2007 4.2L FSI w/ rough idle P0102 P010C Low MAF
   #21
stone4779
C?ID=366133
small update:
The new MMI control circuit board came in early this morning at 10AM!
I installed it after work, and now have restored function of the MMI. Navigation, radio, CD changer, setup menus the works. The telephone doesnt work, but I am guessing that is referring to an actual in-car phone? May need to look into a way to add bluetooth after I get the engine and trans codes sorted out.
So although the car still doesnt drive perfect, at least I can stop worrying about spending time/money getting a working screen.
Small victories!
   #22
stone4779
C?ID=366133
I confirmed again today that if I plug in the driver's side high pressure fuel regulator (N276) the 15A fuse pops.
If I unplug N276, and then install a new 15A fuse..clear the codes, and then the fuse doesnt pop.
So I am pretty sure that driver's side high pressure fuel regulator valve is toast. We have been planning to get it soon.
   #23
stone4779
C?ID=366133
I was finally able to make time to get the 24 hour erWin subscription to download everything they had on Audi Q7s. Lots of juicy info in there. Although I am still trying to find out how I can use my multimeter to test all the sensors one by one. Like info on what the proper resistance should be for each sensor or device. I tested the resistance of the pins on the connector on the chassis side of the driver's side HPFR. (Not the pins on the actual HPFR)
I made a diagram to define which pins I am referring to in order to be more clear.
Ignition key OFF
32.4 Ohms across the two pins A & B
Pin A to ground = 26.5 Ohms
Pin A to Pos(+) battery terminal = 0.00 Ohms no resistance at all
Pin B to ground = 5.84 Ohms
Pin B to Pos(+) = 0.00 Ohms
Now I wanted to check voltage. Still with the ignition key OFF.
Pin A to ground = no voltage (1 mA or so)
Pin A to Pos(+) = 12.26v
Pin B to ground = no voltage (1 mA or so)
Pin B to Pos(+) = 12.26v
Pin A to Pin B = 0.3 mV so basically nothing
Now with the Ignition key ON:
Pin A to ground = 2.45v
Pin B to ground = 1.79v
It was difficult to get in there to measure the resistance across the two pins on the actual N276 HPFR. I may just pull it off to check the condition of the camshaft follower so that if it does need to be replaced, when we order the new N276 HPFR for the driver's side...we can go ahead and get the camshaft follower as well. and of course a new o-ring seal.
stone4779
C?ID=366133
I do have a lot of wiring diagrams from erWin...I need to map all the sensors that are throwing codes for short to ground and for low signal..and find the common points to look for failure. I will post up what I find out.
   #25
stone4779
C?ID=366133
Small note: I have been referring to "N276"..which is wrong. My generic scanner says N276, but it is in fact I believe N402.
I measured the resistance across the two pins on each HPFR and the passenger side (which hasnt been throwing codes) is within spec (1.5Ω), but the driver's side is only 0.5Ω.
Audi spec for N402 (and N290) is between 1.5Ω and 11Ω +/- 0.5Ω @ 68°F.
Guess we are replacing N402 (driver's side) HPFR. I need to inspect the cam follower still in order to make sure we do/dont need a new one.
   #26
stone4779
C?ID=366133
I will be posting up some wiring diagrams I got from erWin. Here is a diagram showing fuse S13 (the one the blows when I plug in the driver's side high pressure fuel regulator connector)
It also shows N402(driver HPFR) wiring diagram
I would like to test things while I wait for the new fuel pump. Any tips on a good approach to verifying the wiring and other sensors on fuse S13 are good to go would be highly appreciated. It would suck to buy a brand new fuel pump only to mess it up!
Thanks!
   #27
OK, so fuse S13 feeds five different current tracks, only one of which (194) is shown here.
Now the only thing on the other side of N402 is the ECU, which actuates N402 by closing "closing a switch" to ground inside the ECU. Since the other side of N402 has +12 on it, this is called a "low side switch".
If S13 blows when N402 is plugged in, and doesn't blow when N402 isn't plugged, in, then N402 almost certainly has to be bad (resistance too low, pulling too much current through S13 when the ECU tries to turn it on). But you measured 34 ohms? I'm confused.
NostraJackAss
Or wiring to ECU is possibly shorted direct to other track/ground..........
123 load lights!
   #29
stone4779
C?ID=366133
First, thanks for the reply Uwe!
and yes I did measure 32.4 Ohms across the two pins on the N402 connector on the CHASSIS side, not on the actual N402 itself.
