Coding for 2014-2017 (preferably 2015) Audi A8 L with night vision and no ACC
andy86na
C?ID=175954
I retrofitted the car with night vision assist. All parts are in but need to check the coding before taking it to the dealer for calibration. Can someone with an equivalent car post the VCDS readout in full?
Thanks,
Andy
South Molton, UK
To know if their car is equivalent we'll need you to post a full unedited Auto-Scan of your car :thumbs:
Aitrui
planet earth
C?ID=277621
I have lot of A8 and A8L logs, never seen any A8 4H in my life, which didn't had ACC but had Nightvision. In my region, seems everyone ordered ACC when bougth the car.
I'm pretty sure it can be coded to work.
andy86na
C?ID=175954
Here is the full scan. Note: Original instrument cluster (ending in 920K) has been replaced with the new cluster (ending in 820M), with same options except it also has Night Vision.
I will take any logs with NV you can supply, with or without ACC. Wibb be of help no matter what.
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 28 34 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 69 6C 6D 6F 72 81 82 84 88 89 8F 90
VIN: WAU3GAFDXFN033671   Mileage: 55874km-34718miles
84-Night Vision -- Status: Malfunction 0010
Address 01: Engine (J623-CREC)       Labels: None
   Part No SW: 4H2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---
   Coding: 0A2A0034052E010E3004
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214H2907551A 003001
   ROD: EV_ECM30TFS0214H2907551A_003.rod
   VCID: 2A18E7DA4DBEBC1AA3-807E
Readiness: 0000 0100
   Part No SW: 4H1 927 158 CS    HW: 0BK 927 156 AD
   Component: 0BK 30TFSIUSA H19 1003
   Revision: --H19---
   ROD: EV_TCMALX51011.rod
   VCID: 03466A7E8A548D52C0-8056
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Coding: 8CE5F3C031A7CF03E200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 43C6AA7ECAD44D5280-8016
   Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 ED
   Component: BCM2 2.0      H36 0560
   Coding: 0DA76F4E000000000000
   VCID: 70AC35B2A3E286CA2D-8024
   Serial number: 3215000006041013
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000134646510
   Coding: C018320085047201010001010101112131313333283333
   VCID: 3522C4A69C00E3E23E-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 668122BE780100
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D12ECC67C50AB2246-8078
   Part No SW: 4H0 907 063 DB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0311
   Revision: 19020001    Serial number: 00001009913801
   Coding: 01050011043C9FE089004884A0003800009CF308A60802218000081471101700006000240B0000
   VCID: 6B9622DE8AC4651218-803E
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 141213  H36 0090
   Serial number:         150112121046
   Coding: 0045F7
   Serial number: 23726008
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 G    HW: 4H0 941 531 G
   Component: E1 - LDS  H01 0044
   Serial number: 10 05 2017  00001273
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01E238CF
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA120043000011408128
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 7F89C297000000000001
   Part No SW: 4H0 959 655 G    HW: 4H0 959 655 G
   Component: Airbag10.43   H63 0083
   Revision: --------    Serial number: 003KC0016N8U
   Coding: 303331323130303232304A55304C34483053
   VCID: 3A38D79ABD1E0C9AD3-806E
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 01335OB5000V0
   Coding: 000434
   VCID: 383CCD928B121E8A25-806C
   Subsystem 1 - Part No SW: 4H0 951 528 K    HW: 4H0 951 528 K
   Component: E221 - MFL  H09 0010
   Serial number: 10 01 2015  A0023143
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 820 M    HW: 4H0 920 820 M
   Component: TBenUSA---NV- H53 0707
   Revision: 37081202    Serial number: 658270614592016
   Coding: 0B6608001B41D705020000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K.rod
   VCID: 2E10EBCA7156D03A7F-807A
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 M    HW: 4H0 919 204 M
   Component: Analoguhr D4  H05 0225
   Serial number: 2150107000640
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000001721922
   Coding: C0CD075200
   VCID: 75A204A6D480A3E2FE-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 52027916341911404958
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 15040000227021200410
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 22
                    Mileage: 55797 km
                    Date: 2019.03.23
                    Time: 22:24:27
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 11 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 22
                    Mileage: 55797 km
                    Date: 2019.03.24
                    Time: 01:27:47
                    Voltage terminal 30: 12.1 V
                    Control Module temperature: 10 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 383CCD9283121E8A25-806C
   Coding: 008001
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F2EF6CE765CD93274-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000134646138
   Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA7702FV6J
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373ECEAE8E0C11F22C-8062
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0357636404
   Coding: 040211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3326FABE9A74FDD210-8066
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0040
   Serial number: 0359120701
   Coding: 040211
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000136209870
   Coding: 011F1F005E0062C202003016
   VCID: 48DCBD52FBF26E0A55-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0013416637
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0360603437
   Coding: 0106023A00FA719FB0B0C784220316470000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0081
   Serial number: 00000000000000268580
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 503200052210
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H13 0080
   Serial number: A2015000000000837242
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 502700050418
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 503200051988
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 502700050426
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93426885
   Revision: CJ007001    Serial number: 00000000164677
   Coding: 030000
   VCID: 1D723C0604F05BA2D6-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000136212532
   Coding: 011F1F005E0062C202003006
   VCID: 3C34D182BF2A32AAC1-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001368793
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Coding: 02F2021122200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   VCID: 312AF0B66068CFC262-8064
   Coding: E00200
   Coding: E00200
Address 56: Radio (R)       Labels: None
   Part No SW: 4GD 035 082 G    HW: 4GD 035 082
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 315B00F7509983
   Coding: 020007010000000001
   Part No SW: 4H0 035 746 J    HW: 4H0 035 746 J
   Component: H-BNT-NA      H42 0902
   Revision: --------    Serial number: 503BS0F7504524
   Coding: 02020000000BF5EF5516AB1E00000003140001000000000000
   VCID: 2F2EF6CE7E5CD93274-807A
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDEY9005WGQ
   Subsystem 3 - Part No SW: 4H1 919 600 M    HW: 4H1 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000185879
   Component: CD-Database  5950
03389 - Data Set Implausible
            000 -  -
                    Reset counter: 236
                    Mileage: 55790 km
                    Date: 2019.03.23
                    Time: 13:52:12
                    Voltage: 14.50 V
                    Bin. Bits:      010
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000135051251
   Coding: 010F1F00400062C202003006
Address 69: Trailer        Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Coding: 0109080000000000
   Shop #: WSC 00417 219 93288
   VCID: 71AA30B6A8E88FC222-8024
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0204399
   Coding: 020D000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI_008_AU64.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 020501161
   Coding: 021004C120
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FAE36CEB6DC993234-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000177363
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63864AFE6A142D52A0-8036
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000135051250
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H09 0083
   Revision: 0L0D5015    Serial number: SN150107  0345
   ROD: EV_GSM2x3Mono.rod
   VCID: 2B16E2DE4244A51258-807E
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4H0 919 617     HW: 4H0 919 617
   Component: HeadUpDisplay H17 0021
   Coding: B20000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 6D922CC6BCD06B2206-8038
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201503
   Coding: 210000
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C14E1C2474AA22A51-8078
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1531000240
12 Faults Found:
4107 - No Basic Setting
          B2010 00 [009] -  -
          [NightVision ECU: basic settings are missing or not correct]
                    Reset counter: 237
                    Mileage: 55797 km
                    Date: 2019.03.23
                    Time: 20:07:32
                    Image processor: error number-Image processor: error number 2: 00 00 00 00
                    Image processor: error number-Image processor: error number 1: 13 C0 00 04
                    Voltage terminal 15: 11.80 V
                    Dynamic calibration-Dynamic calibration: yaw angle offset: -0.20 °
                    Dynamic calibration-Dynamic calibration: pitch angle offset: 1.00 °
                    Dynamic calibration: status-Dynamic calibration: pitch angle offset: 0.00 °
                    Dynamic calibration: status-Dynamic calibration: OFF
                    Dynamic calibration: status-Distance traveled with active dynamic calibration: 10096 km
8704 - Databus
          [BCM1 (RLS_01): no signal: no communication]
                    Reset counter: 26
                    Mileage: 55829 km
                    Date: 2019.03.24
                    Time: 09:02:06
8960 - Databus
          [BCM2(VIN_01): no signal: no communication]
                    Reset counter: 26
                    Mileage: 55859 km
                    Date: 2019.03.24
                    Time: 11:22:48
9216 - Databus
          [Gateway(Gateway_07): no signal: no communication]
                    Reset counter: 26
                    Mileage: 55865 km
                    Date: 2019.03.24
                    Time: 12:01:52
9217 - Databus
          [Gateway(Gateway_11): no signal: no communication]
                    Reset counter: 26
9729 - Databus
          [Kombi_02 (Instrument Cluster): outer temperature: no signal: no communication]
                    Reset counter: 26
9744 - Databus
          [Kombi_HUD_01 (Kombi): no signal: no communication]
                    Reset counter: 26
10240 - Databus
          [Klemmen_Status: no signal: no communication]
                    Reset counter: 26
                    Mileage: 55829 km
                    Date: 2019.03.24
                    Time: 09:02:06
10256 - Databus
          [Diagnose_01: no signal: no communication]
                    Reset counter: 26
                    Mileage: 55874 km
                    Date: 2019.03.24
                    Time: 14:43:29
10272 - Databus
          [Motor_02: no signal: no communication]
                    Reset counter: 26
10304 - Databus
          [EFF_01: no signal: no communication]
                    Reset counter: 26
          U1101 00 [008] - Active
          [Active component protection]
                    Reset counter: 25
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00020102069701
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00020102071901
   Coding: 366FF2
   Coding: 0006F009031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3228FFBA656EF4DA1B-8066
End----------(Elapsed Time: 05:57, VBatt start/end: 12.6V/12.7V)-----------
andy86na
C?ID=175954
Does anyone have coding examples?
Aitrui
planet earth
C?ID=277621
Here are some, i didn't checked the production dates, only which has night vision.
Wednesday,20,March,2019,11:03:14:10366
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
Workshop Code: 332 00001 000022
VIN: WAUZZZ4HXAN002275   License Plate: A8_4H_42TDI
Mileage: 184525km-114658mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 1B 22 28
          34 36 3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 84
          85 88 89 8B 8E 8F 90
VIN: WAUZZZ4HXAN002275   Mileage: 184525km-114658miles
Address 01: Engine (J623-CDSB)       Labels:* Redir Fail!
   Part No SW: 4H0 907 409 D    HW: 4H0 907 409
   Component: 4.2TDI EDC17  X09 0002
   Revision: 34X09---
   Coding: 0106002C291F0268
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM42TDI1114H0907409D 001002
   ROD: EV_ECM42TDI1114H0907409D.rod
   VCID: 2D12C1177C39402246-8078
10271 - Diesel Particle Filter: Differential Pressure Sensor 2
          P245F 00 [237] - Implausible Signal
                    Mileage: 184405 km
                    Date: 2019.03.18
                    Time: 05:48:04
                    Engine speed: 0.00 /min
                    Coolant temperature: 44 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.420 V
                    Vehicle speed: 0.00 km/h
                    Exh p P Flt Diff B1: 22 hPa
                    Exh p P Flt Diff B2: 32 hPa
                    Particle filter: offset for differential press.: 21 hPa
                    Particle filter bank 2: diff pressure offset: 26 hPa
                    Exh p Diff Ofs Val Old B1 mp: 20 hPa
                    Exh p Diff Ofs Val Old B2 mp: 25 hPa
Readiness: 1 1 0 0 1
   Part No SW: 4H1 927 158 Q    HW: 0BL 927 156 E
   Component: 0BL 42 TDIRdW H05 1009
   Revision: --H05---
   Coding: 001111
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMALX51011 001013
   ROD: EV_TCMALX51011_001.rod
   VCID: 3E30F65BA15FCBBAEF-806A
   Part No SW: 4H0 907 379 A    HW: 4H0 907 379 A
   Component: ESP PREMIUM   H08 0151
   Coding: E4FAA200275F4500E300
   ASAM Dataset: EV_ESPPremi 004012
   ROD: EV_ESPPremi_004_AU64.rod
   VCID: 302CD8636B0B2DCA6D-8064
0694 - Tire Pressure Warning
          C102D 00 [009] -  -
                    Fault Frequency: 41
                    Reset counter: 52
                    Mileage: 183306 km
                    Date: 2019.03.14
                    Time: 14:02:37
                    VzRef: B5
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 12
                    F-Path: 47
                    F-Type: 0D
                    Uz: B4
0717 - Tire Pressure Warning
          C102D 00 [009] -  -
                    Fault Frequency: 69
                    Reset counter: 52
                    Mileage: 182588 km
                    Date: 2019.03.09
                    Time: 08:19:22
                    VzRef: C5
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 12
                    F-Path: 47
                    F-Type: 04
                    Uz: B6
   Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 L
   Component: BCM2 2.0      H12 0510
   Coding: 05070001000000000000
   Shop #: WSC 05635 001 1048576
   VCID: 6C940C138FA3892A11-8038
   Subsystem 1 - Part No SW: 4H0 905 852 A    HW: 4H0 905 852 A
   Serial number: 0210000010828004
   Part No SW: 4H0 959 760 A    HW: 4H0 959 760 A
   Component: MEM-BFS       H07 0114
   Revision: AA000000    Serial number: 00001001388065
