Lost remote fob function (7L6 Touareg)
   #21
Akron04
C?ID=364043
Are Antennas somehow shared somewhere in TPMS with Kessy in tracks for remote functions or supply?
TPMS deletes for shame dismissed treats?
My search (so far) of the 1000+ page wiring diagram hasn't yet shown that. HOWEVER it appears that the door button switch connectors that I disconnected months ago MAY share the same connector as the door antennas. Tomorrow I will reconnect the front two, since I know one rear one was faulted but can't remember which one. I've been under the belief that for some reason the car can no longer "see" my fobs. There MUST be another antenna(s) or it would not have worked until now.
I am learning A LOT here. Tonight I was pulling fuses, checking them, with the car running. Pulled one of the KESSY fuses, car shut off. TPMS immediately came back on. Hmmm. Found there are two fuses for TPMS, one on each side. I replaced the missing fuse. Found a blown fuse for the aux head lamps 20A, replaced that. Also replaced the radio and amplifier fuses.
Thinking: rerun coding 07 with no changes on CAN 19? See if it finds the KESSY again with ALL the fuses in?
Frankly I don't like living without the radio, I'll have to determine why it was drawing so much power when off. Could be the amp, I never checked to see which one. Could be as simple as the remote on/off control from the radio has a bad wire so the amp just stays on. I'll investigate that further once I sort out this remote issue.
What the hell, the laptop is charged and I'm wide away. I'll go run that CAN coding and see what happens lol. Can't hurt at this point.
Dana: your suggestion of the label file helped immensely for me to understand things a bit better. Thank you!
   #22
Akron04
C?ID=364043
There are antennas all over. Front and rear bumpers, central, luggage rear, two interior, and a couple of others I counted, plus the 4 in the doors which presumably are there to sense the key when it's in your pocket.
Ran auto scan tonight to clear out all the codes I created by pulling fuses. Came up clean afterwards. TPMS light is lit. No code for that, I'll scan again at work tomorrow.
I need to ask the dealer if they tried just flashing back to stock. If not, why not? That would rule out anything I did I would think. I AM learning a lot about this SUV. Interesting stuff. Hoping to get the two front door antenna/button connectors hooked back up tomorrow during the day. We will see what, if anything, that does.
I have it on a charger now, as has been the custom since I bought it a year ago. Oddly no errors for the radio system. However tonight was the first time during a scan it ever showed "Diag." on the MFD.
I have two weeks to sort this out before deciding if I want to go back to the dealer and spend $500 plus in labor. My KESSY IS bad. It makes the clicks and "Shift into P" on the dash from time to time, although that seems to have cleared up since I disconnected the door antenna/button connectors.
There is a KESSY for it on eBay right now for $119. Worth buying? Difficult to program or just plug it in and do the key sync thing? Tempted to just track down a TPMS module but I don't really want TPMS, planning on winter tires on another set of rims, would rather NOT buy 4 more sensors. I check tire pressures every third fill up religiously, always have. I have no need for a TPMS really. Which there was a better option to delete it. Maybe just remove the module?
   #23
I would think you'd need the PIN for the used KESSY. Do you have some means to obtain that?
I really don't think the remote problem is intrinsically related to killing off TPMS. Lots of people have done that on T1s for various reasons (mainly because those first generation TPMS systems were a royal PITA) and I don't recall any other complaints that remotes stopped working as a result.
OP: I can help you get pins or do a data transfer with proper credentials..........
Uwe : Back then, the cars were newer and the antennas or tracks were not as damaged as they are now for water ingress & time for corrosion to do all kinds of wonderful things.
OP: Did you verify that tracks of all antennas are proper and isolate them for Kessy and TPMS?
   #25
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
There are two KESSY variants for this platform. One does true keyless entry (unlock when you touch the door handle) and the lower end one only does remote control where you have to press the button. Can you confirm which you have/had? It's possible during your KESSY recoding adventure that you told it you don't have keyless.
   #26
Akron04
C?ID=364043
I was able to get my pin for the one in the car now. I would assume that if I plugged another one it I could get the pin in the same manner, thru the diagnostic port......
   #27
Akron04
C?ID=364043
Jack,
By credentials I would assume you mean a copy of my title to show proof of ownership?
I have NOT verified TPMS and Kessy separation. I have identified a bunch of antennas for the Kessy though. Both bumpers, a few inside, one in one of the pillars I believe. I think I tracked down about 7 last night scanning thru the wiring diagram.
My Kessy is keyless entry. A function I do not need or care for but would replace with the same part. I found one on eBay, all numbers are the same except no "C" on the very end.
