Dynaudio menu in Discover Media PQ
TBAx
C?ID=287144
I am pretty sure this can not be enabled via VCDS, as it requires to upload the Dynaudio dataset.
tos
Finland
C?ID=89390
Could You explain ? Or what should I do? thank you
downtime
Finland
C?ID=280813
TBAx is correct. In addition to change the 5F coding for external sound system, you also need to upload a dataset, means you need to flash correct parameters to audio system so that it physically enables correct outputs etc.
Edit: hey hey hey, you have PQ platform car. That should go fine without datasets. Those are for mqb cars usually.
Make sure your adaptations point to external amp and 5f long coding has sound system and external speakers set.
golfi_vend
Tartu, Estonia
C?ID=195131
Discover Media PQ uses parameters
But does it really have dynaudio menu? I thought just coding/adaption and done...
tos
Finland
C?ID=89390
Thank You.
I found this coding info:
Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)
Address 5F, adaptations:
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ==> change to activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ==> change to "Databus Infotainment"
MAS00950-Audio Parameter,0
ENG117919-Startup_Screen_Sticker_HMI ==> 00 02 for Dynaudio
Bolded
works, I got volume working and sound quality is much better.
Dynaudio logo will be on startup screen.
Coding byte 11 > 05 is not working, only 03 works
Only the settings the dynaudio menu is missing.
TBAx
C?ID=287144
Good question, but I guess yes ¯\_(ツ)_/¯
golfi_vend
Tartu, Estonia
C?ID=195131
Well value 05 needs newer UDS amplifier:
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00010730
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1.rod
   VCID: 6D84C329AD1DE4BFA9E-8038
I'm not sure if this is described in label file for now, haven't done PQ MIB-s for a while.
Yet I ask, are You sure there is menu for Dynaudio in PQ?
kamold
Australia
C?ID=241363
I remember playing around with this a few years ago.
I was able to get the Dynaudio menu up on the Discover Media unit, however it didn't have any effect on the amplifier.
From what I can tell the only support is for regular 3 band equalizer.
dieseltje
The Netherlands
C?ID=148044
Today I completed my Dynaudio amp setup with Discover Media dab+
I changed the adaptation settings according the above
Also in longcoding Byte 11 coded 03 as mentioned instead of 05
after that I rebooted the DM and was suprised with the noise.
I could not turn on/off the DM, totally no controls. Music very loud.
I had to change Byte 11 back to 05 and reboot of the DM. After that system worked fine again.
Why should I have to change code to 03?
Also I couldn't notice any change in sound quality.
Mileage: 371870km-231069mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 36 42 44 46 47 4F 52 53
          5F 62 69 72
VIN: WVWZZZ3CZ8E231165   Mileage: 371870km-231069miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 CN    HW: 03L 907 309
   Component: R4 2,0L EDC F001AG  6220
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 73EFF525127D28D2D0-8026
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 1464
   Revision:    51112    Serial number: 00000902190468
   VCID: 132F95A532BD88D270-8046
   Part No SW: 3C0 698 109 E    HW: 3C0 614 109 AF
   Component: J104    C4 440 V3   0017
   Revision: --025---    Serial number: 00000104023403
   Coding: 0024854
   VCID: 2C5D2E598FC3372A51-8078
   Part No SW: 35D 907 044 B    HW: 35D 907 044 B
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0600004A02
   ROD: EV_ACClimaBHBVW411_VW46.rod
   VCID: 2649DC71592F0D7A87-8072
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 174
                    Mileage: 371870 km
                    Date: 2019.04.08
                    Time: 16:17:28
   Revision: 00H54000    Serial number: 01000008249495
   Coding: F5888F3510041A1147000F000F00000080195D436400010C000000000000
   VCID: 71E3FF2D68611AC222-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 070308 003  0205
   Coding: 00049077
   Shop #: WSC 12345
   Component: RLS     150408 046  0204
   Coding: 00995365
   Shop #: WSC 12345
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35821333801492
   Coding: 118101
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 336F35259AFD68D210-8066
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 M    HW: 3AA 907 567
   Component: AC201  RDW A    036 0243
   Revision: 00036000    Serial number: 00000000507894
   Coding: 0010000
   VCID: 356B0B3D5C8976E23E-8060
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP7DDMR3
   Coding: 0012341
   Shop #: WSC 05311 000 00000
   VCID: 3B7F1D057AADA092C8-806E
   Subsystem 1 - Serial number: 6333FTS679040708
   Subsystem 2 - Serial number: 6343FTS643870708
   Subsystem 3 - Serial number: 6353ETS6T8U1TVNP
   Subsystem 4 - Serial number: 6363ETS6VSJ1TVNP
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
   Component: J0527               0030
   Revision: 00035000    Serial number: 3C0953507
   Coding: 0201822
   VCID: 72E1F0216D6721DADB-8026
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 3C8 920 880 T    HW: 3C8 920 880 T
   Component: KOMBI         H04 1008
   Coding: 160D000000