   Coding: C018320085043201010001010101112131313333283333
   VCID: 312ADD67680124C262-8064
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 4 Zonen H12 0064
   Coding: 381101B80C
   ASAM Dataset: EV_AirCondiFront 001048
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 2208222B35E78F5AEB-8076
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Fault Frequency: 30
                    Reset counter: 52
                    Mileage: 181688 km
                    Date: 2019.02.04
                    Time: 10:06:40
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H09 0083
   Revision: 15009001    Serial number: 00000000449876
   Coding: 0200201050B49FF1FB810004A0001908009CC3088A000121800008002100
   VCID: 291A350740D15C02AA-807C
   Component: WWS641 100109  H32 0040
   Serial number:         100210144608
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10790313
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 10 02 2010  00000150
   Subsystem 4 - Part No SW: 4H0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0020
   Serial number: 0000001805568R04HR05
   Subsystem 5 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Component: EVLS-SG  H07 0275
   Serial number: WA090995000000018266
   Coding: 020100
   Component: AQ_Hum_Sensor  H01 0001
   Serial number: 68080F05000000000001
03020 - Local databus 2
                    Fault Status: 00101100
                    Fault Frequency: 116
                    Reset counter: 69
                    Mileage: 181688 km
                    Date: 2019.01.20
                    Time: 15:12:00
                    Reset counter: 29
                    Mileage: 181688 km
                    Date: 2019.02.04
                    Time: 10:06:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2306272F22FD8652E0-8076
   Part No SW: 4H0 919 475 C    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H05 0011
   Revision: 11001001    Serial number: 44831001304058
   Coding: 300902
   ASAM Dataset: EV_AU64XParkiAssis2 005003
   ROD: EV_AU64XParkiAssis2.rod
   VCID: 3228D26B65071FDA1B-8066
Address 11: Engine II (J624)       Labels:* None
   Revision: 34X09---
   ASAM Dataset: EV_ECM42TDI2114H0907409D 001002
   ROD: EV_ECM42TDI2114H0907409D.rod
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Coding: 3604010201
   Shop #: WSC 02152 823 182615
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 291A350748D15C02AA-807C
   Part No SW: 4H0 959 655     HW: 4H0 959 655
   Component: Airbag10.43   H11 0012
   Revision: --------    Serial number: 003CM0013XA+
   Coding: 30314246313130303033554A304C34483053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001008
   VCID: 73A6176FDA9D56D2D0-8026
   Serial number: 3572DRB40000ABC50A8%
   Serial number: 3582DRB40000A93110DO
   Serial number: 3515JRB405270PNABPBM
   Serial number: 3525JRB405A70PNCEPTB
   Serial number: 3554VRB405B6B1V4F1PS
   Serial number: 3564VRB405B6B1V4K8N$
   Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JBF0000Q
   Coding: 00003C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Component: E221 - MFL  H06 0009
   Serial number: 02 12 2009  11002372
   Part No SW: 4H0 920 830 F    HW: 4H0 920 830 F
   Component: TDieRDWACCNV- H31 0189
   Revision: 21459120    Serial number: 658260314MT1000
   Coding: 03070800BF000008000000
   Shop #: WSC 99999 975 12345
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   VCID: 281C300353DB650AB5-807C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Serial number: 1121114000731
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 A    HW: 4H0 265 105 A
   Component: Standheizung  H20 0230
   Revision: 34003004    Serial number: 20100210012914
   Coding: 5D1300
   VCID: 200C282333EB9D4AFD-8074
   Part No SW: 4H0 907 468 C    HW: 4H0 907 468 C
   Component: J533--Gateway H07 0175
   Revision: --------    Serial number: 00000000007064
   Coding: 00C1037D00
   ASAM Dataset: EV_GatewUDS 001021
   ROD: EV_GatewUDS_AU57.rod
   VCID: 312ADD67600124C262-8064
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0130
   Serial number: 00000000005646099250
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 92
                    Mileage: 184425 km
                    Date: 2019.03.20
                    Time: 07:55:41
                    Voltage terminal 30: 12.4 V
                    Control Module temperature: 24 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 69
                    Mileage: 181688 km
                    Date: 2019.01.20
                    Time: 15:15:00
                    Voltage terminal 30: 11.6 V
                    Control Module temperature: 19 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 69
                    Mileage: 181688 km
                    Date: 2019.01.26
                    Time: 14:46:41
                    Voltage terminal 30: 11.9 V
                    Control Module temperature: -1 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 4H0 907 144     HW: 4H0 907 144
   Component: DYNAMIKLENK.  H06 0070
   Revision: 50001005    Serial number: --------------
   Coding: 8B0000
   VCID: 658279376C49B8624E-8030
   Part No SW: 4H0 907 163     HW: 4H0 907 163
   Component: 4 Wheel Drive H11 0005
   Serial number: 001802100001002
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
   VCID: 66807E3B994FB37A47-8032
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H11 0062
   Coding: 0100000000
   ASAM Dataset: EV_AirCondiHeck 001038
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H14 0099
   Coding: 008006
   Shop #: WSC 02152 823 28888
   ASAM Dataset: EV_AirSuspe 003024
   VCID: 2E10C61B713F3B3A7F-807A
          C10C8 00 [009] -  -
                    Reset counter: 52
                    Mileage: 181771 km
                    Date: 2019.02.26
                    Time: 10:35:59
   Component: MEM-FS        H07 0114
   Revision: AA000000    Serial number: 00001001388069
   Coding: C0183B0085053201010001010101112131313333203333
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0011
   Revision: --------    Serial number: EJ1370002FL$000
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH03 0110
   Revision: 00H03000    Serial number: 6PZ 010 287-00
   Coding: 0000101
   Shop #: WSC 32623 001 1048576
   VCID: 6D92011774B9802206-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0110
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F06.01.1200H010003CH10017˙
   Subsystem 4 - Serial number: H10017˙
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000102904929
   Coding: 011F1E205E0062C202000007
   VCID: 3B36FF4FBA4DDE92C8-806E
   Revision: 00002001    Serial number: 0127100162
   Coding: 011A0E2000397585B32007F28E0000000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000006270
   Subsystem 2 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 4 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.022  H06 0004
   Serial number:     WOO1000705U
   Coding: 001F00
   Subsystem 5 - Part No SW: 4H0 947 135 K    HW: 4H0 947 135 K
   Component: Dachelektroni  H12 0070
   Serial number: A2010000000000034662
   Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO10001QPR
   Part No SW: 4H0 035 223     HW: 4H0 035 223
   Component: BOSE G3 D4    H07 0050
   Revision: CI007500    Serial number: 00000000001005
   VCID: 5BF65FCF5A0DFE92E8-800E
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0162
   Revision: --------    Serial number: 0000102903700
   VCID: 3A38FA4BB577E79AD3-806E
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000347817
   VCID: 2A18CA0B4DD7571AA3-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357     HW: 4H4 907 357
   Component: ....AFS13.... H01 0091
   Serial number: 100219-0004-080
   Coding: 11116F33F91AFA00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 6FAE1B1FB6B5723234-803A
H02 0003
   Coding: 1A0000
H02 0003
   Coding: 1A0000
   Part No SW: 4E0 035 061 L    HW: 4E0 035 061
   Component: Radio U DAB   H46 0085
   Revision: AB001007    Serial number: 014BF0A7503412
   Coding: 010103010000000001
   VCID: 2404243327F3816A99-8070
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Component: HybridTV-DVB  H06 0550
   Revision: R0060000    Serial number: 76300802696101
   Coding: 01010000
   VCID: 302CD863630B2DCA6D-8064
   Part No SW: 4H0 035 670 P    HW: 4H0 035 670
   Component: H-BNT-EU      H48 0798
   Revision: --------    Serial number: 410BG0A7552050
   Coding: 020100000001FBEF75168F1E00000003000001000000000000
   Shop #: WSC 54172 001 1048576
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Subsystem 2 - Part No SW: 4F0 910 393 AH    HW: 4F0 862 393 E
   Component: BTHS  H24 0750
   Serial number: P10000090048
   Subsystem 3 - Part No SW: 4H0 919 604 F    HW: 4H0 919 604 F
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDC9300VWX-
   Subsystem 4 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600 B
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000004507
   Subsystem 5 - Part No: 8R0 060 961
   Component: CD-Database  1886
            000 -  -
                    Reset counter: 28
                    Mileage: 181669 km
                    Date: 2019.01.16
                    Time: 09:35:10
                    Text: DU902A,Front,M,0,0,6
02067 - Optical Databus; Unpermitted Wake-Up Request
            000 -  -  - Intermittent
                    Reset counter: 69
                    Mileage: 181688 km
                    Date: 2019.01.20
                    Time: 15:14:19
                    Voltage: 11.80 V
03623 - Invalid Secruity/Release Code
            000 -  -
                    Reset counter: 28
                    Mileage: 181669 km
                    Date: 2019.01.16
                    Time: 09:35:09
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000102939855
   Coding: 010F1E20400062C202000007
   VCID: 393AE547B071EC82DA-806C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H03---    Serial number: 525PA8-J01D12Y
   Coding: 1021002
   Shop #: WSC 02313 785 00200
   VCID: 65827937AC49B8624E-8030
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 F
   Component: HDSG-Modul    H11 0036
   Revision: 09145325    Serial number: 042000108
   Coding: 0210044000
   ASAM Dataset: EV_DeckLidContrUnit 001025
   VCID: 3B36FF4FB24DDE92C8-806E
   Revision: --------    Serial number: 000000003496
   ROD: EV_Ambie.rod
   VCID: 6386672F6A7DC652A0-8036
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000102939114
   Part No SW: 4H1 927 731     HW: 4H1 927 731
   Component: GSM-LL        H07 0083
   Revision: 0L0D4011    Serial number: SN100210  0096
   VCID: 6A980A0B8D57971A63-803E
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 D    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H08 0022
   Serial number: 0K84AE40002640
   Coding: 1101
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H07 0006
   Serial number: 00000000001004218208
   Part No SW: 4H0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H20 0016
   Revision: --------    Serial number: ---------------
   Coding: EC060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 271E333F5EC56A72BC-8072
   Part No SW: 4H0 907 182 A    HW: 4H0 907 182 A
   Component: IVB           H03 0027
   Serial number: 00448453082201
   Coding: 764FF2
   Serial number: 00448453419701
   Coding: 364FF2
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3604010201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
Address 8E: Image Processing (J851)       Labels:* Redir Fail!
   Part No SW: 4H0 907 107     HW: 4H0 907 107
   Component: BV-SG         H25 0008
   Serial number: 000040051802107
   Coding: 01A08201
   ASAM Dataset: EV_BVS 001007
   ROD: EV_BVS.rod
   VCID: 648464336F73C16A59-8030
   Component: RGS-VL        H16 0080
   Coding: 0066F609031F0376070308014240C0010000
   ROD: EV_RGS_L.rod
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H04 0070
   Coding: 0066F609031F037E070308014240C0010000
   ROD: EV_RGS_R.rod
   VCID: 70AC1863AB8B6DCA2D-8024
End----------(Elapsed Time: 03:21, VBatt start/end: 14.4V/14.6V)-----------
Wednesday,06,February,2019,13:05:39:10366
VIN: WAUZZZ4HXAN003667   License Plate: A8_4h
Mileage: 361453km-224596mi   Repair Order:
Scan: 01 02 03 05 06 08 09 0E 10 11 31 15 16 17 18 19 22 34 36 3B
          42 46 52 53 55 56 5F 62 6D 72 81 84 85 88 89 8F 90
VIN: WAUZZZ4HXAN003667   Mileage: 361453km-224596miles
   Part No SW: 4H0 907 409     HW: 4H0 907 409
   Component: 4.2TDI EDC17  H02 0010
   Revision: 34H02---
   Coding: 0106002C291F0168
   Shop #: WSC 08161 234 87797
   ASAM Dataset: EV_ECM42TDI1114H0907409 001016
   ROD: EV_ECM42TDI1114H0907409.rod
   VCID: 699A750788519C026A-803C
10265 - Mass Air Flow Sensor (G246)
          P010B 00 [039] - Implausible Signal
                    Mileage: 361453 km
                    Date: 2019.02.05
                    Time: 19:15:45
                    Engine speed: 1132.00 /min
                    Vehicle speed: 37 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.060 V
                    Crankshaft speed (RPM): 1132.0 /min
                    Vehicle speed: 38.45 km/h
                    AFS dm B1: 84.6 kg/h
                    AFS dm B2: 53.8 kg/h
                    AFS r Norm B1 mp: 0.9125
                    AFS r Norm B2 mp: 1.4349
                    Intake air temperature: 36.9 °C
   Component: 0BL 42 TDIRdW H07 1009
   Revision: --H07---
   Coding: 001111
   Part No SW: 4H0 907 379     HW: 4H0 907 379
   Coding: E4EAA20027574500E300
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 L
   Component: BCM2 2.0      H13 0560
   Coding: 01071001000000000000
   VCID: 6E90061BB9BF7B3A3F-803A
   Serial number: 0210000032095013
   Revision: AA000000    Serial number: 00001001386109
   Component: Klima 3 Zonen H12 0040
   Coding: 3811002804
0324 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 72
                    Mileage: 361449 km
                    Date: 2019.02.05
                    Time: 18:25:42
   Component: BCM1 2.0      H11 0083
   Revision: 15011001    Serial number: 00000000640029
   Coding: 0200E01050B49FE1EB810004E00019080F9CC3080A000101800008402100
   Component: WWS641 100309  H32 0040
   Serial number:         100414012027
   Coding: 0045F7
   Serial number: 10855414
   Coding: 025523
   Serial number: 07 04 2010  00000064
   Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0275
   Serial number: WA091314000000029667
   Coding: 020300
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5818C815000000000001
03608 - Humidity Sensor in Fresh Air Intake Duct
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 72
                    Mileage: 361449 km
                    Date: 2019.02.05
                    Time: 18:25:00
   Part No SW: 4H0 035 108 A    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0120
   Revision: AA001001
   VCID: 1E7016DB099FABBACF-804A
   Revision: 11001001    Serial number: 44831003305068
   Coding: 100102
   Revision: 34H02---
   ASAM Dataset: EV_ECM42TDI2114H0907409 001016
   ROD: EV_ECM42TDI2114H0907409.rod
   Part No SW: 4H0 959 655 B    HW: 4H0 959 655 B
   Component: Airbag10.43   H22 0026
   Revision: --------    Serial number: 003G10011LWW
   Coding: 30314246304230303034554A304C34483053
   VCID: 3522E977946908E23E-8060
   Serial number: 3575HRB40616O2OU8P5
   Serial number: 3585HRB40536CMJOCHUF
   Serial number: 3515JRB40576094IE99R
   Serial number: 3525JRB40556094IF99R
   Serial number: 3554VRB405H6NG4EK9MB
   Serial number: 3564VRB405J6NG4EJHCB
   Revision: --------    Serial number: 90815JD80000N
   Coding: 000034
   Subsystem 1 - Part No SW: 4H0 951 528 G    HW: 4H0 951 528 G
   Component: E221 - MFL  H04 0009
   Serial number: 08 03 2010  33005831
