A2F3AF57D-8024
   Component: WWS57X 150211  H37 0080
   Serial number:         150216124312
   Coding: 0045F7
   Serial number: 23783453
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 26 02 2015  00000172
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 70884397000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290FFF595972CB6FDFD-807C
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1003J2GQ
   Coding: 30333130313630323437554A304C34473053
   VCID: 3B233511A3EE49FFBD1-806E
   Serial number: 3575HRB405R33HNKA83Q
   Serial number: 3585HRB4055373K63137
   Serial number: 3515JRB405V35IMQ80V9
   Serial number: 3525JRB405136K44BPC
   Serial number: 3554VRB4055352USNH2
   Serial number: 3564VRB405L352USD9A2
   Revision: --------    Serial number: 90372OC40003T
   Coding: 0000DC
   VCID: 372B29219F466D9F599-8062
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 14 02 2015  B0046748
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H08 0043
   Revision: 04001037    Serial number: 658050315596015
   Coding: 138E0A004F452008010400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 33331D318BBE81BF651-8066
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140912135011
   Coding: 5D3F01
   VCID: 2615F46548ECE417F2F-8072
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001752716
   Coding: C0CD074418
   VCID: 73B3DD31CB3EC1BFA51-8026
   Serial number: 6114185803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1412220000000000033D
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   VCID: 7CA1F60DE6E08EC7F4B-8028
   Revision: AA000000    Serial number: 00000138195316
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77ABE921DFC6AD9F999-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA82093LMG
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635242598CC949742F-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0366301422
   Coding: 040311
   VCID: 392F2F19A9D27BEFAFD-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0367089970
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F17015E00628002080013
   VCID: 45D753E9D5AA0F0FDB5-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0020537707
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0362711599
   Coding: 0100063800B93080C32008840C010E470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00011413809
   Component: TSG BF        H03 0507
   Coding: 011F17015E00628002080002
   VCID: 46D554E5E8AC0417D2F-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001381341
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070B496D9AD74F335-8078
   Coding: 04FA02102A600200
   VCID: 34311E2D8EB086877CB-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
   Component: RMC Cnct Nav  H61 0139
   Coding: 0100000101D5DB474C2B060301010000000001
   VCID: 221DE87524C418379E7-8076
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464B/0F2705992
   Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OC50006O
   Component: TSG HL        H03 0507
   Coding: 010F15004000628002080002
   VCID: 49CF5FD9F9B2EB6F3FD-801C
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 044500038
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0507
   Component: DPC-SG        H27 0081
   Coding: 7A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01064D5680DE4724B-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270BF9614F66FD1FC99-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000620503157
   Coding: 04C099181211
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 00660600031F0376000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F173971A2B3AF17D-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150360032
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:05, VBatt start/end: 12.4V/12.3V)-----------
Thank in advanced.
Audi dealer, or an independent mechanic with a legitimate ODIS and GeKo access credentials.
Bogdan.audi
Ukraine
C?ID=90275
Hey. As I remember, block 46 is not necessary to change. Its parameter is required.
CuturiloD
Serbia
C?ID=361908
I was try to recode my Modul 46 ( byte 2 bit 3 and byte 7 bit 0), also modul 05 (byte 0 bit 2 and byte 2 bit 4).
When I press DO IT for coding VCDS give to me message “code is out of area” or “code is rejected” or something like that.
It is correct procedure or I doing something wrong?
Bogdan.audi
Ukraine
C?ID=90275
Hello. This is done with other tools(VCP,SRT CAN). It is necessary to fill in the data set in the block.
CuturiloD
Serbia
C?ID=361908
Hello, thanks for answer. I was find the guy who have this tools. But I need data for my BCM. Do you maybe correct have data?
Bogdan.audi
Ukraine
C?ID=90275
Hello.
Vcp----A6_start_auth_4H0907064Fx.zdc
I think a person who has tools knows how to use them))))
XPepino
Czech Republic
C?ID=91614
Hello guys
Can you tell me if your original 46 unit was working with kessy or you have to swap it ?
I have: Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
I still have no connected sensors and antena, but i first tried, if my 46 Comfort unit is ok for kessy.
I flashed it twice:
A6_start_auth_4H0907064Fx.zdc - everything ok, but after flash is still not possible recode to Advanced key. There is no option to get this back to NoKessy with this ZDC, so after flash there was not working start button (i have to put key to place on NAVI, after this it started). So i tried second one:
A7_start_auth_4h0907064BP,BR,BT,DB,DC,Dx,Ex,Fx,Gx.zdc -after flash there was error - no antena connected - it seems to be fine, but in VCDS 05 and 46 i was not able to recode to Advanced Key - coding rejected! In this ZDC is return process - no keyless so i flashed back to non Keyless version! After this everything works like before.
In discusion it seems that unit ending xxxxN have no ability of keyless, what do you mean?
In second car i already sell i have kessy and this unit: Part No SW: 4H0 907 064 GP HW: 4H0 907 064 GP
Thank you for your time and reply :-)
CuturiloD
Serbia
C?ID=361908
Hi,
Sorry but I was gave up from this retrofit because I was sell this car. And I can confirm nothing with this topic.
But if You solve problem with parametrization on Your #46, I still have antens and sensors.
XPepino
Czech Republic
C?ID=91614
I think, that i have to swap 46 Comfort unit - i see lot of scans, and no xxxxxN comfort unit have keyless.
I let audi swap it, so i will see if it will be ok. I already have all stuff for it but thank you ...
I let here know my conclusion...
