How to troubleshoot no response from controller for 02 Transmission
JohnInSeattle
C?ID=327749
I am a newbie with VCDS but not with electronics, just need some troubleshooting help.
Working on two almost identical Beetles. 2005 and 2004, both TDI with DSG transmissions.
It works great on the 2005, diagnosed and fixed several issues with several systems, including the transmission, communicates with all the controllers.
When I connected it to the 2004 I can see all the systems except the transmission which gives the dreaded "no response from controller".
The transmission in the 2004 seems to be working but started juddering on takeoff a few days ago, hence the scan.
I already have a new camshaft position sensor on order, hoping that may be causing the juddering, certainly causing some hard starting issues.
Just need some ideas what to check on why no transmission?
I do have a scope and logic analyzer if needed.
John.
Sunday,24,March,2019,09:59:32:10819
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: 3VWCR31C54M418504   License Plate: ROSIE
Mileage: 226520km-140753mi   Repair Order:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCR31C54M418504   Mileage: 226520km-140753miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 997 016 M    HW: 028 101 114 7
   Component: R4 1,9L EDC G000DG  2878
   Revision: 12345678    Serial number: VWZ5Z0D1251113
   Coding: 0150038
   Shop #: WSC 23337 444 64779
   VCID: 280905DB3EE1BF77F6D-5160
16791 - EGR Sensor 2
            P0407 - 000 - Signal too Low
                    Torque: 0.0 Nm
                    Lambda: -7.6 %
                    Mass Air / Rev.: 1000.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
19463 - Camshaft Position Sensor (G40)
            P3007 - 000 - No Signal - Intermittent
                    RPM: 882 /min
                    Torque: 48.0 Nm
                    Voltage: 14.21 V
                    Bin. Bits: 00001100
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
Readiness: 1 1 1 1 1
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019458
   Shop #: WSC 00066 000 00000
   VCID: 3431E1ABF229CB974A5-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AG
   Component: 01 AIRBAG VW71      0710
   Coding: 0012337
   VCID: 7CA1098B9AF9C3D7C25-5160
   Subsystem 1 - Part No: 1C0 959 339 F
   Component: BF-Gewichtsens. 006 0007
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 M
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11232
   Shop #: WSC 23344
   VCID: 2B03FAD72A17946F1BF-4B1E
   3VWCR31C54M418504     VWZ5Z0D1251113
00771 - Fuel Level Sensor (G)
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B92DBBC3B1B7B76ED-4B1E
   Part No: 1C0 959 799 G
   Component: 2K Komfortgerát HLO 0004
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B23CA97DA7704EF8BF-4B1E
   Subsystem 1 - Part No: 1C2959802A
   Component: 2K Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C2959801A
   Component: 2K Tõrsteuer.BF KLO 0202
   Part No: 1C0 035 196 H
   Component:  RADIO DE2         0004
   Coding: 06031
   Shop #: WSC 00066
   VCID: 241111EB47C95B17DA5-51CE
00856 - Radio Antenna
            36-10 - Open Circuit - Intermittent
End----------(Elapsed Time: 03:54, VBatt start/end: 12.0V/12.1V)-----------
Since none of the other modules are fussing that the TCM is off line, the first thing I'd do is check continuity of the K-Line (that's the single-wire dedicated diagnostics "bus") from Pin 7 of the OBD-II port to the corresponding pin on the TCM (mechatronic).
JohnInSeattle
C?ID=327749
Thank you.
I think this is correct, the K-Line appears to be pin 1 on the DSG plug, is that correct? is there a wire color used for it?
Not going to have time to test until Wednesday.
DrPeter
16.4905° S, 151.7375° W
You can verify this information in the Official Factory repair manuals and wiring diagrams.
Having a quick look at the above picture, there are a few discrepancies / modifications needed.
Pin T20/13 = [15-Powrer] (Key on power)
Pin T20/11 and T20/18 = [30-Powers] (Battery power)
Pin T20/16 and T20/19 = [Grounds]
Hope this helps,
drpeter
JohnInSeattle
C?ID=327749
After taking out the battery and tray I was able to get to the TCM plug and test the connectivity.
Pin 1 on the TCM plug is connected to pin 7 on the ODBII port.
I tested pin 1 on the TCM and found it is connected via a diode drop (.7v) to Ground on the TCM port.
I double checked another core DSG transmission I have and it was the same.
Thinking it might have just needed a wiggle or reboot, I put it all back together and it worked.
Connected to the TCM just fine and it reported no error codes.
Whew!
If I ever get a module not talking in the future I will try rebooting first.
Thanks all.
