Hi
I wonder if someone can point me in the right direction.
I have an Audi Q7 2008 with the following autoscan.....
Loads of codes but the main issue is poor charging and flat battery issues
It has had a new battery but I have not been able to code the energy management because I can't establish communication with 61. Battery Regul.
I have good live and earth at the module and opposing seemingly ok CAN signals. I have tried a new module.
So many fault codes!
Has anyone seen this before?
Tuesday,09,April,2019,17:52:17:20916
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4L28D055959 License Plate: DV08NBN
Mileage: 180040km-111871mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 34 37 42 46 47 4F
52 55 56 61 62 67 6D 6F 72 76 77
VIN: WAUZZZ4L28D055959 Mileage: 180040km-111871miles
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: Malfunction 1010
1E-Media Player 2 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (CAS) Labels:. 059-907-401-CAT1.clb
Part No SW: 4L1 910 401 D HW: 4L0 907 401 A
Component: 3.0TDI EDC17G100AG 0080
Revision: --H01--- Serial number:
Coding: 0121002C190F0168
Shop #: WSC 00052 210 88667
VCID: 24405212E78A4B6A99-8070
049425 - No Communication with Battery Energy Control Module
U0111 - 001 -
Fault Status: 01100001
Fault Frequency: 52
Mileage: 179371 km
Date: 2019.08.10
Time: 10:30:37
RPM: 777 /min
Voltage: 13.30 V
Bin. Bits: 00000000
(no units): 4.0
Bin. Bits: 00000000
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 000 - Signal too High (Rich)
Mileage: 179386 km
Date: 2019.08.10
Time: 15:52:53
RPM: 2079 /min
Speed: 106.4 km/h
Lambda: 67.9 %
(no units): 0.0
Voltage: 0.980 V
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Mileage: 180041 km
Date: 2007.05.16
Time: 14:52:04
Voltage: 8.44 V
Temperature: 48.6°C
Lambda: 0.0 %
Torque: 0.0 Nm
049682 - Steering Column Control Module
U0212 - 002 - No Communications - Intermittent
Mileage: 180041 km
Date: 2007.05.16
Time: 14:01:29
Voltage: 11.55 V
Bin. Bits: 00000000
(no units): 8.0
Bin. Bits: 00000000
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 HT HW: 09D 927 750 HT
Component: AL 750 6A 1164
Revision: 00H78000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 071A259E767C80729C-8052
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
00364 - Terminal 15 Slave
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0103569
VCID: 295E432680A89602AA-807C
Reset counter: 44
Mileage: 179375 km
Date: 2019.08.10
Time: 10:58:39
Count: 10305
Count: 128
Count: 35072
Reset counter: 44
Mileage: 179451 km
Count: 128
Count: 2881
Count: 297
Count: 26880
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601501008404
Coding: 0000147
VCID: 63C2110EA2040C52A0-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
02072 - Control Module for Energy Management (J644)
Reset counter: 35
Mileage: 179371 km
Date: 2019.08.10
Time: 10:30:44
Fault Frequency: 12
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 12:06:54
Fault Frequency: 37
Reset counter: 84
Mileage: 179412 km
Date: 2019.08.11
Time: 11:10:26
00230 - Transmission Park Selector Switch (F305)
Fault Status: 00101010
Reset counter: 82
Mileage: 179938 km
Date: 2007.05.16
Time: 13:37:36
Address 07: Control Head
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 B HW: 4L0 820 043 L
Component: KLIMABETAETIGUNGH07 0030
Revision: 00---013 Serial number: 00000000158125
Coding: 0001046
VCID: 2342510EE2844C52E0-8076
10 Faults Found:
01854 - Heated Seat; Front Right (Z46)
Reset counter: 44
Mileage: 179371 km
Date: 2019.08.10
Time: 10:23:53
Temperature: 18.0°C
Reset counter: 35
Mileage: 179371 km
Date: 2019.08.10
Time: 10:23:53
Bin. Bits: 001111
Fault Frequency: 12
Reset counter: 84
Mileage: 179375 km
Date: 2019.08.10
Time: 10:58:57
Voltage: 9.90 V
Reset counter: 84
Mileage: 179781 km
Date: 2019.08.16
Time: 16:48:44
Bin. Bits: 01111