   VCID: 3D7B131DACB9AEA2F6-8068
   Part No SW: 7N0 907 530 BC    HW: 1K0 907 951
   Component: J533  Gateway H41 1663
   Revision:   H41       Serial number: 260112F2002064
   Coding: 462006
   VCID: 72E1F021AD6721DADB-8026
   Part No SW: 3AA 959 433 F    HW: 3AA 959 433 E
   Component:    IMMO         042 0429
   Shop #: WSC 43138 001 1048576
   VCID: 3C7D1E197FA3A7AAC1-8068
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000001
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0321
   Revision: 12101005    Serial number: 0000886354
   Coding: 0011F7
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0307
   Serial number: 00000000331050
   Coding: 0000D0
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Component:    KSG PQ47 ELV 042 0714
   Coding: 1891020051034E7F00021C1F7008CFCE707801
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 J    HW: 3C0 035 456 J
   Component: DSP 10 Kanal
   Revision: 00H05001    Serial number: 75815000315901
   VCID: 2757D17596251472BC-8072
   Component: EZE_2         H41 1663
   Coding: 00000009
   VCID: 6FE7F955BE550C3234-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0006086936
   Coding: 0011F6
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 36690C31898F7DFA37-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0307
   Serial number: 00000000340928
   Coding: 0000D0
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000055708
   Coding: 0000057
   Shop #: WSC 12346 987 64321
   VCID: 2855D2499B3B1B0AB5-807C
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: VWZAZ2R8029459
   Coding: 027312010000000011111105018808001F0106C4002001008F
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2143CF6D3001EA42F2-8074
   Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 174
                    Mileage: 371870 km
                    Date: 2019.04.08
                    Time: 16:17:30
                    Voltage terminal 30: 13.9 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
   Component: Anhaenger     H16 0070
   Revision: 3A002001    Serial number: 00000110888610
   Coding: 0100000200000000
   Shop #: WSC 05314 000 00000
   VCID: 2E59245179DF453A7F-807A
End-------------------------(Elapsed Time: 03:16)--------------------------
nirvananils
C?ID=289109
Actually I retrofit Dynaudio in my MK5 Golf, from Factory it has Volkswagen Sound but I changed DSP first in Passat B6 Dynaudio because it´s P&P but DM PQ doesn´t like it. There´s no regulation of noise level. So I´ve done my own wire adapter aswell. In next 3 weeks I will try again to get DM PQ working in my car, then I will check if Dynaudio Sound Menu is available. I checked VCP dataset, but there´s no special Dynaudio or DSP Dataset except Multivan but it´s another platform. Maybe it´s dependent from firmware
siLc
Tallinn, Estonia
C?ID=330192
DM PQ doesn't play nice with Dynaudio amps other than 3AA035466. 3C0035456 and 3AA035456 usually need to be swapped out. Volkswagen Audio amp 5K0035456 works fine with DM PQ.
dieseltje
The Netherlands
C?ID=148044
Good news. We did manage to get all up and running incl functioning Dynaudio menu in Passat B6/7/CC
first of all you will need dynaudio 3AA035466, the 12channel type amp make panasonic.
This one supports UDS protocol and you will need a Discover Media PQ at least E type or G type. Software type 03xx or higher.
worldonfire
Estonia
C?ID=297208
Hello!
Tried also this dynaudio menu. Menu appears, but I cannot reccon any sound change whel selecting "authentic", "soft", "dynamic" or "speech".
Only sound change is when I open sliders from dynaudio menu and change "bass" "mid" and "trebel"
From adaptions "audio parameter" is set to 0 and
are correct.
Also byte 11 is coded to 06.
With other codings, dynaudio menu did not appear.
Amplifier should be correct:
   VCID: 6D84C329AD1DE4BF121-8038
and 5f should be also new enough.:
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0468
   Serial number: VWZAZ2U0607362
   Coding: 02840201AA00000011110006000908001F0100C4002001008E
   ROD: EV_MUStd4CTSAT_VW46.rod
   VCID: 2412E60D3E57E5F78DF-8070
   Subsystem 1 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
dieseltje
The Netherlands
C?ID=148044
You're correct in that. After tweaking with soundsettings and storing those, it works.
Looks like there should be some data sets needed for discovermedia with Dynaudio.
When you have a passat b8 with factory dynaudio those settings are there, but with a system with no correct dynaudio sets (in the DM PQ) settings are all 0
worldonfire
Estonia
C?ID=297208
What do you mean by "tweaking with sound settings and storing those" ?
Tried to load datasets to discovery and amplifier but no luck. Those "authentic", "soft", "dynamic" or "speech" do not change anything.
And when bass, mid, treble menu is active and adjusted, then it is same for every menu (authentic, soft, dynamic or speech).
nirvananils
C?ID=289109
Same for me in Golf 5 with Retrofitted DM PQ an Dynaudio from Scirocco. I tried many things to get these Sound Profiles working. Actually car is in garage because dameged exhaust. After repair i will try to bring a new dataset with ODIS in that car. Maybe it works.
I used Panasonic 5K0035456B DSP