I found a TPMS for $50, I'm going to get that. Worst case I'll just deal with the warning light during the winter on winter tires. Would prefer a full delete however based upon the wiring diagrams everything seems to be very interrelated and it's not likely wise to just remove the module and recode on a car I am trying to get into tip top shape.
What I have learned is that these cars had a lot of new features that are now common on new cars, VW just had some trouble with the execution in these early ones. Mine is in really great overall shape and very low miles. I want it to last me awhile, at least a few years, at which point I'd like a newer Q7 V8.
   #28
Akron04
C?ID=364043
I've ordered a TPMS module and a Kessy module. Worst case I can pull my existing Kessy and do the diode repair I have seen on Club Touareg. I happen to have the right tools to do that (electronic soldering equipment).
Meanwhile I'm going to keep plugging away at this one. Mainly reading the wiring diagrams to make sense of how it all ties together. Haven't gotten to the door antennas yet today. Too busy at work. Hoping to do that right after work.
   #29
Jack,
Yes drivers license & registration and or title to correlate the owner record of custodial care proof.
   #30
Aitrui
planet earth
C?ID=277621
I just noticed this thread, I'm in the same situation as you, but with a VW phaeton. Not the same kessy, but very close.
After I did auto scan and clear all fault code, I lost remote funcionality. The car still in the shop, I did try everything I can, to learn back the remote, but there is no way in this state it's possible.
I can't even learn a second key to the kessy,but it had 2 working key before. I tried it with pin, over Gekko, no joy.
I'm pretty sure the remote was working, because I opened it with a remote, sat in, did a scan as I always do when customer drops off the car, and after I was done,remote was gone.
I did not think VCDS caused this till I saw this thread, I was thinking how unlucky I'm again, and how these stupid VW immo system fuxx me over most of the time.
A used kessy on the way, but i will investigate more after reading this....
Attached autoscan. Don't mind the errors, the car came in for repair.
Wednesday,13,March,2019,10:55:11:10366
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
Workshop Code: 332 00001 000022
VIN: WVWZZZ3DZ    License Plate: PHAETON
Mileage: 229550km-142635mi   Repair Order:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN:    Mileage: 229550km-142635miles
   Part No SW: 3D0 907 401 A    HW: 8E0 907 401 AB
   Component: 3.0L V6TDI  G000AG  0010
   Revision: --H01---    Serial number: VWZ3Z0F1562086
   Coding: 0011773
   Shop #: WSC 80093 222 69422
   VCID: 1D7211D7C599B0A2D6-5160
012697 - Control Circuit for Intake Manifold Runner (Bank2)
               P3199 - 002 - Implausible Signal - Intermittent
                    Mileage: 229556 km
                    Torque: 167.7 Nm
                    Voltage: 12.16 V
                    Duty Cycle: 84.8 %
                    Duty Cycle: 0.4 %
                    Duty Cycle: 20.5 %
008209 - Intake Manifold Flap; Bank 2
               P2011 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 229556 km
                    RPM: 693 /min
                    Torque: 54.6 Nm
                    Voltage: 11.86 V
                    Duty Cycle: 80.9 %
                    Duty Cycle: 7.9 %
                    Duty Cycle: 80.9 %
   Part No SW: 09L 927 760 J    HW: GS1 911 4
   Component: AG6 09L 3,0 TDI RdW 2806
   Revision: --H01---    Serial number:        4273271
   Coding: 0000001
   VCID: 3E30F65B685FCBBAEF-5160
002069 - Upshift Switch Circuit for Tiptronic (F189)
               P0815 - 001 - Electrical Malfunction - Intermittent
                    Fault Status: 00100001
                    RPM: 800 /min
                    RPM: 800 /min
                    (no units): 23.0
                    (no units): 21.0
                    Temperature: 83.0°C
                    T.B. Angle: 0.0°
002309 - Gate Select Position Circuit for Tiptronic (F189)
               P0905 - 000 - Implausible Signal - Intermittent
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008356
   Shop #: WSC 75337 000 00000
   VCID: 6B960F0F4BAD8E1218-51CE
            000 -  -  - Intermittent
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406418    Serial number: VWZ3Z0F1562086
   Coding: 0004328
   Shop #: WSC 01065 000 00000
   VCID: 281C30039ADB650AB5-5160
00087 - Terminal 30 for Starting Relevant Consumers
00172 - Key 2 not learned
            008 - Implausible Signal
01176 - Key
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1720
   Coding: 0000003
   VCID: 77BE237F07E53AF2EC-5160
