Turning off DRL winking in updated C7 S6
kczach
C?ID=123637
Hi all,
I have a 2017 S6. With the updated VAG-COM software there is now a long coding helper in module 9. I was looking to turn off the winking feature, however there are a lot of lighting options available. I did uncheck the box on byte 27, bit 4 which was something like turn off led with turn signal.
When I did this the lower led would flash opposite the yellow blinker. I don't really want to be that flashy like an emergency vehicle!
Is there other coding that needs to be done i.e. dimming of led? As mentioned earlier there are a lot of options and I don't really want to start checking boxes willy-nilly.
Thanks for your help in advance.
Monday,21,January,2019,16:55:43:49599
VCDS Version: 18.9.1.0 (x64)
VIN: WAUHFAFC4HN122204   License Plate: CLZ
Mileage: 16688km-10369mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 BA
VIN: WAUHFAFC4HN122204   Mileage: 16688km-10369miles
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0002
   Revision: NCH63---
   Coding: 0A2500326546010E3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 234F11CC2A144752E0-8076
Readiness: 0010 0101
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H06 0007
   Revision: --H06---
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 3065EE806BE2ECCA6D-8064
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65BED449A67D2B921B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 4183BB44D048754292-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0825
   Coding: 0DA86F4E000000000000
   VCID: 00057E4093C2BC4ADD-8054
   Serial number: 3217000044182016
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 05041700040969
   Coding: 688130B85D0000
   VCID: 6AD13CE88DBE561A63-803E
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 2102003S    Serial number: 00001631940501
   Coding: 01050011043C9FF2F90148C7A0003800CF9CD208AE08022180000894F10017020060002D0B0000
   VCID: 79F313A4F018ED829A-802C
   Component: WWS57X 170301  H38 0080
   Serial number:         170308110529
   Coding: 0045F7
   Serial number: 20172518X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
   Component: E1 - LDS  H07 0044
   Serial number: 29 03 2017  00000451
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z02D5DBEB
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA127015000030971731
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 37284C9800PAG0MUFU03
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 295303E448389D02AA-807C
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0092
   Revision: --------    Serial number: 003G0003ZU67
   Coding: 303331343135303334354A55304C34473053
   VCID: 346DE2909FFAD0EA09-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y170001L1E40G
   Serial number: 3575HRB405T4CVFI58VM
   Serial number: 3585HRB405T468HIC91H
   Serial number: 3515JRB400U599TUIH3A
   Serial number: 3525JRB4014599TUE0TY
   Serial number: 3554VRB400659I8MP24H
   Serial number: 3564VRB400459I8MS96S
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QD40000S
   Coding: 0004FC
   VCID: 3875D6A08B92348A25-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 11 01 2017  C0010692
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
   Component: TBenUsaAccNv  H15 0225
   Revision: 15001309    Serial number: 658050417596017
   Coding: 03CF0905BF51D705020200
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 3C7DCAB0B7AA18AAC1-8068
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002573622
   Coding: C0ED074814
   VCID: 3D7BC7B4ACB011A2F6-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 0986723504
   Voltage stabilizer:
   Serial number: 17012100000000000169
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 0E0100
   VCID: 3A71CCA8B59E269AD3-806E
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 67D745DC96AC6B727C-8032
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 003003170001009
   VCID: 285506E05332A40AB5-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 04041700041266
   Coding: 20
   VCID: 3E79C0B8A1B60ABAEF-806A
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F67EDFC76DCF33274-807A
   Revision: AA000000    Serial number: 00000250158008
   VCID: 77F7159CC60CFBF2EC-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02RDES
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3777D59C8E8C3BF22C-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0437049975
   Coding: 040211
   VCID: 3973D3A4B8982D82DA-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0436831968
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015E00628002000013
   VCID: 458BAF54CC605962AE-8010
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000689500
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A71CCA8BD9E269AD3-806E
   Revision: 00002001    Serial number: 0437268663
   Coding: 0106063A00FA718581B0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000392588
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST001J0OFN00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00032177956
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 6600213=
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002000002
   VCID: 4689A858F166527AA7-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002154574
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3261E48865EEDEDA1B-8066
   Coding: 04FA0A1122600400
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 D    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   053 0902
   Serial number: A741C0H7535311
   Coding: 017551020000000013220002041A00102F0007E5F17001047E
   VCID: 1F471D3C067C63B2C4-804A
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY807NQ1
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349QD60002J
   Compact Disc Database:
   Component: Gracenote2---  --- 3011
   Component: TSG HL        H03 0511
   Coding: 010F17004000628002000002
   VCID: 4993A364E078BD024A-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0380
   Revision: 11001001    Serial number: 82330JG0394149
   Coding: 0212000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 056700456
   Coding: 111104C120
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H09 0306
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   VCID: 356BDF949480C9E23E-8060
   Component: DPC-SG        H28 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C5DFAF047CA882A51-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 275705DC5E2CAB72BC-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002450204177
   Coding: 04C1BA1B0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3163EB8460E8E5C262-8064
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 170307200507
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813008226001
   ROD: EV_AEMLearAU64X_AU57.rod
End-------------------------(Elapsed Time: 07:09)--------------------------
Sent from Mail for Windows 10
Maybe Byte 3, bit 7?
kczach
C?ID=123637
Thanks for the response Uwe. Byte 3 bit 7 didn't work. It still wants to wink. If someone wants a busy turn signal bit 27 byte 4 is the way to go. It alternates flashing yellow top led with the white bottom one. A little bit busy for me.
