Not able to access all cloud functions
Delfin
C?ID=363796
First post. Please forgive me if I don't get all of the terminology correct. HEX-NET, VCDS-mobile, Macbook Pro, Firefox. 2013 Audi A7.
Was able to get HEX-NET configured in infrastructure mode, run an autoscan, update the ASAM file(s), upload the saved auto-scan log to VCDS-cloud. I've inserted the log file that I downloaded from VCDS-cloud.
I was able to make one adaptation, channel 2 Auto Trans, clicked on the cloud function button to get to the "Single Gear Display" and changed it to "D on/S on".
When I went to make the next adaptation, channel 17 Instruments, when I click on the cloud function button, it shows the trying to connect to the VCDS-cloud, then it says success, but then it redirects me to the VCDS-cloud login page. Tried it multiple times, being already logged in to VCDS-cloud in the same tab, a different tab, or not logged in at all. Same result.
Is there anything special that I have to do when configuring Firefox so that the cloud function button will work for all controller channels?
Thanks.
#hndoc:?docid=00004C4B&xt=hnh:776D89676ABF5F1B01223B2731F9D141D6841CCD379726C927D04532219F98BB
VCDS Mobile 0.4437.0.4
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 47 52 53
	 55 56 5F 62 6C 6D 72 8F 90
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
Address 01: Engine  (CTUA4 J623)	Labels: 4G-01.lbl
	Part No SW: 4G0 907 551 D	HW: 4G0 907 551 A
	Component: 3.0l V6 TFSI
	Revision: --H07---
	Coding: 1A2A0034052601060000
	Shop #: WSC 02391 785 00200
	ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
	ROD: EV_ECM30TFS0214G0907551D.rod
	VCID: 2A1791AB9D10A160C6B684-807F
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: 4G-02.lbl
	Part No SW: 4G1 927 158 A	HW: 0BK 927 156 AM
	Component: 0BK 30TFSIUSA H16 1006
	Revision: --H16---
	Coding: 000002
	ROD: EV_TCMAL551211_002_AU57.rod
	VCID: 2D1D9AB7ACFEB65823D4A7-8078
Address 03: ABS Brakes  (J104)	Labels: 4G0-907-379-V1.clb
	Part No SW: 4G0 907 379 H	HW: 4G0 907 379 H
	Component: ESP PREMIUM   H09 0361
	Revision: --------
	Coding: 44A78F0322E5F1C04B00
	ASAM Dataset: EV_ESPPremiAU57X 004028
	VCID: 362FB5DB59A8F580520E00-8063
0486 - Function Restriction due to Faults in Other Modules
	U1113 00 [008] -
Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
	Part No SW: 4H0 907 064 CR	HW: 4H0 907 064 CR
	Component: BCM2 2.0      H33 0433
	Coding: 0DAA2046000000000000
	VCID: 7BB964EF220AF0E8EDC019-802E
	Subsystem 1 -
	Subsystem 2 - 	Part No SW: 4H0-905-852-C
Address 08: Auto HVAC  (J255)	Labels: 4G-08.clb
	Part No SW: 4G0 820 043 AF	HW: 4G0 820 043 AF
	Component: KLIMA 4 ZONEN H13 0076
	Coding: 6603207A49
	ASAM Dataset: EV_AirCondiComfoUDS 002036
	VCID: 63893C8FBABA3028C5F011-8036
Address 09: Cent. Elect.  (J519)	Labels: 4H-09.clb
	Part No SW: 4H0 907 063 CG	HW: 4H0 907 063
	Revision: 11012002
	Coding: 0D072091073E9FE081000884A0003820CF9CD208A6090225800308457B00
	Shop #: WSC 02311 785 00200
	VCID: 6FA140BF66729C4851489D-803A
	Subsystem 1 - 	Part No SW: 4G1-955-119	Labels: 1Kx-955-119.clb
	Component: WWS57X 130115H36 0080
	Coding: 0045F7
	Subsystem 2 - 	Part No SW: 8U0-955-559-B	Labels: 8U0-955-559.clb
	Component: G397_RLFS    H06 0002
	Coding: 02006E
	Subsystem 3 - 	Part No SW: 4G0-941-531-E
	Component: E1 - LDS     H07 0044
	Subsystem 4 - 	Part No SW: 4G0-907-410-A
	Component: USHL4.2      H30 0030
	Subsystem 5 - 	Part No SW: 8K0-959-772-E
	Component: SLR-B8       H06 0007
	Coding: 853000
	Subsystem 6 - 	Part No SW: 4G0-907-472