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 007 AR
   Component:    ZAB COCKPIT      0253
   Coding: 0400725
   VCID: 699A750741519C026A-5160
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 J
   Component: Climatronic D1      2031
   Coding: 0000001
   VCID: 25023937EDC978628E-5160
00716 - Air recirculation Flap Positioning Motor (V113)
            014 - Defective
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 L    HW: 3D0 937 049 L
   Component: J519                6200
   Revision: -4003---    Serial number: --------------
   Coding: 600200002B2115000000000000000000
   Shop #: WSC 33316 133 59432
   VCID: 3326D76F531D16D210-5160
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 E
   Component: 0J Airbag 8.4E+ H12 0935
   Coding: 0012362
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Component: Lenksäulenmodul     3401
   Coding: 0000232
   VCID: 2F2EDB1FBF35323274-5160
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No: 3D0 920 885 A
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0022111
   Part No: 3D0 815 005 AA
   Component: Standheizung        2426
   Shop #: WSC 45555 125 45725
   VCID: 5CF45CD39E03F9AAE1-5160
01415 - Recirculating Pump (V55)
            010 - Open or Short to Plus
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
   VCID: 70AC1863628B6DCA2D-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000001
   VCID: 66807E3B504FB37A47-5184
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Shop #: WSC 00999 444 64523
   VCID: 271E333F97C56A72BC-5160
01598 - Drive Battery Voltage
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1720
   Coding: 0000004
   VCID: 6FAE1B1F7FB5723234-5160
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 JX
   Component:    NAVIGATION       0188
   Coding: 0400000
   Shop #: WSC 75337 150 179924
   VCID: 136677EF335DF6D270-5160
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 C
   Component: Dachmodul           0708
   Coding: 0000015
   VCID: 2306272FE3FD8652E0-5160
00220 - Connection to Sunroof
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
00926 - Terminal 30
00198 - Automatic Day/Night Interior Mirror (Y7)
00403 - Sunroof Motor (V1)
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000001
   VCID: 679E733F5745AA727C-5160
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: X3 HSG              0102
   Coding: 0000040
   Shop #: WSC 00046 000 00000
   VCID: 3326D76F531D16D210-4B1E
   Subsystem 1 - Part No: 3D1 959 701 L
   Component: Tuersteuergeraet FS 6001
   Subsystem 2 - Part No: 3D1 959 702 L
   Component: Tuersteuergeraet BF 6001
   Subsystem 3 - Part No: 3D0 959 703 K
   Component: Tuersteuergeraet HL 6001
   Subsystem 4 - Part No: 3D0 959 704 K
   Component: Tuersteuergeraet HR 6001
   Subsystem 5 - Part No: 3D0 909 610 A
   Component: 3G HDSG             2320
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
01134 - Alarm Horn (H12)
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 3D0 035 465 A
   Component: 08K-AUDIOVERST      0112
   VCID: 1F0E2BDFCF95A2B2C4-5160
Address 65: Tire Pressure        Labels: None
   Part No: 3D0 907 273
   Component: Reifendruckueberw.  0018
   Coding: 0010324
   Shop #: WSC 17301 666 36123
   VCID: 6386672FA37DC652A0-5160
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D1 955 119 A
   Component: Front Wiper         2005
00155 - Driver-Passenger Side Control Module Communication
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 24042433E6F3816A99-5160
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 D
   Component: 01 Einparkhilfe     0907
   VCID: 2B16CF0F8B2D4E1258-5160
Address 77: Telephone        Labels: 3W7-035-385.lbl
   Part No SW: 3W7 035 385 H    HW: 3W7 035 385 H
   Component: UHV Premium rSAP    0037
   Coding: 0002320
   VCID: 41CA8DA719A1B44292-5160
End----(Elapsed Time: 08:14, VBatt start/end: 11.7V/11.6V. VIgn 0.0V)------
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 18: DTCs cleared
Address 19: DTCs cleared
Address 29: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 39: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 65: DTCs cleared
Address 68: DTCs cleared
Address 71: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
Akron04
C?ID=364043
AItrui,
Seems we are in the same boat. Incidently I DID clear my codes and that was when the trouble started. That would not be a VCDS issue since I would think any diag product that can erase codes would do the same.
There is a clue in my first scan post. Under KESSY. Something about not having a baseline on the remotes. I am suspicious the car was in "limp" mode for the remotes and clearing the code changed that.
On a lark I had my remotes tested today. Both fully functional with full battery voltage. Still no luck.
