Seat Ibiza ABS CODING
Astro
Europe
C?ID=359798
Hello
Im new on this forum so this is my first post
Today a seat ibiza came to my garage with the abs light blinking and i entered to check dtc it showed that the ecu not coded so i called the costumer and he sayd that he changed the abs ecu and it lost the coding when i entered on coding the whole coding was all 0000000 and i thought that anyone can help
Thank you very very much
Sunday,03,March,2019,17:09:40:48952
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
VIN: VSSZZZ6JZAR034785   License Plate: 04-270-HA
Mileage: 193050km-119955mi   Repair Order: 1
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR034785   Mileage: 193050km-119955miles
44-Steering Assist -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 045-906-013-BMS.clb
   Part No SW: 045 906 013 AD    HW: 045 906 013 AB
   Component: R3 1,4L EDC 0000SG  3065
   Revision: --H04---    Serial number:
   Coding: 0053071
   Shop #: WSC 61321 000 1048576
   VCID: D1EAF7DA485682C282-8084
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 13765 790 00041
   VCID: CED0ECA69D689D3A9F-809A
            000 -  -
                    Fault Frequency: 55
                    Reset counter: 241
                    Mileage: 192854 km
                    Date: 2013.07.21
                    Time: 01:24:32
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x1013
                    Hex Value: 0x149E
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045     HW: 6J0 820 045
   Component: J301  Klimaanlage   0280
   Revision: 00 23 08    Serial number: 0000000195307-
   VCID: E3862D1222EA005220-80B6
   Part No SW: 6R0 937 086 B    HW: 6R0 937 086 B
   Component: PQ25 BCM      H08 0025
   Revision: BD008001    Serial number: 9953A175090518
   Coding: 3E882BE888610100002000003E0B1C800000400F600000002000
   Shop #: WSC 64564 324 38760
   VCID: BB36B5723ADA189248-80EE
   Subsystem 1 - Part No SW: 6R0 959 801     HW: 6R0 959 801   Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  001 0237
   Coding: 020000
   Subsystem 2 - Part No SW: 6R0 959 802 B    HW: 6R0 959 802 B  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  001 0241
   Coding: 020000
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10AirbagA0A H09 0018
   Revision: --------    Serial number: 003DW0047EG3
   Coding: 003041
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: C2C8C8965530695A0B-8096
   Serial number: 3496GRB402V8VO8ETRPL
   Serial number: 3506GRB40279F7IH44F+
   Part No SW: 6J0 920 801 A    HW: 6J0 920 801 A
   Component: KOMBI         H07 0110
   Coding: 110A00
   Shop #: WSC 06402 785 00200
   VCID: A502730AA45EBE620E-80F0
   Part No SW: 6N0 909 901     HW: 6R0 937 086 B
   Component: GW-K-CAN TP20 0025
   Coding: 022200
   VCID: F0AC525E231CABCAAD-80A4
                    Reset counter: 18
                    Mileage: 192639 km
                    Date: 2013.07.14
                    Time: 20:32:53
   Component: IMMO          H07 0110
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10111
   Shop #: WSC 06402
   VCID: AE108C266DA8FD3AFF-80FA
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: F0AC525EE31CABCAAD-80A4
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J0 035 153 B    HW: 6J0 035 153 B
   Component: Radio G3 UL   H56 0034
   Revision: 0H001001    Serial number: SEZ1Z2I6316244
   Coding: 0503040002
   Shop #: WSC 04941 000 00000
   VCID: A3066D12A26A405260-80F6
End----------(Elapsed Time: 00:51, VBatt start/end: 12.6V/12.6V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
I'm sorry, it's the best I can do. If you need it done quickly, go to the VW dealer and do an SVM. And please post the solution.
Astro
Europe
C?ID=359798
thank you very much tested but its not working
any other idea
NEtech
Denmark
C?ID=56995
First write numbers for wsc, importer, device no. for example described here.
[Save]
[Close VCDS]
Start VCDS again
Try to enter the Secure Access that is showed first.
Then use this Coding:
1000000008000000000000
Please explain what happens, is it accepted or not, what is the message ?
Has the ABS controller been changed ?
It does not look like it is from this car.
Astro
Europe
C?ID=359798
[Save]
[Close VCDS]
Start VCDS again
the abs controller is changed but i dont know what controller did they add on the car and i tried youre coding but still not work now its the length of coding very short
NEtech
Denmark
C?ID=56995
How did it not work?
What was the message, make a screenshot and show here.
Yes it is short, that is the test.
Astro
Europe
C?ID=359798
brother i tried the coding and it showed coding rejected but now i saw that abs controller that they put in the car hasnt the same numbers as the old one now isnt being coded thats the problem
United States
That's exactly what we are looking to determine. The incorrect ABS module may not accept factory condition coding and in other cases the incorrect diagnostic VIN (due to used 01-Engine module or 17-Instrument cluster) may explain rejected coding. All zero WSC, Importer or Equipment numbers can also be responsible for rejected coding.
For those reasons the exact error message you are receiving may shed light on the situation. I would also check the Advanced ID function in addresses 01, 17 and 25 and add that data to a log so it can be posted for evaluation similar to this thread: https://forums.ross-tech.com/showth...ding-(MK60EC1)&p=157233&viewfull=1#post157233
I would plug in the original module to see if it communicates at all and save a scan to see if the original coding is still present. If you can obtain any data out of the original unit please post it here.
