2013 Audi Allroad B8 - intermittent hard start
4lane
US
C?ID=8554
The past two days I've had three intermittent occurrences of a hard start while all other starts were normal, on a B8 2013 Audi Allroad.
1) Press Ignition Button : car fires and immediately stalls
2) Press Ignition Button Second Time: car continually cranks for ~5s before starting, after which it seems to run normally
I ran a scan and received the following. I'm looking at fault 4106 - Bank 1; System too Rich at Idle, since it gives a date when it occurred, although this wasn't the date of the most recent occurrence for some reason. I was thinking the N80 valve might be faulty but wasn't sure if that could lead to an intermittent hard start I'm experiencing. Any help is appreciated.
Sunday,31,March,2019,16:07:42:02305
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WA1UFAFL0DA069272   License Plate:
Mileage: 83230km-51716mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          6C 6D 72
VIN: WA1UFAFL0DA069272   Mileage: 83230km-51716miles
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0008
   Revision: ECH09---
   Coding: 722A0013242600062000
   Shop #: WSC 54964 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
   ROD: EV_ECM20TFS0118K5907115F.rod
   VCID: 3537DC2F05C1E6BF7DB-8060
          P0456 00 [096] - Very Small Leak Detected
          P2188 00 [096] - -
                    Mileage: 83212 km
                    Date: 2019.03.29
                    Time: 10:48:43
                    Engine speed: 794.00 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 85 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 14.182 V
                    Unlearning counter according OBD: 35
                    Median injection timing: 0.990 ms
                    Engine operating condition: Idling
   Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   VCID: 74B1212B4E3BBFB78A5-8020
   Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
   Component: ESP8 quattro  H09 0100
   Coding: 0E1D18
   Shop #: WSC 06334 000 00000
   VCID: 4CC199CB76CB8777325-8018
   Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H10 0602
   Coding: 0D820000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 035372F71B15880F83F-8056
   Serial number: 2312000100185014
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Revision: C1000000    Serial number: 01110520121266
   Coding: 6480208000
   VCID: 3333E2370B35F88F53F-8066
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000030437701
   Coding: 26000091863CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
   Shop #: WSC 08185 444 103375
   VCID: 78A9151B52D3DBD7A6D-802C
   Component: WWS 110512  H07 0070
   Serial number: SWF12050115803
   Coding: 00FD11
   Serial number: 20271225
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000305120151
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1NZ702
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 2908C126000000000001
   Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
   Component: AirbagVW-AU10 H46 0610
   Serial number: 003KEDA014G
   Coding: 303844354A32303030304A55304C384B3053
   Shop #: WSC 00040 002 1048576
   VCID: 47CBA6E76F2D642F1F7-8012
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200008MMA
   Serial number: 6334MSME6E514072C
   Serial number: 6344MSME6F222D3BS
   Serial number: 6352QSME441653628
   Serial number: 6362QSME4F15014CK
   Serial number: 63732SME6D14325A0
   Serial number: 63832SME4C145162Z
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120514001084
   Coding: 000017
   VCID: 4FFB8EC787DDBC6F577-801A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NTC23475D
   Coding: 8B3629020301D705020000
   VCID: 323DE733F42FF187589-8066
   Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H10 0025
   Revision: 1Y030014    Serial number: 1441Y125030368
   Coding: 00C303FF00
   VCID: 3FDBBE07377D2CEFA77-806A
   Serial number: 8175957401
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 173
                    Mileage: 82983 km
                    Date: 2019.03.24
                    Time: 11:57:15
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 11
                    Bin. Bits:    00000
            000 -  -  - Intermittent
                    Reset counter: 174
                    Mileage: 83002 km
                    Date: 2019.03.24
                    Time: 15:14:24
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 10
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000029145580
   Coding: 00581B00000000000000
   VCID: 3B23CA17236530CF8BF-806E
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000029908343
   Coding: 011C13205E00410001
   VCID: 4DC794CF8DD18E7F25B-8018
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0020526803
   Coding: 100000000001
   Shop #: WSC 08185 444 122181
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3431E12B0EBBFFB74A5-8060
   Revision: 00002001    Serial number: 0176517259