Since I have not much to lose at this point but potentially a fortune to save at the dealer I am very tempted to flash 05's coding 07 to a non keyless system. My theory being this will freak out the ECU lol. Cause it to reset something internally. Then code back to my current code and see what happens. Worst case I trigger Immo and I fix that with my key pin. Best case the remotes start working. Likely case: nothing happens lol.
   #32
Aitrui
planet earth
C?ID=277621
To make things interesting, I did a auto scan on a nearly same phaeton, some day before, but didn't cleared the fault codes when the autoscan was done. I had to do injector seals, and DPF service regen, and I like to do that with oem tool, that's why I never used VCDS on this car to erase the fault codes, I did it with oem tool!
It's also still in the shop, and the remote still work. I could easly find out if VCDS doing this for sure, I just have to do an auto scan with fault clear in the end, and we will see. :rolleyes: Used kessys are cheap, if vcds covering the used part cost (if it dies, I can video the whole opening the car,etc... ), I can try it tomorrow.It will be fun either way, the suspens will kill me while waiting there for 8!! minutes to finnish the thing. Oh god, I hate old cars... :)
Attached autoscan also.
Monday,11,March,2019,13:03:11:10366
VIN: WVWZZZ3DZ   License Plate: PHATEON_2
Mileage: 302490km-187958mi   Repair Order:
VIN: WVWZZZ3DZ78004301   Mileage: 302490km-187958miles
   Revision: --H01---    Serial number: VWZ3Z0G1600201
   Coding: 0011773
   Shop #: WSC 11255 455 45725
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 001 - Restricted/Clogged - MIL ON
                    Fault Status: 11100001
                    Mileage: 302490 km
                    Torque: 0.0 Nm
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 001 - Open Circuit
                    Fault Status: 01100001
                    Mileage: 302490 km
                    RPM: 1029 /min
                    Torque: 171.6 Nm
                    Duty Cycle: 12.0 %
                    Voltage: 14.36 V
                    Duty Cycle: 18.9 %
                    Temperature: 10.8°C
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 001 - Open Circuit
                    Mileage: 302490 km
                    RPM: 1029 /min
                    Torque: 171.6 Nm
                    Duty Cycle: 12.0 %
                    Voltage: 14.36 V
                    Duty Cycle: 18.9 %
                    Temperature: 10.8°C
005662 - Glowplug for Cylinder 5 (Q15)
               P161E - 001 - Open Circuit
                    Mileage: 302490 km
                    RPM: 1029 /min
                    Torque: 171.6 Nm
                    Duty Cycle: 12.0 %
                    Voltage: 14.36 V
                    Duty Cycle: 18.9 %
                    Temperature: 10.8°C
Readiness: 1 1 0 0 0
   Revision: --H01---    Serial number:        4315190
   Coding: 0000001
   Coding: 0008356
   Revision: 68406418    Serial number: VWZ3Z0G1600201
   Coding: 0004328
00956 - Key 2
   Coding: 0400425
00857 - CD Changer Unit (R41)
            003 - Mechanical Failure
   Coding: 0000001
   Part No SW: 3D0 937 049 M    HW: 3D0 937 049 M
   Component: J519                6500
   Revision: -4004---    Serial number: --------------
   Coding: 600100002B211D010000000000000000
   VCID: 3424D473561311EA09-5160
   Component: 0H Airbag 8.4E+ H12 0935
   Coding: 0012360
   Part No: 3D0 953 549 D
   Coding: 0000031
   VCID: 2E10C61BB83F3B3A7F-5160
01750 - Multi-Function Switch in Steering Wheel (E440); Left
   Coding: 0021111
   Part No: 3D0 815 005 AG
   Shop #: WSC 64441 124 1048576
   VCID: 6288622BBC67CF5AAB-5160
01406 - No Flame
            007 - Short to Ground
00664 - Fuel gauge
   Coding: 0000006
   Part No: 3D0 909 157 A
   Coding: 0000001
   VCID: 271E333F97C56A72BC-5184
   Coding: 0005521
   Coding: 0400000
   VCID: 3B36FF4F7B4DDE92C8-5160
00625 - Vehicle Speed Signal
   Part No: 3D0 907 135 D
   Component: Dachmodul           0802
   Coding: 0000057
   Part No: 3D0 909 158 A
   Coding: 0000001
   VCID: 281C30039ADB650AB5-5184
   Coding: 0000040
   Shop #: WSC 64441 124 00000
   Subsystem 1 - Part No: 3D1 959 701 G
   Subsystem 2 - Part No: 3D1 959 702 G
   Subsystem 3 - Part No: 3D0 959 703 G
   Subsystem 4 - Part No: 3D0 959 704 G
   Subsystem 5 - Part No: 3D0 909 610 C
   Component: 3L HDSG             2330
00984 - Left Tail Light (M4)
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D1 955 119 B
   Component: Front Wiper         2306
   Coding: 0015669
   Shop #: WSC 01065 000 376832
   Part No SW: 3W7 035 385 P    HW: 3W7 035 385 P
   Coding: 0002320
   VCID: 49DA958721917C024A-5160
End-(Elapsed Time: 08:31, VBatt start/end: 14.8V/14.8V. VIgn 0.0V, udsna)--
Aitrui
planet earth
C?ID=277621
AItrui,
It's not coding for sure. You can try it, you can't make things worse, but it will not solve your problem.
