Hello everyone. First time posting. was wondering if you guys could help me. so here is what happened mmi died and another shop changed it. so mmi started working but no sound. Fuses checked, optical bus diagnostics done and everythig seems OK. Autoscan down below
thanks for your help
Thursday,21,March,2019,09:08:26:24100
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
VIN: WAUEFAFL3DA148538 License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
72
VIN: WAUEFAFL3DA148538 Mileage: 65450km-40668miles
09-Cent. Elect. -- Status: Sporadic communication error 1000
Address 01: Engine (0-----CAEB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 C HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09---
Coding: 4A030013242400062000
Shop #: WSC 04039 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115C 001006
ROD: EV_ECM20TFS0118K5907115C.rod
VCID: 3228E235657145DA1B-8066
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K2 927 155 E HW: 0AW 927 156 K
Component: 0AW 20TAVSUSA H05 0003
Revision: --H05--- Serial number: 0000000974
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A02431
ROD: EV_TCMVL381.rod
VCID: 373ED3218E13A0F22C-8062
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CH HW: 8K0 907 379 CH
Component: ESP8 front H09 0100
Coding: 081D18
VCID: 014A7DF998572E42D2-8054
02214 - Tire Pressure Warning
Reset counter: 41
Mileage: 65452 km
Date: 2018.11.13
Time: 01:35:52
Hex Value: 0x0000
Hex Value: 0x0702
Hex Value: 0x0021
Hex Value: 0x1BA9
Hex Value: 0x0000
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H11 0621
Coding: 0D814000000000000000
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Serial number: 0812000166707014
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000222218016
Fault Status: 00101101
Reset counter: 81
Mileage: 65452 km
Date: 2018.11.13
Time: 00:00:01
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01101020120303
Coding: 6400208000
VCID: 393AD519B007B682DA-806C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000489663702
Coding: 26000091863CAFC00000480300003D0D0F1C5208A2090221000008004000020100000030000000
VCID: 78BC101DCB8D6F8AE5-802C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 091012 H07 0080
Serial number: SWF12100096167
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20631161
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000210120112
Component: USHL4.2 H30 0030
Serial number: 0000002274555R38T602
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 6E384F46000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD90V48L
Coding: 303844354730303030304A55304C384B3053
Shop #: WSC 09805 002 1048576
VCID: 4AD89AD5EDE12D1A43-801E
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R120000AGFL
Serial number: 6334MSME7166053DE
Serial number: 6344MSME7165532FI
Serial number: 6352QSME2125287AE
Serial number: 6362QSME4C242C70L
Serial number: 63732SME49241658
Serial number: 63832SME4924244A$
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20121011000234
Coding: 000036
VCID: 4FEE8BC11E83083214-801A
Part No SW: 8K0 920 982 D HW: 8K0 920 982 D
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBI36LK9D
Coding: 8BB609000301D705020000
VCID: 3522D9299C1F52E23E-8060
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y129280141
Coding: 80C303FF00
VCID: 44C4B4EDC7C5FB6AB9-8010
Serial number: 5180858101
00457 - Control Module for Network (J519)
Reset counter: 81
Mileage: 65452 km
Date: 2018.11.13
Time: 00:00:01
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000039539758
Coding: 00581B00000000000000
VCID: 3B36CF11BA3B8492C8-806E
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13204E00410001
VCID: 56E07EA5215979FAD7-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0021900568
Coding: 100000000001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3424E42D9F654BEA09-8060
18689 - Terminal 30
U140A 00 [009] - Open Circuit
[Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
Reset counter: 41
Mileage: 65452 km
Date: 2018.11.13
Time: 00:06:39
Write only channel
Revision: 00002001 Serial number: 0184829737
Coding: 0106023A00FA400580B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000000583166
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Reset counter: 81
Mileage: 65452 km
Date: 2018.11.13
Time: 00:00:01
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55E279A93C5F72E2DE-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001186863
ROD: EV_ParkiBrake_AU48.rod
VCID: 383CD01D830DAF8A25-806C
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156H-0C7621138
Coding: 020007010000000000
Shop #: WSC 31414 790 00001
VCID: 210A1D793897CE42F2-8074
Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
Component: H-BNT-NA H43 0624
Revision: -------- Serial number: 204JY0C7535433
Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
VCID: 373ED3218613A0F22C-8062
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130JQ0C2552604
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001297653
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
01524 - Antenna for Telephone
Fault Status: 00101011
Reset counter: 41
Mileage: 65452 km
Date: 2018.11.13
Time: 01:58:02
Voltage: 12.40 V
00822 - Connection DSP to Radio
Reset counter: 41
Mileage: 65452 km
Date: 2018.11.13
Time: 01:41:05
Voltage: 13.40 V
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C13204000210001
VCID: 59FA759950475682FA-800C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2791UV
Coding: 1000006
VCID: 383CD01D4B0DAF8A25-806C
Component: TSG HR H07 0304
End----------(Elapsed Time: 02:01, VBatt start/end: 13.8V/13.7V)-----------