   Coding: 0126023A20BA709580B0023200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000519778
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Component: DSP Prem      H04 0030
   Revision: 00004001    Serial number: 94814003201301
   VCID: 2D07F44FED11AE7F05B-8078
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000029772602
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000000048809
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D51B12D31BD766D-806C
   Part No SW: 4G0 035 080 G    HW: 4G0 035 080
   Revision: AB001007    Serial number: 158H10E7505942
   Coding: 020007010000000001
   Shop #: WSC 01238 002 1048576
   VCID: 221D1773A4CF6107A89-8076
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 A
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 096E 0C7510836
   Coding: 010200050006A1EF41028B4E00000403140000000000000000
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130EG0CS169387
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001153298
   Component: CD-Database  3371
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 173
                    Mileage: 82983 km
                    Date: 2019.03.24
                    Time: 11:47:26
                    Voltage: 11.90 V
01043 - Control Module; Incorrect Software Version
            000 -  -
                    Reset counter: 152
                    Mileage: 83234 km
                    Date: 2019.03.30
                    Time: 15:42:55
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000030049731
   Coding: 010C13204000210001
   VCID: 43D3B2F75B95480FC3F-8016
   Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
   Component: J772__Rearview      0140
   Revision: --H06---    Serial number: 525PA8-J229325
   Coding: 1000007
   VCID: 392FD01F255902DF993-806C
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C21C90B266B37F7825-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000030050712
End----(Elapsed Time: 02:08, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
NostraJackAss
I ran a scan and received the following. I'm looking at fault 4106 - Bank 1; System too Rich at Idle, since it gives a date when it occurred, although this wasn't the date of the most recent occurrence for some reason. I was thinking the N80 valve might be faulty but wasn't sure if that could lead to an intermittent hard start I'm experiencing. Any help is appreciated.​
Car is under warranty still?
Vehicle Identification No.WA1UFAFL0DA069272
ModelAudi A4 Av. Allroad
quattro 2.0
A4AR
Date of production23.05.2012
Year2013
Sales type8KH52A
Engine CodeCPMA
Transmission CodeNGR
Emission standard7GBEmission standard ULEV 2
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L<<<<<<<<<<<<<<<<<<<<<< Firmware appears to be up to date!
:rolleyes:
Revision: ECH09---
P2188 00 [096] - -
Mileage: 83212 km
Date: 2019.03.29
Time: 10:48:43
OP:
Can you please post the following MODE's of the OBD2?
In VCDS MODE's : 1, 3, 7 & 9.
Absolutely check N80 & sump for gasoline contamination from injector leak down or HPP failure too!
Is car modified in anyway?
Did you JPPSG?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=156577&viewfull=1#post156577
You may find this thread link helpful......
https://forums.ross-tech.com/showth...ases-and-vacuum-amp-so-should-you!-Air-leaks!
Thank you
4lane
US
C?ID=8554
Hi! Car is not under warranty. It is stock w/ no mods. Here are the ODBII modes:
Tuesday,02,April,2019,21:31:08:02305
VCDS Release 18.9.1 (x64):  Generic OBD2
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Failed or Incomplete
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Failed or Incomplete
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring:  Failed or Incomplete
Exhaust Gas Recirculation:  Failed or Incomplete
Tuesday,02,April,2019,21:31:23:02305
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Tuesday,02,April,2019,21:31:36:02305
Mode 07: Pending emission related fault codes
Tuesday,02,April,2019,21:31:54:02305
Type 02 - VIN : WA1UFAFL0DA069272 (Address E8)
Type 04 - Calibration ID : 8K5115F 0008AVBB (Address E8)
Type 04 - Calibration ID : 8K1158  100622   (Address E9)
Type 06 - Calibration Verification Number : 511D777D (Address E8)
Type 06 - Calibration Verification Number : 59BB2F44 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 359
    Ignition cycle count : 1964
         Catalyst monitor bank 1 : 684 / 353
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 588 / 359
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 1524 / 359
         AIR monitor : 0 / 0
         EVAP monitor : 55 / 53
         Secondary O2 Sensor monitor bank 1 : 531 / 353
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Tuesday,02,April,2019,21:33:41:02305
Mode 1:Read Data
06:Short Term Trim - Bank 1     0.0 %
07:Long Term Trim - Bank 1     4.7 %
15:Bank 1 Sensor 2 Status     0.455 V
34:Bank 1 Sensor 1 Status     1.013 Lambda  0.016 mA
NostraJackAss
Yeah maybe a siphon effect gong on with N80 so observe if this happens at all during fill ups with fuel.