The two pins on N402 itself, came to 0.5 Ohms. Out of spec.
So the connector on the chassis side should test as an open circuit? because pins A to B on mine do have about 32 Ohms of resistance. Just trying to clarify. :)
I will be at work all day, but this evening I want to set aside at least an hour or two for me to test the wiring as best I can.
thanks again!
   #30
stone4779
C?ID=366133
123 load lights!
Thanks for your reply as well, Jack! :thumbs:
Yes I was afraid of that lol. That is a great video, thanks! I am gearing to go then! I already have the pages in the service manual handy that show removal of the ECM so that I can gain access to the pins on the ECM connector.
So I am guessing that I need to test the resistance of the wire coming from pin 35 of the T60 connector on the ECM, to the wire that is brown w/ a black stripe on the connector going to N402?
and then conduct a load test on it as well?
I do not have a probe light at all (I know I know lol.. how have I survived thus far in life? lol) lots of squinting at the screen on the multimeter lmao xD
I will see if I can get a probe light with 55W bulb to do the load test ;)
thanks again Uwe and Jack. I really really appreciate having outside input to confirm or deny my thinking here and to have a little bit of direction. I am excited to be learning how to do all this properly.
   #31
That's for all intents and purposes a dead short; 0.5 ohms would pull 24A from 12V, and my guess is the actual resistance is lower than that 'cause you're probably not taking the resistance of the meter leads into account.
What size is the S13 fuse?
NostraJackAss
Why no auto-scan yet and why not verified?
Hmmm let me see I would know for sure, as would the collective, what fuse is what if we had an auto-scan?
   #34
stone4779
C?ID=366133
That is correct. 0.5 ohms is plenty of resistance to blow s13 at anywhere near 12 volts. Especially since there are other things running off that fuse simultaneously presumably.
S13 is listed as a 15A fuse.
Thanks again for the reply Uwe. 👍
   #35
stone4779
C?ID=366133
Woops! My mistake Jack, I should have posted the amperage rating of the fuse s13 already...its 15A.
And believe me, there is nothing more in this world that I desire than to obtain and post a full auto scan using vcds. Finances preclude me from getting it right now, but hopefully next week!
I do thank you for your time kind sir
   #36
NostraJackAss
Well I hope you get better financially and become a collective member in the registered area soon.
Give the Borg ship a VIN number please, that surely doesn't preclude you financially & so data can be observed to try to help you.
Resistance is .......
   #37
stone4779
C?ID=366133
Thank you, as do I :) I will be a verified member within 1-2 weeks most assuredly. ;)
Oh and I'm sorry, I should have posted the VIN. I had a link up to a PDF containing a scan which had the VIN in it in the original post, but the link went dead for some reason. :facepalm: my mistake. I hadnt even checked if the links worked until just now. woops. long week!
The VIN for the vehicle in question is:
WA1AV74L17D026123
Input appreciated!
   #38
stone4779
C?ID=366133
On a side note but still related...I have an itching to get one of THESE as well:
"Kzyee KM10 Power Circuit Probe Kit, Automotive Circuit Tester with Auto Electrical System Testing Functions (Digital Voltage Tester/Multimeter/Short Finder/Battery Test/Power or Ground Supply)"
and maybe one of these:
"Adjustable Current Voltage Analog Simulator Signal 0~20mA Generator DC 0~10V"
I figure they might be handy to quickly check things.
Also today I am getting a couple test probe lights to load test the circuit! :thumbs:
There is a three pack that has one probe test light for 6/12v, one for 18/24/36v, and a 3rd test probe which just checks for continuity they have at a local supply store for $7, it is on the way home from work so I am going to stop by this afternoon for it.
I figure I can hack one to run a 55w light bulb or something though the circuit to see if lights up, and if so, is it as bright as just connecting same 55w light bulb directly to the positive and negative of the battery? Does it flicker if I wiggle the wiring?
I look forward to finding out! :D :cool:
   #39
NostraJackAss
Vehicle Identification No.WA1AV74L17D026123
Modelaudi q7 qu. 4.2
AQ7
Date of production23.06.2006
Year2007
Sales type4LB5EL
Engine CodeBAR
Transmission CodeHPH
If you would be so kind & take a picture of the engine controller you have please and post it?
[TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PA[/TD]
[TD]Standard wheel bolts[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]1CN[/TD]
[TD]Vehicle class differentiation -4L0-[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]7GA[/TD]
[TD]Emission standard LEV 2[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D6[/TD]
[TD]Trailer hitch[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UB[/TD]
[TD]Airbag for NAR[/TD]
[/TR]
[TR]
[TH="align: left"]Label for central electric[/TH]
[TD="class: prCode"]0W2[/TD]
[TD]Label for central electric system
English-speaking countries[/TD]
[/TR]
[TR]
[TH="align: left"]Tray areas package[/TH]
[TD="class: prCode"]QE1[/TD]
[TD]Storage compartment package 1[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XL[/TD]
[TD]Exterior mirrors with memory feature,
auto-dimming, power-folding/adjustable/
heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SG[/TD]
[TD]Left exterior mirror, flat[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RW[/TD]
[TD]Right exterior mirror, convex (US)
large viewing field[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8U[/TD]
[TD]Executive US equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KF[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J0Z[/TD]
[TD]Battery 520 A (110 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1LF[/TD]
[TD]Silver caliper[/TD]
[/TR]
[TR]
[TH="align: left"]Receiver (car phone)[/TH]
[TD="class: prCode"]QF0[/TD]
[TD]Without receiver (car phone)[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0A[/TD]
[TD]build parts set without county specific documentatio[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A2[/TD]
[TD]CD changer[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C00[/TD]
[TD]Operating permit, initial registration[/TD]
[/TR]
[TR]
[TH="align: left"]Shock absorption/suspension, chassis[/TH]
[TD="class: prCode"]1BW[/TD]
[TD]Comfort suspension 2[/TD]
[/TR]
[TR]
[TH="align: left"]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S1[/TD]
[TD]Bright roof rails[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FU[/TD]
[TD]Big roof system[/TD]
[/TR]
[TR]
[TH="align: left"]Differential lock[/TH]
[TD="class: prCode"]1Y0[/TD]
[TD]without differential lock[/TD]
[/TR]
[TR]
[TH="align: left"]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G4[/TD]
[TD]Insert for the filling up of unleaded
fuel[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AJ[/TD]
[TD]Electronic immobilizer, with anti-theft
alarm system and backup horn[/TD]
[/TR]
[TR]
[TH="align: left"]Inserts[/TH]
[TD="class: prCode"]5TA[/TD]
[TD]Tamo wood trim[/TD]
[/TR]
[TR]
[TH="align: left"]Scuff plates[/TH]
[TD="class: prCode"]7M0[/TD]
[TD]Plastic scuff plates in door apertures[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X7[/TD]
[TD]Park distance control in rear plus rear
view camera system[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K9[/TD]
[TD]Daytime headlights with automatic headlight control
and coming home function[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Interior noise suppression measures[/TH]
[TD="class: prCode"]3W4[/TD]
[TD]Acoustics package "Standard"[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GH[/TD]
[TD]Alternator 190 A[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission types/gearshift mechanisms[/TH]
[TD="class: prCode"]0G7[/TD]
[TD]tiptronic[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YC[/TD]
[TD]Weight range 3
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]0JB[/TD]
[TD]Weight category front axle
weight range 2[/TD]
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]T8T[/TD]
[TD]8-cyl. petrol engine 4.2 l assembly 079.A (ALU)[/TD]
[/TR]
[TR]
[TH="align: left"]Tie down straps/net/pocket[/TH]
[TD="class: prCode"]6M0[/TD]
[TD]Without tie down straps/net/pocket[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T1[/TD]
[TD]Cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Garage door opener[/TH]
[TD="class: prCode"]VC1[/TD]
[TD]Garage door opener[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G0R[/TD]
[TD]6-speed automatic transmission for
four-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]Rear trim panel[/TH]
[TD="class: prCode"]6V2[/TD]
[TD]Rear trim panel[/TD]
[/TR]
[TR]
[TH="align: left"]Molded headliner[/TH]
[TD="class: prCode"]6NJ[/TD]
[TD]Standard molded headlining[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]5KL[/TD]
[TD]Five rear seats (with armrest)[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AD[/TD]
[TD]Climatronic, free of cfc[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8EH[/TD]
[TD]Bi-functional headlamps with gas
discharge lamp, for driving on the right
(US design)[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U1B[/TD]
[TD]Instrument cluster with mph
speedometer, clock, tachometer and trip
