Tuesday,12,March,2019,21:20:43:63906
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 18.9.1.0 HEX-NET : 0.4437.4
VIN: WAUZZZ8V6H1018992 License Plate:
Mileage: 47024km-29219mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F BB BC
VIN: WAUZZZ8V6H1018992 Mileage: 47024km-29219miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CHZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 AB HW: 04C 907 309 AE
Component: R3 1.0l TFS H25 3494
Revision: W1H25---
Coding: 02250032232401083000
Shop #: 06385 790 00016
Dataset: EV_ECM10TFS01104C906026AB 002006
ROD: EV_ECM10TFS_VW37.rod
VCID: 618AADCE70B00842B2-8034
CAN Converter 01:
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 049 M HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0902
Revision: 00005026 Serial number: CU501608145951
Shop #: 17734 418 534600
Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 47DE5356FE5456725C-8012
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 AR HW: 5Q0 614 517 AG
Component: ESC H62 0642
Revision: 00000000 Serial number: 62206000000379
Coding: 13F18AA22421127489800E0980C525C8512448917001A472022100040208420000000012121212B835351919323200
Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
VCID: 014A8D4E90F0A842D2-8054
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0414425164
Coding: 030C0C
Shop #: 00000 000 00000
Dataset: EV_KessyHellaMQBAB 002019
VCID: 3B363FA6B29C0292C8-806E
Part No SW: 8V0 820 043 M HW: 8V0 820 043 M
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001020885
Coding: 03100003110000001000000000001400
Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 3C343CBAB79205AAC1-8068
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: A7A8044800PAG0MUFU03
590082 - Control Circuit for A/C Compressor
B10A9 15 [008] - Open or Short to Plus
Reset counter: 16
Compressor shut-off requirement: Engine running time too short: engine start not detected by CAN
Compressor current: specified value: 0.000 A
Voltage terminal 30: 12.1 V
Outside air temperature: 40 °C
Engine speed: Measured value not available
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: MQBAB M+ H34 0236
Serial number: 02001623201269
Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7EB0F6B2E10ED7BAAF-802A
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160717 043 0585
Serial number: 160727145509
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62174594
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - H05 0032
Serial number: 25 05 2016 00001162
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 HW: 5QA 919 283
Component: 4 KanalH07 0031
Serial number: 000308419616217
Coding: 0700040011
Dataset: EV_EPHVA14AU3700000 009027
ROD: EV_EPHVA14AU3700000.rod
VCID: 075E9356BED496729C-8052
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR23ELZI
Coding: 98CCC000000000005C54000000C800000065
Dataset: EV_AirbaVW20SMEVW37X 002154
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 106CB80ACB9AD1CA4D-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 908 16
Serial number: 357000000000EAB08D1T
Subsystem 2 - Part No SW: ----------- HW: 480 001 908 16
Serial number: 35800000000D7031CD1N
Subsystem 3 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 35100019B20F2B25F354
Subsystem 4 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 35200019B20F2B2422C/
Subsystem 5 - Part No SW: ----------- HW: 480 400 408 16
Serial number: 3550002B521FBE81D05F
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Revision: -------- Serial number: 20081604400272
Coding: A018
Dataset: EV_SMLSKLOMQB 020002
VCID: 0D52A17EDCA8FC22A6-8058
Part No SW: 8V0 920 872 N HW: 8V0 920 872 N
Component: KOMBI H04 8316
Coding: 27A41A182A8000080100A8001001000000000000
Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 48DC506AF34A590A55-801C
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW High 212 2265
Revision: -------- Serial number: 20081610801387
Coding: 030100043F0857005B000248100B00000001010000000000000000000000
Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CB4FCBAF712C5AA81-8028
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20160824074456 20155
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001608174846
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Fault Frequency: 173
Reset counter: 15
Mileage: 29847 km
Date: 2018.06.22
Time: 01:09:46
Supply voltage: Terminal 30: 12.2 V
Terminal 15: OFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000140221002
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3424149A9FC2CDEA09-8060
Component: FS 020 0041
Serial number: 080816EH709593
Coding: 001C1B205C01040000001002
Dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43C64746CA6C7A5280-8016
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 45C2595EC4584462AE-8010
Component: BFS 020 0041
Serial number: 050816EH514021
Coding: 001C13205E01040000001002
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 42C84242D576735A8B-8016
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: - 001 0230
Coding: 0ECE00102B200200
Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E3036B2A18E17BAEF-806A
Part No SW: 81A 035 824 HW: 81A 035 824
Component: MU-S--ER 710 0740
Coding: 01730100FF00000011110001000A00002F0024060170010002
Dataset: EV_MUStd6C3DELP 001013
ROD: EV_MUStd6C3DELP_AU37.rod
VCID: 608CA8CA7BBA014ABD-8034
Subsystem 1 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY20722V
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 BB HW: 8V0 919 614 BB
Component: ControlUnit_B H50 0103
Serial number: ALJAL106051600020209
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: HFS 020 0041
Serial number: 210716EGK0758A
Coding: 000C13204001040000001002
Dataset: EV_DCURearDriveMINKLO 006003
Component: HBFS 020 0041
Serial number: 210716EGK07587
Dataset: EV_DCURearPasseMINKLO 006003
End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.0V)-----------
Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27A41A182A8000080100A8001001000000000000,to,27AC1A182A8000080100AA001001000000000000,(06385/790/00016),
Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A182A8000080100AA001001000000000000,to,27AC1A182A8000080101AA001001000000000000,(06385/790/00016),
Address 09,5Q0 937 084 CF,channel IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,adapted from,not active ,to,active ,
Address 09,5Q0 937 084 CF,channel IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,adapted from,active ,to,not active ,
Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A182A8000080101AA001001000000000000,to,27AC1A982A8000080101AA001001000000000000,(06385/790/00016),
Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A982A8000080101AA001001000000000000,to,27AC1A182A8000080101AA001001000000000000,(06385/790/00016),
Address 09,5Q0 937 084 CF,channel ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,adapted from,not active ,to,active ,
Address 09,5Q0 937 084 CF,channel IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,adapted from,not active ,to,active ,
Address 09,5Q0 937 084 CF,channel IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,adapted from,not active ,to,active ,
Address 09,,channel IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,adapted from,not active ,to,active ,
Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A182A8000080101AA001001000000000000,to,27AD1A182A8000080101AA001001000000000000,(06385/790/00016),
Address 09,5Q0 937 084 CF,channel ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,adapted from,not active ,to,active ,