I don't know yet what happening, but just think about it, nearly same kessy system, both had key errors, and after auto scan and fault clearing, both lost remote functions, and we met here at the VCDS forum.
   #34
Akron04
C?ID=364043
It does seem strange! MY initial scan was full of codes, mostly from the constantly drained battery. But I did have these codes in that scan:
Address 05: Acc/Start Auth.        Labels: None   Part No SW: 7L0 909 137 C    HW: 7L0 909 137 C   Component: 1W Kessy            6850     Revision: 00H22071    Serial number: VWZ3Z0D7160299   Coding: 0147688   Shop #: WSC 26071 444 85803   VCID: 33331EE3172BFEAF53F-5160
   Subsystem 1 - Part No: XXXXXXXXXXX    Component: ELV                 XXXX
4 Faults Found: 00003 - Control Module         012 - Electrical Fault in Circuit         Freeze Frame:                Fault Status: 01101100                Fault Priority: 2                Fault Frequency: 0                Reset counter: 252                Time Indication: 0                Date: 2000.00.00                Time: 22:02:06
00668 - Supply Voltage Terminal 30         002 - Lower Limit Exceeded - Intermittent         Freeze Frame:                Fault Status: 00100010                Fault Priority: 2                Fault Frequency: 1                Reset counter: 231                Time Indication: 0                Date: 2000.00.00                Time: 13:36:48
00087 - Terminal 30 for Starting Relevant Consumers         002 - Lower Limit Exceeded - Intermittent         Freeze Frame:                Fault Status: 00100010                Fault Priority: 2                Fault Frequency: 1                Reset counter: 231                Time Indication: 0                Date: 2000.00.00                Time: 13:36:50
01299 - Diagnostic Interface for Data Bus (J533)         005 - No or Incorrect Basic Setting / Adaptation - Intermittent         Freeze Frame:                Fault Status: 00100101                Fault Priority: 3                Fault Frequency: 14                Reset counter: 231
What sticks out to me is that last one, No or incorrect basic setting / Adaptation - Intermittent. The way these Kessy's sync keys is when you start the car with them. Which, quite frankly is the way ALL cars should be for remote sync. But if I read that code right it's as if the adaptation (sync) is not working correctly. Hence using my OLD sync to keep the remotes working until the problem is fixed ie "limp home". Clear the codes, that went away and SO DID the remote functionality.
Call me crazy but, to me at least, it is very odd that it worked before I did anything with a VCDS and does not work now. Granted there were problems. Granted I'm putting in a new used Kessy to solve it and hopefully the door button issue, but still, what would/could VCDS do that would cause the kessy remote adaptation to stop working.
For my keys the 7 bit codes are 1100000 should be 1101000, bit 4 meaning it's synced. Very simply the keys refuse to sync. They will sync up with Immo no problem. In fact with the WRONG coding (for a non keyless 6-speed) I just sync'ed up all three, my dealer neglected to do my valet key. So twice now with VCDS I have successfully sync'ed up to Immo but cannot sync up to remote. And the keys test postive for signals, so it's unlikely the keys.
   #35
Akron04
C?ID=364043
I fixed it!!!!
Confirming how I did it now. Will post back shortly. Running a scan. Then going to try and disable TPMS again, clear codes, and see if problem repeats itself.
The main trick, what I think actually worked, is very interesting.
   #36
Akron04
C?ID=364043
Well I coded 05 07 to 0006376 for non keyless 6 speed auto. Then tonight for some odd reason I decided to put a key on in the ignition, lock the door with the other, unlock it while holding down the unlock button then release and hold again. Got a chirp! Did the other key, same thing. Swapped 05 07 back to my original 0147688. Keys still worked.
Ran a scan, lost them again.
Had a code in 05 for intermittent short.
