Controller Module Mapping
NZDubNurd
New Zealand
C?ID=230482
Hi all,
The engine ECU in my Touran comes up as "Redir Fail!" under labels.
Whats the MOST helpful way to map the module, and send it to Ross-Tech?
In the Wiki (Control Module Maps), it says to use either of the two options:
Autoscan with debug level 2, or map the individual module (this sounds like it maybe the better option?)
If Individual module, is it best to use the security access code? Does that give better info?
(I'll ask about codes in another question ;))
Cheers,
Allan.
Of the Engine is the module of primary concern, just do that module. The results for that module will be the same; but it will be faster.
You shouldn't need to use a security code.
NZDubNurd
New Zealand
C?ID=230482
Thanks - I get it done when I have a chance :-)