   Part No SW: 4H0 920 800 F    HW: 4H0 920 800 F
   Component: TDieRDW---NV- H29 0185
   Revision: 19409111    Serial number: 658220410593000
   Coding: 132608009B000008010000
   ROD: EV_RBD4K.rod
   VCID: 2502393724C978628E-8070
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 D    HW: 4H0 919 204 D
   Component: Analoguhr D4  H04 0210
   Serial number: 1100312021988
   Revision: 34003004    Serial number: 20100323170506
   Coding: 5D1300
   Revision: --------    Serial number: 00000000013679
   Coding: 00C1037D00
   Serial number: 00000000005640101940
   Serial number: 000204100001000
   Part No SW: 4H0 907 553 B    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H16 0095
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003017
   VCID: 2B16CF0F422D4E1258-807E
   Revision: AA000000    Serial number: 00001001385479
   Coding: C018330085053201010001010101112131313333203333
   Revision: --------    Serial number: EJ13700039JW000
   Component: TSG FA        H02 0158
   Revision: --------    Serial number: 0000103178298
   Coding: 011D0E205E00628202000002
   Shop #: WSC 02312 785 00200
   Revision: 00002001    Serial number: 0129313868
   Coding: 011A062000393481A32007B2880000000000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Subsystem 3 - Part No SW: 4H0 947 135     HW: 4H0 947 135
   Component: Dachelektroni  Hxx 0070
   Component: TSG BF        H02 0158
   Revision: --------    Serial number: 0000103062123
   Part No SW: 4H0 907 801 C    HW: 4H0 907 801 A
   Component: EPB-4         H03 0009
   Revision: --------    Serial number: 00000000001067
   ASAM Dataset: EV_ParkiBrake 001015
   Component: ....AFS13.... H01 0055
   Serial number: 100409-0004-041
   Coding: 11116F33F81AE200
H02 0003
   Coding: 1A0000
H02 0003
   Coding: 1A0000
   Part No SW: 4E0 035 056 H    HW: 4E0 035 056
   Component: Radio U STD   H45 0048
   Revision: AB001007    Serial number: 012DF0A7503007
   Coding: 010003020100000001
   Part No SW: 4H0 035 642 D    HW: 4H0 035 642
   Component: H-B-EU        H48 0078
   Revision: --------    Serial number: 406DM0A7505060
   Coding: 010000000001B3ED45140B1E00000003E6000100
   Subsystem 1 - Part No SW: 4H0 919 604 B    HW: 4H0 919 604 B
   Component: DU8 D4 SV NB  H44 0021
   Serial number: AUZ8ZDA110049M6
   Subsystem 2 - Part No SW: 4H1 919 609 E    HW: 4H1 919 609
   Component: E380 BDT D4  H09 0062
   Serial number: 00000000007062
   Subsystem 3 - Part No: 8R0 060 961
   Component: TSG HL        H04 0158
   Revision: --------    Serial number: 0000103315764
   Coding: 010D0E204000628202000002
   Part No SW: 4H0 959 107 F    HW: 4H0 959 107 F
   Component: HDSG-Modul    H11 0632
   Revision: 09145325    Serial number: 104000261
   Coding: 0200044000
   ASAM Dataset: EV_DeckLidContrUnit 001023
0004 - No Basic Setting
          B2010 00 [137] -  -
          [Steuergerät nicht kalibriert]
                    Reset counter: 72
                    Mileage: 361449 km
                    Date: 2019.02.05
                    Time: 18:25:41
                    Voltage terminal 30: 11.72 V
   Component: TSG HR        H04 0158
   Revision: --------    Serial number: 0000103315701
   Component: GSM-LL        H04 0081
   Revision: 0L0D4011    Serial number: SN100303  0084
   ASAM Dataset: EV_GSM2x3Mono 001014
   Component: NV-ECU-Gen1   H09 0022
   Serial number: 0K84AE40003899
   Coding: 1101
   Serial number: 00000000001006210589
   Coding: E4000000
   Part No SW: 4H0 907 182 C    HW: 4H0 907 182 C
   Serial number: 00448453041501
   Coding: 764FF2
   Serial number: 00448453092101
   Coding: 364FF2
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H04 0060
   Coding: 00060000031F030000030801424CDA000000
   ASAM Dataset: EV_RGS_L 002006
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H04 0060
   ASAM Dataset: EV_RGS_R 002006
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:31, VBatt start/end: 14.1V/14.4V)-----------
Wednesday,25,July,2018,11:04:45:10366
VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
Workshop Code: 785 02313 000200
VIN: WAUZZZ4H1AN001855   License Plate: A8_4H_
Mileage: 194119km-120619mi   Repair Order:
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 22 28 34
          36 3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 84 85
          88 89 8B 8E 8F 90
VIN: WAUZZZ4H1AN001855   Mileage: 194119km-120619miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
   Component: 4.2TDI EDC17  X02 0010
   Revision: 34X02---
   VCID: 699A750788519C0C90-803C
5453 - Starter Relay
          P3088 00 [096] - Electrical Malfunction
                    Mileage: 194028 km
                    Date: 2018.07.24
                    Time: 16:21:38
                    Coolant temperature: 63 °C
                    Intake air temperature: 62 °C
                    Voltage terminal 30: 11.540 V
                    Crankshaft speed (RPM): 0.0 /min
                    Battery voltage: 11700 mV
                    Status of starter activation-Bits 0-7: 00000001
                    Starter control: terminal 50-Bits 0-7: 00000000
                    Coolant temperature: 77.9 °C
                    Brk st Mn Raw-Bits 0-7: 00000001
   Revision: --H05---
   Coding: 001111
   VCID: 3E30F65BA15FCBB415-806A
Address 03: ABS Brakes (J104)       Labels:. 4H0-907-379.clb
   VCID: 302CD8636B0B2DC497-8064
0697 - Tire Pressure Warning
          C102D 00 [009] -  -
                    Fault Frequency: 41
                    Reset counter: 0
                    Mileage: 193919 km
                    Date: 2018.07.19
                    Time: 12:41:30
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: A0
                    Bit Info 4: 00
                    F-Path: 47
                    F-Type: 0A
                    Uz: 8A
0720 - Tire Pressure Warning
          C102D 00 [009] -  -
                    Fault Frequency: 41
                    Reset counter: 0
                    Mileage: 193919 km
                    Date: 2018.07.19
                    Time: 12:41:30
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: A0
                    Bit Info 4: 00
                    F-Path: 47
                    F-Type: 01
                    Uz: 8A
   Component: BCM2 2.0      H13 0510
   Shop #: WSC 44609 000 1048576
   VCID: 6C940C138FA38924EB-8038
   Serial number: 0209000096409015
   Revision: AA000000    Serial number: 00001001384604
   Coding: C008320085043201010021212121312131313333283333
   VCID: 312ADD67680124CC98-8064
   Component: Klima 4 Zonen H12 0040
   Coding: 389101BE0C
   VCID: 2208222B35E78F5411-8076
0130 - Motor for  Left Side Window Defrost Flap
          B10D7 21 [008] - Signal Amplitude Too Low
                    Fault Frequency: 17
                    Reset counter: 39
                    Mileage: 193963 km
                    Date: 2018.07.20
                    Time: 08:34:38
0138 - Motor for  Right Side Window Defrost Flap
          B10D8 21 [008] - Signal Amplitude Too Low
                    Fault Frequency: 23
                    Mileage: 193963 km
                    Date: 2018.07.20
                    Time: 08:34:36
   Revision: 15009001    Serial number: 00000000449847
   Coding: 0200201050B49FE1EB810004A0001908009CC3088A000121800008002100
   VCID: 291A350740D15C0C50-807C
   Serial number:         100210151748
   Coding: 0045F7
   Serial number: 10770056
   Coding: 025523
   Serial number: 08 02 2010  00000074
   Serial number: 0000001805568R045D05
   Serial number: WA100102000000015512
   Coding: 020300
   Serial number: D9088E05000000000001
   Revision: AA001001
   VCID: 1E7016DB099FABB435-804A
   Revision: 11001001    Serial number: 44831001303273
   Coding: 300902
   VCID: 3228D26B65071FD4E1-8066
   Revision: 34X02---
4528 - Coolant Fan Control Circuit 2
          P0481 00 [047] - Electrical Malfunction
                    Mileage: 193919 km
                    Date: 2018.07.19
                    Time: 12:51:04
                    Coolant temperature: 59 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 11.120 V
                    Mean injection quantity: 0.00 mg/stroke
                    Fuel temperature: 34.8 °C
                    Correction factor of the fuel temp for eng protection: 0.0000
                    Air mass at air mass meter 2: 0.0 mg/stroke
                    APP r: 0.00 %
   Coding: 3604010201
   Shop #: WSC 26867 136 83146
   VCID: 291A350748D15C0C50-807C
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_QEPBACC_FAIL]
                    Mileage: 193864 km
                    Date: 2018.07.12
                    Time: 12:26:29
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 12.433 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Revision: --------    Serial number: 003CM0012X0U
   VCID: 73A6176FDA9D56DC2A-8026
   Serial number: 3572DRB40000AAE0EABC
   Serial number: 3582DRB40000AAB1417V
   Serial number: 3515JRB405470PNC6HAC
   Serial number: 3525JRB405470PNCK0MM
   Serial number: 3554VRB405B6B1V4P16J
   Serial number: 3564VRB405F6B1V478CJ
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Revision: --------    Serial number: 90815JAT0000U
   Coding: 00043C
   VCID: 3228D26B6D071FD4E1-8066
   Subsystem 1 - Part No SW: 4H0 951 528 H    HW: 4H0 951 528 H
   Serial number: 16 12 2009  13000506
   Component: TDieRDWACCNV- H29 0185
   Revision: 19409111    Serial number: 658010210593565
   Coding: 130608009F000008000000
   ROD: EV_RBD4K.rod
   VCID: 281C300353DB65044F-807C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 F    HW: 4H0 919 204 F
   Serial number: 1100129000880
1048578 - No Basic Setting
          B2010 00 [009] -  -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 245
                    Mileage: 193864 km
                    Date: 2018.07.12
                    Time: 12:26:29
   Revision: 34003004    Serial number: 20100122222211
   Coding: 5D1300
   VCID: 200C282333EB9D4407-8074
   Revision: --------    Serial number: 00000000005868
   Coding: 00C1037D00
   VCID: 312ADD67600124CC98-8064
6656 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
                    Reset counter: 245
                    Mileage: 193864 km
                    Date: 2018.07.12
                    Time: 12:28:12
                    Voltage terminal 30: 10.1 V
                    Voltage terminal 15: 10.0 V
                    Control Module temperature: 44 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: On
                    Datenfeld: 0
   Serial number: 000802100001007
   VCID: 66807E3B994FB374BD-8032
   Component: Klima Fond    H11 0040
   Coding: 0100000000
   ROD: EV_AirCondiHeck_AU64.rod
   Component: LUFE-DAEMPFER H14 0095
   Coding: 008002
   VCID: 2B16CF0F422D4E1CA2-807E
          C10C8 00 [008] -  -
                    Reset counter: 34
                    Mileage: 193919 km
                    Date: 2018.07.19
                    Time: 09:28:22
   Revision: AA000000    Serial number: 00001001384533
   Shop #: WSC 02686 136 56792
   Revision: --------    Serial number: EJ1370001LL1000
   VCID: 2D12C1177C39402CBC-8078
   Component: J769  SWA MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   Coding: 0000101
   VCID: 6D92011774B9802CFC-8038
   Component: J770  SWA Slave H01 0050
   Subsystem 3 - Serial number: 5F31.01.1000H010003CH10469˙
   Subsystem 4 - Serial number: H10469˙
   Revision: --------    Serial number: 0000102767852
   VCID: 3B36FF4FBA4DDE9C32-806E
   Revision: 00002001    Serial number: 0126529614
   Serial number: 00000000000000005178
   Serial number:     WOO100060R8
   Coding: 001F00
   Serial number: A2010000000000020504
   Serial number:     WOO10001JHC
   Revision: CI007500    Serial number: 00000000000640
   VCID: 5BF65FCF5A0DFE9C12-800E
   Revision: --------    Serial number: 0000102767246
   VCID: 3A38FA4BB577E79429-806E
   Part No SW: 4H0 907 801 B    HW: 4H0 907 801 A
   Component: EPB-4         H03 0007
   Revision: --------    Serial number: 00000000001135
   VCID: 271E333F5EC56A7C46-8072
   Serial number: 100205-0004-000
   Coding: 11116F33F91AEA00
   Shop #: WSC 55649 001 1048576
   VCID: 6FAE1B1FB6B5723CCE-803A
H02 0003
   Coding: 1A0000
H02 0013
   Coding: 1A0000
764928 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Reset counter: 245
                    Mileage: 193864 km
                    Date: 2018.07.12
                    Time: 12:26:32
   Part No SW: 4E0 035 061 G    HW: 4E0 035 061
   Component: Radio U DAB   H46 0042
   Revision: AB001007    Serial number: 014BG0A7503440
   VCID: 1F0E2BDF0E95A2BC3E-804A
03455 - Function Restriction due to Faults in Other Modules
            000 -  -
                    Reset counter: 245
                    Mileage: 193864 km
                    Date: 2018.07.12
                    Time: 12:26:48
                    Bin. Bits: 00000000 00000001
   Part No SW: 4F0 919 129 C    HW: 4F0 919 129
   Component: HybridTV-DVB  H06 0390
   Revision: R0060000    Serial number: 76300802664802
   Coding: 01010000
   VCID: 2C14CC134F234924AB-8078
   Part No SW: 4H0 035 670 D    HW: 4H0 035 670
   Component: H-BNT-EU      H48 0078
   Revision: --------    Serial number: 410BT0A7550767
   Coding: 010100000001FBEF75160B1E0000000380000100
   VCID: 250239372CC9786C74-8070
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsystem 2 - Part No SW: 4H0 919 604 B    HW: 4H0 919 604 B
   Serial number: AUZ8ZDA1100288W
   Subsystem 3 - Part No SW: 4H1 919 600 B    HW: 4H1 919 600 B
   Component: E380 BDT D4  H09 0055
   Serial number: 00000000003679
03787 - Rotation Mechanism for Display Module Front
                    Fault Status: 00100011
                    Reset counter: 38
                    Mileage: 194028 km
                    Date: 2018.07.24
                    Time: 14:11:41
                    Voltage: 12.50 V
   Revision: --------    Serial number: 0000102818678
   VCID: 393AE547B071EC8C20-806C
   Revision: --H03---    Serial number: 525PA8-J01D0HF
   Coding: 1020002
   VCID: 65827937AC49B86CB4-8030
   Revision: 09145325    Serial number: 027000062
   Coding: 0200044000
   Revision: --------    Serial number: 000000003113
   ROD: EV_Ambie.rod
   VCID: 6386672F6A7DC65C5A-8036
   Revision: --------    Serial number: 0000102819213
   Revision: 0L0D4010    Serial number: SN100112  0108
   VCID: 6A980A0B8D57971499-803E
   Serial number: 0K84AE40002485
   Coding: 1101
   Serial number: 00000000001002015580
Address 85: On Board Cam. (J852)       Labels:* None
   Component: DPC-SG        H20 0014
   Coding: EC060000
   Serial number: 00448453538301
   Coding: 764FF2
   Serial number: 00448453461001
   Coding: 364FF2
   Coding: 3604010201
          U1113 00 [008] - -
                    Mileage: 193864 km
                    Date: 2018.07.12
                    Time: 12:26:29
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 12.478 V
                    Velocity_vehicle_reference: -0.00 m/s
   Serial number: 000040050902107
   Coding: 01A08200
   ROD: EV_BVS.rod
   VCID: 648464336F73C164A3-8030
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Coding: 0066F609031F037E070308014240C2000000
   ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   ROD: EV_RGS_R.rod
   VCID: 70AC1863AB8B6DC4D7-8024
End----------(Elapsed Time: 03:06, VBatt start/end: 12.2V/12.1V)-----------
Thursday,12,July,2018,10:34:55:10366
VIN: WAUZZZ4H0DN001835   License Plate: S8_4H
Mileage: 171483km-106554mi   Repair Order:
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 20 22 28 34 36
          3B 3C 42 46 47 52 53 56 5F 62 6C 6D 6F 72 81 84 85 88 89 8B
          8E 8F 90 A9 BA
VIN: WAUZZZ4H0DN001835   Mileage: 171483km-106554miles
85-On Board Cam. -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CGTA)       Labels: Redir Fail!
