5301 - Throttle Actuator Control Circuit - PLEASE HELP. LIMP MODE AND NOW DPF PROBLEM
yerfdog
Pirate
Hi All,
I have been having some trouble with my car. I got a check light on and read the code.
[b]Removed.  Data from a clone/pirate copy of VCDS is not welcome here.[/b]
I had a read and thought that it was the throttle body or ASV. I changed it for a new one as when i opened it up all the cogs have been warn away and it was slipping like mad.
However, i still can not clear the fault code on VCDS. I read that there should be a fuse that probably gone. I can not find any fuses gone, I check with a multi meter. Where is these fuse ?
Also, how can i activate the throttle body in VCDA to see if it is working and what blocks can i check for it status?
This whole thing have caused my DPF to block and i cant regen in VCDS. (I hope if i clear the fault it will regen)
PLEASE HELP
Viking
C?ID=151455
Given the lack of information available in your post, it's not possible to even guess. It's forum policy to include a ful autoscan which will help massively.
yerfdog
Pirate
Sorry,
This is the full scan.
All codes are clear now apart from the 1- Engine ones.
Any guidance would be great.
