VW Golf MK6 Highline BCM/CECM Upgrade
Mark Hudson
C?ID=290534
Hi, I have a 2010 VW Golf GTD which currently has a midline CECM installed. I would like to upgrade this to a highline CECM to allow me to install genuine Xenon headlights & genuine LED tail lights with genuine LED licence plate lights (without the bulb out error). I have attached an autoscan from the vehicle, I would be grateful if anyone could advise me on the compatible/correct highline module. The ORIGINAL (midline) module part number is: 1K0 937 086 C.
Thanks In Advance.
Mark
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW376274   Mileage: 110400km-68599miles
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LC    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000SG  9977
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 26214 051 00000
   VCID: 71AA066D68FB97C222-8024
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B600D09290000680D06EB901D0082300800
   Shop #: WSC 01642 210 00002
   VCID: 78BC3B49CB81C68AE5-802C
                    Fault Status: 00100101
                    Reset counter: 23
                    Mileage: 110345 km
                    Date: 2013.07.23
                    Time: 14:56:21
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 212
                    Count: 41216
                    Count: 7936
                    Count: 64000
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   VCID: 7EB02D51E1A5F8BAAF-802A
          B10AB F0 [009] - Too Low
                    Reset counter: 186
                    Mileage: 79657 km
                    Date: 2017.01.12
                    Time: 09:31:32
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0575
   Revision: 00103 AG
   Coding: 48180A3A9827F1C044080080640081E443D10088736D8520648000200000
   VCID: 302CC3696371DECA6D-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 17031  21  0512
   Coding: 009795
   Component: RLS 250310 05  54  0403
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
                    Fault Status: 00101110
                    Reset counter: 23
                    Mileage: 87371 km
                    Date: 2012.03.05
                    Time: 16:14:23
                        Term 15 Off
                    Voltage: 14.00 V
                        Term 50 Off
                    Fault Frequency: 38
                    Reset counter: 25
                    Mileage: 109924 km
                    Date: 2013.07.18
                    Time: 17:06:08
                    Voltage: 13.90 V
                        Term 50 Off
            000 -  -  - Intermittent
                    Reset counter: 23
                    Mileage: 110345 km
                    Date: 2013.07.23
                    Time: 14:40:33
                    Voltage: 11.75 V
                        Term 50 Off
   Part No SW: 5K0 959 655 E    HW: 5K0 959 655 E
   Component: AirbagVW10G   037 0606
   Serial number: 003FLR00KVTH
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C34E759B7392AAAC1-8068
   Serial number: 3572MSME2B225451ZZZP
   Serial number: 3582MSME4A400351ZZZL
   Serial number: 3512QSME08285615ZZZQ
   Serial number: 3522QSME10385377ZZZQ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000502
   VCID: 78BC3B490B81C68AE5-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K6 920 970 E    HW: 5K6 920 970 E
   Component: KOMBI         H03 0305
   Coding: 770F00
   VCID: 3620F5718915F0FA37-8062
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 280310F2000229
   Coding: E9807F06000212000003
   VCID: 699A6E0D402B6F026A-803C
   Component: IMMO          H03 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9811018D2D641A63-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667915165
   VCID: 2600253151B5807A87-8072
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 312AC66DA87BD7C262-8064
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0000692
   VCID: 3228C961AD7DECDA1B-8066
00110 - Right Mirror Turn Signal Lamp (L132)
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: RCD310 EU     H11 5032
   Revision: -----01S    Serial number: VWZ4Z2K1157974
   Coding: 0300040004
   VCID: 6582623D6C334B624E-8030
00857 - CD Changer Unit (R41)
                    Reset counter: 238
                    Mileage: 110345 km
                    Date: 2013.07.23
                    Time: 14:54:30
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 3424CF795769E2EA09-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 3522F27D5C13FBE23E-8060
00935 - Electric Window Motor; Rear Right (V27)
End----------(Elapsed Time: 01:04, VBatt start/end: 14.0V/14.1V)-----------
myounus
Northwest UK
C?ID=321059
Hi Mark. The easiest way to check this is to stick a VIN into ETKA of a gtd or gti with xenons and document the part number. I'm not home at the minute (at work) but from memory I think it's 1K0938087L.
Mark Hudson
C?ID=290534
Hi, thanks for you’re reply. I have done this and it has given me a different part number (1K0 937 087 E) however it has three letters at the end (Z00) or something like that, when I put my own vin in I get the same part number but with a different three letters... I would like to fit a used module to keep prices down but I’m not sure how I would match the three letters to a second hand module as I haven’t seen one with these letter displayed anywhere yet. I don’t know if there is more than one module that would do the job, I know ETKA gives the latest part number on (superseded). Any advice would be helpful.
Thanks Again
Mark
That would be the "index" or "color code" and likely reflects the parameterization of the module.
Mark Hudson
C?ID=290534
So in other words it doesn’t matter about that code for picking up a used module, I will just be able to re-parameterise the module?
Mark
m87a
Bosnia and Herzegovina
C?ID=156900
Here is from my GTD higline bcm with bi xenon led and rear led lights
   Part No SW: [B][COLOR="#FF0000"]1K0 937 087 J[/COLOR][/B]    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 [B][COLOR="#FF0000"]0615[/COLOR][/B]
   Revision: 00103 AD
   Coding: 66180A3AE8251A0000C80080300089EC47FD0088733D8520E48840240040
   VCID: 38756AA58B5F81FEAE-806C
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 30101  26  0512
   Coding: 009F95
   Component: RLS 161010 05  54  0403
   Coding: 0730AD
if you decide to go for HBA later, then you need 1K0 937 087 R (or any other bcm with sw higher than 615, next sw is 651...)
as for index there is no need since byte 18 will be recoded, and you can use even skoda bcm with correct coding
I'm not sure where you got that idea.
Mark Hudson
C?ID=290534
As far as I was aware when you program in a new module with ODIS it parameterises the module which is making me think that you don’t need a specificly parameterizes module if you are going to re-code/adapt/parameterize it when you put it into the car...
Mark Hudson
C?ID=290534
   Revision: 00103 AD
   Coding: 009F95
   Coding: 0730AD
That’s great, thanks for that, does yours have LED licence plate lamps?
Cheers
Mark Hudson
C?ID=290534
for LED license plate lights you need sw0651 ;)
Is there any particular part number for a module with sw0651?
Mark
myounus
Northwest UK
C?ID=321059
Mark
M87a already answered that, "then you need 1K0 937 087 R". The letters at the end of the part number represent a later software version, after single letters VW have started using double letters. However, with a certain third party tool you can upgrade the software on any BCM. We shall leave that conversation there!
Get yourself the most appropriate 'letter' version you can find.
Mark Hudson
C?ID=290534
Sorry, that’s just me not reading his post correctly! Thanks for clearing that up, thanks a lot for all your help.
Regards
Mark
