Monday,11,March,2019,16:51:46:36750
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
VIN: TMBBJ7NE6E0143013 License Plate: SM63
Mileage: 104346km-64837mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBJ7NE6E0143013 Mileage: 104346km-64837miles
Address 01: Engine (J623-CKFC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 111D0012030501090000
Shop #: WSC 73430 031 00103
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AAEFAEC4C57A137D09-802E
Part No SW: 0D9 300 040 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4305
Revision: 05852204 Serial number: TFK01311181889
ROD: EV_TCMDQ250021.rod
VCID: 221EE28C844709F7A89-8076
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 600240000004FF
Coding: 1A078A912424096F0077060141C6245851249000608224F000610070C002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4BC06F28534DE8BF3BF-801E
Part No SW: 5E0 907 044 E HW: 5E0 907 044 E
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 01110104000100011005000000100000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_003_SK37.rod
VCID: 2708F398EF65ECDFFF7-8072
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011335300203
Coding: 0F001842424700DB07A04082B10407280000000000000000000000000000
Shop #: WSC 73430 790 00103
ROD: EV_BCMBOSCH_012.rod
VCID: 79ACE5E04951AA2FD93-802C
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 131209 041 0570
Serial number: 131212215056
Coding: 0E4FFD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY1312042QB
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000058268484
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20594528
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831336000773
Coding: 0001050011
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 382A20E432DB732766D-806C
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PS27KE%
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F580BF85775841FE77-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 012 13
Serial number: 3576U00000008BB48E0L
Subsystem 2 - Part No SW: ----------- HW: 454 001 112 13
Serial number: 3586U000000CD4C48E0X
Subsystem 3 - Part No SW: ----------- HW: 454 800 912 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R5C1D8102000000+
Subsystem 4 - Part No SW: ----------- HW: 454 800 612 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R30398802000000X
Subsystem 5 - Part No SW: ----------- HW: 454 802 111 13
Component: FrontSensor_D 114 0149
Serial number: 3556V7B4D3902000000D
Part No SW: 5Q0 953 507 DB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 03121304220842
Coding: 0410
ROD: EV_SMLSKLOMQB_012_AU37.rod
Part No SW: 5E0 920 961 D HW: 5E0 920 961 D
Component: KOMBI 233 2210
Coding: 23A502082180AF0001083E00000000
VCID: 290CF5A0F971DAAFE93-807C
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1164
Revision: -------- Serial number: 0001378792
Coding: 030100040F087300EF0002481C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3E2636FC10FF4D17AC1-806A
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0204131213
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6201122203
Part No SW: 5Q4 959 393 B HW: 5Q4 959 393 B
Component: TSG FS 009 0014
Serial number: 0000086214242
Coding: 001000208001040000001100
VCID: 42DE420C640729F7C89-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001439171
Coding: 1D0200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DC4D00610132EFD13-8014
Part No SW: 5Q4 959 392 B HW: 5Q4 959 392 B
Component: TSG BFS 009 0014
Serial number: 0000086729982
Coding: 001000208C01040000001100
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001487254
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 842 A HW: 5E0 035 842 A
Component: MU-S-D-ER 040 0490
Serial number: S7E00501140568
Coding: 03730100FF0000001111120100A800002F0000860100010002
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 211CED80814112EFB13-8074
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9NK600QAQ
B201A 00 [009] - -
Reset counter: 176
Mileage: 104344 km
Date: 2019.03.11
Time: 16:36:19
Voltage terminal 30: 12.2 V
End----------(Elapsed Time: 01:14, VBatt start/end: 12.4V/12.3V)-----------
That fault gets mentioned a lot on briskoda.net and is caused by the switches in selector lever being faulty or intermittent. Most owners have had the whole selector replaced under warranty but as yours is a 2014 model you would need to press the dealer and/or Skoda UK for as much goodwill contribution as you can get.Thanks.
I clear scan nearly every month but AUTO TRANS Fault shows up every time
would really like to get to the bottom of this.
but the stop start has got me real worried
P1734 00 [002] - -
What exactly were the original BEM values, and what did you change them to? You may have confused the battery management system...battery is Varta
BEM Code 7P0 915 105
68ah 380 A
when i checked only 68ah was inputted
and fleeze under manufacturer ???
I changed it to vao
7P0 915 105 has only 9 characters. not 10 or 11 so abit lost
and serial number was blank
If it shows up in the Gateway after a while, I would get it fixed, per Dave's post #6.Thanks Uwe, yeah I have read thr a few posts "intermittent/ not confirmed so haven't been that concerned as you've stated, but would be nice to get it cleared sometime. It's thrown up them codes for well over 18 months with stop start working fine. It does show up in gateway once a month but after clearing it goes back to Address 02: ok
Apologies for misunderstanding. Have you had this car since new? Is the battery the original one?Uwe, I've not changed the battery.
I went in and checked to see if the original battery was coded in after watching your
Video, on coding in batteries and found that only 68ah and fleece was inputed.
No serial number was present.
And my battery has only 9 characters 7PO 915 105
That's where I got lost