Verify sump for fuel from HPP or fuel injector leak by or down to oil.
4lane
US
C?ID=8554
This issue disappeared for a while but has recently resurfaced. On a recent day, after driving to a store, came back out and car would not fire. Put gas pedal to floor and cranked and it immediately fired. Check engine light came on and the following DTCs were pulled. Of other note: fuel mileage was noticed to have dropped 3 mpg/hwy recently as well. There has never been a siphon effect at refueling, nor does the engine ever misfire, stall, or stutter. It is only a rare issue at initial start. I sense a hint of gas smell in oil but I'm unsure if it is excessive or not. Engine oil has always stayed at full level, but has dropped a quart (@8k miles) which was unusual.
Any opinion whether these issues point more toward N80, or PCV, or HPFP as the culprit?
Sunday,07,June,2020,08:39:18:02305
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Mileage: 98110km-60962mi   Repair Order:
          6C 6D 72
VIN: WA1UFAFL0DA069272   Mileage: 98110km-60962miles
   Revision: ECH09---
   VCID: 3537DC2F05C1E6B3B0D-8060
          P2188 00 [232] - -
                    Mileage: 97906 km
                    Date: 2020.05.28
                    Time: 16:34:15
                    Engine speed: 827.00 /min
                    Normed load value: 23.5 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.442 V
                    Median injection timing: 1.585 ms
                    Brake actuated status-Bits 0-7: 59
                    Engine torque: 60.3 Nm
Readiness: 0000 0100
   Revision: --H16---
   Coding: 000002
   VCID: 74B1212B4E3BBFBB473-8020
   Coding: 0E1D18
   VCID: 4CC199CB76CB877BFF3-8018
   VCID: 035372F71B1588034E9-8056
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 78
                    Mileage: 97895 km
                    Date: 2020.05.28
                    Time: 16:04:28
   Coding: 6480208000
   VCID: 3333E2370B35F8839E9-8066
   Coding: 26000091803CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
   VCID: 78A9151B52D3DBDB6BB-802C
   Coding: 00FD11
   Coding: 02005D
   VCID: 47CBA6E76F2D6423D21-8012
   Coding: 000017
   VCID: 4FFB8EC787DDBC639A1-801A
   VCID: 323DE733F42FF18B95F-8066
   Coding: 00C303FF00
   VCID: 3FDBBE07377D2CE36A1-806A
   VCID: 3B23CA17236530C3469-806E
   VCID: 4DC794CF8DD18E73E8D-8018
   VCID: 3431E12B0EBBFFBB873-8060
   VCID: 2D07F44FED11AE73C8D-8078
   VCID: 3829D51B12D31BDBABB-806C
   VCID: 221D1773A4CF610B65F-8076
   Coding: 010200050006A1EF41028F4E00000403140000000000000000
   VCID: 43D3B2F75B9548030E9-8016
   Coding: 1000007
   VCID: 392FD01F255902D3545-806C
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   VCID: 3C21C90B266B37FB4F3-8068
                    Reset counter: 132
                    Mileage: 98050 km
                    Date: 2020.06.04
                    Time: 18:52:02
End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Sunday,07,June,2020,09:26:15:02305
VCDS Release 20.4.1 (x64):  Generic OBD2
Fuel System:  Passed
Sunday,07,June,2020,08:44:54:02305
Sunday,07,June,2020,08:45:03:02305
Sunday,07,June,2020,08:45:23:02305
    OBD Monitoring Conditions Encountered count : 570
    Ignition cycle count : 3292
         Catalyst monitor bank 1 : 1086 / 534
         O2 Sensor monitor bank 1 : 969 / 570
         EGR-VVT monitor : 2584 / 570
         AIR monitor : 0 / 0
         EVAP monitor : 101 / 104