   Part No SW: 4H0 907 557     HW: 4H0 906 014
   Component: 4.0l V8TFSI / H56 0010
   Revision: NCH56---
   Coding: 022A00326546010A1000
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM40TFS0114H0907557 001012
   ROD: EV_ECM40TFS0114H0907557.rod
   VCID: 6D920117BCB9802CFC-8038
   Part No SW: 4H1 927 158 EG    HW: 0BK 927 156 AG
   Component: 0BK 40TFSIUSA H16 1002
   Revision: --H16---
   VCID: 79BA2547F8F12C8C60-802C
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: C2FDA30043BFC500E300
   ASAM Dataset: EV_ESPPremi 005013
   VCID: 3424D4739F1311E4F3-8060
   Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 CB
   Component: BCM2 2.0      H32 0510
   Coding: 05A72F46000000000000
   Shop #: WSC 00870 233 179043
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000029561643
   VCID: 3522E9779C6908ECC4-8060
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 4 Zonen H20 0120
   Coding: 680100B834
   ASAM Dataset: EV_AirCondiFront 001050
   VCID: 2502393724C9786C74-8070
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001315391
   Coding: 0907201009749FF3BB810044A0001800009CC3080E000101800108546F21
   VCID: 6FAE1B1FBEB5723CCE-803A
   Component: WWS641 120202  H35 0080
   Serial number:         120305010403
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Serial number: 10250330
   Coding: 025523
   Serial number: 01 05 2012  00000051
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000010051200010606
   Coding: 100000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000011051200010673
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Serial number: WA103086000001301760
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 8E580A26000000000001
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   VCID: 2208222B3DE78F5411-8076
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061213000918
   Coding: 280B01
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77BE237FCEE53AFC16-8022
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H17 0400
   Coding: 7E04010101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2A18CA0B4DD7571459-807E
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG008JCG7
   Coding: 30314246323430303031554A304C34483053
   VCID: 3620EE7B896F03F4CD-8062
   Serial number: 3575HRB405H1C4LG9HBK
   Serial number: 3585HRB405H1C4LG81G9
   Serial number: 3515JRB404P184COC812
   Serial number: 3525JRB404P184COCOL$
   Serial number: 3554VRB400I4UI5CAHOD
   Serial number: 3564VRB400G4UI5CT9CB
   Revision: --------    Serial number: 90815LE700004
   Coding: 00003C
   VCID: 373EE37F8665FAFCD6-8062
   Component: E221 - MFL  H08 0009
   Serial number: 19 04 2012  D0111717
   Part No SW: 4H0 920 830 N    HW: 4H0 920 830 N
   Component: TBenRDWACCNV- H72 0515
   Revision: 35081077    Serial number: 658090512592011
   Coding: 03870802B7400008000100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 K    HW: 4H0 919 204 K
   Component: Analoguhr D4  H05 0224
   Serial number: 1120426000179
   Part No SW: 4H0 907 468 AB    HW: 4H0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000512733
   Coding: 00ED074800
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 71AA1D67A08164CCD8-8024
   Serial number: 00000000004970826964
   Voltage stabilizer:
   Serial number: 12130000824011200410
   Part No SW: 4H0 907 144 C    HW: 4H0 907 144 C
   Component: DYNAMIKLENK.  H06 0100
   Revision: 51001005    Serial number: --------------
   Coding: 090100
   VCID: 281C30035BDB65044F-807C
   Part No SW: 8K0 857 511 F    HW: 8K0 857 511 A
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04018B6B74745D545420363E00
   VCID: 3424D473971311E4F3-8060
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 000505120001010
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   Component: Klima Fond    H16 0120
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008006
   VCID: 2E10C61B713F3B3485-807A
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000029561826
   Component: SARA 6D red   H02 0020
   Revision: --------    Serial number: EJ1BPA3700NCYU0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000103
   VCID: 2E10C61BB93F3B3485-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F14.05.1200H020003CX24339˙
   Subsystem 4 - Serial number: X24339˙
   Component: TSG FA        H06 0263
   Revision: --------    Serial number: 0000126389751
   Coding: 011F1E005E0062C202083017
   VCID: 48DC9083FB9B8504AF-801C
   Revision: 00002001    Serial number: 0175209660
   Coding: 011A0E2000B93581B330C7840C03010F0000000000000000000000000000
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H11 0080
   Serial number: A2012000000000563840
   Subsystem 4 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84249365
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000000767
   Coding: 030000
   VCID: 1C741CD31F83B9A4DB-8048
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000127271417
   Coding: 011F1E005E0062C202083007
   VCID: 3C34FC53BF43D9A43B-8068
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000300521
   Part No SW: 4H0 035 053 E    HW: 4H0 035 053
   Component: Radio U Basic H60 0093
   Revision: AB001007    Serial number: 228E.0C7510775
   Coding: 010003010000000001
   VCID: 210A2D2738E1944C08-8074
   Part No SW: 4H0 035 670 N    HW: 4H0 035 670 N
   Component: H-BNT-EU      H44 0526
   Revision: --------    Serial number: 179EV0C7500711
   Coding: 030100000201F9EF75948B1E00000003000001000000000000
   VCID: 2F2EDB1F7E35323C8E-807A
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Subsystem 2 - Part No SW: 4F0 910 393 AD    HW: 4F0 862 393 E
   Component: BTHS  H25 0730
   Serial number: P12000697255
   Serial number: AUZ8ZDC9300ECGP
   Serial number: 00000000081082
   Subsystem 5 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
            000 -  -
                    Reset counter: 5
                    Mileage: 169958 km
                    Date: 2018.06.27
                    Time: 13:05:23
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000127372428
   Coding: 010F1E00400062C202083007
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0120
   Revision: 11001001    Serial number: 82330JF0041862
   Coding: 0209000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 005023
   ROD: EV_CamerSysteTopViewAUDI_005.rod
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 120200075
   Coding: 0210044000
   VCID: 3D32F157AC59D0AC0C-8068
   Revision: --------    Serial number: 000000072521
   Coding: 200000
   ROD: EV_Ambie.rod
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000127372149
   Component: GSM-LL        H08 0083
   Revision: 0L0D5013    Serial number: SN120411  0270
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40070218
   Coding: 1100
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001211400032
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: E8060000
   VCID: 26003E3B59CF73747D-8072
0001 - Front Heater for Lane-Holding Assist
          C1101 15 [008] - Open or Short to Plus
                    Reset counter: 66
                    Mileage: 170333 km
                    Date: 2018.06.29
                    Time: 11:51:38
                    Outside air temperature: -28.5 °C
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 41.0 °C
   Serial number: 00005931264101
   Coding: 766FF2
   VCID: 2F2EDB1F7635323C8E-807A
   Serial number: 00005931295802
   Coding: 366FF2
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Coding: 7E04010101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000051505127
   Coding: 01A0BA031111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   ROD: EV_RGS_L.rod
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 120411200472
   VCID: 2C14CC1347234924AB-8078
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000205904
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
1295 - Drivetran Mounting
          C1154 02 [009] - Signal Failure
                    Reset counter: 5
                    Mileage: 169958 km
                    Date: 2018.06.27
                    Time: 13:05:23
End----------(Elapsed Time: 03:05, VBatt start/end: 12.1V/12.0V)-----------
Wednesday,13,June,2018,10:37:19:10366
VIN: WAUZZZ4H9AN001053   License Plate: A8_4H_
Mileage: 204682km-127183mi   Repair Order:
          36 3B 3C 42 46 47 52 53 56 57 5F 62 6C 6D 6F 72 81 84 85 88
          89 8B 8E 8F 90
VIN: WAUZZZ4H9AN001053   Mileage: 204682km-127183miles
Address 01: Engine (J623-CDSB)       Labels:* None
   Part No SW: 4H0 907 409 M    HW: 4H0 907 409
   Component: 4.2TDI EDC17  H02 0001
   Revision: 34H02---
   Shop #: WSC 46154 000 1048576
   ASAM Dataset: EV_ECM42TDI1114H0907409M 001001
   ROD: EV_ECM42TDI1114H0907409M.rod
   Component: 0BL 42 TDIRdW H04 0006
   Revision: --H04---
   Coding: 001111
   Shop #: WSC 03654 128 08094
   Shop #: WSC 57005 000 1048576
   Serial number: 0209000065492008
   Revision: AA000000    Serial number: 00001001382181
   Component: Klima 4 Zonen H12 0061
   Coding: 389101BE0C
   ASAM Dataset: EV_AirCondiFront 001047
   Revision: 11012002    Serial number: 00000000847001
   Coding: 0907201009349FE38B810004A0001800009CC3080E000101800108542F00
   Component: WWS641 091120  H32 0032
   Serial number:         091210130043
   Coding: 0045F7
   Serial number: 10731090
   Coding: 025523
   Serial number: 13 01 2010  00000060
   Subsystem 4 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
   Component: A31 LED Mod1L  H01 0006
   Serial number: 00000009121000010846
   Coding: 100000
   Subsystem 5 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
   Component: A27 LED Mod1R  H01 0006
   Serial number: 00000008121000010354
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Serial number: WA090557000000011328
   Coding: 020300
   Serial number: 74080ED4000000000001
   Revision: AA001001
   VCID: 2306272F22FD865C1A-8076
   Revision: 11001001    Serial number: 44830930801362
   Coding: 300902
   Revision: 34H02---
   ASAM Dataset: EV_ECM42TDI2114H0907409M 001001
   ROD: EV_ECM42TDI2114H0907409M.rod
   Coding: 3604010201
   Shop #: WSC 02152 128 89021
   Revision: --------    Serial number: 003CM0012D3D
   Serial number: 3572DRB40000A7A4BB3%
   Serial number: 3582DRB40000A7A88B1%
   Serial number: 3515JRB405C70PNCA8AF
   Serial number: 3525JRB405C70PNC60JD
   Serial number: 3554VRB405270PNC6PG$
   Serial number: 3564VRB404U70PNCCO5I
   Revision: --------    Serial number: 90815JAC00018
   Coding: 00003C
   Serial number: 23 10 2009  11001340
   Revision: 18409109    Serial number: 658210110593476
   Coding: 1307080097000008000000
   ROD: EV_RBD4K.rod
   Analog_clock:
   Serial number: 1111208000463
   Revision: 34003004    Serial number: 20091214060911
   Coding: 1D1200
   Revision: --------    Serial number: 00000000004456
   Coding: 00C1037D00
   Serial number: 00000000005640002086
   Serial number: 000801100001025
   Coding: 0100000000
   ASAM Dataset: EV_AirCondiHeck 001037
   Coding: 008002
   Shop #: WSC 02152 128 28888
   Revision: AA000000    Serial number: 00001001382428
   Revision: --------    Serial number: EJ1370000ZZS000
   Component: J769  SWA MasterH02 0100
   Coding: 0000101
   Component: J770  SWA Slave H01 0100
   Subsystem 3 - Serial number: 5F14.01.1000H010003CH11236˙
   Subsystem 4 - Serial number: H11236˙
   Revision: --------    Serial number: 0000102666954
   Revision: 00002001    Serial number: 0125944966
   Serial number: 00000000000000004515
   Serial number:     WOO100029YK
   Coding: 001F00
   Component: Dachelektroni  H11 0070
   Serial number: A2010000000000014353
   Serial number:     WOO10000VTZ
   Revision: CI007500    Serial number: 00000000001315
   Revision: --------    Serial number: 0000102493418
   Revision: --------    Serial number: 00000000244579
   Component: Radio U DAB   H45 0085
   Revision: AB001007    Serial number: 014AM0A7502259
   VCID: 2404243327F3816463-8070
   Revision: R0060000    Serial number: 76300802598802
   Coding: 01010000
   VCID: 302CD863630B2DC497-8064
   Part No SW: 4H0 035 654     HW: 4H0 035 670 C
   Component: H-BNT-EU      H43 0939
   Revision: --------    Serial number: 060A 0C7519399
   Coding: 020100000001FBEF75168B1E00000003000001000000000000
   VCID: 6386672F627DC65C5A-8036
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Serial number: AUZ8ZD9110012HX
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600 B
   Serial number: 00000000002821
   Subsystem 4 - Part No: 8R0 060 961 C
            000 -  -
                    Reset counter: 101
                    Mileage: 204682 km
                    Date: 2018.06.12
                    Time: 10:34:09
            000 -  -
                    Reset counter: 101
                    Mileage: 204682 km
                    Date: 2018.06.12
                    Time: 10:34:09
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00010000
02169 - Front Right Microphone (R141)
                    Fault Status: 01101100
                    Reset counter: 101
                    Mileage: 204682 km
                    Date: 2018.06.12
                    Time: 10:34:09
                    Voltage: 12.60 V
   Revision: --------    Serial number: 0000102635692
   Revision: --H03---    Serial number: 525PA8-J9ZD08D
   Coding: 1020002
   Revision: 09145325    Serial number: 358900094
   Coding: 0210044000
   VCID: 3B36FF4FB24DDE9C32-806E
   Revision: --------    Serial number: 000000002122
   ROD: EV_Ambie.rod
   Revision: --------    Serial number: 0000102635691
   Revision: 0L0D4009    Serial number: SN091218  0100
   Serial number: 0K84AE40001271
   Coding: 1101
   Component: NV-CAM-Gen1  H06 0006
   Serial number: 00000000000935313382
9984 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [LWR_AFS: kein Signal: keine Kommunikation]
                    Reset counter: 101
                    Mileage: 204682 km
                    Date: 2018.06.12
                    Time: 10:34:06
   Coding: EC060000
0734 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [AFS_Timeout]
                    Reset counter: 101
                    Mileage: 204682 km
                    Date: 2018.06.12
                    Time: 10:34:06
                    Outside air temperature: -37.5 °C
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 51.0 °C
   Serial number: 00443894132701
   Coding: 764FF2
   Serial number: 00443894129401
   Coding: 364FF2
   Coding: 3604010201
   Component: BV-SG         H24 0008
   Serial number: 000040052001107
   Coding: 01A08200
   ROD: EV_BVS.rod
   Component: RGS-VL        H04 0070
   Coding: 0066F609031F037E070308014240C2010000
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:08, VBatt start/end: 12.6V/12.3V)-----------
Friday,12,May,2017,08:02:10:10366
VCDS Version: 17.1.3.0  HEX-NET CB: 0.4334.4
VIN: WAUZZZ4H5EN015845   License Plate: A8_4H_2015
Mileage: 167131km-103850mi   Repair Order:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 1B 22 28 30 34 36
          3B 3C 42 44 46 47 48 52 53 55 56 57 5B 5F 62 6C 6D 6F 72 7F
          81 82 84 85 88 89 8A 8B 8D 8E 8F 90 AC
VIN: WAUZZZ4H5EN015845   Mileage: 167131km-103850miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CTBA)       Labels: None
   Part No SW: 4H0 907 401 H    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0003
   Revision: 58H14---
   Coding: 0A2A403A056601030800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114H0907401H 001006
   ROD: EV_ECM30TDI0114H0907401H.rod
   VCID: 291A350748D15C099E-807C
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30 TDIRdW H18 1002
   Revision: --H18---
   ROD: EV_TCMALX51011_002.rod
   VCID: 7CB43C53F7C319A1B5-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: 60FDEB2006BFD704E300
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71AA1D67A08164C916-8024
   Part No SW: 4H0 907 064 EB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0521
   Coding: 05A76F0E000000000000
   VCID: 6D920117B4B9802932-8038
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000098775533
   Coding: C018B60085047201010001010101112131313333283333
   VCID: 3522E9779C6908E90A-8060
Address 08: Auto HVAC (J255)       Labels: 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 36110AF83C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_AU64.rod
   VCID: 2D12C1177C39402972-8078
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000802666401
   Coding: 0105001440349FF2F9014084A0001800009CC30A2E080201800008946101170000400019010000
   VCID: 689C70039B5BA50141-803C
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140322  H36 0090
   Serial number:         140327211700
   Coding: 0045F7
   Serial number: 22518244
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4H0 941 531 G    HW: 4H0 941 531 G
   Component: E1 - LDS  H01 0044
   Serial number: 15 04 2014  00000401
   Component: EVLS-SG  H08 0300
   Serial number: WA107823000006937665
   Coding: 020300
   Serial number: E4294227000000000001
Address 10: Park/Steer Assist (J791)       Labels: None
   Part No SW: 4G0 919 475 C    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0031
   Revision: --------    Serial number: 56261410702187
   Coding: B82B04
   ASAM Dataset: EV_EPHVA2CAU64X0000 001005
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 312ADD67600124C956-8064
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H19 0032
   Coding: 7E04020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   VCID: 2B16CF0F422D4E196C-807E
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1001BDP-
   Coding: 30333045313430303031554A304C34483053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3B36FF4FB24DDE99FC-806E
   Serial number: 3575HRB404T2E3MGEH1T
   Serial number: 3585HRB404T2FNOGFP6O
   Serial number: 3515JRB400O50VVGI1L7
   Serial number: 3525JRB401050VVGN1HT
   Serial number: 3554VRB40572OBT6J1M1
   Serial number: 3564VRB400E50VKSLODW
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 01335NDO000IK
   Coding: 0000FC
   VCID: 373EE37F8665FAF918-8062
   Serial number: 27 02 2014  D0413698
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 830 R    HW: 4H0 920 830 R
   Component: TDieRDWACCNV- H53 0622
   Revision: 36081096    Serial number: 658150414592017
   Coding: 13860800BF550008000000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 3424D4739F1311E13D-8060
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 M    HW: 4H0 919 204 M
   Component: Analoguhr D4  H05 0225
   Serial number: 2140324006689
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 122
                    Mileage: 165881 km
                    Date: 2017.05.08
                    Time: 09:36:50
Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140307162849
   Coding: 5D1F01
   VCID: 26003E3B51CF7371B3-8072
   Part No SW: 4H0 907 468 AE    HW: 4H0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001360610
   Coding: 80CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   ROD: EV_GatewPKOUDS_VW51.rod
   VCID: 74A41473DF9351E1FD-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 61092751201911051135
   Voltage stabilizer:
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 0B0100
   VCID: 393AE547B071EC89EE-806C
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 000504140001014
   VCID: 281C300353DB650181-807C
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 L    HW: 4H0 919 158 L
   Component: Klima Fond    H16 0200
   Coding: 3700000000
   ASAM Dataset: EV_AirCondiHeck 002001
   VCID: 393AE547B871EC89EE-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000058017
   Coding: 01010101000000000001000202
   VCID: 648464336773C1616D-8030
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F2EDB1F7635323940-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000098775535
   Coding: C018BF8085857201030001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7100EY7E
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_VW51.rod
   VCID: 383CE043837BF58111-806C
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0331013688
   Coding: 040311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3326D76F9A1D16D924-8066
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0030
   Serial number: 0331808162
   Coding: 040311
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000098004708
   Coding: 011F1E015E0062C202083017
   VCID: 48DC9083FB9B850161-801C
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0010478898
   Coding: 011101010001
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 3228D26B65071FD12F-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0333863196
   Coding: 011A0E2080B9399FF320C7840E0316470000000000000000000000000000
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 414700069056
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 N    HW: 4H0 947 135 N
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000786432
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 415200070571
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 414700069060
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 415200070569
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93214453
   Revision: CJ007001    Serial number: 00000000097017
   Coding: 030000
   VCID: 1D7211D70499B0A9E2-8048
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
   Component: MEM-FS-Fond   H06 0158
   Revision: AA000000    Serial number: 00000097444751
   Coding: C01892808500700D0B00392038193A2039203B3B202020
   VCID: 3228D26B6D071FD12F-8066
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000098502004
   Coding: 011F1E015E0062C202083006
   VCID: 3C34FC53BF43D9A1F5-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001035935
   ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Coding: 02F20A20221B0200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7530
   Coding: E00300
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0021
   Coding: E00300
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0021
   Coding: E00300
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109D/0E7918407
   Coding: 010103010003000001
   VCID: 281C30035BDB650181-807C
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801301221301
   Coding: 01000400
   VCID: 2D12C1177439402972-8078
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0158
   Revision: AA000000    Serial number: 00000097427289
   Coding: C01896808500700D0B00392038193A2039203B3B382020
   Part No SW: 4H0 035 670 P    HW: 4H0 035 670 P
   Component: H-BNT-EU      H47 0798
   Revision: --------    Serial number: 179D 0E7520364
   Coding: 02010000000BFFEF7DB4CB1E00000003080001000000000000
   VCID: 312ADD67680124C956-8064
   Subsystem 1 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDEC901BXWS
   Subsystem 2 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Serial number: 00000000155954
02446 - Disk Drive Mechanical Malfunction
                    Reset counter: 81
                    Mileage: 164952 km
                    Date: 2017.05.04
                    Time: 15:56:02
                    Voltage: 12.70 V
                    ON Time: 4481 h
01524 - Antenna for Telephone
                    Fault Status: 00101011
                    Fault Frequency: 8
                    Reset counter: 125
                    Mileage: 165373 km
                    Date: 2017.05.06
                    Time: 14:42:38
                    Voltage: 12.40 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000099364512
   Coding: 010F1E01420062C202083006
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 4S0 907 441     HW: 5Q0 907 441
   Component: D4-PA RVC Mid H06 0030
   Coding: 024611010A01000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002001
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 70AC1863AB8B6DC119-8024
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 111400139
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FAE1B1FB6B5723900-803A
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000148256
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6386672F6A7DC65994-8036
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000099382439
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 776 K    HW: 4H0 035 776 J
   Component: H-BN-EU       H47 0799
   Revision: --------    Serial number: 185DZ0E7509024
   Coding: 02010000000100400100001400001300000000000000000000
   VCID: 3326D76F921D16D924-8066
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDE1201AZ7T
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDE1201AZBX
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238NDA00011
   Component: CD-Database  5571
   Subsystem 5 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H09 0083
   Revision: 0L0D5015    Serial number: SN140409  0459
   ROD: EV_GSM2x3Mono.rod
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4H0 919 617     HW: 4H0 919 617
   Component: HeadUpDisplay H16 0019
   Coding: D30000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 6D920117BCB9802932-8038
Address 84: Night Vision (J853)       Labels: None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0105
   Serial number: 622352400201414
   Coding: 201100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C14CC134723492165-8078
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1403100145
Address 85: On Board Cam. (J852)       Labels: None
   Component: DPC-SG        H26 0081
   Coding: EA160000
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00016207044101
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00016207043302
   Coding: 366FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00016208180701
   Coding: 306F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   VCID: 2E10C61B713F3B314B-807A
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Component: ACC3          H21 0032
   Coding: 7E04020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
   Serial number: 00016208171902
   Coding: 306F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
   Part No SW: 4H0 907 107 F    HW: 4H0 907 107
   Component: BV-SG         H31 0081
   Serial number: 005000210804147
   Coding: 02C0BB031111
   ROD: EV_BC7.rod
   VCID: 2A18CA0B4DD7571197-807E
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 140980303
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 03:48)--------------------------
Tuesday,28,February,2017,14:31:57:10366
VIN: WAUZZZ4H1AN001385   License Plate: A8_4H_2017
Mileage: 203092km-126195mi   Repair Order:
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 1B 22 28
          34 36 3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 84
          85 88 89 8B 8E 8F 90
VIN: WAUZZZ4H1AN001385   Mileage: 203092km-126195miles
81-Gear Shift -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
Address 01: Engine (J623-CDSB)       Labels: None
   Revision: 34H02---
   Coding: 0106002C291F0268
   Shop #: WSC 21240 142 91110
   VCID: 699A750788519C095E-803C
5619 - Engine Off Timer Performance
          P150A 00 [096] - -
                    Mileage: 201361 km
                    Date: 2017.02.01
                    Time: 16:25:12
                    Engine speed: 0.00 /min
                    Coolant temperature: 35 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 10.580 V
                    Unlearning counter according OBD: 11
                    Vehicle speed: 0.00 km/h
                    Battery voltage: 10600 mV
                    CAN status - engine control module-Bit 0: 00000000
                    CAN status - transmission control module-Bit 0: 00000000
                    CAN status - brake control module 1-Bit 0: 00000000
                    CAN status - brake control module 2-Bit 0: 00000000
   Part No SW: 4H1 927 158 Q    HW: 0BL 927 156 E
   Component: 0BL 42 TDIRdW H04 0004
   Revision: --H04---
   Coding: 001111
   ASAM Dataset: EV_TCMALX51011 001012
   ROD: EV_TCMALX51011_001.rod
   VCID: 3E30F65BA15FCBB1DB-806A
12459 - Limp Mode due to Control Module Reset
          P1703 00 [096] - -
                    Voltage terminal 30: 14.092 V
                    Transmission input speed: 668.00 /min
                    Transmission output speed: 0.00 /min
                    Engine torque: -16 Nm
                    Transmission fluid temperature: 70 °C
                    Accelerator position: 15 %
                    Driving position: P
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Engine speed: 678 /min
                    Transfer speed from ESP: 0.00 km/h
                    Transfer speed from ESP: valid
   Part No SW: 4H0 907 379 A    HW: 4H0 907 379 A
   Component: ESP PREMIUM   H08 0151
   Coding: E4FAA200275F4500E300
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 004012
   ROD: EV_ESPPremi_004_AU64.rod
   VCID: 302CD8636B0B2DC159-8064
          C102D 00 [008] -  -
                    Reset counter: 3
                    Mileage: 201602 km
                    Date: 2017.02.05
                    Time: 16:59:41
                    VzRef: 37
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 1F
                    F-Path: 47
                    F-Type: 0A
                    Uz: B7
          C102D 00 [008] -  -
                    Reset counter: 3
                    Mileage: 201574 km
                    Date: 2017.02.05
                    Time: 16:35:54
                    VzRef: 68
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 1F
                    F-Path: 47
                    F-Type: 01
                    Uz: B6
   Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 L
   Coding: 05070001000000000000
   Shop #: WSC 00911 233 12906
   VCID: 6C940C138FA3892125-8038
   Subsystem 1 - Part No SW: 4H0 905 852 A    HW: 4H0 905 852 A
   Serial number: 0209000074994009
   Part No SW: 4H0 959 760 A    HW: 4H0 959 760 A
   Component: MEM-BFS       H07 0114
   Revision: AA000000    Serial number: 00001001383533
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Coding: 381101B80C
   ASAM Dataset: EV_AirCondiFront 001048
   VCID: 2208222B35E78F51DF-8076
          B10D7 21 [009] - Signal Amplitude Too Low
                    Reset counter: 245
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:03
                    Voltage terminal 30-Data: 14.0 V
                    Outside air temperature-Data: 12.50 °C
                    Interior temperature-Data: 23.80 °C
                    Defrost flap motor for left side window-Act.value: 10000
                    Defrost flap motor for left side window-Specified value: 10000
                    Defrost flap motor for left side window-Stop open: 0
                    Defrost flap motor for left side window-Stop closed: 0
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [008] - Signal Amplitude Too High
                    Reset counter: 28
                    Mileage: 200302 km
                    Date: 2017.01.19
                    Time: 13:05:56
                    Voltage terminal 30-Data: 14.1 V
                    Outside air temperature-Data: 5.00 °C
                    Interior temperature-Data: 13.80 °C
                    Defrost flap motor for right side window-Act.value: 8000
                    Defrost flap motor for right side window-Specified value: 8000
                    Defrost flap motor for right side window-Stop open: 0
                    Defrost flap motor for right side window-Stop closed: 0
          B10D8 21 [009] - Signal Amplitude Too Low
                    Fault Frequency: 198
                    Reset counter: 245
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:07
                    Defrost flap motor for right side window-Act.value: 10000
                    Defrost flap motor for right side window-Specified value: 10000
0141 - Motor for  Right Side Window Defrost Flap
          B10D8 29 [008] - Signal Implausible
                    Reset counter: 28
                    Mileage: 200302 km
                    Date: 2017.01.19
                    Time: 13:05:56
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H09 0083
   Revision: 15009001    Serial number: 00000000445978
   Coding: 0200201050B49FF1FB810004A0001908009CC3088A000121800008002100
   VCID: 291A350740D15C099E-807C
   Component: WWS641 091120  H32 0040
   Serial number:         091210123017
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10751435
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 26 01 2010  00000061
   Subsystem 4 - Part No SW: 4H0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0020
   Serial number: 0000001805568R03S605
   Subsystem 5 - Part No SW: 4H0 907 705 G    HW: 4H0 907 705 C
   Component: EVLS-SG  H07 0250
   Serial number: WA090557000000010165
   Coding: 020100
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H01 0001
   Serial number: EA08CDD4000000000001
                    Fault Status: 00101101
                    Fault Frequency: 16
                    Reset counter: 30
                    Mileage: 202493 km
                    Date: 2017.02.16
                    Time: 08:40:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2306272F22FD8659D4-8076
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 C    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H05 0011
   Revision: 11001001    Serial number: 44830930801460
   Coding: 300902
   ASAM Dataset: EV_AU64XParkiAssis2 005003
   ROD: EV_AU64XParkiAssis2.rod
Address 11: Engine II (J624)       Labels: None
   Revision: 34H02---
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Coding: 3604010201
   Shop #: WSC 21239 142 85248
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU57X_001.rod
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 30
                    Mileage: 200835 km
                    Date: 2017.01.27
                    Time: 17:27:16
                    Control Module temperature: 13 °C
                    Voltage terminal 15: 13.824 V
                    Velocity_vehicle_reference: 6.97 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.13 m/s˛
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 18
                    Reset counter: 30
                    Mileage: 202493 km
                    Date: 2017.02.16
                    Time: 08:40:39
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 13.878 V
                    Velocity_vehicle_reference: 35.17 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.14 m/s˛
   Part No SW: 4H0 959 655     HW: 4H0 959 655
   Component: Airbag10.43   H11 0012
   Revision: --------    Serial number: 003CM0012MS4
   Coding: 30314246313130303033554A304C34483053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001008
   VCID: 73A6176FDA9D56D9E4-8026
   Serial number: 3572DRB40000AA34E0B
   Serial number: 3582DRB40000AA34CAB4
   Serial number: 3515JRB405A70PNC8P5N
   Serial number: 3525JRB405470PNC8996
   Serial number: 3554VRB404S70PNCDPFR
   Serial number: 3564VRB404U70PNCJ1IF
   Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JAD00023
   Coding: 00003C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Component: E221 - MFL  H06 0009
   Serial number: 02 12 2009  11002283
   Part No SW: 4H0 920 830 F    HW: 4H0 920 830 F
   Revision: 19409111    Serial number: 658010210593562
   Coding: 03060800BF000008000000
   Shop #: WSC 00015 123 123456
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   Analog_clock:
   Serial number: 1100112001006
   Part No SW: 4H0 265 105 A    HW: 4H0 265 105 A
   Component: Standheizung  H20 0230
   Revision: 34003004    Serial number: 20100111100811
   Coding: 5D1300
   VCID: 200C282333EB9D41C9-8074
   Part No SW: 4H0 907 468 C    HW: 4H0 907 468 C
   Component: J533--Gateway H07 0175
   Revision: --------    Serial number: 00000000005385
   Coding: 00C1037D00
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_GatewUDS 001021
   ROD: EV_GatewUDS_AU57.rod
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0130
   Serial number: 00000000005640001980
   Part No SW: 4H0 907 144     HW: 4H0 907 144
   Component: DYNAMIKLENK.  H06 0070
   Revision: 50001005    Serial number: --------------
   Coding: 8B0000
   VCID: 658279376C49B8697A-8030
   Part No SW: 4H0 907 163     HW: 4H0 907 163
   Component: 4 Wheel Drive H11 0005
   Serial number: 001401100001028
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
   VCID: 66807E3B994FB37173-8032
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Coding: 0100000000
   ASAM Dataset: EV_AirCondiHeck 001038
   Coding: 008006
455693 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Fault Frequency: 16
                    Reset counter: 30
                    Mileage: 202493 km
                    Date: 2017.02.16
                    Time: 08:40:37
          C10C8 00 [008] -  -
                    Reset counter: 247
                    Mileage: 200300 km
                    Date: 2017.01.19
                    Time: 10:40:02
   Component: MEM-FS        H07 0114
   Revision: AA000000    Serial number: 00001001382453
   Coding: C0183B0085053201010021212121312131313333203333
            000 -  -  - Intermittent
                    Fault Frequency: 71
                    Reset counter: 8
                    Mileage: 201766 km
                    Date: 2017.02.08
                    Time: 18:39:03
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0011
   Revision: --------    Serial number: EJ13700018EO000
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Coding: 0000101
   VCID: 6D92011774B9802932-8038
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F25.01.1000H010003CH10891˙
   Subsystem 4 - Serial number: H10891˙
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Revision: --------    Serial number: 0000102737489
   Coding: 011F1E205E0062C202000007
   VCID: 3B36FF4FBA4DDE99FC-806E
   Revision: 00002001    Serial number: 0125945386
   Coding: 011A0E2000397585B32007F28E0000000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000005532
   Subsystem 2 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 4 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.022  H06 0004
   Serial number:     WOO10002HSM
   Coding: 001F00
   Subsystem 5 - Part No SW: 4H0 947 135 K    HW: 4H0 947 135 K
   Component: DACHELEKTRONI  H11 0070
   Serial number: H2010000000000001726
   Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO100012DY
   Part No SW: 4H0 035 223     HW: 4H0 035 223
   Component: BOSE G3 D4    H07 0050
   Revision: CI007500    Serial number: 00000000001417
   VCID: 5BF65FCF5A0DFE99DC-800E
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Revision: --------    Serial number: 0000102666201
   VCID: 3A38FA4BB577E791E7-806E
   Revision: --------    Serial number: 00000000001267
   VCID: 271E333F5EC56A7988-8072
Address 55: Headlight Range (J431)       Labels: 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357     HW: 4H4 907 357
   Serial number: 100127-0004-136
   Coding: 11116F33F91AFA00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0003
   Coding: 1A0000
H02 0003
   Coding: 1A0000
0061 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 30
                    Mileage: 202493 km
                    Date: 2017.02.16
                    Time: 08:40:38
   Part No SW: 4E0 035 061 L    HW: 4E0 035 061
   Component: Radio U DAB   H46 0085
   Revision: AB001007    Serial number: 014AI0A7503236
   Coding: 010103010000000001
   VCID: 2404243327F38161AD-8070
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Component: HybridTV-DVB  H06 0550
   Revision: R0060000    Serial number: 76300802613102
   Coding: 01010000
   VCID: 302CD863630B2DC159-8064
   Component: H-BNT-EU      H48 0798
   Revision: --------    Serial number: 410BN0AB000848
   Coding: 010100000001FBEF75160B1E00000003800001000000000000
   Serial number: AUZ8ZDA11001F6-
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000003434
   Component: CD-Database  1886
            000 -  -
                    Reset counter: 207
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:08
                    Text: KBD_FD4,TPE,M,0,0,6
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 207
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:06
                    Voltage: 14.30 V
03623 - Invalid Secruity/Release Code
            000 -  -
                    Reset counter: 207
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:07
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 6
03677 - Missing Secruity/Release Code
            000 -  -
                    Reset counter: 207
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:07
                    Voltage: 14.30 V
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Revision: --------    Serial number: 0000102699611
   Coding: 010F1E20400062C202000007
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H03---    Serial number: 525PA8-J01D027
   Coding: 1021002
   VCID: 65827937AC49B8697A-8030
   Revision: 09145325    Serial number: 009000372
   Coding: 0200044000
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [008] - Short to Plus
                    Fault Frequency: 50
                    Reset counter: 30
                    Mileage: 201362 km
                    Date: 2017.02.01
                    Time: 18:32:51
                    14.39 V
   Revision: --------    Serial number: 000000002447
   ROD: EV_Ambie.rod
   Revision: --------    Serial number: 0000102699632
   Part No SW: 4H1 927 731     HW: 4H1 927 731
   Revision: 0L0D4009    Serial number: SN091216  0045
   VCID: 6A980A0B8D57971157-803E
10005 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 247
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:11
                    Voltage terminal 15: 14.1 V
                    Voltage terminal 30: 14.3 V
                    Driving position: P
                    Selector lever position: drive lane (X)
Address 84: Night Vision (J853)       Labels: 4H0-907-547.clb
   Part No SW: 4H0 907 547 D    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H08 0022
   Serial number: 0K84AE40001726
   Coding: 1101
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
12306 - Video Cable for Night Vision System
          B11E1 29 [009] - Signal Implausible
                    Reset counter: 245
                    Mileage: 200300 km
                    Date: 2017.01.18
                    Time: 14:09:03
                    Voltage terminal 15: 14.0 V
                    Image processor: temperature: 25 °C
                    Microprocessor malfunction type: Cold_start_reset
                    Image processor: error number: C3 05
   Coding: EC060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 55E249F7342928E9EA-8000
   Part No SW: 4H0 907 182 A    HW: 4H0 907 182 A
   Component: IVB           H03 0027
   Serial number: 00448453262301
   Coding: 764FF2
   Serial number: 00448453248401
   Coding: 364FF2
0098 - Compressor for Multi-Contour Seat
          B11CD 11 [024] - Short to Ground
                    Reset counter: 210
                    Mileage: 200539 km
                    Date: 2017.01.21
                    Time: 11:29:38
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3604010201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU57X_001.rod
Address 8E: Image Processing (J851)       Labels: Redir Fail!