Reset counter: 81
Mileage: 179856 km
Date: 2019.08.17
Time: 13:29:07
Reset counter: 81
Mileage: 179938 km
Date: 2007.05.16
Time: 13:34:17
Voltage: 8.20 V
Reset counter: 82
Mileage: 179938 km
Date: 2007.05.16
Time: 13:37:40
Temperature: 49.0°C
Temperature: 18.0°C
Load: 8.8 %
Temperature: -55.0°C
RPM: 760 /min
Absolute Pres.: 7.0 bar
Current: 0.000 A
Temperature: 10.0°C
01853 - Heated Seat; Left Front (Z45)
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.16
Time: 12:00:48
Temperature: 8.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Fault Status: 01101010
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.16
Time: 12:00:48
Temperature: 8.0°C
Fault Status: 00101100
Reset counter: 84
Mileage: 180041 km
Date: 2007.05.16
Time: 14:01:28
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0013121
VCID: 316EAB46A878EEC262-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00022806
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150059
Shop #: WSC 31414
Fault Status: 00101011
Reset counter: 75
Mileage: 179368 km
Date: 2019.08.10
Time: 10:33:00
00908 - Control Module for Wiper Motor
Reset counter: 80
Mileage: 179780 km
Date: 2019.08.16
Time: 16:50:00
Fault Frequency: 15
Reset counter: 84
Mileage: 179472 km
Date: 2019.08.13
Time: 14:06:00
Fault Frequency: 8
Reset counter: 84
Mileage: 179472 km
Date: 2019.08.14
Time: 12:04:00
Address 0E: Media Player 1
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D046S6Z
Coding: 0014129
VCID: 2E54B03AB946F13A7F-807A
Subsystem 1 - Serial number: 6332QSME512E2E3BR
Subsystem 2 - Serial number: 6342QSME5B540839L
Subsystem 3 - Serial number: 6352QSME5B540707G
Subsystem 4 - Serial number: 6362QSME5B571739Q
Subsystem 5 - Serial number: 63734SME5247240D
Subsystem 6 - Serial number: 63834SME526D096DD
002 - Lower Limit Exceeded - Intermittent - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
000 - - - Intermittent - MIL ON
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055080420161
Coding: 0102142
VCID: 275A451E96BCA072BC-8072
Component: E0221 H02 0030
Fault Frequency: 39
Reset counter: 44
Mileage: 179371 km
Date: 2019.08.10
Time: 10:23:55
Reset counter: 84
Mileage: 179646 km
Date: 2019.08.15
Time: 18:13:06
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 981 B
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 741548X28
Coding: 3681458
Shop #: WSC 50741 067 57207
Reset counter: 81
Mileage: 179475 km
Date: 2019.08.13
Time: 14:05:49
00771 - Fuel Level Sensor (G)
Fault Status: 00100111
Reset counter: 81
Mileage: 179856 km
Date: 2019.08.17
Time: 15:33:19
00438 - Fuel Supply Sensor 2 (G169)
Reset counter: 81
Mileage: 179856 km
Date: 2019.08.17
Time: 15:33:19
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 E
Component: Heizgeraet H08 0090
Revision: 0000000D Serial number: 00000009014264
Coding: 0000001
VCID: 60C81E02B312174ABD-8034
00664 - Fuel gauge
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08219835B
Coding: F55BBE7F70720200
VCID: 2D56B736B4408A2246-8078
Reset counter: 35
Mileage: 179371 km
Date: 2019.08.10
Time: 10:24:04
Reset counter: 35
Mileage: 179371 km
Date: 2019.08.10
Time: 10:25:00
00384 - Optical Databus
Reset counter: 75
Mileage: 179451 km
Date: 2019.08.11
Time: 12:10:52
Reset counter: 80
Mileage: 179856 km
Date: 2019.08.17
Time: 15:36:23
Reset counter: 81
Mileage: 179938 km
Date: 2007.05.16
Time: 13:34:17
Reset counter: 84
Mileage: 180041 km
Date: 2007.05.16
Time: 14:00:26
Address 1E: Media Player 2
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
VCID: 2A5CBC2A85AE9D1AA3-807E
Fault Frequency: 27
Reset counter: 168
Mileage: 179375 km
Date: 2019.08.10
Time: 10:58:33
Error Code: 13
Reset counter: 168
Error Code: 64
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Reset counter: 78
Mileage: 179675 km
Date: 2019.08.15
Time: 18:44:28
Error Code: 68
Fault Status: 00101001
