VW Golf 2015 AC fault code.
Souriau
Newry, NI, UK
C?ID=86928
I have a car with this DTC in 08: Auto HVAC (J301)
1048835 - Functionality limited due to Engine Control Module.
Does anyone know what this is?
Saturday,30,March,2019,13:25:49:62062
VCDS Version: 18.9.1.0
Workshop Code: 000 18261 018261
VIN: WVWZZZAUZFW144139   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFW144139   Mileage: 141818km-88121miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 8125
   Revision: 83H22---
   Coding: 01190012034505082000
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002013
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: F9F3A9F7782BBC821A-80AC
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 62774000001817
   Coding: 01FA8AA1242409700378060341CC2980512490C0608294F3F4605078C002
   VCID: C58B1507445308622E-8090
   Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: B97369F738AB7C825A-80EC
          P1719 00 [008] - -
                    Fault Frequency: 91
                    Reset counter: 33
                    Mileage: 133906 km
                    Date: 2019.02.01
                    Time: 18:08:13
                    Voltage terminal 30: 14.1 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011428001637
   Coding: 03000842C201027B0B244080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: FDFBBDE76C0380A236-80A8
   Component: WWS    140926  042 0551
   Serial number:         140930230624
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y14M10D07H17M16S32
   Coding: 00A8DD
   Serial number: 000000000ZY142583BEC
   Serial number: 00000000000060604164
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 28
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331427302369
   Coding: 0071051001
   VCID: BD7B7DE72C8340A276-80E8
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 07101403210259
   Coding: 00000300FE0739
   VCID: B8756CF303A1658AA5-80EC
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR09EVB9
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: FF0747EF660F92B224-80AA
   Belt Pretensioner left:
   Serial number: 34169661C19091470020
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169662C02101470041
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 810 14
   Serial number: 357670000005B281411I
   Subsystem 4 - Part No SW: -----------    HW: 480 000 910 14
   Serial number: 3586700000078471411J
   Subsystem 5 - Part No SW: -----------    HW: 480 402 409 14
   Serial number: 3516502AD175A90622AB
   Subsystem 6 - Part No SW: -----------    HW: 480 402 409 14
   Serial number: 3526502AD175A90273EI
   Subsystem 7 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 355650299175A924E35I
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 08101404220723
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: FBFFB3FF72178E9208-80AE
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         203 5297
   Coding: 27A401002780260001886A011400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: E6C9F28B1995237AC7-80B2
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Fault Frequency: 15
                    Reset counter: 8
                    Mileage: 134517 km
                    Date: 2019.02.05
                    Time: 16:32:03
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002546571
   Coding: 030100040B087300EF00005C080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   VCID: C2810E1B557D3F5A0B-8096
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140002464190044402
   Coding: 2CFFFF
   Serial number: 3771274703
   Serial number: 24091406071699
   Coding: 003B0220D001048100001000
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: C1830117507B244212-8094
   Serial number: 28091403110084
   Coding: 003B0020DE01048100801000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    041 0430
   Serial number: V7F00210141357
   Coding: 02730001FF00000021111201000800001F0100060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: E7D7FF8F1E9F3A72FC-80B2
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS40434P
   Subsystem 2 - Part No SW: 5G0 919 866 Q    HW: -----------
   Component:  ECE 2015  --- 0045
End-------------------------(Elapsed Time: 03:58)--------------------------
Hmm... Looks like the ECU requested a "PTC Reduction".
Are all parts in this car original?
Does it have Start/Stop? What kind of shape is the battery in?
Souriau
Newry, NI, UK
C?ID=86928
The vehicle is not here at present but will be toward the end of this week, I will check.
Souriau
Newry, NI, UK
C?ID=86928
The car is back and another scan.
The customer does not use Start/Stop feature but it is fitted to the vehicle.
The fault came back up that evening last week when I cleared all DTC and it happen at 22:09,
The customer told me that his car was parked at home and last switched off around 19:00.
what is MSG?
