No Haldex function
Viking
C?ID=151455
Is it possible to flash the software to higher level, or new controller needed?
   #22
I would think it's possible to flash it.
golfi_vend
Tartu, Estonia
C?ID=195131
It most certenly is. Now is there corresponding TPI for Skoda is another question.
Valpaoy
Finland
Okay, all fixed. How it all got mixed up and not working I don't know, it was like this when I bought it.
The fix was (using VCDS of course)
Start the engine.
1. Open Controller 22 - AWD
2. Open Basic Settings - 04
3. In Basic Settings use the drop down selection box to select "MAS02928 - Pump Motor"
4. Hit "Go" and let it run. Took a minute or so, during which time I could hear the Haldex pump cycling up and down and relearning its function.
After a while the Pump Basic Setting function "Finished Correctly", and everything started to work properly.
Printscreen of the values now is here.
http://www.viking-heating.co.uk/damage/yeti fixed.png
Massive thanks to my new best friend Matt at www.haldexrepairs.co.uk for taking the time to listen and understand what was going on, and then coming up with the solution. :thumbs:
Hi all,
I just read also www.haldexrepairs.com, thanks Matt @threepot, you have good information on your page!
My haldex problem occurred through fault code on auto scan presented here:
Sunday,21,June,2020,20:59:44:05483
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 20.4.1.0
Dealer/Shop Name: Valtterin Paja Oy
VIN: WVWZZZAUZEP542660 License Plate: R-7
Mileage: 208312km-129439mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 13 15 16 17 18 19 22 2B 42 44 52 55 5F 69
VIN: WVWZZZAUZEP542660 Mileage: 208312km-129439miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EA HW: 04L 907 309 D
   Component: R4 2,0L EDC H22 8126
   Revision: 83H22---
   Coding: 1119001A045605083000
   ASAM Dataset: EV_ECM20TDI01104L906021EA 002007
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 68DFB6FC9366B0C6A3-803C
   Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
   Component: ESC H31 0472
   Revision: 00000000 Serial number: 6304300000141E
   Coding: 04FA62A12424096E037D070641C32920462490C0E08294F3F4605074C009
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 071D9540BE385FBE4A-8052
   Revision: 00021000 Serial number: 0194742813
   Coding: 030C0C
   Shop #: WSC 00028 028 00023
   VCID: 3A7B3CB4BD4AF25605-806E
   Part No SW: 5G0 907 044 AB HW: 5G0 907 044 AB
   Component: Climatronic H02 0805
   Revision: 00001K06
   Coding: 02020104204101011005000000101000
   VCID: 67DDB5C09E78BFBEAA-8032
   Air quality sensor:
   Part No SW: 5Q0 937 086 Q HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0095
   Revision: -------- Serial number: 86582910130021
   Coding: 00030A46C24122FB4BE44000001C07081C00000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 489F567CF3A690C683-801C
   Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
   Component: WWS 131030 042 0551
   Serial number: 131031211222
   Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
   Component: RLFS 024 0042
   Serial number: Y13M11D06H20M40S13S6
   Coding: 00A8DD
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 04111376510977
   Coding: 00000900FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3663288489521636E1-8062
   Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
   Component: AirbagVW20 014 0385
   Serial number: 003F6R024DF%
   Shop #: WSC 00028 028 00064
   VCID: 41894B58D09CA18E44-8014
   Subsystem 1 - Part No SW: ----------- HW: 480 001 510 13
   Serial number: 35767000000E42711E0S
   Subsystem 2 - Part No SW: ----------- HW: 480 001 510 13
   Serial number: 35867000000197DC0E0%
   Subsystem 3 - Part No SW: ----------- HW: 480 400 511 13
   Serial number: 3516502BD1118A30824+
   Subsystem 4 - Part No SW: ----------- HW: 480 400 511 13
   Serial number: 3526502AD1118A32F3CG
   Subsystem 5 - Part No SW: ----------- HW: 480 402 610 13
   Serial number: 3556502AF1230BB190AD
   Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
   Component: Lenks.Modul 075 0135
   Revision: FF027027 Serial number: 20131104500125
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73E5D190DAA0431E06-8026
   Part No SW: 5G0 920 871 A HW: 5G0 920 871 A
   Component: KOMBI 353 2210
   Coding: 07A41010AF80000800886A01040000
   VCID: 285FF6FC53E670C663-807C
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
   Component: STH-MQB 006 0069
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
   Component: R149 T91-LIN 003 0301
   Serial number: 00000000000000735513
0139 - Recirculation pump
          B1382 15 [009] - Open or Short to Plus
                    Reset counter: 77
                    Mileage: 197813 km
                    Date: 2020.06.09
                    Time: 12:15:24
                    Operating condition of parking heater: System malfunction
                    71
                    Coolant temperature of parking heater: 43 °C
