2019 vw polo powersteering crash data stored
Frikki
South Africa
C?ID=357723
hi there all members. i used to have original vcds interface before it got lost, so i went for aftermarket one. but decided to get the new hex v2 interface. i have the following problem with power steering unit. i used several different log in access codes which is excepted by controller. after that i try and reset to factory settings. it shows RUNNING. and after about 6 seconds it shows STOP RUNNING. it needs to run at least for a few seconds to work successfully. vehicle has been in a left front smash. airbags did deploy. many thanks for assistance. keep well.
Thursday,28,March,2019,15:39:07:62451
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: AAVZZZAWZJU070769   License Plate:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: AAVZZZAWZJU070769   Mileage: 7905km-4911miles
Address 01: Engine (J623-CHZL)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BD    HW: 04C 907 309 AT
   Component: R3 1.0l TFS   H21 5150
   Revision: WXH21---
   Coding: 01110012230411080000
   Shop #: WSC 31414 790 00200
   ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
   ROD: EV_ECM10TFS01104C906026BF.rod
   VCID: 649058E3BED480171A5-8030
   CAN Converter 01:
          U0428 00 [039] - -
                    Mileage: 7905 km
                    Date: 2019.03.28
                    Time: 15:07:34
                    Engine speed: 0.00 /min
                    Coolant temperature: 86 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 12.321 V
                    Outside air temperature: 27 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 9.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Engine operating condition: Idling
Readiness: 1110 0001
   Part No SW: 2Q0 614 517 AB    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0223
   Serial number: 08502397180624
   Coding: 09034B64154890ADD203A81C24E342A649124D26224A242444541254452442659248B26444522424222A482AA23196421D8C6942B8
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
   VCID: 6E843ACB60183A477C1-803A
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 207
                    Mileage: 7905 km
                    Date: 2019.03.28
                    Time: 15:07:32
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 D    HW: 2G2 820 045 D
   Component: SG_AC_Manuell H50 0301
   Coding: 012100000800000001000400020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0.rod
   VCID: 221C1EFBE440CE27A89-8076
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H98 0916
   Serial number: 08001818400493
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77AA1FAF1F427B8FAF7-8022
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000021729029
   Coding: 1F0000
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000021430448
   Coding: 050000
   Serial number: 000000000ZY181343L7G
   Serial number: 00000000000099527694
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC000000000005C0000CF008800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025C7E7B44802E27889-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 061 606 18
   Serial number: 3577Y22C3272ABA4E1BI
   Subsystem 2 - Part No SW: -----------    HW: 442 061 606 18
   Serial number: 3587Y22B32771D0511C
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 505 18
   Serial number: 35177839F29B22A2C28W
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 505 18
   Serial number: 35277839F29B22A3922P
   Subsystem 5 - Part No SW: -----------    HW: 442 131 109 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11A92A3CAD512E3
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 207
                    Mileage: 7905 km
                    Date: 2019.03.28
                    Time: 15:08:19
   Part No SW: 2G0 920 730 A    HW: 2G0 920 730 A
   Component: KOMBI         209 0461
   Coding: 24A0010021000008010800000000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001023
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 1F1A170FD732E3CF877-804A
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H98 0916
   Coding: 030000046F085600F8000048080E00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0.rod
   VCID: 6FBA27CF6712334F777-803A
   Subsystem 2 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1007BAB9
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 620 6030
   Serial number: 0571200CB4J1603
   Coding: 00000000000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 3A2CC69B6CD0A6E7909-806E
15788544 - Crash Shut-Down Activated
          P1609 00 [137] - -
          [DEM_FRONT_CRASH_FAULT]
                    Mileage: 7905 km
                    Date: 2019.03.28
                    Time: 15:35:28
                    Engine speed: 0 /min
                    Terminal 15 status: On
                    Voltage terminal 30: 12.35 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
   Part No SW: 17A 035 869     HW: 17A 035 869
   Component: MU-E--ER      690 8740
   Serial number: 07061800011365
   Coding: 027200003C00000041110001000110001F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 68884CD342FCE47736D-803C
End----------(Elapsed Time: 01:14, VBatt start/end: 12.4V/12.3V)-----------
Got Frikki Verfied. Moving to Car Repair Support.
Frikki
South Africa
C?ID=357723
Thanks. Any idea why I have this problem UWE. Many thanks.
Why? Because the car was crashed. ;)
But no, I do not have any specific advice or procedure for this newer TRW_G4L_MQBA0 steering rack, and it sounds like you've already tried the stuff documented for the previous generation EPS_TRW_ALow?
Frikki
South Africa
C?ID=357723
Yes I have. And I have always succeeded with previous generation Polo. The new polo with chassis aw is a headache☺ thanks
Frikki
South Africa
C?ID=357723
any idea why would RUNNING be interrupted in basic settings? could it be that the power steering unit is not happy with something, that's why it stops running. thanks.
Shuhel
Birmingham, UK
C?ID=368132
Hi frikki, did you find a solution for the new rack?
Frikki
South Africa
C?ID=357723
Customer said some other mechanics did something to vehicle for powersteering to work. Cant tell me what exactly. But it did work. Problem still is to get g85 calibrated. I'm still waiting for customer to bring car back to me. To try calibrate g85 sensor. Thanks
Shuhel
Birmingham, UK
C?ID=368132
there is a guys up in manchester claiming he can do this with his vcds for £100 but wont give away the procedure, i offered him payment over the phone but didnt want to tell me :/
seems like this new rack only a few people worked it out how to do it.
i cant wait!!
Jamesvag
Belfast, UK
C?ID=13104
Hi. I have same problem in 2016 Fabia can’t calibrate G85. Was hoping you got a solution😬
Many thanks
Hi. I have same problem in 2016 Fabia can’t calibrate G85. Was hoping you got a solution��
Many thanks
Hi and welcome. Please post an Auto-Scan so people can see exactly what this car is made of.
iichel
Netherlands, Operation Market Garden
C?ID=284912
Calibrate G85 in a 6C0 car is quite easy. I'm not sure this applies to a 2Q0 car as well.
Your 2016 Fabia will be a 6C0 car.
With a running engine and standing still
- Turn steering wheel fully left and hold, wait for beep
- Turn steering wheel fully right and hold, wait for beep
- Center steering wheel
- Open 44 steering angle with vcds, Security acces 17580
- Basic settings - steering angle - zero setting
- DONE :D
haruto0
Unauthorized Advertiser
C?ID=345518
i cant wait!!
Try this link on ebay.They do it cheaper and i had to get mine fixed.I tried everywhere dealership wanted to change rack and ecu at silly money but these guys did it for £80.
https://www.ebay.co.uk/itm/[redacted]
This is your final warning: Refrain from making these disingenuous posts. I know for a fact that the eBay listing you're trying to advertise here belongs to you.
