Audi A3 8P 2009 ABS Long Coding (MK60EC1)
gazpot0111645
C?ID=255209
Good Evening All,
I have a friend that took it upon himselft to replace his instrument cluster before I had ever ran an autoscan to save his coding. Now that he has the cluster fitted there is faults left right and centre. One of which I am struggling to sort is the long coding for the abs module is now all set at 0's. Here is his autoscan. Is there anyway of calculating a long code? His car is:
Audi A3 8P RHD
1.8TSI
3 Door
Automatic
Tuesday,26,February,2019,18:57:55:40380
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8P5AA034091   License Plate: GV09WGF
Mileage: 182590km-113456mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56
VIN: WAUZZZ8P5AA034091   Mileage: 182590km-113456miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 L    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH06---    Serial number: AUX7Z0I6FNF0FG
   Coding: 0103000C24070160
   Shop #: WSC 00191 264 15243
   VCID: 428B1DC61D126D5A8B-8016
               P0299 - 000 - Control Range Not Reached - Intermittent
                    Mileage: 182471 km
                    Date: 2019.02.25
                    Time: 00:55:07
                    RPM: 5408 /min
                    Load: 78.4 %
                    Speed: 53.0 km/h
                    Temperature: 99.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.589 V
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - Intermittent
                    Mileage: 182516 km
                    Date: 2019.02.25
                    Time: 16:46:46
                    RPM: 5998 /min
                    Load: 82.3 %
                    Speed: 139.0 km/h
                    Temperature: 93.0°C
                    Temperature: 21.0°C
                    Voltage: 13.716 V
001299 - Incorrect Immobilizer Key
               P0513 - 000 -  - Intermittent
                    Mileage: 371674 km
                    Date: 2019.02.15
                    Time: 00:00:16
                    RPM: 811 /min
                    Load: 14.1 %
                    Temperature: 93.0°C
                    Temperature: 66.0°C
                    Voltage: 11.684 V
               U0155 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 92.0°C
                    Temperature: 66.0°C
                    Voltage: 11.938 V
004688 - Fuel Level too Low
               P1250 - 000 -
                    Mileage: 182598 km
                    Date: 2019.02.26
                    Time: 18:47:45
                    RPM: 748 /min
                    Load: 13.3 %
                    Temperature: 100.0°C
                    Temperature: 73.0°C
                    Voltage: 13.081 V
   Part No SW: 0AM 300 048 M    HW: 0AM 927 769 D
   Component: GSG DSG AG7     403 9032
   Revision: 00040034    Serial number: TFK01010080145
   Shop #: WSC 38488 001 1048576
   VCID: 3A7B652675C2259AD3-806E
006300 - Function Restriction due to Insufficient Pressure Build-Up
               P189C - 000 -  - Intermittent
                    Reset counter: 6
                    Mileage: 182483 km
                    Date: 2019.02.25
                    Time: 10:10:21
006242 - Powertrain Data Bus
               P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Reset counter: 10
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 19021 000 1048576
   VCID: 000FD7CE939EBF4ADD-8054
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 252
                    Mileage: 182598 km
                    Date: 2019.02.26
                    Time: 18:50:39
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 4161
                    Count: 47616
            000 -  -
                    Reset counter: 252
                    Mileage: 182598 km
                    Date: 2019.02.26
                    Time: 18:47:28
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 195
                    Count: 44288
   Part No SW: 8P0 820 043 BL    HW: 8P0 820 043 BL
   Component: KlimavollautomatH09 0130
   Revision: 000656      Serial number: 8P0820043BL
   VCID: 77FDBC120650F8F2EC-8022
                    Reset counter: 36
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   104 0575
   Revision: 00104 AH
   Coding: 06000A2FB005F000207041E00100094C437E25AA306DD929E40008840040
   Shop #: WSC 00441 210 88110
   VCID: 326B4D066DB2DDDA1B-8066
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 5 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
                    Reset counter: 248
                    Mileage: 182442 km
                    Date: 2019.02.24
                    Time: 23:57:55
                    Voltage: 13.50 V
                        Term 50 Off
                    Reset counter: 37
                    Mileage: 371674 km
                    Voltage: 11.80 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93640919504584
   Coding: 000103
   Shop #: WSC 06314 000 00000
   VCID: 428B1DC6DD126D5A8B-8016
                    Reset counter: 37
                    Temperature: 0.0°C
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003FB00282KI
   Coding: 303142413039303030384A55305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FAD24F21640903214-801A
   Serial number: 34928RB400004EC86F97
   Serial number: 35028RB400004EC85FC1
   Serial number: 35128RB400004EC8FCC9