odometer[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L7[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming, with compass[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K4H[/TD]
[TD]Closed body[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SS[/TD]
[TD]Luggage compartment floor covering[/TD]
[/TR]
[TR]
[TH="align: left"]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH="align: left"]child safety[/TH]
[TD="class: prCode"]4H5[/TD]
[TD]Electrically operated child lock[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y2[/TD]
[TD]Tropical zones[/TD]
[/TR]
[TR]
[TH="align: left"]Seat ventilation/massage seat[/TH]
[TD="class: prCode"]4D0[/TD]
[TD]Without seat ventilation/massage seat[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z6[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]1A2[/TD]
[TD]Fuel system for SI engine with direct
injection (FSI)[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH="align: left"]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]License plate bracket front (small, NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K4[/TD]
[TD]with no paint conversation[/TD]
[/TR]
[TR]
[TH="align: left"]Rear cargo area[/TH]
[TD="class: prCode"]3GD[/TD]
[TD]Plane rear cargo area[/TD]
[/TR]
[TR]
[TH="align: left"]Light package (lighting)[/TH]
[TD="class: prCode"]QQ1[/TD]
[TD]With additional lights (interior
lighting)[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]QZ0[/TD]
[TD]Speed-sensitive power steering
(Servotronic) w/ limited steering lift
mechanism)[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P1[/TD]
[TD]Power adjustable lumbar support in front
seats[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]2ZM[/TD]
[TD]Leather-wrapped multi-function steering
wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RY[/TD]
[TD]loudspeaker with BOSE-sound[/TD]
[/TR]
[TR]
[TH="align: left"]Steering column systems[/TH]
[TD="class: prCode"]2C7[/TD]
[TD]Safety steering column with electric
axial and tilt adjustment[/TD]
[/TR]
[TR]
[TH="align: left"]Air cleaner (engine)[/TH]
[TD="class: prCode"]1L2[/TD]
[TD]Air cleaner for dusty regions with
saturation indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Leather scope[/TH]
[TD="class: prCode"]7HA[/TD]
[TD]Without leather trim[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q5[/TD]
[TD]Dynamic headlight range control,
with cornering light (AFS 1)[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E6[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q4[/TD]
[TD]Multi-function display/trip computer
with check control[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]MN5[/TD]
[TD]8-cylinder SI engine 4.2 l/257 kW (32V)
FSI
base engine is T8T[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q2[/TD]
[TD]navigation system with colour screen[/TD]
[/TR]
[TR]
[TH="align: left"]Audi Sport/ Quattro GmbH[/TH]
[TD="class: prCode"]FQ0[/TD]
[TD]Series wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Quality class[/TH]
[TD="class: prCode"]AQ0[/TD]
[TD]Standard-production quality[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]CJ3[/TD]
[TD]Alloy wheels 9J x 19 -- painted, style:- 5 thin
spokes[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8DY[/TD]
[TD]Radio "HIGH" America[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JA[/TD]
[TD]Non smoker version[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K7[/TD]
[TD]Tire pressure monitoring system 433 MHz
Basic[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]HL7[/TD]
[TD]All-season tires 265/50 R19 110H xl
(NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G1[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Wheelbases[/TH]
[TD="class: prCode"]0E2[/TD]
[TD]Long wheelbase[/TD]
[/TR]
[TR]
[TH="align: left"][/TH]
[TD="class: prCode"]PAW[/TD]
[TD]cold-weather package[/TD]
[/TR]
[TR]
[TD="class: prCode"]PND[/TD]
[TD]navigation system plus incl. MMI for
export[/TD]
[/TR]
[TR]
[TD="class: prCode"]PRY[/TD]
[TD]cast aluminium alloy wheels, 8.5Jx19,
7-arm "Structure" design, with 265/50 R
19 tyres[/TD]
[/TR]
[TR]
[TD="class: prCode"]PTA[/TD]
[TD]technical package for USA[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]7F9[/TD]
[TD]Gearshift knob/handle in plastic/leather[/TD]
[/TR]
[TR]
[TH="align: left"]Self-collection / special control[/TH]
[TD="class: prCode"]A00[/TD]
[TD]No self-collection[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH="align: left"]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SJ[/TD]
[TD]Tail light cluster, normal design (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E9[/TD]
[TD]Trunk lid power closing
with operating lever inside[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper systems[/TH]
[TD="class: prCode"]VJ4[/TD]
[TD]bumper reinforced[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P5[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N1F[/TD]
[TD]Seat trim covers in leather, G-grain
pattern/leatherette, B-grain pattern[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3L4[/TD]
