Marcus.Moodley
Hi All,
I own a 2013 golf 7, GTI , DSG
I would like to change my ordinary blinking indicator tail lights to running lights.
Please advise me
Is this possible, and if so,
which code do I use.?
Please also, refer to auto scan below.
Please advise me
Tuesday,09,April,2019,14:50:57:29224
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 18.9.1.0
VIN: WVWZZZAUZDW165282 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F A9
VIN: WVWZZZAUZDW165282 Mileage: 89108km-55369miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 091D00324424050B2000
ASAM Dataset: EV_ECM20TFS0215G0906259 001009
ROD: EV_ECM20TFS0215G0906259_VW37.rod
VCID: 6BD324DD82F7D81218-803E
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
Mileage: 88717 km
Date: 2019.04.01
Time: 18:26:44
Engine speed: 743.50 /min
Normed load value: 18.8 %
Vehicle speed: 4 km/h
Coolant temperature: 96 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.550 V
Unlearning counter according OBD: 20
Engine: operating status: IS
N_TOOTH: 738 /min
T_AST_SAE: 401 s
Engine oil temperature: 38.0 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 20090.0 kPa
FUP_EFP_MES: 4882.18 hPa
Part No SW: 0D9 300 040 B HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4002
Revision: 05652104 Serial number: TFK01304130806
ROD: EV_TCMDQ250021.rod
VCID: 16252529E9F5B5FA17-8042
P1734 00 [002] - -
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6111300000013D
Coding: 01FA93A13426297103790608C1C5A980C92C94C0608395F500420038C109
VCID: 7BF3149DF297489288-802E
0213 - Vacuum sensor
C10A3 29 [008] - Signal Implausible
Reset counter: 244
Date: 2019.03.27
Time: 19:43:45
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 219
Mileage: 67956 km
Date: 2017.12.17
Time: 10:47:18
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 9
Mileage: 88951 km
Date: 2019.04.05
Time: 18:15:46
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120014200100011005000012101800
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 3665C5A9893555FA37-8062
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011311901762
Coding: 03101B46C24122FB0FA44080B10C0708100A000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_010.rod
VCID: 4685B569F9D5C57AA7-8012
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130419 042 0551
Serial number: 130426110501
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M05D01H21M19S54S4
Coding: 00A8DD
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY130931KQ3
Serial number: 00000000000056572436
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO2142181-
Coding: 181801
B1263 01 [008] - Electrical Failure
Reset counter: 17
535060 - Databus
Reset counter: 207
Mileage: 88640 km
Date: 2019.03.29
Time: 16:08:53
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231312301395
Coding: 0031051011
ASAM Dataset: EV_EPHVA18AU3700000 002019
VCID: 3B73D49DB2178892C8-806E
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R04T4ST
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4089A371DBF1EB4A9D-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 404 13
Serial number: 357670000003EA952D0+
Subsystem 2 - Part No SW: ----------- HW: 480 002 204 13
Serial number: 35867000000CB85D3D08
Subsystem 3 - Part No SW: ----------- HW: 480 402 504 13
Serial number: 3516502BF101233471E+
Subsystem 4 - Part No SW: ----------- HW: 480 400 205 13
Serial number: 3526502BB1012331806R
Subsystem 5 - Part No SW: ----------- HW: 480 402 504 13
Serial number: 3556502AF105065292D8
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 27041308490180
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 79FF0E95F8AB7A829A-802C
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 313 2210
Coding: 27AD09082B80000800082A00000000
VCID: 6CD127C187F9DF2A11-8038
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000539284
Coding: 030100042B085900EF00026A1C0F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130000545320093172
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2404110403
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02028864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B53E4DD4277181258-807E
4186894 - Internal Control Module Memory Check Sum Error
B2000 47 [009] - Watchdog/safety µC failure
Mileage: 63599 km
Date: 2017.10.10
Time: 17:20:34
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 26041304080705
Coding: 003E02208001040000001000
VCID: 3F8BA08DA60F94B2E4-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001329375
Coding: 0D0000
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 246
Mileage: 87213 km
Date: 2019.02.22
Time: 14:18:02
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 D
Component: EPS_MQB_ZFLS 501 5011
Coding: 0101
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: 3363FCBD9A4740D210-8066
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 16021301100875
Coding: 003E00208E01040000801000
VCID: 3E75DD89A1059DBAEF-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001287756
Coding: 050000
Fault Frequency: 12
Reset counter: 15
Mileage: 85708 km
Date: 2019.01.10
Time: 23:24:08
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029E01000B000200
VCID: 3D77DA85AC0386A2F6-8068
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
5276433 - Stationary Cornering Lamp Left
C1083 11 [008] - Short to Ground
Reset counter: 17
Mileage: 72831 km
Date: 2018.03.16
Time: 05:32:02
5276435 - Stationary Cornering Lamp Left
C1083 13 [009] - Open Circuit
Reset counter: 232
Mileage: 63483 km
Date: 2017.10.06
Time: 15:29:25
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 039 0407
Serial number: V1C00105130572
Coding: 02730000FF00000011110001001800001F0203860100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 275B18ED5E9F3C72BC-8072
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N2402ST1
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0011
Serial number: 130415200097
End-------------------------(Elapsed Time: 04:45)--------------------------
Gateway Installation List: 5Q0 907 530 M
Address 09: Cent. Elect. Labels: 5Q0-937-08X-HV1.clb
Control Module Part Number: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component and/or Version: BCM MQBAB H H14 0106
Software Coding: 03101B46C24122FB0FA44080B10C0708100A000000000000000000000000
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_BCMCONTI 010001 (VW37)
535060 - Databus
Reset counter: 232
Mileage: 89108 km
Date: 2019.04.08
Time: 14:57:55
Address 09: DTCs cleared
Address 20: High Beam Assist. Labels: 8X0-857-511.clb
Control Module Part Number: 5G0 857 511 D HW: 5G0 857 511 D
Component and/or Version: FLA H05 0002
Software Coding: 02028864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009 (VW37)
Mileage: 63599 km
Date: 2017.10.10
Time: 17:20:34
Address 20: DTCs cleared
