Hello, I'm having problems with a Led stop adaptation, the car is a Seat Leon FR 2012, on the coding VCDS there aren't any option to do this coding. The led stops are factory LED tail lights.
Thanks!
Thanks!
Work Shop Code: WSC 04941
VCID: 43858FCAC218E906C65-8016
Advanced Identification
Identification: SME-RBG
Revision: BL111001
Date: 11.04.11
Manufacturer number: 0005
Test stand number: 2871
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 0000.00.00
Flash Tool Code: 00000 000 00000
Software
BAP: 01.04.00
Misc.
Hardware number: 5K0 937 087 Q
Workshop System Name: J519
VCDS Info:
Labels: 1K0-937-08x-09.clb
VCDS Version: Release 12.12.2
Data version: 20140212
JJIMENEZ SERVICIO TECNICO
Monday,17,March,2014,18:11:22:36145
Chassis Type: 1P (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: VSSCL61P6CR000196
02-Auto Trans -- Status: Sporadic communication error 1000
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 1P0 907 115 AD HW: 1P0 907 115 Q
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0303000C1C070160
Shop #: WSC 06402 785 00200
VCID: 6DD10972741CCF76401-8038
Readiness: 1010 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 054 L HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2604
Revision: 05351112 Serial number: 00001102191806
VCID: 1F4D23BACE30EDE682D-804A
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 143B6012092200FA280C06ED901F0041350800
Shop #: WSC 04941 000 00000
VCID: 76E3261EC14A0CAEB1B-8023
7 Faults Found:
00526 - Brake Light Switch-F
Reset counter: 146
Mileage: 16921 km
Date: 2031.14.10
Time: 11:32:45
Count: 15
Count: 14
Count: 12800
Count: 148
Count: 49922
Count: 254
Fault Status: 00100011
Reset counter: 146
Mileage: 16919 km
Date: 2031.14.10
Time: 11:30:23
Count: 8
Count: 2
Count: 4608
Count: 83
Count: 50177
Count: 254
Reset counter: 146
Mileage: 16919 km
Date: 2031.14.10
Time: 11:30:23
Count: 8
Count: 2
Count: 4608
Count: 67
Count: 50177
Count: 254
Reset counter: 146
Mileage: 16927 km
Date: 2031.14.10
Time: 21:15:01
Count: 12
Count: 28672
Count: 8195
Count: 43776
Count: 512
Count: 254
02214 - Tire Pressure Warning
Reset counter: 150
Mileage: 16931 km
Date: 2031.14.13
Time: 16:58:39
Count: 32768
Count: 4608
Count: 397
Count: 50434
Count: 766
Fault Status: 00101101
Reset counter: 152
Mileage: 16809 km
Date: 2031.14.09
Time: 03:27:52
Count: 2
Count: 14
Count: 29184
Count: 8193
Count: 50688
Count: 254
Reset counter: 170
Mileage: 17197 km
Count: 7
Count: 13
Count: 12288
Count: 128
Count: 29952
Count: 254
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0702
Revision: 00001001
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3D71F932ACFC9FF6B01-8068
Part No SW: 5K0 937 087 Q HW: 5K0 937 087 Q
Component: BCM PQ35 H+ 111 0148
Revision: BL111001
Coding: 4C180A3E8037B0C0428800809500810442D19BA8527D89605C8040040040
Shop #: WSC 04941 123 12345
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 16041 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171 A
Component: Innenraumuebe 010 4974
Fault Status: 00101010
Reset counter: 170
Mileage: 17198 km
Date: 2032.14.03
Time: 04:22:15
Term 15 On
Voltage: 13.80 V
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 5P0 919 475
Component: PARKHILFE 4K H07 0005
Revision: -------- Serial number: 89341109213759
Coding: 000104
VCID: 3A7BF22EB5D2A8CE953-806F
00532 - Supply Voltage B+
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 03:58:19
Temperature: 19.0°C
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 03:57:29
Temperature: 19.0°C
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__A09 VW10 HI 1918
Revision: 22014000 Serial number: 003K0P7GQDN4
Coding: 0012345
VCID: 4C97A4F62F46267E37F-8019
Subsystem 1 - Serial number: 6332MTS640340931
Subsystem 2 - Serial number: 6342MTS621210931
Subsystem 3 - Serial number: 6351HTS6FO9LU9KJ
Subsystem 4 - Serial number: 6361HTS6Q5F0U9KJ
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 03:56:25
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20110418301243
Coding: 189A140002
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF33E3EE17A44EEE9B-802B
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: E30000
0516 - Databus
Reset counter: 146
Mileage: 16927 km
Date: 2031.14.10
Time: 21:15:02
136194 - Supply voltage
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:18:23
Part No SW: 1P0 920 851 B HW: 1P0 920 851 B
Component: KOMBI H06 0420
Coding: 110A00
Shop #: WSC 13107 102 20971
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2C57C4764786067E17F-8079
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 146
Mileage: 16927 km
Date: 2031.14.10
Time: 21:15:01
13635840 - Supply voltage
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:11:56
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 010411F6000592
Coding: 350202
VCID: 306FD00663AE629E2B7-8065
Fault Status: 00110100
Reset counter: 146
Mileage: 16927 km
Date: 2031.14.10
Time: 21:15:02
00381 - Databus Instrument Cluster
Reset counter: 146
Mileage: 16927 km
Date: 2031.14.10
Time: 14:42:48
01304 - Radio
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 00:07:20
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:11:22
03272 - Control Module for Audio Interface
Reset counter: 127
Mileage: 11743 km
Date: 2022.14.15
Time: 19:33:48
Component: IMMO H06 0420
VCID: EADB826E0DF2584EA53-80BF
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0507
Revision: 12110009 Serial number: 0002519082
Coding: 0010B0
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: EDD189723C1C4F76C01-80B8
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005738381
Coding: 000090
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 141
65793 - Supply voltage
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:14:17
131329 - Rear Door Control Module
B11ED F0 [008] - Supply Voltage too Low
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:18:52
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 140
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 142 3201
Revision: 00H20000
VCID: 3467DC1657B65EBE4FF-8061
01316 - ABS Control Module
Reset counter: 146
Mileage: 16919 km
Date: 2031.14.10
Time: 11:30:24
Voltage: 14.00 V
DU
Temperature: 40.0°C
RPM: 2189 /min
Speed: 18.0 km/h
Speed: 18.0 km/h
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0507
Revision: 14110009 Serial number: 0002471378
Coding: 0010B0
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: EED38E7E311AB46EF9B-80BB
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005731959
Coding: 000090
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 129
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:14:12
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:19:15
Reset counter: 140
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669640414
Coding: 0D00000001010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: E2CBEA4EF5C2000E6D3-80B7
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 127
Mileage: 11743 km
Date: 2022.14.15
Time: 20:05:50
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:12:08
U1400 00 [008] - -
Reset counter: 169
Mileage: 17197 km
Date: 2032.14.00
Time: 04:11:11