Its not taking the keys again.
I've cleared TPMS. Went back to 0006376, did the key thing. No luck. Back on 0147688 now and clearing DTCs. We will see.
Maybe I got lucky for a moment and caught it while the connection was good? No clue. Going to try the key trick again after codes clear.
If that doesn't work it looks like pull the kessy and check its contacts.
My first scan had some codes I haven't seen lately. Ill post it and the after one here in a bit. In the car now clearing codes.
   #38
Hmmm maybe the car is having hot flashes being an older lady or hot & bothered and needs a special massage from having a "wet kessy" being temperamental with no one to push its remote button proper?
   #39
Akron04
C?ID=364043
Jack you may not be far off the mark about the wet kessy. The day I picked up the car it was pouring rain. That night I got a flat and discovered about an inch of water in the tire well. Dried it all up. Traced the leak to a poor rear hatch strut repair. Same time the ride control module died, it was soaked. As well as a sensor back there. I forget which one it was. Cleaned terminals. Put in new parts. All of that worked fine since. Soon after I cleared out the sunroof drains and hood drains. The car smelled musty. Was very humid inside for some time I believe. Detailing fixed that but I will BET I will find some corroded contacts on this journey.
Here's the weird thing. It took the keys when it had this code:
Kessy:
00003 Control module
012 - electrical fault in circuit
Charging my laptop. I can post the full thing later.
I wonder if that code puts it in limp? And in limp it accepted the keys?
No clue but I am on a mission here! Making progress. Its in the kessy. There will be another here in less than a week. But I'd love to fix this one and put that one on the shelf. TPMS too.
   #40
Akron04
C?ID=364043
Kessy code:
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 Version: Beta 19.1.2 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000
Diagnostic Trouble Code Report Thursday,21,March,2019,17:52:11:59747
VIN:    License Plate: Mileage:    Repair Order:
Control Module Part Number: 7L0 909 137 C    HW: 7L0 909 137 C  Component and/or Version: 1W Kessy            6850           Software Coding: 0147688            Work Shop Code: WSC 26071 444 85803                      VCID: 33331EE3172BFEAF651-5160           Additional Info: XXXXXXXXXXX ELV                 XXXX              Additional Info: Geraet 85803
00003 - Control Module             012 - Electrical Fault in Circuit             Freeze Frame:                    Fault Status: 01101100                    Fault Priority: 2                    Fault Frequency: 0                    Reset counter: 61                    Time Indication: 0                    Date: 2000.00.00                    Time: 05:08:10
"Working" code. It stopped working right after this scan:
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Beta 19.1.2(x64) Data version: 20190131 DS301.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Thursday,21,March,2019,21:30:38:59747
VIN: WVGCM77L14D062138   License Plate: CDS001-FIX Mileage: 165910km-103091mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006)) Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGCM77L14D062138   Mileage: 165910km-103091miles ------------------------------------------------------------------------------Address 01: Engine        Labels: 077-907-560-AXQ.lbl   Part No SW: 4D0 907 560 DA    HW: 8E0 907 560    Component: 4.2L V8/5V      G   0050     Coding: 0007875   Shop #: WSC 05246 444 58887   VCID: 6889B98F1E6D4D77003-5160
No fault code found. Readiness: 0000 0001
------------------------------------------------------------------------------Address 02: Auto Trans        Labels: 09D-927-750.clb   Part No: 09D 927 750 BG   Component: AL 600 6Q           0579     Coding: 0004153   Shop #: WSC 26085 444 84534   VCID: 74B1DDFF52A5B997BCB-5160
------------------------------------------------------------------------------Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl   Part No: 7L0 907 379 D   Component: ESP ALLRAD MK25     0108     Coding: 0014593   Shop #: WSC 31414 000 00000   VCID: 3A2D33C730410FE7A67-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,21:30:38:59747 Page 2
Address 05: Acc/Start Auth.        Labels: None   Part No SW: 7L0 909 137 C    HW: 7L0 909 137 C   Component: 1W Kessy            6850     Revision: 00H22071    Serial number: VWZ3Z0D7160299   Coding: 0147688   Shop #: WSC 26071 444 85803   VCID: 33331EE3172BFEAF651-5160
