Throttle valve adaptation issue
Ape Factory
C?ID=321067
I've done throttle valve adaptation before and did so again right after cleaning my throttle bodies. No issues.
I went to do it today, just to record it for a how to video and decided to try and record the screen through the Microsoft function. It slowed the computer down tremendously and I had to stop it. Well the adaptation stopped too.
As a result, I have a DTC that will not clear.
On top of that, I ran the throttle valve adaptation again and could not hear the usual clicking of the throttle butterflies as they're activated. I tried to clear the DTC's and then cycle the ignition. No luck.
Next I disconnected the negative to the battery. Connected everything up again and this time, running the adaptation, I heard the clicking. But it literally sat there for minutes on end and never finished up. Tried repeatedly with no luck and the codes will not clear.
This is on a 2013 Audi RS5
2761 - Throttle Actuator (J338)
P1579 00 [039] - Adaptation Not Started
as well as...
10253 - Throttle Throttle Controller 2 (J544)
P3037 00 [039] - Adaptation no Started (it really says no instead of not)
Any idea? Car starts fine. And thanks in advance.
Please post an Auto-Scan for context.
If the engine was completely cold, try warming it up a bit. Check battery voltage as well.
Ape Factory
C?ID=321067
Engine was warm, within the acceptable range. I believe the coolant was about 80 degrees Celsius. Battery voltage was 12.3.
It's just strange that it will not clean the DTC for the throttle bodies. If I do it repeatedly, it'll clear but it's not really cleared and comes back if I check it again. There's been a lot of "buggery" since updating to the latest version, especially with logging.
Ape Factory
C?ID=321067
Here's my entire auto scan.
Monday,11,March,2019,15:35:30:27520
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WUAC6AFR6DA902467   License Plate:
Mileage: 89100km-55364mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
          52 53 56 5F 6C
VIN: WUAC6AFR6DA902467   Mileage: 89100km-55364miles
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l JHM.9X/  H04 0005
   Revision: NAH04---
   Coding: 1A25003225C6080D3000
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
   ROD: EV_ECM42FSI0118T2907560F.rod
   VCID: 3FDBBD3337FB04FFA77-806A
10253 - Throttle Controller 2 (J544)
                    Mileage: 89105 km
                    Date: 2019.03.11
                    Time: 14:15:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 89 ∞C
                    Intake air temperature: 64 ∞C
                    Voltage terminal 30: 11.968 V
                    AFS dm: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Idling
                    Mileage: 89105 km
                    Date: 2019.03.11
                    Time: 14:15:22
                    AFS dm: 0.0 kg/h
   Part No SW: 8T0 927 156 F    HW: 0B5 927 156 J
   Component: 0B5 42 FSINAR H01 0008
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001012
   ROD: EV_TCMDL501021.rod
   VCID: 40D9BECF4A057B07DED-8014
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 302D1A
   VCID: 45D7AFDB55A75E2FEDB-8010
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H12 0633
   Coding: 0D804000000000000000
   VCID: 045172DF1E1DA727BA5-8050
   Serial number: 2313000016339008
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000051213831
   Coding: 00037025002C00000000
   Shop #: WSC 06342 000 00000
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01200220130492
   Coding: 4802200000
   VCID: 392FD32B295F2ACF993-806C
                    Fault Status: 00100011
                    Fault Frequency: 29
                    Reset counter: 247
                    Mileage: 88168 km
                    Date: 2019.02.17
                    Time: 10:37:31
                    Voltage: 14.30 V
                    Temperature: 26.0∞C
                    Temperature: 20.0∞C
                    Count: 11062
                    Count: 10974
                    Bin. Bits: 01000000
                    Bin. Bits: 10001011
                    Time: 255.00 s
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000554864301
   Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
   Shop #: WSC 92630 444 123950
   VCID: 7AAD0C276CD9E1D7D09-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150213  H15 0080
   Serial number: SWF13020150148
   Coding: 00FD11
   Serial number: 21004112
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000502130647
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4SYJ02
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 7C48C296000000000001
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0100
   Coding: 00333E
   VCID: 323DE407F429D997589-8066
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD91EW3S
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD9CE77C39B157009-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000CJ7S
   Serial number: 6334MSME780331656
   Serial number: 6344MSME78406157C
   Serial number: 6352QSME62282B44G
   Serial number: 6362QSME5F2C5372T