[TD]Electric seat adjustment for both front
seats, driver's seat with memory system[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A4[/TD]
[TD]Seat heater for front and rear seats
separately controlled[/TD]
[/TR]
[TR]
[TH="align: left"]Safety certificate[/TH]
[TD="class: prCode"]0LM[/TD]
[TD]With special labels
safety certificates for California[/TD]
[/TR]
[TR]
[TH="align: left"]sun visors[/TH]
[TD="class: prCode"]5XH[/TD]
[TD]Sun visors, with vanity mirror
illuminated on driver's and front passenger side[/TD]
[/TR]
[TR]
[TH="align: left"]Audio-response system/voice control[/TH]
[TD="class: prCode"]QH2[/TD]
[TD]voice control[/TD]
[/TR]
[TR]
[TH="align: left"]Lane change assist/lane keeping system[/TH]
[TD="class: prCode"]7Y1[/TD]
[TD]Lane change assist[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KF[/TD]
[TD]heat protective glass for door, side and rear
windows, darkened from b-pillar[/TD]
[/TR]
[TR]
[TH="align: left"]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y3[/TD]
[TD]Roll-up sunhade for rear window and
rear door windows[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer[/TH]
[TD="class: prCode"]0BB[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AB[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Handling production and pre-production[/TH]
[TD="class: prCode"]FA0[/TD]
[TD]Control of standard production[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K7[/TD]
[TD]Central locking system "Keyless Entry"
"two-stage unlocking"[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B34[/TD]
[TD]Legal requirements USA[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Transit coating[/TH]
[TD="class: prCode"]NT2[/TD]
[TD]Transit coating (type 3)[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV4[/TD]
[TD]Satellite radio reception USA[/TD]
[/TR]
[TR]
[TH="align: left"]Assembly parts for engine (drive bearing)[/TH]
[TD="class: prCode"]1VJ[/TD]
[TD]Assembly part for 8-cyl. engine[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EP[/TD]
[TD]Special identification label (USA)[/TD]
[/TR]
[TR]
[TH="align: left"]Type sign[/TH]
[TD="class: prCode"]2Z1[/TD]
[TD]Type sign at rear
and "Quattro" nameplates respectively[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T1[/TD]
[TD]First aid kit[/TD]
[/TR]
[TR]
[TH="align: left"]Front seats[/TH]
[TD="class: prCode"]Q1A[/TD]
[TD]Standard seats in front[/TD]
[/TR]
[TR]
[TH="align: left"]Storage compartment -- veneered key storage box[/TH]
[TD="class: prCode"]4Y0[/TD]
[TD]Without storage compartment/safe box[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9ZG[/TD]
[TD]preperation for mobile phone with hands free teleph.[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GP[/TD]
[TD]Windshield in heat-insulating glass with
sunshield and viewing window for vehicle
identification number[/TD]
[/TR]
[TR]
[TH="align: left"]Central display and control unit[/TH]
[TD="class: prCode"]QW1[/TD]
[TD]Central control unit in front[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Decorative trims[/TH]
[TD="class: prCode"]4ZB[/TD]
[TD]Bright decorative trims[/TD]
[/TR]
[TR]
[TH="align: left"]Additional body panels,
side[/TH]
[TD="class: prCode"]6EQ[/TD]
[TD]Additional stone guard body covers
(type 2)[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B7[/TD]
[TD]Child seat anchors as per Canadian
requirements a. ISOFIX child seat system[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
   #40
stone4779
C?ID=366133
AQ7
Year2007
Sales type4LB5EL
Engine CodeBAR
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
heated[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]CD changer[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
fuel/fuel type[/TH]
fuel[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
equipment[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]tiptronic[/TD]
[/TR]
[TR]
[TD]Weight range 3
[/TR]
[TR]
weight range 2[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
(US design)[/TD]
[/TR]
[TR]
[/TR]
[TR]
odometer[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
filling[/TD]
[/TR]
[TR]
[/TR]
[TR]
requirements[/TD]
[/TR]
[TR]
(ISOFIX)[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
lighting)[/TD]
[/TR]
[TR]
[/TR]
[TR]
mechanism)[/TD]
[/TR]
[TR]
seats[/TD]
[/TR]
[TR]
wheel[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
FSI
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
spokes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
Basic[/TD]
[/TR]
[TR]
(NAR)[/TD]
[/TR]
[TR]
brand[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
export[/TD]
[/TR]
[TR]
19 tyres[/TD]
[/TR]
[TR]
[/TR]
[TR]
airbag[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
rear[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
side[/TH]
(type 2)[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
And a close up of the information on the label:
As always, thank you for your time, Jack. 🙏