   Part No SW: 4H0 907 107     HW: 4H0 907 107
   Component: BV-SG         H25 0008
   Serial number: 000040050202107
   Coding: 01A08201
   ASAM Dataset: EV_BVS 001007
   ROD: EV_BVS.rod
   VCID: 648464336F73C1616D-8030
0091 - Function Limitation due to Missing Video Data
          C1108 00 [008] -  -
                    Fault Frequency: 18
                    Reset counter: 30
                    Mileage: 203074 km
                    Date: 2017.02.28
                    Time: 14:08:34
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H04 0060
   Coding: 0066F609031F037E070308014240C0000000
   ASAM Dataset: EV_RGS_L 002006
   ROD: EV_RGS_L.rod
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H04 0060
   ASAM Dataset: EV_RGS_R 002006
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:06, VBatt start/end: 12.0V/14.5V)-----------
Friday,20,January,2017,11:23:26:10366
VCDS Version: 17.1.2.0  HEX-NET CB: 0.4334.4
Data version: 20170107 DS267.0
Workshop Code: 785 02313 000200
VIN: WAUZZZ4H7DN029728   License Plate: A8_4H_HYBRID_2NDCRASH
Mileage: 62923km-39098mi   Repair Order:
Chassis Type: 4H (4H1)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 20 28 30 34 36 3B 3C
          40 42 44 46 47 48 51 52 53 56 57 5B 5F 62 65 6C 6D 6F 72 7F
          81 84 85 88 8A 8C 8D 8E 8F 90
VIN: WAUZZZ4H7DN029728   Mileage: 62923km-39098miles
30-Special Function II -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
40-AC Compressor -- Status: Malfunction 0010
48-Seat, Rear, DS -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
5B-Seat,Rear,PS -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: Malfunction 0010
8A-Multicont. Seat Rear,DS -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
8D-Multicont. Seat Rear,PS -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (0-MA--CHJA)       Labels: None
   Part No SW: 4H0 907 115 B    HW: 8R0 907 115 G
   Component: 2.0l R4/4V TF H57 0003
   Revision: NDH57---
   Coding: 0A2A0013652400022000
   Shop #: WSC 02446 666 28888
   ASAM Dataset: EV_ECM20TFS0114H0907115B 002004
   ROD: EV_ECM20TFS0114H0907115B_002.rod
   VCID: 2502393724C97869B0-8070
13 Faults Found:
          U1113 00 [032] - -
                    Mileage: 62882 km
                    Date: 2016.12.13
                    Time: 01:55:54
                    Coolant temperature: 21 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 12.934 V
                    Unlearning counter according OBD: 37
                    Median injection timing: 0.000 ms
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 78.89 %
                    Engine torque: 0.0 Nm
12577 - DC/DC Converter
          P0A94 00 [032] - Inadequate Performance
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:00:50
                    Engine speed: 1228.00 /min
                    Normed load value: 31.8 %
                    Coolant temperature: 11 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 13.216 V
                    Current speed of electric motor: 1200.5 /min
                    Operating state of electric drive-Bit 0: 10
                    Transfer electric drive to combustion drive-Bit 0: 0
                    Electric drive motor: mode of operation-Bit 0: 4
                    Operational state of the hybrid battery-Bit 0: 1
                    High-volt. battery: charge state: abs. value: 40.40 %
                    Air temperature of high-voltage / hybrid battery: -4.0 °C
17122 - Drive Motor A
          P0A90 00 [032] - Performance
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:00:50
                    Current speed of electric motor: 1195.0 /min
4527 - Coolant Fan Control Circuit 1
          P0480 00 [040] - Electrical Malfunction
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:00:12
                    Coolant temperature: 24 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 12.274 V
                    Unlearning counter according OBD: 34
                    Cruise control switch actuation-Bit 0: 0
                    Cruise control switch actuation-Bit 8: 0
4528 - Coolant Fan Control Circuit 2
          P0481 00 [040] - Electrical Malfunction
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:00:12
                    Relative load value: 78.54 %
5456 - Starter Will Not Turn
          P3054 00 [229] - Jammed or Electrical Malfunction
                    Mileage: 62888 km
                    Date: 2016.12.13
                    Time: 04:18:45
                    Coolant temperature: 89 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 12.510 V
                    Relative load value: 71.67 %
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
                    Mileage: 62882 km
                    Date: 2016.12.13
                    Time: 01:56:23
                    Voltage terminal 30: 11.426 V
17427 - Implausible Data Received from Transmission Control Module
          U0402 00 [032] - -
                    Mileage: 62882 km
                    Date: 2016.12.13
                    Time: 01:55:52
                    Voltage terminal 30: 11.661 V
4629 - ECM Power Relay Load Circuit
          P068A 00 [096] - Opens Too Early
                    Coolant temperature: 4 °C
                    Voltage terminal 30: 11.120 V
                    Unlearning counter according OBD: 35
                    Current speed of electric motor: 0.0 /min
                    Status transition of transmission control module sequencing-Bit 0: 0
                    Status transition of engine control module sequencing-Bit 0: 0
                    E-machine torque actual value: 0.0 Nm
                    Emachine_achievable_enginetorque_maximum_value: 0.0 Nm
                    Clutch K0: Status-Bit 0: 0
17262 - Terminal 30
          U140A 00 [032] - Open Circuit
                    Vehicle speed: 255 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [040] - Malfunction
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:00:14
                    Unlearning counter according OBD: 36
12584 - HV Components
          P0AB9 00 [032] - System Failure
                    Mileage: 62882 km
                    Date: 2016.12.12
                    Time: 00:03:18
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 11.355 V
                    Status transition of engine control module sequencing-Bit 0: 8
                    Clutch K0: Status-Bit 0: 1
12591 - HV Components
          P0AB9 00 [109] - System Failure
                    Mileage: 62882 km
                    Date: 2016.12.10
                    Time: 03:07:39
                    Coolant temperature: 86 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 13.287 V
                    Current speed of electric motor: 933.0 /min
                    Status transition of transmission control module sequencing-Bit 0: 1
                    Status transition of engine control module sequencing-Bit 0: 2
                    E-machine torque actual value: 82.5 Nm
                    Emachine_achievable_enginetorque_maximum_value: 208.0 Nm
                    Transfer electric drive to combustion drive-Bit 0: 7
Readiness: 0010 0101
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4H1 927 158 BP    HW: 0BW 927 156 S
   Component: 0BW 20TFSIRdW H16 1004
   Revision: --H16---
   ASAM Dataset: EV_TCMAL551511 002022
   ROD: EV_TCMAL551511.rod
   VCID: 7F4ECB5FE6D502B99A-802A
12483 - System Voltage
          P0562 00 [032] - Too Low
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:30
                    Voltage terminal 30: 8.942 V
                    Voltage supply of regulator valves: 8.915 V
                    Voltage terminal 15: 9.0 V
                    Engine speed: 0 /min
                    Transmission input speed: 0.00 /min
                    Driving position: P
                    selected gear: without traction
                    Starting clutch status: Kupplung geoeffnet
                    E-machine cut-out clutch status: geoeffnet
                    M015_Time Normal Mode: 169 s
                    M019_Time Since Reset: 7650 ms
                    M018_Time In Afterrun: 0 s
                    Transmission fluid temperature: 6 °C
13785 - HV Components
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:18
                    Voltage terminal 30: 11.405 V
                    Transmission input speed: 1173.00 /min
                    Transmission output speed: 1176.00 /min
                    Engine torque: -37 Nm
                    Transmission fluid temperature: 71 °C
                    Starting clutch status: Kupplung geschlossen
                    E-machine cut-out clutch status: geregelt geschlossen
                    Engine speed: 1307 /min
                    Transfer speed from ESP: 71.06 km/h
   Part No SW: 4H0 907 379 H    HW: 4H0 907 379 H
   Component: ESP PREMIUM   H10 0471
   Coding: 10C5CB0008A3D300E300
   ASAM Dataset: EV_ESPPremi 005018
   VCID: 373EE37F8E65FAF912-8062
0089 - Function Restriction due to Faults in Other Modules
          U1113 00 [136] - -
                    Reset counter: 22
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:18:04
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 10
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 34
                    F-Type: 02
                    Uz: 74
0120 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:23
                    VzRef: 00
                    Bit Info 1: C0
                    Bit Info 2: 02
                    Bit Info 3: 80
                    Bit Info 4: 00
                    F-Path: 3B
                    F-Type: 35
                    Uz: 90
0462 - Supply voltage
          U1011 00 [136] - Voltage too Low
                    Fault Frequency: 18
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.31
                    Time: 11:21:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 12
                    Bit Info 3: 00
                    Bit Info 4: 00
                    F-Path: 03
                    F-Type: 24
                    Uz: 58
0773 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.10.31
                    Time: 11:21:00
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 12
                    Bit Info 3: 00
                    Bit Info 4: 00
                    F-Path: 3B
                    F-Type: 34
                    Uz: 58
0788 - Function Restriction due to Implausible Message(s)
          U1112 00 [136] - -
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.13
                    Time: 01:55:54
                    VzRef: 00
                    Bit Info 1: C0
                    Bit Info 2: 40
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 2A
                    F-Type: 28
                    Uz: A2
   Part No SW: 4H0 907 064 CB    HW: 4H0 907 064 CB
   Component: BCM2 2.0      H33 0433
   Coding: 05C72F46000000000000
   VCID: 6B960F0F8AAD8E1926-803E
                    Fault Frequency: 17
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:50:08
                    Fault Frequency: 165
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:10
   Part No SW: 4H0 959 760 H    HW: 4H0 959 760 H
   Component: MEM-BFS       H09 0163
   Revision: AA000000    Serial number: 00000045785147
   Coding: C018B60084002201040001010101112909313229283232
   VCID: 383CE0438B7BF5811B-806C
03766 - Motor for Seat Belt Height Adjustment
                    Fault Status: 01100101
                    Reset counter: 156
                    Mileage: 53200 km
                    Date: 2016.08.01
                    Time: 14:24:08
                    Fault Frequency: 11
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:08
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.11.08
                    Time: 12:23:09
03325 - Switch for Backrest Angle Adjustment: Back
                    Fault Status: 00100011
                    Reset counter: 23
03661 - Control Module for Seat Adustment; Rear Passenger-Side
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 01:57:40
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 3 Zonen H20 0130
   Coding: 64810ADE9E
   ASAM Dataset: EV_AirCondiFront 001050
   VCID: 291A350748D15C0994-807C
12 Faults Found:
0326 - Sunlight Photo Sensor
          B10E8 15 [008] - Open or Short to Plus
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:53:57
                    Outside air temperature-Data: 7.50 °C
                    Interior temperature-Data: 6.60 °C
0235 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:54
                    Voltage terminal 30-Data: 8.5 V
                    Outside air temperature-Data: 8.00 °C
                    Engine speed-Data: 0 /min
0315 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:28
                    Voltage terminal 30-Data: 11.9 V
                    Outside air temperature-Data: 14.00 °C
0280 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 23
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:01:00
                    Outside air temperature-Data: 77.50 °C
                    Engine speed-Data: 882 /min
0291 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:28
                    Terminal 15 status: Terminal 15 on
0325 - Control Module for Auxiliary Heater
          B10C0 16 [008] - Voltage Too Low
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:13:41
                    Voltage terminal 30-Data: 9.9 V
0314 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:31
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 22
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:26
0289 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:54
0387 - Sunlight Photo Sensor
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:53:57
0390 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.11.28
                    Time: 23:31:48
                    Voltage terminal 30-Data: 5.8 V
                    Shut-off valves for coolant: status-Shut-off valve for coolant: interior: target: Open
                    Shut-off valves for coolant: status-Shut-off valve for coolant: interior: actual: Open
                    Shut-off valves for coolant: status-Shut-off valve for coolant: battery: target: closed
                    Shut-off valves for coolant: status-Shut-off valve for coolant: battery: actual: Open
0395 - Function limitation due to crash signal
          B1397 00 [008] -  -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:19
                    Voltage terminal 30-Data: 12.1 V
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001703134
   Coding: 0907201009749FE089810084A0001800009CC30AC8000121800108546F21
   VCID: 6FAE1B1FBEB572390A-803A
   Component: WWS641 130207  H35 0080
   Serial number:         130223110334
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Serial number: 10255601
   Coding: 025523
   Serial number: 22 03 2013  00001114
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Serial number: 0000002274537R13ZS01
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000020031300010493
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000020031300010755
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Serial number: WA104972000003067664
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 6B398B96000000000001
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.07
                    Time: 16:54:00
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.21
                    Time: 11:18:00
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.21
                    Time: 11:18:00
                    Fault Frequency: 59
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:00
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:00
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:00
03645 - Output Module for LED Headlamps; Left
                    Fault Frequency: 21
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.10
                    Time: 07:19:00
   Revision: AA001001
   Coding: 020000
   VCID: 2306272F22FD8659DE-8076
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:09
                    Voltage: 7.00 V
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:50:26
                    Voltage: 8.60 V
02261 - Data Medium
                    Fault Status: 00101110
                    Fault Frequency: 77
                    Reset counter: 22
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 07:02:47
                    Text: 00000000
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061308500888
   Coding: A80125
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 71AA1D67A08164C91C-8024
9 Faults Found:
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [008] - Open or Short to Ground
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 08:31:28
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [008] - Open or Short to Ground
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:30
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [008] - Open or Short to Ground
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:30
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [008] - Open or Short to Ground
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:30
1112625 - Front Right Parking Aid Sensor
          B10FA 31 [008] - No Signal
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 08:31:28
1112113 - Front Left Center Parking Aid Sensor
          B10F8 31 [008] - No Signal
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 08:31:28
1112369 - Front Right Center Parking Aid Sensor
          B10F9 31 [008] - No Signal
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 08:31:28
13635840 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:37
          U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:37
   Part No SW: 4H0 959 655 F    HW: 4H0 959 655 F
   Component: Airbag10.43   H51 0053
   Revision: --------    Serial number: 003KB0014JKZ
   Coding: 3032373630344E303032554A304C34483053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001023
   VCID: 393AE547B871EC89E4-806C
   Serial number: 3575HRB40591TEI450IA
   Serial number: 3585HRB405B1TEI468KO
   Serial number: 3515JRB400650G4GAOL5
   Serial number: 3525JRB400A50G4G7117
   Serial number: 3554VRB40590I70G0OVS
   Serial number: 3564VRB40590I70GN99F
23 Faults Found:
9447424 - Front crash data stored
          B1028 00 [136] -  -
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:18
9466352 - Crash Data from Belt Tensioner Stored
          B1071 F0 [136] - Unknown Error Elaboration
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:19
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [136] - Open or Short to Plus
                    Mileage: 62883 km
                    Date: 2016.11.28
                    Time: 14:41:02
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [136] - Open or Short to Plus
                    Mileage: 62883 km
                    Date: 2016.11.28
                    Time: 14:41:03