   Serial number: 35228RB400004EC85F8%
   Serial number: 35547RB400004ED99B85
   Serial number: 35647RB400004ED99C32
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Reset counter: 37
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0012142
   VCID: 468301D6313A517AA7-8012
   Component: E0221           H06 0030
   Part No SW: 8P0 920 982 M    HW: 8P0 920 982 M
   Component: KOMBIINSTR. VDO H02 0980
   Revision: D0H02002    Serial number: 2246I002001550
   Coding: 0000408
   VCID: 438518C20208645280-8016
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K09715036C
   Coding: EDA11F06000202000101
   VCID: 66C3E15651FA717A47-8032
                    Reset counter: 36
                    Reset counter: 36
   Revision: D0H02002    Serial number: AUX7Z0I6FNF0FG
   Shop #: WSC 00441 210 97470
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 M    HW: 8P0 959 801 M
   Component: Tuer-SG         H04 0100
   Coding: 0000564
   VCID: 458106DA0C3C5A62AE-8010
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 233    2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F6D4472BE80F03274-807A
                    Reset counter: 37
                    Voltage: 11.88 V
                        DD
                    Temperature: 35.0°C
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 182598 km
                    Date: 2019.02.26
                    Time: 18:12:26
                    Battery Volts: 13.5 V
                        DU
                    Temperature: 39.0°C
                    Count: 9
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 8P0 959 802 M    HW: 8P0 959 802 M
   Coding: 0000564
   Shop #: WSC 00441 210 91369
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AFBA5263542E59A93-802E
                    Reset counter: 37
   Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
   Component: R Concert2+     H02 0280
   Revision: 00H02000    Serial number: AUZ1Z3I5132594
   Coding: 0330101
                    Reset counter: 37
End-------------------------(Elapsed Time: 02:19)--------------------------
Many Thanks
Gary
United States
Please verify this is the actual VIN: WAUZZZ8P5AA034091
Also, check the Advanced ID function in addresses 01, 17 (and 25 which may not show a VIN at all) to verify the same VIN is shown diagnostically. Add the data to a log if you spot anything goofy so it can be pasted here.
As long as all of the VINs match we should be able to assist.
gazpot0111645
C?ID=255209
Thank you for your reply, My friend has now been back to me and i have logged the following as requested. All VINs seem to match.
Saturday,02,March,2019,15:00:54:40380
                Address 01: Engine
Control Module Part Number: 8P7 907 115 L
  Component and/or Version: 1.8l R4/4V TFSI     0030
           Software Coding: 0103000C24070160
            Work Shop Code: WSC 00191
Advanced Identification
     Identification: RB8-658
     Revision: AAH06---
     Date: 29.06.09
     Test stand number: 1354
     Manufacturer number: 1623
Flash Status
     Programming Attempts: 3
     Successful Attempts: 3
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 72587 264 00191
     Flash Date: 11.01.19
Software
     A0101
     A5.1.6a
Misc.
     Hardware number: 8P0 907 115 Q
     Immo Challenge: 08 26 10 6A
Car Info
     Chassis Number: WAUZZZ8P5AA034091
     Engine code: CDA
VCDS Info:
       Labels: 06J-907-115-CDA.clb
       Readiness: 06F-907-115-AXX.crd
Saturday,02,March,2019,15:04:54:40380
Control Module Part Number: 8P0 920 982 M
  Component and/or Version: KOMBIINSTR. VDO H02 0980
           Software Coding: 0000408
            Work Shop Code: WSC 12345
     Identification: VDD-024
     Revision: D0H02002
     Date: 15.07.09
     Test stand number: 7601
     Manufacturer number: 0556
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Flash Tool Code: 00000 000 00000
     Flash Date: 15.07.09
Misc.
     Hardware number: 8P0 920 982 M
     Lot Number:
     Type Lock: VDD-
Car Info
VCDS Info:
Saturday,02,March,2019,15:03:27:40380
           Software Coding:
            Work Shop Code: WSC 00441
     Revision: D0H02002
     Date: 15.07.09
Misc.
     Lot Number:
     Type Lock: VDD-
     Immo Challenge: FB CB 45 38
Car Info
VCDS Info:
Many Thanks
Gary
United States
Thanks for confirming all diagnostic VINs match! I believe the factory condition 03-ABS coding was:
13424012092500FEC80B02ED901A0081B900
The Basic Settings on this page apply: VW Golf (1K) Brake Electronics (MK60EC1)
[HR][/HR]
Vehicle Identification No. WAUZZZ8P5AA034091
Model audi a3 1.8 fsi
A3
Date of production 23.07.2009
Year 2010
Sales type 8P1B6G
Engine Code CDAA
Transmission Code LSS
G1C 7-speed automatic transmission
L0R Right-hand drive
1N3 Speed-related variable steering assist (Servotronic)
0YE Weight range 5 installation control only, no requirement forecast
2UC Sports version
1AT Electronic stability control (ESC)
1ZE Disc brakes in front (Geomet D)
1KD Disc brakes in rear
UG1 Hill hold control
7K0 Without tyre pressure monitor
7X1 Park distance control
7L3 Without start/stop system without regenerative braking​
gazpot0111645
C?ID=255209
Hi,
I can confirm that the coding that Dana provided worked. I performed basic settings and clear of all faults. Many thanks to you all for your time and effort helping me with this, it is much appreciated.
Regards
Gary