	Component: A31 LED Mod1LH02 0002
	Subsystem 7 - 	Part No SW: 4G0-907-472
	Component: A27 LED Mod1RH02 0002
	Subsystem 8 - 	Part No SW: 4H0-907-705-K
	Component: EVLS-SG      H08 0300
	Coding: 020300
	Subsystem 9 - 	Part No SW: 4H0-907-658
	Component: AQ_Hum_SensorH03 0003
	Subsystem 10 - 	Part No SW: 4G0-907-472-A
	Component: A32 LED Mod2LH02 0002
	Subsystem 11 - 	Part No SW: 4G0-907-472-A
	Component: A28 LED Mod2RH02 0002
Address 10: Park/Steer Assist  (J446)	Labels: 4H0-919-475-7X2.clb
	Part No SW: 4H0 919 475 AA	HW: 4H0 919 475 AG
	Component: PARKHILFE ACC H01 0083
	Revision: 11001001
	Coding: A8C304
	ASAM Dataset: EV_EPHVA18AU57X0000 004009
	ROD: EV_EPHVA18AU57X0000_004.rod
	VCID: 71A546C7704692B8477C8B-8024
Address 15: Airbags  (J234)	Labels: 4H0-959-655.clb
	Part No SW: 4G0 959 655 A	HW: 4G0 959 655 A
	Component: Airbag10.43   H33 0033
	Revision: --------
	Coding: 303145313131303030314A55304C34473853
	ROD: EV_AirbaAU10BPAAU64X_AU57.rod
	VCID: 33298CCF4ADAE0A8751061-8066
	Subsystem 1 - 	Part No SW: 5C6-959-339-B
	Component: BF-Gewichtss.H10 0046
	Serial Number: 6940000Y150001FDGC0U
	Subsystem 2 - 	Serial Number: 3575HRB40651S1NK49HL
	Subsystem 3 - 	Serial Number: 3585HRB40671SJR24HH-
	Subsystem 4 - 	Serial Number: 3515JRB400K4UPLK80TH
	Subsystem 5 - 	Serial Number: 3525JRB400250DEK4PF2
	Subsystem 6 - 	Serial Number: 3554VRB401G50CU4GHR3
	Subsystem 7 - 	Serial Number: 3564VRB401I50D5Q7GR.
Address 16: Steering wheel  (J527)	Labels: 4H0-953-568.clb
	Part No SW: 4G0 953 568 A	HW: 4G0 953 568 A
	Component: Lenks.Modul   H05 0201
	Revision: 00000000
	Coding: 000034
	VCID: 302383C3BBCCC3B008F246-8065
	Subsystem 1 - 	Part No SW: 4G0-951-528-A
	Component: E221 - MFL   H08 0010
Address 17: Instruments  (J285)	Labels: 4H0-920-xxx-17.clb
	Part No SW: 4G8 920 983 E	HW: 4G8 920 983 E
	Component: TBenUsa       H79 0515
	Revision: 28460208
	Coding: 0BE601060B43D705020100
	ASAM Dataset: EV_RBD4K 004046
	ROD: EV_RBD4K_AU57.rod
	VCID: 3731B8DF5EA20C88493835-8062
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 4G0 907 468 AC	HW: 4G0 907 468 AC
	Component: J533--Gateway H12 0037
	Revision: --------
	Coding: 00CD073000
	ASAM Dataset: EV_GatewPkoUDS 001018
	Subsystem 1 - 	Part No SW: 8T0-915-181
	Component: J367-BDMHellaH03 8041
	Serial Number: 6508419001
	Subsystem 2 -
Address 28: HVAC, Rear  (E265)	Labels: 4G0-919-158.clb
	Part No SW: 4G0 919 158 J	HW: 4G0 919 158 J
	Component: KLIMA FOND    H07 0076
	Coding: 20
	ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	Part No SW: 4G8 959 760 A	HW: 4G8 959 760 A
	Component: MEM-FS        H03 0154
	Revision: AA000000
	Coding: C0581B008F006001000001010101102030303232203232
	VCID: 3833BBE353BC1BF040223E-806D
Address 3B: Sensor Elect.  (J849)	Labels: 4G0-907-637.clb
	Part No SW: 4G0 907 637 K	HW: 4G0 907 637 F
	Component: SARA 6D       H02 0056
	Revision: --------
	ASAM Dataset: EV_SARA2 005012
	ROD: EV_SARA2_005.rod
Address 42: Door Elect, Driver  (J386)	Labels: None
	Part No SW: 4G8 959 793 J	HW: 4G8 959 793 G
	Component: TSG FA        H03 0507
	Revision: --------
	Coding: 011F57024E00628002000402
	VCID: 47D1C81F2E42640839D845-8012
Address 44: Steering Assist  (J500)	Labels: 4G0-909-144.clb
	Part No SW: 4G0 909 144 L	HW: 4G0 909 144 G
	Component: RCEPS         H36 0010
	Revision: 00001000
	Coding: 101000010000
	ASAM Dataset: EV_RCEPS 009008
	ROD: EV_RCEPS_009.rod
	VCID: 322789CBB5C0E9A07EE67C-8067
Address 46: Central Conv.  (J393)	Labels: 4H0-907-064-46.clb
	Coding: 0126023A20FAF00580B00A8402010D070000000000000000000000000000
