DAB Option Missing
GXCars
C?ID=248011
Just got a 2015 golf 7 DSG GTD and there is no DAB option in the menu,
Car has Discover PRO GEN I with Dynaudio
MIB unit is a DAB one, car has the correct PR code and its all wired to the DAB aerial etc so it "should" work, dealer is a bit stumped - has anyone seen this before or could shed any light on it, I'm wondering is something else isnt coded on the car that stops the DAB option appearing in the menu, I've checked the coding and it seems OK done all of the soft resets etc, disconnected battery but nothing, if anyone could shed any light or share the coding from a similarly equipped car I'd be grateful
Thanks in advance
Monday,01,April,2019,11:54:44:17347
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZAUZFW153245   License Plate:
Mileage: 128475km-79830mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 2B 42 44 47 52 55 5F
          A9
VIN: WVWZZZAUZFW153245   Mileage: 128475km-79830miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7540
   Revision: 81H22---
   Coding: 011D0012036505083000
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002008
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 78F8497EC390888AE5-802C
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4504
   Revision: 05853104    Serial number: TFK01410060431
   ROD: EV_TCMDQ250021.rod
   VCID: 2644570659A4CE7A87-8072
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 62874000000185
   Coding: 01FA8AA13425096F0379060441C82980512C90C0608294F5F8625078C209
   VCID: 4684F786F9E42E7AA7-8012
   Revision: 00021000    Serial number: 0349298287
   Coding: 030C0C
   VCID: 3A7C9376BD1C5A9AD3-806E
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00120114202400011005000200101000
   VCID: 73E27E52DAF6EBD2D0-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011428902739
   Coding: 03111B66C20122FB0B244080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0008219E9B40C04ADD-8054
   Component: WWS    141010  042 0551
   Serial number:         141013164524
   Component: RLHS  037 0059
   Serial number: S4Y14M10D23H15M38S35
   Coding: 00A8EE
   Serial number: 000000000ZY1426125LA
   Serial number: 00000000000060660992
   Sun Roof:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST00007HRF00000
   Coding: 181901
          B1263 01 [009] - Electrical Failure
                    Reset counter: 190
                    Mileage: 128439 km
                    Date: 2019.03.30
                    Time: 16:00:06
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331428209346
   Coding: 0071051011
   VCID: 3D76986AAC326DA2F6-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 16101403272545
   Coding: 001C1300FE0739
   VCID: 3878897E8310488A25-806C
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR09LPHG
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F0AA262E6BEBFB2A4-802A
   Belt Pretensioner left:
   Serial number: 34169661C06101440307
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169662C02101470074
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 810 14
   Serial number: 357670000008B420311F
   Subsystem 4 - Part No SW: -----------    HW: 480 001 810 14
   Serial number: 3586700000085781311K
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3516502A1175A9258251
   Subsystem 6 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3526502C5175A9055231
   Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
   Serial number: 3556502AB18166B231EE
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 16101404220629
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BF25672F2A6A39288-802E
   Part No SW: 5G1 920 957     HW: 5G1 920 957
   Component: KOMBI         301 4270
   Coding: 27AD01182F80260001886A011400000000000000
   VCID: 6DD6682ABCD23D2206-8038
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002605074
   Coding: 030100040B087300EF00027E1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 428CEB96D5CC125A8B-8016
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 29140002220950014414
   Coding: 2DFFFF
   Serial number: 4522884703
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
   Component: FLA           H05 0002
   Revision: AA001001
   Coding: 02028867727261565623393E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B52A6324246F31258-807E
   Revision: 00000000    Serial number: 14000285865004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3460BD4E9F78ACEA09-8060
   Serial number: 26091402090200
   Coding: 003F1220D001048100001000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3566804A9402B5E23E-8060
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401SPW0
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001005
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63C20E126A167B52A0-8036
   Serial number: 06101401101769
   Coding: 003F1020DE01048100801000
   VCID: 418EE49AD0CA094292-8014
   Coding: 029E01000B010200
   VCID: 4088E19EDBC0004A9D-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
   Component: MU-H-ND-EU    H43 0376
   Serial number: A310J0EB006645
   Coding: 027300010000000011111202000800031F0202E60100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1A3C73F61DDC7A9A33-804E
   Component: ABT_High  H61 0030
   Serial number: VWZ8Z9PS100WKE
   Subsystem 2 - Part No SW: V03 959 806 ET    HW: -----------
   Component: ECE 2019  --- 0175
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Component: SAS-GEN 2     H06 0014
   Serial number: 140909200868
   VCID: 6BD2663282C6331218-803E
End-------------------------(Elapsed Time: 04:58)--------------------------
Coding looks OK to me as well, but that doesn't mean others should double-check us.