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [136] - Open or Short to Plus
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 16:31:13
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 16:31:13
          B1000 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 07:09:49
9437201 - Igniter for Driver's Airbag
          B1000 11 [136] - Short to Ground
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:22
9437723 - Igniter for Passenger's Airbag
          B1002 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.11.28
                    Time: 14:41:05
9437713 - Igniter for Passenger's Airbag
          B1002 11 [136] - Short to Ground
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9571867 - Ignitor for Drivers Airbag Release Valve
          B120E 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9572123 - Ignitor for Passenger Airbag Release Valve
          B120F 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9442587 - Igniter for battery interrupt
          B1015 1B [137] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
          B1006 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [136] - Resistance Too High
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:21
9441563 - Rear; driver's side; side-airbag igniter
          B1011 1B [136] - Resistance Too High
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 05:39:45
9441307 - Rear; passenger's side; side-airbag igniter
          B1010 1B [136] - Resistance Too High
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 05:39:45
1049862 - Databus
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:30
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:42
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815LGA0000H
   Coding: 0004B4
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0010
   Serial number: 09 01 2013  33330542
00889 - Horn (H)
                    Fault Status: 00100111
                    Fault Frequency: 17
                    Reset counter: 22
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:14:19
                    Reset counter: 25
                    Reset counter: 22
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 24
   Part No SW: 4H0 920 800 N    HW: 4H0 920 800 N
   Component: TBenRDW---NV- H52 0515
   Revision: 34480076    Serial number: 658220113592040
   Coding: 13A7090053450008000300
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: 2D12C1177C39402978-8078
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Serial number: 2130312002281
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:54:11
16773127 - Analog Clock
          U1096 00 [008] - No Communications
                    Reset counter: 24
16776976 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:30
1048580 - Button for Trip Odometer Reset
          B11FE 13 [008] - Open Circuit
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 06:36:51
   Part No SW: 4H1 907 468 B    HW: 4H1 907 468 B
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000768920
   Coding: 00D10AFF00
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: 312ADD67600124C95C-8064
   Subsystem 1 - Part No SW: 4H0 915 181 E    HW: 4H0 915 181 E
   Serial number: 60066030242071107201
   Battery monitoring control unit 2:
10 Faults Found:
5048 - Control Module for Multi-Contour Seat; Rear Driver Side
          U1087 00 [008] - No Communications
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:46:12
                    Voltage terminal 30: 11.6 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 10 °C
                    System status: Awake_Timer_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
5049 - Control Module for Multi-Contour Seat; Rear Passenger Side
          U1089 00 [008] - No Communications
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 01:57:15
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5052 - Control Module for Seat Adjustment Rear Drivers Side
          U10B3 00 [008] - No Communication
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:46:12
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5053 - Control Module for Seat Adjustment Rear Passenger Side
          U10B4 00 [008] - No Communication
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 01:57:15
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5701 - High Beam Assistant Control Module
          U1070 00 [008] - No Communication
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.11.30
                    Time: 04:34:45
                    Voltage terminal 30: 11.1 V
                    Voltage terminal 15: 11.1 V
                    Control Module temperature: -1 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: On
                    Datenfeld: 0
5080 - Front Left belt tensioner control module
          U107C 00 [008] - No communication
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:57:15
                    Voltage terminal 15: 11.6 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5081 - Front Right belt tensioner control module
          U107D 00 [008] - No communication
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:57:15
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.11.30
                    Time: 02:55:51
                    Voltage terminal 30: 9.1 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0017 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.12.02
                    Time: 08:40:13
                    Voltage terminal 30: 7.9 V
                    Control Module temperature: 4 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 46
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.11.30
                    Time: 02:59:51
                    Voltage terminal 30: 9.9 V
                    Control Module temperature: -2 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 3
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 F    HW: 8K0 857 511 A
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04018B646E6E645A5A253D3E00
   VCID: 3424D473971311E137-8060
   Part No SW: 4H0 919 158 H    HW: 4H0 919 158 H
   Component: Klima Fond    H21 0121
   Coding: 3600000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 3522E977946908E900-8060
0077 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:07
0152 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:57:19
                    Voltage terminal 30-Data: 11.6 V
                    Outside air temperature-Data: 11.00 °C
0153 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:57:19
0102 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:07
   Revision: S0H06000    Serial number: 00000000039350
   Coding: 01010101000000000001000102
   VCID: 648464336773C16167-8030
                    Fault Frequency: 15
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:49:13
                    Reset counter: 22
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:08
   Part No SW: 4G0 907 553 E    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0781
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003024
136194 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:47
          C10C8 00 [008] -  -
                    Reset counter: 26
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:26:11
136196 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 23
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000055473659
   Coding: C018BF8085853201070001010101112131313333203333
   VCID: 3522E9779C6908E900-8060
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:56:13
                    Fault Frequency: 11
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:05
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:57:18
03794 - Switch for Massage
                    Reset counter: 25
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA7700MSAP
8393216 - Pitch Rate
          C10B7 F0 [008] - Gradient too High
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:18
                    DCU_Internal_DTC: 80 12 00
                    Ignition Cycle Count: 14485
                    DCU Temperature: 37 °C
                    Voltage terminal 30: 12.6 V
                    Voltage VBG 22: 2.5 V
                    Roll rate sensor: -0.00 rad/s
                    Pitch rate sensor: -0.07 rad/s
                    Yaw rate sensor: 0.00 rad/s
                    Yaw rate sensor 2: 0.00 rad/s
                    Longitudinal acceleration sensor: -42.94 m/s˛
                    Lateral acceleration sensor 1: -1.07 m/s˛
                    Lateral acceleration sensor 2: 0.00 m/s˛
                    Body acceleration sensor: 1.31 m/s˛
                    Debug Data: 00 00 00 00 00 00 00 00
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000102
   VCID: 2E10C61BB93F3B3141-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F27.03.1300H02000AMS14465˙
   Subsystem 4 - Serial number: S14465˙
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:54
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:57
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:54
01024 - Rain Sensor (G213)
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 23:55:55
Address 40: AC Compressor (J842)       Labels: None
   Part No SW: 4G0 260 797     HW: 4G0 260 797
   Component: ES34          H01 0001
   ASAM Dataset: EV_AirCondiCompr_ES34 S03001
   ROD: EV_AirCondiCompr_ES34.rod
   VCID: 6A980A0B8D5797115D-803E
             U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:40
                    Voltage terminal 15: 8.9 V
                    Compressor speed: 0 /min
                    Compressor current: 0.0 A
                    Compressor temperature: 0 °C
                    Compressor main status: Not available
                    Compressor enabling: Not available
                    Compressor speed specified value: 0 /min
                    Availability of high voltage: Not available
                    Hybrid battery voltage: 100.0 V
                    Compressor motor current: 0.0 A
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000055808577
   Coding: 011F1E015E0062C202083016
   VCID: 48DC9083FB9B85016B-801C
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:01
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 05:39:45
Address 44: Steering Assist (J500)       Labels: None
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0018280133
   Coding: 001000010100
   VCID: 3228D26B65071FD125-8066
18689 - Terminal 30
          U140A 00 [008] - Open Circuit
                    Reset counter: 23
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:37:13
                    valid
   Revision: 00002001    Serial number: 0302392575
   Coding: 011A0E2000B97D9FB330C7801A03012F0000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000133762
   Subsystem 4 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Serial number: 311400042044
   Coding: 020200
   Subsystem 5 - Part No SW: 4H0 947 135 R    HW: 4H0 947 135 R
   Serial number: A2013000000000691424
   Coding: 070000
   Serial number: 310300039613
   Coding: 020200
   Serial number: 311400042043
   Coding: 020200
   Subsystem 8 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Serial number: 310300039600
   Coding: 020200
   Subsystem 9 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84359194
11 Faults Found:
00218 - Humidity Sensor (G355)
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:23
02907 - Control Module for Roof Shade (J394)
                    Fault Status: 00100101
                    Reset counter: 28
                    Mileage: 62882 km
                    Date: 2016.12.13
                    Time: 01:55:18
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 23:55:54
03932 - Real Lid/Hatch Opening Sensor
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.13
                    Time: 01:55:18
01512 - Control Module for Sliding Roof
                    Reset counter: 28
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:48:02
02906 - Control Module for Sliding Roof; Rear (J392)
                    Reset counter: 28
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:48:03
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 22:58:25
01308 - Control Module for Roof Electronics (J528)
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 22:58:25
02201 - Trunk / Luggage Compartment Closing Assist; Position - Unlocked (F332)
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.11.30
                    Time: 02:55:44
                    Reset counter: 22
                    Mileage: 62883 km
                    Date: 2016.11.08
                    Time: 12:27:20
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.11.30
                    Time: 02:55:41
   Part No SW: 4H1 035 465 B    HW: 4H1 035 465
   Component: BO G3 D4 ANC  H03 0150
   Revision: 09000000    Serial number: 0012309
   Coding: 020101
   VCID: 26003E3B51CF7371B9-8072
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 00703130023171
11 Faults Found:
                    Reset counter: 23
                    Voltage: 8.50 V
                    Temperature: 23.0°C
                    Bin. Bits: 00000100
                    Voltage: 8.50 V
                    Temperature: 29.0°C
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:15
                    Voltage: 8.50 V
                    Temperature: 8.0°C
                    Bin. Bits: 00000100
                    Voltage: 10.00 V
                    Temperature: 9.0°C
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 25
                    Voltage: 11.60 V
                    Temperature: 1.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 6.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 25
                    Voltage: 11.60 V
                    Temperature: 1.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 6.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
03017 - Motor for Left Front Treble Speaker (V344)
                    Reset counter: 25
                    Voltage: 11.60 V
                    Temperature: 1.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 6.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
03016 - Motor for Front Right Treble Speaker (V345)
                    Reset counter: 25
                    Voltage: 11.60 V
                    Temperature: 1.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 6.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 25
                    Voltage: 11.80 V
                    Temperature: 13.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 22.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 25
                    Voltage: 11.50 V
                    Temperature: 12.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 21.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
02753 - Inside Microphone (R74)
                    Reset counter: 25
                    Voltage: 11.20 V
                    Temperature: -4.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 1.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 23:56:09
                    Voltage: 11.50 V
                    Temperature: 0.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 7.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 23:56:09
                    Voltage: 11.50 V
                    Temperature: 0.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 7.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000053984457
   Coding: C01892808500300D0B00392038193A2039203B3B202020
   VCID: 3228D26B6D071FD125-8066
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:50:23
                    Fault Frequency: 13
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:07
   Part No SW: 4H0 907 080 B    HW: 4H0 907 080 B
   Component: Audi C7/D4 HY H18 0001
   Revision: --------
   ASAM Dataset: EV_DMCM03020214H0907080B 001001
   ROD: EV_DMCM030202106F907080H.rod
   VCID: 26003E3B59CF7371B9-8072
17659 - HV Electronics Coolant Pump Control
          P0CEA 00 [032] - Implausible Signal
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:00:50
                    Voltage terminal 30-Battery voltage: 13.780330 V
                    RPM of electric machine-N_EM: 1197.50 /min
                    Drive control condition-STATE_EM_MOD_CAN: speed control (external)
                    Torque: current value-TQI_EM_CAN_MVB: -20.3 Nm
                    Power electronics heat sink temperature-PIT_S16TEMPERATURE_DCBLP: 12.16 °C
                    Voltage of intermediate circuit-S16DCLINKVOLTAGE_MVB: 263.69 V
17929 - Invalid Data Received from Diagnostic Gateway Module
          U0447 00 [040] - -
                    Fault Frequency: 20
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:27
                    Voltage terminal 30-Battery voltage: 11.668016 V
                    RPM of electric machine-N_EM: 0.00 /min
                    Time since terminal 15 ON-T_AST_SAE: 0 s
                    Electrical drive control module: operating status-ECUM_ESYSTEMSTATE_ENVD: ECUM_Run
                    Intermediate circuit voltage-DCSP__S16HVVOLTAGE: 264.19 V
5751 - 14V Power System Voltage
          P0A8D 00 [032] - too Low
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:57
                    Voltage terminal 30-Battery voltage: 8.449253 V
                    Drive control condition-STATE_EM_MOD_CAN: Standby
                    Torque: current value-TQI_EM_CAN_MVB: 0.0 Nm
                    Power electronics heat sink temperature-PIT_S16TEMPERATURE_DCBLP: 6.44 °C
                    Voltage of intermediate circuit-S16DCLINKVOLTAGE_MVB: 272.38 V
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000055334112
   Coding: 011F1E015E0062C202083006
   VCID: 3C34FC53BF43D9A1FF-8068
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:01
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 05:39:45
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000632565
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B16CF0F422D4E1966-807E
10554390 - Supply voltage
                    Reset counter: 238
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:41
                    Voltage terminal 30: 8.9 V
                    Internal Fault ID: 40
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
721408 - Terminal 30
                    Reset counter: 238
                    Voltage terminal 30: 0.0 V
                    Internal Fault ID: 61
                    Vehicle speed: 510 km/h
                    Network management state: Reset
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: Emergency running mode
                    Status ParkingBrake left: Initializing
                    Status ParkingBrake right: Initializing
461568 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:28
                    Voltage terminal 30: 11.5 V
                    Internal Fault ID: 147
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4H0 035 061 Q    HW: 4H0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 440CK0D7520007