	Subsystem 1 - 	Part No SW: 4G0-959-719
	Component: GTO BF       H01 0080
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part No SW: 4G8-959-591
	Component: J245 PS40.039H01 H01
	Coding: 101F00
	Subsystem 4 -
	Subsystem 5 -
01403 - Glass-Break Sensors; Rear
Address 47: Sound System  (J525)	Labels: None
	Part No SW: 4G0 035 223 C	HW: 4G0 035 223 A
	Revision: CJ007001
	Coding: 030000
	VCID: 1D7D4A77DC5E5ED8B33417-8048
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Part No SW: 4G8 959 792 J	HW: 4G8 959 792 G
	Component: TSG BF        H03 0507
	Revision: --------
	VCID: 46CFC51B29487D00C2AE50-8013
Address 53: Parking Brake  (----)	Labels: 4H0-907-801.clb
	Part No SW: 4H0 907 801 F	HW: 4H0 907 801 A
	Component: EPB-4         H03 0013
	Revision: --------
	Shop #: WSC 00000 000
	ROD: EV_ParkiBrake_AU57.rod
	VCID: 2B1994AF92EAB8683DA089-807E
333568 - Function Restricted due to Missing Message(s)
	U1111 00 [000] -
334080 - Function Restricted due to Missing Message(s)
	U1111 00 [000] -
331264 - Function Restricted due to Missing Message(s)
	U1111 00 [000] -
331520 - Function Restricted due to Missing Message(s)
	U1111 00 [000] -
331776 - Function Restricted due to Missing Message(s)
	U1111 00 [000] -
460800 - Function Restriction due to Faults in Other Modules
	U1113 00 [000] -
Address 55: Xenon Range  (J431)	Labels: 8X0-907-357.clb
	Part No SW: 4H0 907 357 B	HW: 4H0 907 357 B
	Component: ....LWR12.... H02 0010
	Coding: 1223A6601002A500
	ROD: EV_HeadlRegulBasic.rod
Address 56: Radio  (R)	Labels: None
	Part No SW: 4G0 035 082 E	HW: 4G0 035 082
	Component: Radio U SIRIU H60 0121
	Revision: AB001007
	Coding: 020007010000000001
	VCID: 2207798BE52061208E462C-8077
Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
	Part No SW: 4G0 035 746 D	HW: 4G0 035 746 B
	Component: H-BNT-NA      H50 0622
	Revision: --------
	Coding: 090200040003E1EF45128B3E00000003100001000000000000
	VCID: 28136BA3831C8B70D082EE-807D
	Subsystem 1 - 	Part No SW: 8R0-060-884-BA
	Component: NAR 2013     0703
	Subsystem 2 - 	Part No SW: 4G0-919-605-C
	Component: DU8 C7 SV    H43 0021
	Subsystem 3 - 	Part No SW: 4G1-919-610-C
	Component: E380 BDT C7  H11 0204
	Subsystem 4 - 	Part No SW: 8R0-060-961-E
	Component: CD-Database  4949
Address 62: Door, Rear Left  (J388)	Labels: None
	Part No SW: 4G8 959 795 J	HW: 4G8 959 795 G
	Component: TSG HL        H03 0507
	Revision: --------
	Coding: 010F17024000628002000002
	VCID: 49D5CE27385692782FCC73-801C
Address 6C: Back-up Cam.	Labels: 4H0-907-441.clb
	Part No SW: 4G0 907 441 B	HW: 4H0907441
	Component: SG Rueckfahrkamera   0061
	Revision: --H06---	Serial Number: 525 PA8J2ZG30U
	Coding: 1080013
	VCID: 260F659B89081D00E26EF0-8073
Address 6D: Trunk Elect.  (----)	Labels: None
	Part No SW: 4G8 959 107 R	HW: 4G8 959 107 G
	Component: HDSG-Modul    H13 0043
	Revision: 12013001
	Coding: 0A3305C102
	ASAM Dataset: EV_HDSGAu573 001022
	ROD: EV_HDSGAu573.rod
	VCID: 44CBDF131F745710DCBABA-8011
Address 72: Door, Rear Right  (J389)	Labels: None
	Component: TSG HR        H03 0507
	Revision: --------
Address 8F: Pretension. Front Left  (J854)	Labels: 4H0-980-94x-RGS.clb
	Part No SW: 4H0 980 945 B	HW: 4H0 980 945 C
	Coding: 00060000031F030000030801424CDA010000
	ASAM Dataset: EV_RGS_L 002004
	ROD: EV_RGS_L.rod
	VCID: 312586C7B0C6D2B807FC4B-8064
Address 90: Pretension. Front Right  (J855)	Labels: 4H0-980-94x-RGS.clb
	Part No SW: 4H0 980 946 B	HW: 4H0 980 946 C
	ASAM Dataset: EV_RGS_R 002004
	ROD: EV_RGS_R.rod
Scratching head why it would do that.