Saturday,06,April,2019,11:47:37:46973
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
VIN: WVWZZZAUZFW144139   Mileage: 142716km-88679miles
   Revision: 83H22---
   VCID: F9BAA4B9786EAF821A-80AC
   VCID: C5C2184944161B622E-8090
   Revision: 00001K06
   VCID: B93A64B938EE6F825A-80EC
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 24
                    Reset counter: 60
                    Mileage: 141909 km
                    Date: 2019.03.30
                    Time: 22:09:45
                    Voltage terminal 30: 13.7 V
   VCID: FDB2B0A96C4693A236-80A8
   Coding: 00A8DD
   Coding: 0071051001
   VCID: BD3270A92CC653A276-80E8
   VCID: B83C61BD03E4768AA5-80EC
   VCID: FF4E4AA1664A81B224-80AA
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   VCID: FBB6BEB172529D9208-80AE
   VCID: E680FFC519D0307AC7-80B2
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 58
                    Mileage: 142492 km
                    Date: 2019.04.04
                    Time: 22:05:39
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 58
                    Mileage: 142492 km
                    Date: 2019.04.04
                    Time: 22:05:39
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 142492 km
                    Date: 2019.04.04
                    Time: 22:05:40
   VCID: C2C8035555382C5A0B-8096
   Coding: 2CFFFF
   Coding: 8103
   VCID: C1CA0C59503E374212-8094
   VCID: E79EF2C11EDA2972FC-80B2
End----------(Elapsed Time: 01:40, VBatt start/end: 12.1V/12.1V)-----------
MSG = Motor SteuerGerät (German for Engine Control Unit)
Again, what kind of shape is the car's battery in?
Does the customer have an actual complaint regarding the functionality of the HVAC system?
Souriau
Newry, NI, UK
C?ID=86928
Customer complain of no heating at times, but each time it come to me, all is working, hot air, cold air, all flaps are moving correctly.
I will do a battery test next time he come.
k.barghouthi
Palestine
C?ID=326133
Hi, you should go to 08 measure values and search for shut off condition, you will see the reason why ECU requested AC to switch off or limited.
MartinsX
Riga, Latvia
C?ID=268515
I agree with Uwe. If reading and analyzing DTC and FF data carefully - they are self-explaining.
          P1719 00 [008] - -
                    Fault Frequency: 24
                    Reset counter: 60
                    Mileage: 141909 km
                    Date: 2019.03.30
                    Time: 22:09:45
ECU controls the alternator load and battery SOC, and, by some reason, alternator is overloaded and/or battery SOC is not sufficient, so the ECU requests HVAC to reduce electrical load of subsystem - electrical aux heater.
About the time/date stamp in FF - some modules use strange values here, just look through another autoscans. Dealers tool does not show that figures at all, so I guess SW engineer who wrote the FW code for module doesn't pay a lot of attention to make time/date stamp to be 100% accurate. VCDS use to pull more info out of control modules than dealers tool does.
If this is not that case, then Your customer gave You incorrect information/lied to You. On march 30 22:09, when fault was stored, engine was running:
Souriau
Newry, NI, UK
C?ID=86928
Battery charging idle 14.7v
Alternator load 34%
Battery charging at 2500RPM 14.4v
Alternator load 74% with everything switched on, lights, wiper HRW, blower, AC.
I asked the customer the history and he told me the gearbox was taken out for a new clutch slave cylinder.
So possibility loose connection, earth not properly connected from body to engine/gearbox.
i will check into that.
Saturday,13,April,2019,11:24:39:46973
VIN: WVWZZZAUZFW144139   Mileage: 143664km-89268miles
   Revision: 83H22---
   Revision: 00001K06
          P1719 00 [008] - -
                    Reset counter: 82
                    Mileage: 142820 km
                    Date: 2019.04.06
                    Time: 22:04:14
                    Voltage terminal 30: 13.4 V
   Coding: 00A8DD
   Coding: 0071051001
   Coding: 333135
   Coding: 333135
   Coding: 0C00
          U1110 00 [008] - -
                    Reset counter: 78
                    Mileage: 143110 km
                    Date: 2019.04.08
                    Time: 20:52:03
          U1110 00 [008] - -
                    Reset counter: 74
                    Mileage: 143110 km
                    Date: 2019.04.08
                    Time: 20:52:03
          U1110 00 [008] - -
                    Reset counter: 74
                    Mileage: 143110 km
                    Date: 2019.04.08
                    Time: 20:52:03
   Coding: 2CFFFF
   Coding: 8103
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
This is normal. Seen it many Times with odis and odis suggests just clearing it.
You may also ask dealer if there is sw update for ecu/hvac.