   Coding: 010103010003000001
   VCID: 2C14CC134F2349216F-8078
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:14
                    Voltage: 8.50 V
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:50:32
                    Voltage: 8.60 V
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801300372401
   Coding: 01000400
   VCID: 2D12C1177439402978-8078
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.31
                    Time: 11:20:17
02283 - Video Connection to Output [End Unit]
                    Fault Status: 00101010
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 00:10:12
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000053985998
   Coding: C01896808500300D0F00392038193A2039203B3B3B2020
03785 - Remote Control for Rest-Seat
                    Reset counter: 11
                    Mileage: 54078 km
                    Date: 2016.08.14
                    Time: 09:19:07
03795 - Switch Module for Seat Adjustment
                    Reset counter: 2
                    Mileage: 57517 km
                    Date: 2016.08.26
                    Time: 13:36:54
                    Fault Frequency: 12
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:16:07
   Part No SW: 4H0 035 654     HW: 4H0 035 670 N
   Component: H-BNT-EU      H45 0939
   Revision: --------    Serial number: 179C50D7508766
   Coding: 1B0100000001F1EF5DF78B1E00000003080001000000000000
   VCID: 6386672F627DC6599E-8036
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 4F0 910 393 AH    HW: 4F0 862 393 E
   Component: BTHS  H25 0750
   Serial number: P13000372727
   Subsystem 3 - Part No SW: 4F0 910 393 AH    HW: 4F0 862 393 E
   Serial number: P13000071540
   Subsystem 4 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC9007AJT
   Subsystem 5 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Serial number: 00000000109088
   Subsystem 6 - Part No: 8R0 060 961 E
   Component: CD-Database  4949
11 Faults Found:
            000 -  -
                    Reset counter: 156
                    Mileage: 53200 km
                    Date: 2016.08.01
                    Time: 14:24:14
                    Text: DU903A,Right,M,0,0,6
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 24
                    Time Indication: 15
                    Voltage: 11.50 V
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 26
                    Time Indication: 15
                    Voltage: 6.80 V
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.10
                    Time: 01:41:21
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 10000000 00000000
03367 - Supply Voltage for Display Module
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:34
                    Voltage: 8.20 V
02168 - Left Front Microphone (R140)
                    Reset counter: 25
                    Time Indication: 15
                    Voltage: 11.20 V
02169 - Front Right Microphone (R141)
                    Reset counter: 25
                    Time Indication: 15
                    Voltage: 11.20 V
01524 - Antenna for Telephone
                    Reset counter: 25
                    Mileage: 53210 km
                    Date: 2016.08.01
                    Time: 14:45:27
                    Voltage: 14.00 V
            000 -  -
                    Reset counter: 240
                    Mileage: 62882 km
                    Date: 2016.12.10
                    Time: 04:37:41
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
03787 - Rotation Mechanism for Display Module Front
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 07:12:28
                    Voltage: 11.60 V
                    Reset counter: 24
                    Time Indication: 15
                    Voltage: 14.50 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0273
   Revision: --------    Serial number: 0000055824397
   Coding: 010F1E01420062C202083006
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:58
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000001829
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 689C7003935BA5014B-803C
8392961 - TPMS Transceiver in Front Left Wheel Well
          C104C 01 [008] - Electrical Failure
                    Fault Frequency: 8
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.11.30
                    Time: 02:56:37
8393217 - TPMS Transceiver in Front Right Wheel Well
          C104D 01 [008] - Electrical Failure
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.11.08
                    Time: 12:28:12
8393473 - TPMS Transceiver in Rear Left Wheel Well
          C104E 01 [008] - Electrical Failure
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.11.08
                    Time: 12:28:12
8393729 - TPMS Transceiver in Rear Right Wheel Well
          C104F 01 [008] - Electrical Failure
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.11.08
                    Time: 12:28:12
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0150
   Revision: 11001001    Serial number: 82330JF0079854
   Coding: 020A000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
   ROD: EV_CamerSysteTopViewAUDI_005.rod
9616922 - Supply Voltage for Front Surroundings Camera
          B1284 14 [008] - Open or Short to Ground
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:23
                    Voltage terminal 30: 12.1 V
9617993 - Proximity Camera
          B145C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 240
                    Mileage: 62882 km
                    Date: 2016.12.12
                    Time: 04:06:40
                    Voltage terminal 30: 13.3 V
15729431 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:00
                    Voltage terminal 30: 8.3 V
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:00
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 053300739
   Coding: 0210044000
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6E90061BB1BF7B3101-803A
0014 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:58
                    8.66 V
0011 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Mileage: 62883 km
                    Date: 2016.10.21
                    Time: 11:18:25
                    8.79 V
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000101671
   Coding: 400000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6386672F6A7DC6599E-8036
0003 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:54:11
                    Voltage terminal 30: 8.4 V
                    Control Module temperature: 24 °C
                    Processor load: 37.0 %
                    Status terminal 58s: OFF
0006 - Front Left Footwell Lighting  Color 2
          B111D 01 [008] - Electrical Failure
                    Reset counter: 24
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 06:51:06
                    Control Module temperature: 16 °C
                    Processor load: 36.5 %
0008 - Front Right Footwell Lighting  Color 1
          B111E 01 [008] - Electrical Failure
                    Reset counter: 26
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:16:59
                    Voltage terminal 30: 13.9 V
                    Processor load: 37.5 %
                    Color setting Ambient: Warm white
0010 - Front Right Footwell Lighting  Color 2
          B111F 01 [008] - Electrical Failure
                    Reset counter: 24
                    Mileage: 62883 km
                    Date: 2016.11.08
                    Time: 14:11:53
                    Voltage terminal 30: 11.9 V
0054 - Rear Left Door Sill Lighting
          B1135 01 [008] - Electrical Failure
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:27:23
                    Voltage terminal 30: 11.8 V
                    Processor load: 34.5 %
0056 - Rear Right Door Sill Lighting
          B1136 01 [008] - Electrical Failure
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 03:52:44
                    Voltage terminal 30: 11.4 V
                    Control Module temperature: 12 °C
   Component: TSG HR        H06 0273
   Revision: --------    Serial number: 0000055824469
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:57
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 776 G    HW: 4H0 035 776 J
   Component: H-BN-EU       H45 0638
   Revision: --------    Serial number: 185CM0D7503010
   Coding: 1B010000000100400140001400001300000000000000000000
   VCID: 2F2EDB1F7E3532394A-807A
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDD120103E-
   Subsystem 2 - Part No SW: 4H4 919 607     HW: 4H4 919 607
   Serial number: AUZ8ZDC27008KZ0
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238MCL0000W
   Subsystem 5 - Part No: 8R0 060 884 AR
   Component: ECE 2013  1505
00658 - Control Head
                    Reset counter: 22
                    Mileage: 61801 km
                    Date: 2016.09.15
                    Time: 08:22:05
                    Voltage: 12.60 V
                    Bin. Bits:      001
03368 - Supply Voltage for Display Module 2
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.31
                    Time: 11:20:28
                    Voltage: 7.80 V
03369 - Supply Voltage for Display Module 3
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.31
                    Time: 11:20:28
                    Voltage: 7.80 V
   Part No SW: 4H1 927 731 C    HW: 4H1 927 731 C
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN121106  0274
   ROD: EV_GSM2x3Mono.rod
9987 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:39
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40093546
   Coding: 1200
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H09 0008
   Serial number: 00000000001305600143
4097 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:57
                    Voltage terminal 15: 8.5 V
                    Image processor: temperature: 9 °C
                    Image processor: error number: 00 01
8704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 23:55:53
          B11E1 29 [008] - Signal Implausible
                    Fault Frequency: 74
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:19
                    Voltage terminal 15: 12.4 V
                    Image processor: temperature: 44 °C
                    Image processor: error number: 00 00
9730 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 21
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.20
                    Time: 14:37:30
9475 - Local Data Bus
          U10B8 00 [008] - Defective
                    Reset counter: 25
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 07:26:16
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: E1060000
0001 - Front Heater for Lane-Holding Assist
          C1101 15 [008] - Open or Short to Plus
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.12.11
                    Time: 23:56:46
                    Outside air temperature: -46.0 °C
                    Voltage terminal 15: 13.4 V
                    Control Module temperature: 9.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00010538196102
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F2EDB1F763532394A-807A
0018 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 25
                    Mileage: 62882 km
                    Date: 2016.11.30
                    Time: 05:39:48
0002 - Supply voltage
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:37
0004 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Frequency: 23
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:48:55
Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00010539189402
   Coding: 304F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   VCID: 2E10C61B713F3B3141-807A
                    Reset counter: 23
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:14:37
          U1400 00 [008] - -
                    Fault Frequency: 21
                    Reset counter: 26
                    Mileage: 62883 km
                    Date: 2016.10.10
                    Time: 17:48:55
   Part No SW: 8R0 915 591     HW: 8R0 915 591
   Component: BMS           H08 0543
   Coding: 120200
   Shop #: WSC 62190 001 1048576
   ASAM Dataset: EV_BECM0722011 004016
   ROD: EV_BECM0722011_004.rod
   VCID: 78BC2043C3FB3581DB-802C
13775 - Reversible crash shut-off was triggered
          P168A 00 [032] - -
                    Reset counter: 142
                    Mileage: 62883 km
                    Date: 2016.09.20
                    Time: 06:13:18
                    Pack Voltage: 279.8 V
                    Pack Current: 15.68 A
                    Isolation Resistance: 1016 KOhm
                    Maximum discharge current limit: 156 A
                    BMS_MaxDyn_EntladeStorm: 180 A
                    Contactor Voltage: 278 V
                    Crash status: 00
                    FAN status: 01
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 01
                    (Plus) Contactor Status: 01
                    Terminal 15 status: 01
                    DFCC: 13775
                    Max Cell Temperature: 35 °C
                    Min Cell Temperature: 34 °C
                    Air inlet temperature: 30 °C
                    Air outlet temperature: 34 °C
                    LV Battery Voltage: 13.2 V
                    Min.cell voltage: 3.875 V
                    Max.cell Voltage: 3.890 V
                    Max.cell SOC: 74 %
                    Min.cell SOC: 73 %
                    Max Charge Pack Current(10s duration): 65 A
                    Max Discharge Pack Current(10s duration): 16 A
                    Max Pack Voltage: 284 V
                    Min Pack Voltage(10s duration): 272 V
                    Max.cell Voltage(10s duration): 3.946 V
                    Min.cell Voltage(10s duration): 3.796 V
                    Accelerator Pedal Position D: 14.9 %
                    Calculated LOAD Value: 7.1 %
                    Engine coolant temperature: 94 °C
                    Engine RPM: 1597.50 /min
                    Vehicle Speed Sensor: 74 km/h
                    Absolute Throtle Position: 14.1 %
                    distance traveld since fault memory last cleared: 9683 km
                    control module system voltage: 13.279 V
                    absolute load: 15.7 %
                    Time After Engine Start: 3262 /min
8402 - 14V Power System Voltage
                    Reset counter: 142
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:15:51
                    Pack Voltage: 271.5 V
                    Pack Current: -0.04 A
                    Maximum discharge current limit: 105 A
                    Contactor Voltage: 270 V
                    Crash status: 00
                    FAN status: 00
                    Fuse Status: 00
                    DFCC: 8402
                    Max Cell Temperature: 6 °C
                    Min Cell Temperature: 6 °C
                    Air inlet temperature: 6 °C
                    Air outlet temperature: 6 °C
                    LV Battery Voltage: 8.2 V
                    Min.cell voltage: 3.767 V
                    Max.cell Voltage: 3.781 V
                    Max.cell SOC: 65 %
                    Min.cell SOC: 63 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0 A
                    Max Pack Voltage: 270 V
                    Min Pack Voltage(10s duration): 270 V
                    Max.cell Voltage(10s duration): 3.782 V
                    Min.cell Voltage(10s duration): 3.766 V
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 4 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 0 km/h
                    Absolute Throtle Position: 16.1 %
                    control module system voltage: 8.274 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 /min
13744 - HV Battery Pack Air Flow Valve 1
          P0AD5 00 [032] - Electrical Malfunction
                    Reset counter: 142
                    Mileage: 62883 km
                    Date: 2016.10.14
                    Time: 10:17:58
                    Crash status: 00
                    FAN status: 00
                    Fuse Status: 00
                    DFCC: 13744
                    LV Battery Voltage: 8.6 V
                    Max.cell SOC: 65 %
                    Min.cell SOC: 63 %
                    Max.cell Voltage(10s duration): 3.781 V
                    control module system voltage: 8.681 V
Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
   Serial number: 00010539176701
   Coding: 304F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
If you need more, let me know, I have tons of scans.
andy86na
C?ID=175954
Thanks, very helpful.
andy86na
C?ID=175954
It works! I got a coding dongle from Kufatec, specifically for Night Vision, and it helped finish things up. One thing I don;t have now is full Night Vision Menu in MMI. I only see the contrast option, but no ability to enable pedastrian recognition. Does anyone know how to enable it?
NEtech
Denmark
C?ID=56995
Is your coding for [84] Night Vision 211100
andy86na
C?ID=175954
No, it was 210100. However, I tried changing it, no effect.
andy86na
C?ID=175954
Adaptations to enable night vision in menus
I retrofitted my 2015 A8 with night vision. It works, but I am still missing some menu entries in Driver Assist section. I understand I need to enable the following parameters in modules 5F (or perhaps 84) adaptations. Problem is, I don't know the channel numbers, and for A8 they don't show up in the VCDS drop-down.
If you have A6 or C7 with NIght Vision, could you post the channel numbers you have in 5F or 84 for the following? I believe they are listed, for C7 at least, in VCDS.
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18 activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus Terminal 15
andy86na
C?ID=175954
BTW, there may be user error on my part in terms of accessing the adaptation channels. I used channel mapping application in VCDS and mapped adaptation channels for 5F and 84, but my map looks nothing like the above. None of the channels have labels like "ENG122229...", they just have numbers. Am I looking in the wrong place?
South Molton, UK
What version of VCDS are you using?
Have you tried the latest 18.9.1 or even the beta 19.2.1?
andy86na
C?ID=175954
I just tried 19.2.1. Same story. I can access all adaptation channels but there are no descriptions for them (or almost none).
Can anyone post channel maps for A6 C7 or for Q7, with night vision?
andy86na
C?ID=175954
Post 2014 A8 with night vision will be even better!
andy86na
C?ID=175954
Security code for Night Vision Module
Does anyone have the code? Car is 2015 A8L, but any code will be appreciated.
Threads merged. Please refrain from opening new threads for involving this retrofit when there is already an existing thread.
andy86na
C?ID=175954
Still looking for the security code for the NV module. Anyone has it?