Is it particular to 17-Instruments? I.e. does it only happen on that module? Try some others. You don't actually have to make any changes in the other modules, just see if cloud functions are accessible.
Delfin
C?ID=363796
It will be a couple of days before I'll have time to try it again. When I do, I will try some other modules and report back.
Delfin
C?ID=363796
Had time to work on it this afternoon.
For the controller channels that redirect me to the vcds cloud login page, it always happens for those channels.
For every channel, when I click on the cloud function button, I see three messages pop up.
Connecting to vcds cloud
VCDS cloud connection successful!
and then in the lower left corner of the screen I see: waiting for vcds-cloud.com...
For the controller channels that then redirect, it happens right away. I see something that starts with transferring, then another message that starts with reading, and then the login page is displayed.
For the controller channels that work like I expect them to, I see the waiting for vcds-cloud.com... for much longer, and then the actual cloud menu full of buttons is displayed.
I tried every available channel, I certainly don't see any pattern as to which channels work and which ones don't.
Let me know if you want me to try this again with the debug level set higher so there is some log of what messages Firefox sends to the server, and what messages the server sends back.
Controller      Result - ok - cloud functions available
Module          Result - redirect - redirects to vcds cloud login page
01              redirect
02              ok
03              ok
04              Kline timeout error? N/A
05              ok
08              redirect
09              ok
10              redirect
15              redirect
16              ok
17              redirect
19              ok
28              redirect
36              ok
3B              redirect
42              ok
44              redirect
46              ok
47              ok
52              ok
53              redirect
55              redirect
56              ok
5F              ok
62              ok
6C              ok
6D              redirect
72              ok
8F              redirect
90              redirect
04-Steering Angle is not directly accessible. It has an entry in the Gateway Installation List for for internal data routing purposes.
As for the re-directs on the Cloud functions, I'm going have to to defer to Shaun.
Shaun
On the addresses that are redirecting, if you go back and try again do you eventually get in, or do they consistently fail to let you into the main cloud menu?
Delfin
C?ID=363796
They consistently fail. Making that list I tried each channel in order. For the failing ones, I tried each one two or three times before moving on. When I got done with the last channel, I went back to the top of the list and re-tried each of the failing ones again in order, and they still failed.
Shaun
Can you test one of the failing ones again? I tweaked some things last night.
Delfin
C?ID=363796
Unlikely to get a chance to test it until the weekend. Will let you know the results.
No worries. Shaun is out until sometime next week anyway. A friend of his is getting married out west.
Delfin
C?ID=363796
Went through all of the channels again, and have the same result as before. The same set of channels will bring up the cloud functions menu buttons, and the others take me to the VCDS Cloud login page.
Delfin
C?ID=363796
Don't know if this will help. It is a capture of the activity in a Firefox web debugging window for one of the channels where I ended up at the VCDS Cloud login page.
https://imgur.com/a/N348ofQ
Let me know if that link doesn't work.
I was able to reproduce this "Redirect to the login page" here on one at least control module earlier today.
If I can still do it when Shaun is back come mid-week, he'll hopefully be able to track it down.
Shaun
Alright I might have a fix. Can you give this another try when you get the chance and see if it is still happening?
Delfin
C?ID=363796
It's fixed. Tried it this morning and for all channels I was able to bring up the cloud functions menu.
Thanks.