1 Fault Found: 00003 - Control Module         012 - Electrical Fault in Circuit         Freeze Frame:                Fault Status: 01101100                Fault Priority: 2                Fault Frequency: 0                Reset counter: 69                Time Indication: 0                Date: 2000.00.00                Time: 09:17:34
------------------------------------------------------------------------------Address 06: Seat Mem. Pass        Labels: None   Part No: 7L0 959 760    Component: Sitzverstellung     0701     Shop #: WSC 00000 000 00000   VCID: 77ABEAF343D3D28F999-5160
------------------------------------------------------------------------------Address 08: Auto HVAC        Labels: 7L6-907-040.clb   Part No: 7L6 907 040 H   Component: CLIMAtronic R/L   X 3716     Coding: 0000030   Shop #: WSC 31414 000 00000   VCID: 353720FB195FE09F4B5-5160
1 Fault Found: 01592 - Air Quality Sensor (G238)         014 - Defective
VCDS Self-Diagnosis Log Thursday,21,March,2019,21:30:38:59747 Page 3
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb   Part No: 7L6 937 049 K   Component:                     2703     Coding: 0105948   Shop #: WSC 03128 444 45725   VCID: 44D14D3F42854917CCB-5160
2 Faults Found: 00907 - Intervention load Management         000 - 01299 - Diagnostic Interface for Data Bus (J533)         013 - Check DTC Memory - Intermittent
------------------------------------------------------------------------------Address 15: Airbags        Labels: 3D0-909-601.lbl   Part No: 3D0 909 601 C   Component: 05 Airbag 8.4E++H01 0352     Revision: BB36963     Serial number: 00010123         Coding: 0012341   Shop #: WSC 31414 000 00000   VCID: 2313EEA3A7CB6E2F951-5160
   Subsystem 1 - Part No: 7L0 959 339 B   Component: BF-Gewichtsens. 005 0006
------------------------------------------------------------------------------Address 16: Steering wheel        Labels: 7L6-953-549.lbl   Part No: 7L6 953 549 D   Component: Lenksäulenmodul     3301     Coding: 0000022   Shop #: WSC 31414 000 00000   VCID: 40D9412F569D5537E83-5160
------------------------------------------------------------------------------Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl   Part No: 7L6 920 980 M   Component: KOMBIINSTRUMENT RB8 2935     Coding: 0005231   Shop #: WSC 26085 444 84534   VCID: 42DD4B2758914727FE7-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,21:30:38:59747 Page 4
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl   Part No: 6N0 909 901    Component: Gateway K<>CAN      0101     Coding: 0000006   Shop #: WSC 31414 000 00000   VCID: 70B9D1EF26BD85B7583-5160
------------------------------------------------------------------------------Address 1C: Position Sensing        Labels: 7L6-919-879.lbl   Part No: 7L6 919 879    Component: JCI PathPoint       1700     Shop #: WSC 00000 000 00000   VCID: 04518D3F020589178CB-5160
------------------------------------------------------------------------------Address 22: AWD        Labels: None   Part No: 0AD 927 755 BE   Component: TRANSFERCASE        0122     Shop #: WSC 00000 000 00000   VCID: 7F5B02D36BE3EACFD19-5160
------------------------------------------------------------------------------Address 29: Left Light        Labels: 3D0-909-157.lbl   Part No: 3D0 909 157    Component: EVG GDL+AutoLWR(l)  X012     Coding: 0000003   Shop #: WSC 31414 000 00000   VCID: 6695B7B714795B0732F-5184
1 Fault Found: 00492 - Body Pitch Angle from Level Control Module         008 - Implausible Signal - Intermittent
------------------------------------------------------------------------------Address 34: Level Control        Labels: 7Lx-907-553-34.clb   Part No: 7L0 907 553 F   Component: LUFTFDR.-CDC- 3C3P1 3081     Coding: 0015521   Shop #: WSC 31414 000 00000   VCID: 363527F70459EB8742F-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,21:30:38:59747 Page 5
Address 36: Seat Mem. Drvr        Labels: None   Part No: 7L0 959 760    Component: Sitzverstellung     0701     Shop #: WSC 00000 000 00000   VCID: 77ABEAF343D3D28F999-5160
------------------------------------------------------------------------------Address 37: Navigation        Labels:    VCID: 55F7807BBC0FC09FAB5-FFFE
------------------------------------------------------------------------------Address 39: Right Light        Labels: 3D0-909-158.lbl   Part No: 3D0 909 158    Component: EVG GDL+AutoLWR(r)  0001     Coding: 0000003   Shop #: WSC 62108 001 1048576   VCID: 678BBAB31373420F099-5160
------------------------------------------------------------------------------Address 46: Central Conv.        Labels: 7L0-959-933.lbl   Part No: 7L0 959 933 E   Component: 2M HSG              0201     Coding: 0000085   Shop #: WSC 03128 444 45725   VCID: 3E253FD72C6923C79AF-4B1E
