HVAC problem
Fredrick Awuor
Kenya
C?ID=309834
Hello guys....ECU logs a sympathy code for AC,while going directly to HVAC,no fault code found,can this be a bug in the ECU?.....client claims AC high pressure sender was replaced sometimes back in another workshop when it refused to work.....at the moment AC works just fine .. fault frequency of 79 on ECU is weird .. erasing error on ECU and it comes back immediately the AC is switched on,any hints will be greatly appreciated
Tuesday,26,March,2019,13:18:43:21182
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WVWZZZ1KZAM695976   License Plate:
Mileage: 103990km-64616mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAM695976   Mileage: 103990km-64616miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 AM    HW: 03C 907 309 A
   Component: MED17.5.5           9970
   Revision: LCH02---    Serial number:
   Coding: 0000077
   Shop #: WSC 83300 981 115807
   VCID: 6A8DC02DB07AC2B7209-803E
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
               U1025 - 000 -  - Intermittent
                    Fault Frequency: 79
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 68.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 820.0 mbar
                    Voltage: 12.446 V
001056 - Catalyst System; Bank 1
               P0420 - 000 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100000
                    Mileage: 101307 km
                    Date: 2013.07.07
                    Time: 02:32:16
                    RPM: 2026 /min
                    Load: 32.1 %
                    Speed: 92.0 km/h
                    Temperature: 87.0°C
                    Temperature: 46.0°C
                    Absolute Pres.: 810.0 mbar
                    Voltage: 13.843 V
005241 - Brake Boost Vacuum System
               P1479 - 000 - Mechanical Failure - Intermittent
                    Mileage: 103008 km
                    Date: 2013.08.02
                    Time: 00:48:11
                    RPM: 834 /min
                    Load: 48.6 %
                    Temperature: 87.0°C
                    Temperature: 56.0°C
                    Voltage: 13.462 V
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501311167244
   Shop #: WSC 54094 000 1048576
   VCID: 392F2F61855CB92F993-806C
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B400D092B00FFC81402EB901F0080310000
   Shop #: WSC 00066 000 00000
   VCID: 7AADF06DCCDA7237D09-802E
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00147
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D87CB318D14D58F45B-8038
   Part No SW: 5K0 937 084 C    HW: 5K0 937 084 C
   Component: BCM PQ35 B    011 0029
   Revision: BG011001
   Coding: 0C180E3A982D02C0440000800000002403000088525D8960648000000000
   Shop #: WSC 12345 123 61029
   VCID: 323D184D542A4A77589-8066
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 22051  21  0512
   Coding: 009795
   Part No SW: 5K0 959 655 E    HW: 5K0 959 655 E
   Component: AirbagVW10G   037 0606
   Serial number: 003FLR00M1MP
   Coding: 00003138
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C21367586EE8C07825-8068
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME44716551ZZZQ
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME242F6251ZZZV
   Serial number: 3511HSME3D412921ZZZG
   Serial number: 3521HSME192F3821ZZZN
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001004
   VCID: 025D888DA80A3AF7889-8056
   Part No SW: 5K0 920 860 H    HW: 5K0 920 860 H
   Component: KOMBI         H04 0308
   Coding: 570B00
   VCID: 313F174151AC716F213-8064
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 090510F2000200
   Coding: ED807F06000202002003
   VCID: 698FBF21B57CC9AF293-803C
                    Reset counter: 245
                    Mileage: 87338 km
                    Date: 2012.06.30
                    Time: 04:12:06
   Component: IMMO          H04 0308
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC02DBCFAC2B7209-803E
   Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0308
   Revision: 12101005    Serial number: 0000872788
   Coding: 0012B6
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 2809FA25627630A7F6D-807C
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004862199
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313F17415D2C716F213-8064
   Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0308
   Revision: 14101005    Serial number: 0000889693
   Coding: 0013B6
   ROD: EV_DCU52BrosePasseSide_VW36.rod
   VCID: 290FFF21797C09AFE93-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004852962
   Coding: 000290
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [008] - Electrical Failure
                    Reset counter: 182
                    Mileage: 102782 km
                    Date: 2019.03.08
                    Time: 00:53:29
Address 56: Radio
End----------(Elapsed Time: 01:04, VBatt start/end: 13.7V/13.7V)-----------
It could also be a bug in the HVAC module, or some other.
It looks like there is a software update (0305 -> 0306) available for the HVAC module.
Are all the parts in this car original?
Fredrick Awuor
Kenya
C?ID=309834
Thanks ,apart from the high pressure sender that I couldn't scrutinize, all others are original