There's a veritable boatload of measuring values related to the DAB tuners. You can narrow the selection down some by typing 'digital' or 'DAB' into the search/filter box, then look at them a few at a time. Perhaps some clues there?
Here's a more user-friendly version of the code-string on your hex5F module
Byte	Hex	Binary
0	02	00000010
1	73	01110011
2	00	00000000
3	01	00000001
4	00	00000000
5	00	00000000
6	00	00000000
7	00	00000000
8	11	00010001
9	11	00010001
[b][COLOR="#0000FF"]10	12	00010010[/COLOR][/b]
11	02	00000010
12	00	00000000
13	08	00001000
14	00	00000000
15	03	00000011
16	1F	00011111
17	02	00000010
18	02	00000010
19	E6	11100110
20	01	00000001
21	00	00000000
22	01	00000001
23	00	00000000
24	57	01010111
25		00000000
26		00000000
27		00000000
28		00000000
29		00000000
30		00000000
DAB all happens in software switches on Byte 10
As Uwe says - doesn't look not incorrect!!
GXCars
C?ID=248011
So an update on the issue
Got escalated to VW technical after the software had been reflashed without success who then sent the dealer a “patch” so clearly VW know of an issue, dealer tries the patch which didn’t work and then calls me to say they’ve contacted technical again for a solution.
After reading the self study thing VW put out on the infotainment system I suggested to the dealer they update the cluster and CEM and try again as I’ve seen an issue with a cruise that wouldn’t code via SVM because of this issue. the cluster controls and acts as a gateway for some of the unit.
Get a call an hour later to say it’s fixed - they tried the patch again and the car took the update - funny that isn’t it...
So there clearly is a software issue with some of the units that VW know about
I’ll scan the car when I get it back to see what changes if any I can see and post it up
Thanks for the help so far - much appreciated
GXCars
C?ID=248011
So I went to collect the car and bumped into the tech who was working on it and he explained that they didnt update the cluster they just had a laptop issue when they were trying to load the software but after 3 tries the car took the update and I now have DAB
Having just scanned the car I then get 2 codes in the 5F
The first is check software version management which I've seen before and I changed the adaptation channel for confirmation of installation change and put in a new value using windows calculator, the 5F accepted the code and its now gone
However I now have the following code still present:
B2000 87 [009] - Missing message
Reset counter: 201
Mileage: 121061 km
Date: 2019.04.06
Time: 08:19:07
Voltage terminal 30: 12.1 V
Software module: status-SW_Status_Consistency: 00 20 00
Software module: status-SW_Status_DevName: Dab
Obviously related to the DAB issue, everything now working OK but I'd like to be rid of the code
Any ideas on how to get it gone ?
GXCars: hi -it sounds like your friendly tech left a trailing error code when she loaded the new software (I'm guessing of course). It looks like a SVM trouble code - I think
If I'm correct, the normal way of dealing with this type of error is to calculate a new code for the Confirmation of installation change channel in the hex5F module using the existing code in that channel and a pre-defined key. It's a kind-of cypher process - albeit the encryption key for the cypher is fairly well known on the net (it's hex C9D2. I'm not sure why this particular key is used, but it's a really interesting number - a topic for discussion at another time, perhaps).
Basically the sum that needs to be calculated is: Existing code XOR C9D2 (where XOR = Exclusive OR function).
So - I'm not sure how familiar you might be with the fascinating world of numbers (I'm referring of course to the magical numbers that live in the base 16 number-set and the even more sublime numbers that cohabit in the hexadecimal world as binary numbers).
If the formula above is familiar to you - simply apply the existing code to the XOR function and the cypher key - and enter the result back into the Confirmation of installation change channel.
If all this reads as gobbledygook - post up the existing code in your 5F module and I'm sure that someone here will calculate your new code.
EDIT: or, go back to your friendly dealer and politely suggest that they do the job properly!!;)
PS:Hmm......... why does the forum definition for SVM assert that only dealers can fix this DTC - doing the math ain't rocket science?:confused:
I am skeptical that the procedure you have in mind here is applicable to this fault code.
^^^ Uwe thanks - my bad
GXCars
C?ID=248011
Hi Don,
Yes I'm familiar with the hex calculations and indeed had 2 codes one which was the SVM for change of installation, I ran the hex calculation and cleared the first one expecting that it would probably clear the second.
The dealer applied software version 0407 to the MIB which didnt fix the dab and then applied a patch from VW which I'm wondering if that is causing the checksum error, everything is working fine I just want rid of this code and you would have thought the dealer would have run a scan after they fixed the car.
I'm figuring that the checksum error is something within the actual software and VCDS wont be able to correct it unless someone knows otherwise ?
Ian