   Serial number: 63732SME712B0F585
   Serial number: 63832SME542B2F444
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130219001040
   Coding: 00003E
   VCID: 51FF8B8B91EF828F413-8004
   Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
   Component: KOMBIINSTR.   H35 0556
   Revision: 00300000    Serial number: UVA266K2E
   Coding: 83BF0100AF03D705020000
   VCID: 3D27C73B3D7716EFB5B-8068
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z13204008E
   Coding: 80E3031600
   VCID: 4CC19AFF76CDAF67325-8018
   Serial number: 1367620003
   Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
   Component: DYNAMIKLENK.  H06 0690
   Revision: 52001005    Serial number: --------------
   Coding: 030000
   VCID: 3635D8171841C5B7741-8062
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 001302130001758
   VCID: 2F3BED73E79BF47F377-807A
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000051211560
   Coding: 001B7B25002C00000000
   Shop #: WSC 11251 001 1048576
03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                    Fault Status: 01100101
                    Reset counter: 168
                    Mileage: 88098 km
                    Date: 2019.02.17
                    Time: 09:31:51
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H04 0060
   Serial number: 0192285845
   Coding: 010211
   Shop #: WSC 06324 000 00000
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H04 0060
   Serial number: 0192294703
   Coding: 000102
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F57897B801E5B7941-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0012646993
   Coding: 010000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3431E21F0EBDD7A74A5-8060
   Revision: 00002001    Serial number: 0301332569
   Coding: 0106069A00FAC10581B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000634856
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104645000002650945
   Revision: 00005001    Serial number: 94813011143102
   VCID: 2D07F77BED17866F05B-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F77F9BA507EEAF9DB-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000227161
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D62F12D533C766D-806C
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156B50D7693479
   Coding: 020007010000000001
   VCID: 25170F5BB5E7BE2FCDB-8070
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 1040
   Revision: --------    Serial number: 204BT0D7561283
   Coding: 150200020306A9EF75028B4E00000403140000000000000000
   VCID: 3FDBBD33377B04FFA77-806A
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Component: DU7 High  H42 0104
   Serial number: A130BX0D2659970
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001419689
   Component: CD-Database  4949
No Faults Found
   Revision: --H07---    Serial number: 525PA8-J2Z91FG
   Coding: 1021008
   VCID: 3829D62F1E5533C766D-806C
End----(Elapsed Time: 02:13, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Monday,11,March,2019,17:10:05:27520
          52 53 56 5F 6C
   Revision: NAH04---
                    Mileage: 89104 km
                    Date: 2019.03.11
                    Time: 15:59:40
                    Coolant temperature: 66 ∞C
                    Intake air temperature: 61 ∞C
                    Voltage terminal 30: 11.826 V
                    AFS dm: 0.0 kg/h
                    Mileage: 89104 km
                    Date: 2019.03.11
                    Time: 15:59:40
                    AFS dm: 0.0 kg/h
Readiness: 1110 1101
   Revision: --H01---
   Coding: 302D1A
   Coding: 4802200000
                    Reset counter: 207
                    Mileage: 89104 km
                    Date: 2019.03.11
                    Time: 16:00:11
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 207
                    Mileage: 89104 km
                    Date: 2019.03.11
                    Time: 16:04:56
                    Voltage: 11.70 V
                    Temperature: 28.0∞C
                    Temperature: 26.0∞C
                    Count: 1850
                    Count: 953
                    Bin. Bits: 00000000
                    Bin. Bits: 10001011
                    Time: 2.55 s
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
   Coding: 00333E
   Coding: 00003E
   Coding: 80E3031600
   Coding: 030000
                    Reset counter: 207
                    Mileage: 89104 km
                    Date: 2019.03.11
                    Time: 14:59:28
   Coding: 010211
   Coding: 000102
            000 -  -
                    Reset counter: 207
                    Mileage: 89104 km
                    Date: 2019.03.11
                    Time: 14:59:32
                    Text: DUA130,Front,M,0,0,6
   Coding: 1021008
End----(Elapsed Time: 02:02, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Both faults show battery voltage in the freeze-frame data under 12V.
Personally, the first thing I would try is doing it with a battery charger connected.
Ape Factory
C?ID=321067
I'll try that. I have a voltage meter in the cig lighter and it said 12.3. Guess it's not calibrated.
