New to VCDS....No response from controller
rowe.ajb
C?ID=362936
Good Morning,
Just purchased my first VCDS/VAG-COM Diagnostic System (HEX-V2, 3 VIN). Trying to use this on my 2018 VW Tiguan SEL Premium to release EPB to access rear brake pad/rotors. Followed all recommended procedures... Battery Charger, Cycle parking brake but when I attempt to access Module 53 Parking Brake I get "No Response from controller". Any help on this would be much appreciated.
Autoscan:
Thursday,07,March,2019,07:48:13:18415
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: 3VV4B7AX9JM004435   License Plate:
Mileage: 87861km-54594mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
          47 4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AX9JM004435   Mileage: 87861km-54594miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Coding: 012A00122466010FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00019
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: 3C2135F4C6EFD917825-8068
   Part No SW: 09G 927 158 Q    HW: 09G 927 158
   Component: AISIN AQ8     206 3379
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00454
   ROD: EV_TCMAQ450031_VW32.rod
   VCID: 41DF4400A10DB4FFD13-8014
   Revision: 00000000    Serial number: 51137000000582
   Coding: 0BFA6BA454201B70C57B0303A2C849D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 77ABEAD8BF493A4FAF7-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0439124443
   Coding: 032C2C070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98155138
14222592 - Databus
          [Message ELV_01 missing]
                    Reset counter: 103
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.337 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Actuation to the inside: active
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 K    HW: 5NN 907 044 K
   Component: AC Automat    H35 R552
   Revision: 20K08000    Serial number: 00000D00005997
   Coding: 00020024200118001105010C1211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 54F17D544E7F31576A5-8000
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 25
                    Reset counter: 94
                    Mileage: 84418 km
                    Date: 2019.01.30
                    Time: 18:14:19
                    Outside air temperature: -11.5 °C
                    Voltage terminal 30: 14.7 V
                    System run time-Engine running time: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C86420041700QD
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0C41A534D6CF2997F25-8058
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170308  034 0373
   Serial number: 17030521045020
   Component: RLHS  042 0105
   Serial number: S5Y17M04D04H11M23S20
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 0
                    Mileage: 78375 km
                    Date: 2018.11.15
                    Time: 21:43:49
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 56
                    Mileage: 69935 km
                    Date: 2018.10.08
                    Time: 19:02:52
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617104
   Coding: 0471655011
   VCID: 4BC3662893416EAF3BF-801E
   Component: ACCCONTIMQB   H02 0233
   Coding: 320000C158FF8728749C8145304097
   VCID: 3E253FFCD0F3CB07AC1-806A
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 81
                    Mileage: 83446 km
                    Date: 2019.01.19
                    Time: 13:28:53
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 10 °C
                    Velocity_vehicle_reference: 3.31 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.28 m/s²
196741 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FCTSEN_BLOCKAGE]
                    Reset counter: 105
                    Mileage: 85688 km
                    Date: 2019.02.12
                    Time: 13:52:06
                    Velocity_vehicle_reference: 20.47 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.19 m/s²
196742 - Sensor for Automatic Distance Control
          [FCTSEN_DEC_BLOCKAGE]
                    Reset counter: 77
                    Mileage: 85694 km
                    Date: 2019.02.12
                    Time: 13:58:20
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 11 °C
                    Velocity_vehicle_reference: 19.73 m/s
196743 - Sensor for Automatic Distance Control
          [FCTSEN_INC_BLOCKAGE]
                    Reset counter: 77
                    Mileage: 85676 km
                    Date: 2019.02.12
                    Time: 13:42:48
                    Velocity_vehicle_reference: 20.14 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.56 m/s²
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM059YC9
   Coding: 8CCCFC00000000005000001AC20800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 05579010F5A558DFADB-8050
   Occupant Detection:
   Serial number: IBH00000000000783UU
   Coding: 303352
   Subsystem 2 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35700000000257058223
   Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35800000000B84FC622X
   Subsystem 4 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3510001B524CEFC6F4E
   Subsystem 5 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3520001A525672E632F2
   Subsystem 6 - Part No SW: -----------    HW: 480 400 604 17
   Serial number: 3550001C52502AF2F7BE
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 104 17
   Component: FrontSensor_P  000 6149
   Serial number: 35600019D255D292D6CK
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 21041704401432
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 03538E08FB9166EF83F-8056
   Part No SW: 5NA 920 891 B    HW: 5NA 920 891 B
   Component: KOMBI         406 3192
   Coding: 0BA4001AEF88CF0502886B0B5401000020000000
   VCID: 43D34E08BB11A6EFC3F-8016
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 48
                    Reset counter: 101
                    Mileage: 78042 km
                    Date: 2018.11.13
                    Time: 20:12:18
   Component: GW MQB High   518 5286
   Serial number: 26051700840138
   Coding: 030500347F085900FB07225A1E0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B12B80799328F377-807A
   Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
   Serial number: 0971718391101839BO2B
   Coding: 2E0000
   Serial number: 0377873604
   Serial number: HA1-00025.01.17
   Coding: 0101
   VCID: 4ACD632C9C3B77A7009-801E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45D75010B52598DFEDB-8010
   Serial number: 17000099839012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD4C0D12D647F613-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0021
   Serial number: Y0006QD422694
   Coding: 0010000000000500018280808080000000008101000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                    Reset counter: 107
                    Mileage: 87858 km
                    Date: 2019.03.06
                    Time: 12:46:41
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: HRE_Master    H12 0080
   Serial number: 0438947047
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2738F0DDF5D01FB5B-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0437103107
   Coding: 020111
   Component: TSG FS        010 0032
   Serial number: 5028711600345
   Coding: 003F1B205200028000000000
   VCID: 47CB5A188F298ACF1F7-8012
   Revision: 00000000    Serial number: 0001665557
   Coding: 01000011004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40D94104AA07BDF7DED-8014
   Revision: 00000001    Serial number: VWZ8Z1HBA03AZ4H
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D87C8B0CD15809F45B-8038
   Component: FCM MQB Low   001 0285
   Serial number: 05041700840372
   Coding: 0000000501001D5200210F01090000000000000000000000000000000000
   VCID: 72BDDBCCD42B5F67989-8026
   Component: TSG BFS       010 0032
   Serial number: 6028706600277
   Coding: 003F13205E00028000000000
   VCID: 46D5571C882393C7E41-8012
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0755
   Coding: 027306020000000051220002001808001F0500E401200005C6
   Shop #: WSC 00066 790 00442
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323D1BCC14AB1F67589-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8120
   Serial number: VWZ6ZHT1262966
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 243
                    Mileage: 64014 km
                    Date: 2018.09.08
                    Time: 14:29:15
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 135 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG011168
   Coding: 01230601A20F20000000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 382929E4F2D7F53766D-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0A28
   VCID: 42DD4B0CA40BAFE7C89-8016
   Coding: 02230602C2823A037F1E06020000
   ROD: EV_OCULowMQB.rod
   Serial number: 04041711K21371
   Coding: 0003070601020201002213548050490084000E200020
   VCID: 3B2336E8C3E1DE2F8BF-806E
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       012 0032
   Serial number: 0000251246358
   Coding: 002011200101028000000000
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   VCID: 49CF5C20993D7CBF093-801C
   Component: TSG HBFS      012 0032
   Serial number: 0000251246356
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_006.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C75C9803E347541-8042
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:25, VBatt start/end: 14.8V/14.8V)-----------
_Val
Latvia
C?ID=356659
Are you sure you got right instructions?
There is no "53" before actual autoscan. See next line after "Chassis Type: AX-VW37 (3Q0)".