                    Coolant temperature: 49 °C
                    Engine running status: detected
                    Fuel level: 26 l
                    Heater output: 0 W
0135 - Heater Unit Locked
          B138F 00 [009] - -
                    Reset counter: 77
                    Mileage: 208020 km
                    Date: 2021.01.06
                    Time: 16:59:26
                    Operating condition of parking heater: locked
                    71
                    Coolant temperature of parking heater: 55 °C
                    Coolant temperature: 60 °C
                    Fuel level: 23 l
                    Heater output: 0 W
   Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
   Component: GW MQB High 212 2163
   Revision: -------- Serial number: 31101310800658
   Coding: 030100340B087300EF00025A080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3F8D4DA0A668D77E32-806A
   Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1 H15 0038
   Serial number: 29130000211590053441
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
   Component: J367-BDMHella H03 8043
   Serial number: 6928321703
   Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00021.09.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 46835844F9B286B671-8012
16670 - All-Wheel Drive
          C1113 07 [008] - Mechanical Failure
                    Reset counter: 125
                    Mileage: 208312 km
                    Date: 2021.01.10
                    Time: 00:04:21
   Component: ELV-MQBA H01 0120
   Revision: 00000000 Serial number: 13000251150001
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467128C9F2E0426DF-8060
   Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
   Component: TSG FS 009 0014
   Serial number: 0000081569060
   Coding: 003B1320D000040000001000
   VCID: 4487424CCF8EB4A66F-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV 007 0002
   Serial number: 00000000000003291063
   Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS 125 1063
   Coding: 0102
   Shop #: WSC 31610 001 1048576
   Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
   Component: TSG BFS 009 0014
   Serial number: 0000081576823
   Coding: 003B1120DE00040000801000
   VCID: 43854150CA80B39E56-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG 007 0002
   Serial number: 00000000000003242047
   Coding: 090000
   Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
   Component: AFS-ECU H07 0080
   Coding: 02AA00000B000200
   VCID: 3D7137A8AC64C56E20-8068
   Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
   Component: LeiMo links H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
   Component: LeiMo rechts H05 0012
   Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
   Component: MU-S-N-ER 040 0430
   Serial number: V1F00911132420
   Coding: 02730201FF00000011110001000800031F0100840100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 275DF5C05EF87FBE6A-8072
   Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
   Component: ABT_Std_Nav H51 0022
   Serial number: VWZ8Z9NJ9027H3
   Subsystem 2 - Part No SW: 5G0 919 866 AB HW: -----------
   Component: ECE 2015/16 --- 0051
   Part No SW: 5Q0 907 383 A HW: 5Q0 907 383 A
   Component: Anhaenger H11 0030
   Revision: 6B001003 Serial number: 00000194785929
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 35612F8894541D2EE8-8060
End-------------------------(Elapsed Time: 04:20)--------------------------
Sorry, my scanning computer had wrong date&time.
1. I changed haldex oil and blowed smudge out with pressure air.
2. I demounted haldex pump and washed the filter on it. And more smudge was plowed out with air.
3. Oil in and I carried out pump motor procedure in AWD module basic settings.
4. Message from procedure was "Finished-timeout" and after that "Not running"
So should I change oil and clean the system again after small drive, disassemble the pump and clean it or replace the pump?
On AWD module's basic settings there is also command: resetting of all adaptation values. What this does? Would it be necessary to carry out in this case?
Thanks again for all!
   #26
Gone But Not Forgotten
Update does not fix sludge does it? ;)
Change the oil at least two more times until it drains clean!
   #27
Josh Everett
Orlando, FL, USA
C?ID=381088
@Valpaoy I'm having an identical issue with my Mk7 Golf R where I get the "Finished - timeout" message. Did you find a solution for this or any additional info? I would be very interested in any insights etc. I've only found two issues like this and neither had resolutions posted.
TIA
Josh
   #28
welshkaiboy
H11-2H
I have 2015 VW Tiguan with 80K on it and Matt at Haldexrepairs said any pump that has done more than 45K miles needs swapping out (commutator wears out). My haldex GEN5 pump showed no errors, lots of front wheel spin and no rear drive.
Swapped out the pump and new oil, learn function run and now have 4WD enabled.