   Subsystem 1 - Part No: 7L0 959 701 B   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 B   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 B   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 B   Component: Tuersteuergeraet HR 0201
VCDS Self-Diagnosis Log Thursday,21,March,2019,21:30:39:59747 Page 6
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl   Part No: 7L6 035 466    Component: 12K-AUDIOVERST      0108     Shop #: WSC 00000 000 00000   VCID: 71BFD4EB2DB78CBF57D-5160
1 Fault Found: 00872 - Bass Speaker Rear Left (R15)         011 - Open Circuit
------------------------------------------------------------------------------Address 56: Radio        Labels:    VCID: 55F7807BBC0FC09FAB5-FFFE
------------------------------------------------------------------------------Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl   Part No: 7L6 907 273    Component: Reifendruckueberw.  0052     Coding: 0210390   Shop #: WSC 26085 444 57660   VCID: 75B7E0FB59DFA09F8B5-5160
1 Fault Found: 01521 - Sensor for Tire Pressure         004 - No Signal/Communication - Intermittent - MIL ON
------------------------------------------------------------------------------Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb   Part No: 7L0 955 119 F   Component: Front Wiper         2416     Coding: 0000004   Shop #: WSC 31414 000 376832   VCID: 372B2AF30353128F599-5160
------------------------------------------------------------------------------Address 6E: Ctrl Head Roof        Labels: None   Part No: 7L6 919 044 F   Component: DACHDISPLAY         0530     Revision: 00600530    Serial number: 2009289.02       Shop #: WSC 31414 000 00000   VCID: 3A2D33C730410FE7A67-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,21:30:39:59747 Page 7
Address 76: Park Assist        Labels: None   Part No: 7L0 919 283 E   Component: 0E Einparkhilfe     0907     Shop #: WSC 00000 000 00000   VCID: 382929CF0E4D1DF7503-5160
End----------(Elapsed Time: 09:20, VBatt start/end: 13.9V/13.8
After clearing:
Self-Diagnosis Log Thursday,21,March,2019,22:03:43:59747
VIN: WVGCM77L14D062138   License Plate: NF CODES CLEAR Mileage: 165910km-103091mi   Repair Order:
VCDS Self-Diagnosis Log Thursday,21,March,2019,22:03:43:59747 Page 2
1 Fault Found: 01592 - Air Quality Sensor (G238)         014 - Defective - Intermittent
------------------------------------------------------------------------------Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb   Part No: 7L6 937 049 K   Component:                     2703     Coding: 0105948   Shop #: WSC 03128 444 45725   VCID: 44D14D3F42854917CCB-5160
1 Fault Found: 00907 - Intervention load Management         000 -
VCDS Self-Diagnosis Log Thursday,21,March,2019,22:03:43:59747 Page 3
1 Fault Found: 01325 - Control Module for Tire Pressure Monitoring (J502)         004 - No Signal/Communication - Intermittent
------------------------------------------------------------------------------Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl   Part No: 6N0 909 901    Component: Gateway K<>CAN      0101     Coding: 0000006   Shop #: WSC 31414 000 00000   VCID: 70B9D1EF26BD85B7583-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,22:03:43:59747 Page 4
------------------------------------------------------------------------------Address 36: Seat Mem. Drvr        Labels: None   Part No: 7L0 959 760    Component: Sitzverstellung     0701     Shop #: WSC 00000 000 00000   VCID: 77ABEAF343D3D28F999-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,22:03:43:59747 Page 5
------------------------------------------------------------------------------Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl   Part No: 7L6 035 466    Component: 12K-AUDIOVERST      0108     Shop #: WSC 00000 000 00000   VCID: 71BFD4EB2DB78CBF57D-5160
VCDS Self-Diagnosis Log Thursday,21,March,2019,22:03:43:59747 Page 6
------------------------------------------------------------------------------Address 76: Park Assist        Labels: None   Part No: 7L0 919 283 E   Component: 0E Einparkhilfe     0907     Shop #: WSC 00000 000 00000   VCID: 382929CF0E4D1DF7503-5160
End----------(Elapsed Time: 09:21, VBatt start/end: 13.8V/13.9V)-
Some of those codes I have not seen before and/or I only have seen them when I had the battery drain problem, which is likely back because a fan or motor in the radio doesn't turn off.
Not understanding why a VCDS scan would knock out my remotes AGAIN? I got them working. Coded back to my original KESSY coding, shut it down, remotes still worked. Fired it up, ran a scan, remotes quit. Strange indeed!