Reset counter: 79
Mileage: 179781 km
Date: 2019.08.16
Time: 16:52:52
Error Code: 8
013 - Check DTC Memory
Fault Status: 11101101
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.16
Time: 12:58:46
Error Code: 98
Address 37: Navigation
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00-00000
Coding: 0002651
VCID: 2F6AAD3EBE4CF83274-807A
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.16
Time: 12:00:36
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H08 0060
Revision: 0060 --- Serial number: 01094255600000
Coding: 7348475
VCID: 3362A14E5264DCD210-8066
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
01699 - Motor for Central Locking; Hatch/Trunk (V53)
Fault Status: 01101001
Fault Frequency: 17
Reset counter: 44
Mileage: 179412 km
Date: 2019.08.10
Time: 16:39:34
Fault Frequency: 16
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.17
Time: 09:42:41
03073 - Rear Lid Closed Sensor 1
Reset counter: 81
Mileage: 179938 km
Date: 2007.05.16
Time: 12:39:01
Reset counter: 84
Mileage: 180041 km
Date: 2007.05.16
Time: 15:07:51
Address 47: Sound System
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000075665
Coding: 0011101
VCID: 5EB420FA896621BA8F-800A
Reset counter: 44
Mileage: 179368 km
Date: 2019.08.10
Time: 10:30:00
Voltage: 13.300 V
Temperature: 5.0°C
Reset counter: 80
Mileage: 179856 km
Date: 2019.08.17
Time: 13:19:00
Voltage: 11.700 V
Temperature: 77.0°C
Fault Status: 00110010
Reset counter: 84
Mileage: 179472 km
Date: 2019.08.14
Time: 19:05:00
Voltage: 8.400 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0002651
Fault Frequency: 94
Reset counter: 44
Mileage: 179371 km
Date: 2019.08.10
Time: 10:24:10
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 19:10:39
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 19:10:39
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000022
VCID: 69DE0326402856026A-803C
Component: AFS-Modul links H06 0002
02233 - Left Headlight Power Output Stage (J667)
Reset counter: 79
Mileage: 179781 km
Date: 2019.08.16
Time: 16:51:42
Reset counter: 44
Mileage: 179856 km
Date: 2019.08.17
Time: 13:27:08
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.20
Time: 12:07:34
Address 56: Radio
Address 61: Battery Regul.
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0002058
Fault Frequency: 138
Reset counter: 44
Mileage: 179371 km
Date: 2019.08.10
Time: 10:24:17
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 19:10:39
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 19:10:39
Address 67: Voice Control
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 00613 210 88222
VCID: 6CD07A324FDA432A11-8038
Subsystem 3 - Serial number: RD28.02.08--H25001001C0113ÿ
Subsystem 4 - Serial number: 1C0113ÿ
Fault Frequency: 27
Reset counter: 44
Mileage: 180041 km
Date: 2007.05.16
Time: 14:18:42
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003510394-----
Coding: 0000001
VCID: 65C60F16AC3072624E-8030
Fault Frequency: 137
Reset counter: 44
Mileage: 179371 km
Date: 2019.08.10
Time: 10:24:21
01516 - Terminal 30; Left
Reset counter: 80
Mileage: 179451 km
Date: 2019.08.11
Time: 12:31:13
Fault Frequency: 17
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 12:06:54
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0002058
Fault Frequency: 134
Reset counter: 44
Mileage: 179371 km
Date: 2019.08.10
Time: 10:24:22
Reset counter: 84
Mileage: 179475 km
Date: 2019.08.14
Time: 19:10:39
Part No SW: 4F0 910 283 K HW: 4F0 919 283 K
Component: Parkhilfe 8-Kan H12 0100
Revision: 00H12000 Serial number: 69830804903838
Coding: 0201146
VCID: 2C50BA328F5A832A51-8078
Reset counter: 81
Mileage: 179938 km
Date: 2007.05.16
Time: 13:34:18
Reset counter: 84
Mileage: 179412 km
Date: 2019.08.11
Time: 11:10:34
Address 77: Telephone
End-------------------------(Elapsed Time: 03:07)--------------------------
