A lot of codes, relating to voltage, even in the engine
Jpnankervis
Ecuador
Hi
Im breaking my brain over the amount of codes my Skoda Octavia VRS 2.0 TFSI has, specially regarding voltage.
Below are the codes. I just replaced the battery, with a new and more powerfull if you could call it. So I think the issue might have to do with wiring at this point. But I have no idea where to start. Any ideas will help. Codes below are just a couple but the ones Im more interested in fixing. They are all related to electric issues (interminent communication) in the inmobilizer, radio, etc.
              Thursday,14,March,2019,18:27:34:06158
VCDS Version: Release 18.9.1 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1Z0 907 115 D    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0010
           Software Coding: 0203000318070060
            Work Shop Code: WSC 73430 790 00000
                      VCID: 364DC10C415F73FA37-8062
               P0299 - 002 - Control Range Not Reached
                    Fault Status: 01100010
                    Mileage: 70825 km
                    Time: 12:46:55
                    RPM: 6175 /min
                    Load: 58.8 %
                    Speed: 87.0 km/h
                    Temperature: 90.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 750.0 mbar
                    Voltage: 13.970 V
012555 - Low Pressure Fuel regulation
               P310B - 004 - Fuel Pressure Outside Specification - Intermittent
                    Mileage: 70890 km
                    Time: 18:25:25
                    RPM: 5850 /min
                    Load: 61.9 %
                    Speed: 157.0 km/h
                    Temperature: 89.0°C
                    Temperature: 35.0°C
                    Voltage: 13.716 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - Intermittent
                    Mileage: 71186 km
                    Time: 13:28:41
                    RPM: 1349 /min
                    Load: 25.5 %
                    Speed: 12.0 km/h
                    Temperature: 90.0°C
                    Temperature: 39.0°C
                    Voltage: 13.970 V
Readiness: 0000 0001
Thursday,14,March,2019,18:29:26:06158
                Address 15: Airbags       Labels: 1K0-909-605.lbl
Control Module Part Number: 1K0 909 605 T    HW: 1K0 909 605 T
  Component and/or Version: Q1 AIRBAG VW8   020 2300
           Software Coding: 0020785
                      VCID: 3D5FDE206469A0A2F6-8068
            002 - Lower Limit Exceeded - Intermittent - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
South Molton, UK
It would be a lot easier to help if you post a FULL UNEDITED Auto-Scan.
