Adpmap blockmap uds oh my
BoydG
C?ID=173712
I have a 2019 S3 and I've been trying to implement the Single Gear Display.
All of the mods say to change the adaptation in the auto trans (module 2), however I only have 3 Adaptations for this module. None of which come close to changing the gear display. After dumping admap and blockmap for that module, I was able to find this in the blockmap
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged
I'm familiar with the old HEX/CAN protocol but now using USD things have changed and i'm lost.
In the blockmap, I found the adaptation I want to change, but it was missing from the adaptation drop down.
1) Is is possible to make a custom label file based off of the information in a blockmap file?
2) If so, how do you figure out what the channel information is? Can it be derived from the identifier (IDE02736-ENG100252)
From the information I've been reading, it looks like we (end users) can't make custom labels using this new format.
Which really sucks because we can't send our custom files to you and have to rely on you to add them.
Thursday,21,March,2019,15:02:06:13348
VCDS Version: 19.1.2.0 (x64)  HEX-NET CB: 0.4502.4
Data version: 20190131 DS301.0
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 6C A5 A9 BB BC CF D6 D7
Address 01: Engine (J623-DLRA)       Labels: None
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 0A2500322466010E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: CED0E73291E38139F1-809A
Readiness: 1110 0101
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_AU37.rod
   VCID: A404659AAFEF5B6977-80F0
   Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
   Component: ESC           H25 0640
   Revision: 00000000    Serial number: 63478000000638
   Coding: 31AA6B7D549B23AB89960B6B4099698CD62AC491D0029676184150D482A8420000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: BA38BBE23D6B3D993D-80EE
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0503083488
   Coding: 030C0C1720
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: C3C6C6064AA17C516E-8096
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001728420
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: F6A06FD249F399F919-80A2
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 6B90D46900PAG0MUFU03
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001835300289
   ROD: EV_BCMBOSCH_019.rod
   VCID: 8B562E262271F41156-80DE
   Component: WWS371 181124  043 0585
   Serial number:         181206000637
   Coding: 0A47F7
   Serial number: 21755654X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 09 10 2018  20001876
   Serial number: 00000000000046091300
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST0027Z0W400000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000020121820240419
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318272
   Coding: 0270167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_009_AU37.rod
   VCID: D1EAFC4E80DD9EC1EC-8084
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: B51887E19DFFCC247498815580302600000000000000000004
   VCID: C4C4C51A4FAF7B6957-8090
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Reset counter: 80
                    Mileage: 1963 km
                    Date: 2019.03.21
                    Time: 14:52:09
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 11.3 V
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       181018002
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: C6C0DF127993497949-8092
   Serial number: 003GCR0AY21J
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: C7DED2167E995071B2-8092
   Belt Pretensioner left:
   Serial number: 34230167A09011920501
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A03011920123
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001SMYT4
   Coding: 303439
   Subsystem 4 - Part No SW: -----------    HW: 480 000 401 19
   Serial number: 35700000000DFC0DD533
   Subsystem 5 - Part No SW: -----------    HW: 480 000 401 19
   Serial number: 3580000000069028E53K
   Subsystem 6 - Part No SW: -----------    HW: 480 401 912 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100012E2B76D01C4B7
   Subsystem 7 - Part No SW: -----------    HW: 480 401 912 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001AF2E1DC52971G
   Subsystem 8 - Part No SW: -----------    HW: 480 401 412 18
   Serial number: 35500010C2B7F1C39123
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 412 18
   Component: FrontSensor_P  004 6149
   Serial number: 35600010C2B7F1C3A608
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 B    HW: 8V0 920 890 B
   Component: FBenUSA       H19 0108
   Coding: 00EF18537F9CCF050281FE001800401000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   VCID: BC34BDFA375F03A92F-FFFE
   Serial number: 03121810804856
   Coding: 030100043F085A005B00807EB80B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: EE9047B231A3A139D1-80BA
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20181218080606 21209
   Serial number: 7588600391181211015D
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7762
   Serial number: HA1-00014.11.18
   Coding: 0001
   VCID: CDD2E03E9CE5BA2188-8098
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: C2C8C30255BB755965-8096
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000407845016
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: B12A9CCEE01DFEC18C-80E4
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0630
   Revision: --------
   Coding: 04C002
   VCID: BD32B0FE2C450AA118-80E8
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RLB15339
   Coding: 005E1B205000008000000002
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: BC34BDFA375F03A92F-80E8
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F021J2J
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   Component: FCM MQB Low   002 0345
   Serial number: 20121811601682
   Coding: 000000050900147206113300040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: B522A8DE1475D2E1D0-80E0
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RJP15829
   Coding: 005E13205C00008000000002
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   Part No SW: 8V1 035 880 C    HW: 8V1 035 880 C
   Component: MU-P-LNS-US   055 1363
   Serial number: A702A0KS014566
   Coding: 017351020000000011220002049A00332F0027E401700108FE
   Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
   Component: NAR 2019  --- 0069
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y0FH8L
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BT    HW: 8V0 919 614 BT
   Component: ControlUnit_H  H85 0858
   Serial number: ALJAL118101800050588
   Compact Disc Database:
   Component: Gracenote2  --- 3013
   Component: RVC Compact   H15 0231
   Coding: 0273010102002001400040
   VCID: B93AA4EE386D368134-80EC
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 15111815K23709
   Coding: 040307010000020101222346C14F890092000E20012000
   ROD: EV_MFKBoschMQBB.rod
   VCID: C0CCC90A5BB7674973-8094
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 181103201411
   VCID: BE30B7F2214311B901-80EA
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0187
   Serial number: YE007RJU16282
   Coding: 000E13204000008000000002
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   Component: TSG HBFS003 0187
   Serial number: YE007RJU16288
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   VCID: 977E42566EB900F1E2-80C2
End(Elapsed Time: 18:50, VBatt start/end: 11.5V/11.3V. VIgn 11.3V, Deb=2)--
Look at those block maps.
There's a Measuring Value for it, but no Adaptation Channel.
BoydG
C?ID=173712
So this means you can measure it but you can't change it?
Seems that way.
Unfortunately, we don't make the software inside these control modules, nor define the API used to access the data in them.
BoydG
C?ID=173712
Seems that way.
Understood, There was no attitude in that sentence. :)
I'm just trying to educate myself on what can and can't be done.
How do you (ross-tech) find what adaptations are supported by each module?
I read that with UDS you can't query the module like you can with older protocol.
We look at what the factory tool supports.
