Full scan attached below. Address 5F / 1543 error, is the point of interest.
I've had this '1543' error in my VCDS scans ever since buying the car 2 years ago.
I never managed to find out what was causing the '1543' error, any idea where to start looking to clear it? If that's even possible? I've checked out the Byte_Coding ERRORs on the Long Coding screen, and the settings displayed are in agreement with the features my Golf R has installed. So ... confused.
Thanks in advance!
p.s: not sure if it's related but:
– the USB port below the infotainment has never worked / provided power despite the internal cable and plug appearing to be OK
– the Performance Monitor screen (boost gauges etc.) all work totally fine apart from the Coolant / Oil temp gauge, which has *never* displayed any values, just '---'. The Oil Temp on the dash display *does* work, assuming they're linked in some way.
Thanks in advance!
Thursday,07,March,2019,13:43:47:30140
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.0.2 (x64) HEX-NET CB: 0.4437.4
VIN: WVWZZZAUZEW308972 License Plate:
Mileage: 39211km-24364mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW308972 Mileage: 39211km-24364miles
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322406010B3004
ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
ROD: EV_ECM20TFS0205G0906259B.rod
VCID: 2D12C2E07C6482224E-8079
21392 - Control Module for Exhaust Flap
P14AB 00 [096] - Mechanical Malfunction
Mileage: 39198 km
Date: 2019.03.02
Time: 18:14:18
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 98 °C
Intake air temperature: 59 °C
Voltage terminal 30: 12.597 V
Engine: operating status: ES
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 1323 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 8120.0 kPa
Readiness: 0010 0001
Part No SW: 0D9 300 011 R HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4319
Revision: 05852204 Serial number: TFK01401280197
ROD: EV_TCMDQ250021.rod
VCID: 240427C42FAE436A91-8071
P1734 00 [002] - -
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6035400000090D
Coding: 01FA93A1542029740380070741C56980C92A94C0E08296F7004200B8C208
VCID: 7BB63CB8F290DC9280-802F
Revision: 00021000 Serial number: 0326667815
Coding: 030C0C
VCID: 3A38F9BCBD2A259ADB-806F
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120014200100011005000000101000
VCID: 66807DCC9912717A4F-8033
Air quality sensor:
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011404202066
Coding: 03111A46C24122F30BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140210 042 0551
Serial number: 140212194131
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M02D15H05M34S24S6
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1401626GV
Serial number: 00000000000058712165
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO26952525
Coding: 181801
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331404400467
Coding: 0031051011
VCID: 3E30F5ACA10209BAE7-806B
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 03021441350064
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76A02D8CC9B281FAFF-8023
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R04P251
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 41CA8E50D0FC76429A-8015
Subsystem 1 - Part No SW: ----------- HW: 480 003 101 14
Serial number: 3576700000012C74DE0
Subsystem 2 - Part No SW: ----------- HW: 480 000 702 14
Serial number: 358670000000C6F89E07
Subsystem 3 - Part No SW: ----------- HW: 480 401 302 14
Serial number: 35165029D11D1520D1E9
Subsystem 4 - Part No SW: ----------- HW: 480 401 302 14
Serial number: 35265029911D1525D185
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 14
Serial number: 3556502BD13013F1F025
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10021404220770
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 79BA26B0F8ACEE8292-802D
Part No SW: 5G6 920 870 E HW: 5G6 920 870 E
Component: KOMBI 322 2210
Coding: 27AD0818BB80000E02082A00040000
VCID: 312ADE90605CE6C26A-8065
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001496662
Coding: 030100042B085900EF00026A9C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FCE88A8A60800B2EC-806B
Subsystem 2 - Part No SW: 5G0 959 442 L HW: 5G0 959 442 L Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001009760043432
Coding: 25FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9655742503
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00020.01.14
Coding: 0001
VCID: 46C09D4CF9D2517AAF-8013
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000035193005
Coding: DD00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424D7849F4ED3EA01-8061
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 08021403110745
Coding: 003F1220D001040000001000
VCID: 40CC8B54DBF67F4A95-8015
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001860787
Coding: 1D0000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 3522EA809434CAE236-8061
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 26011403111441
Coding: 003F1020DE01040000801000
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001876220
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 02A602000B000200
VCID: 3D32F2A0AC0412A2FE-8069
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 3Q0 035 877 A HW: 3Q0 035 877 A
Component: MU-S--ROA H24 0245
Serial number: VWZAZ2R0315928
Coding: 02730000FF00000051150001001028001F0207D40120010002
Shop #: WSC 00046 000 00000
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 3326D4989A40D4D218-8067
Subsystem 1 - Part No SW: 5GD 919 605 A HW: 5GD 919 605 A
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RFB003RW
U1014 00 [009] - -
Reset counter: 95
Mileage: 39169 km
Date: 2019.03.02
Time: 11:36:12
Voltage terminal 30: 14.5 V
1637 - Interface for External Media
U11B8 00 [009] - No Communications
[USB - communication error]
Reset counter: 95
Mileage: 39169 km
Date: 2019.03.02
Time: 11:36:13
Interface for external media: status-Status: Open circuit
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 140117200127
End----(Elapsed Time: 01:25, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