         Secondary O2 Sensor monitor bank 1 : 834 / 534
Sunday,07,June,2020,09:28:05:02305
Mode 1:Read Data
05:Engine coolant temperature     61 °C  61 °C
10:Mass Air Flow     3.94 g/s
04:Calculated load value     18.0 %  18.4 %
06:Short Term Trim - Bank 1     -1.6 %
Sunday	7	June	2020	09:29:55:02305-VCID:3537DC2F05C1E6B3B0D-8060	VCDS Version: Release 20.4.1 (x64)	Data version: 20200331 DS317.0
8K5 907 115 F	ADVMB	2.0l R4/4V TF H09 0008
		G004	F0	G032	F0	G038	F0	G039	F0	G094	F0
Marker	TIME	Loc. IDE00025	TIME	Loc. IDE00186	TIME	Loc. IDE00201	TIME	Loc. IDE00202	TIME	Loc. IDE00589
	STAMP	Coolant temperature	STAMP	Fuel low pressure: actual value	STAMP	High fuel pressure: specified value	STAMP	Low fuel pressure: specified value	STAMP	Fuel pressure
		 °C		 kPa		 MPa		 kPa		 kPa rel
	0.09	68	0.21	597.4	0.31	4	0.42	600	0.01	3870
	0.62	68	0.73	600.6	0.84	4	0.95	600	0.53	3910
	1.17	68	1.28	594.4	1.39	4	1.5	600	1.06	3900
	1.71	68	1.81	596.7	1.92	4	2.03	600	1.59	3940
	2.23	68	2.34	597.5	2.46	4	2.56	600	2.14	3870
	2.78	68	2.89	608.1	3	4	3.09	600	2.67	3870
	3.31	69	3.42	601.2	3.53	4	3.64	600	3.21	3950
	3.84	69	3.95	611.1	4.06	4	4.17	600	3.75	3910
	4.37	69	4.48	599.5	4.59	4	4.72	600	4.26	3920
4lane
US
C?ID=8554
Any thoughts on best place to start based on the fact that the issue is intermittent, it's related to starting only, and the car never stutters/hesitates otherwise? I was originally thinking HPFP or sticking injector but the fact that it happens randomly and only at start-up makes me think it's more of an occasional air leak when starting...
4lane
US
C?ID=8554
I'm not thinking the HPFP wouldn't lend itself to such an isolated behavior (only issue is at start), and that throttle to the floor during a hard start wouldn't impact a problematic HPFP.
But, my theory is, the N80 valve could be the culprit if fuel vapors collect and when starting the engine draws in fuel-rich air + more fuel from injectors would create a rich issue leading to a hard start. When this last happened and I put the throttle to the floor when cranking, it allows fresh air in the intake, leaning it back out and allowing the start. Maybe the N80 randomly goes haywire once in a while? The only problem with the theory is that I've never had an issue after refueling and it's such an infrequent occurance.
Thoughts?
4lane
US
C?ID=8554
He doubts me? ......:rolleyes:
Just what is a siphon anyway, do you work for VW-Audi group?
Haha, well I would never doubt you, but I don’t have any start issues after fueling so it’s a little odd in its frequency. My biggest clue was throttle to the floor gets it fired right away. That seems to lead away from HPFP. Can enough N80 leaked vapors lead to gas smell in oil?
4lane
US
C?ID=8554
Hi, a leaking N80 valve would most likely lead to fuel/fuel vapors migrating into the intake system - ;)
HPFPs have been known to leak fuel into the engine's crankcase.
Hope this helps,
drpeter
Very helpful thank you! Here is my current thought:
1. N80: I'm putting my chips here at this point per my explanation above. The only odd part is that it's such an intermittent issue.
2. HPFP: Possible, but when it starts by putting the throttle to the floor the HPFP wouldn't have any change, nor would successful starts when the pedal is to the floor. Plus, I never have any stalling, hesitating, etc. Also, engine oil level has not gone up meaning it's not leaking significant gas into the oil, so I'm not thinking this is the source.
3. Stuck injector: Possible, but the issue is only with starts, not with any other engine issues. Also, engine oil level has not gone up meaning an injector is leaking consistently in the oil, so I'm not thinking the source.
4. PCV: Possible, but PCV issues lead to more lean issues rather than rich issues. But I don't know much more about this.
DrPeter
16.4905° S, 151.7375° W
I do not gamble, if I did, I would say the N80 valve is the logical choice. It is less expensive than a HPFP!!
The intermittent concern can be explained. Here is one possible reason how' this could be:
- The charcoal canister is letting small pieces of carbon to migrate up to the N80 valve.
- When the N80 valve is being commanded open by the ECM, a small piece of carbon gets stuck in the 'shutter/opening'.
- The ECM, now stops the operation of the N80, but the valve can not close 'all the way' because of the stuck carbon.
- The next time the ECM operates the N80, the carbon can move through because it was partially crushed but the 'shutter' in the valve.
- Operation f the N80 valve is back to normal, till the next time there is a bit of carbon causing an issue.
While the valve is (partially) open and the vehicle is shut down, fuel vapors are allowed to pass through and collect in the intake. Thus causing the 'rich' fuel mixture condition and the hard start, intermittently of course.
If I wanted to rule out a possibility of an issue with an N80 valve, I would consider temporarily crimping or blocking the Canister Purge Line (green) to the N80 valve, the area in red is usually a good spot. This will eliminate the possibility of fuel vapors coming into the intake.
(pic of my 2013 Allroad)
The other thing you can do, is to buy a small fuel filter for a Volkswagen Beetle, I am talking about the Air Cooled engines. These fuel filters are clear and will block any carbon particles and if present will allow you to see them inside the clear filter housing.
Bosch part number for the small filter: [0 450 904 058]
Hope this helps,
drpeter
4lane
US
C?ID=8554
Hope this helps,
drpeter
Thank you! Because it's such an intermittent issue it would be difficult to do the pinching test, but I do like the idea of the Beetle fuel filter in that line after I replace the N80 to monitor any carbon particles flowing through. Thank you again!
DrPeter
You are welcome, glad to help. Keep us informed and post some pics up if you find/see any carbon in there... Oh and be sure to install the filter so that the filter element end is in direction coming 'from the fuel tank', that way any carbon can be easily seen on/in the filter/chamber.
ps..... Its a good idea to blow-out/clean the line of the N80 valve!
drpeter
4lane
US
C?ID=8554
drpeter
Will do - thank you again!
NostraJackAss
Ahhhh yup!
Like I said Under useful life warranty, isn't it?
Section 21 Pg. 2 Other Information Engine Code R.CH-No.: Revision DateTest Group DADXJ02.0FUB all
PAGE 63/64 what's it say?
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=29696&flag=1
https://forums.ross-tech.com/showth...ent-hard-start&p=160595&viewfull=1#post160595
Gremling
Norway, Nordland
C?ID=319714
Hi,
I understand that the is a intermittent problem, engine can be hard to start, one fault code that was displayed was not for day of incident?
The above N80 valve has already been discussed.
Check Air mass meter, if this fails, this will have affect on ECMs mapping of fuel air mixture, causing lean/rich, is it visually contaminated, if so clean and test again. This can also be funtionally checked with vagcom or Oscilloscope.
Using Vagcom you can monitor the rail pressure, compare pressure against time taken from start of cranking to engine start. If pressure takes time to build, could be fuel pump issue or seeping injector(s), however if pressure gets up quite fast it is getting interesting.
Either with Vagcom or an oscilloscope connected to rail pressure sender might tell you better with respect to time for pressure build up, use caution and drain pressure from rail, test again. Measure time it takes from start of crank to pressure has built up in rail.
Remember also that this engine has a control valve on camshaft, item 13 in link
https://7zap.com/en/catalog/cars/au...6751e9d28fad/manufacturer/1/627109200::109010
for variable timing, if this control valve acts up, engine can be hard to start. Using an oscilloscope for checking timing, measuring camshaft sensor and crankshaft sensor, this can tell you wether there is a longer gap between camshaft and crankshaft. If longer when engine takes a lot of cranking, suspect VVT control issue.
Regards
Gremling
