B8 Passat R-Line - Active Info Display Retrofit - almost complete
CarlightExpress
C?ID=353848
Hi All
Does anyone have a B8 Passat TDi that they can grab their coding for 17 and 5F for me? I have had the cluster fitted and everything is working fine except for the map display on the cluster, I suspect there's some tweaks that have to be made, but can only find the Golf tweaks and the Passat is slightly different.
TIA
Simon
Since the question is primarily about a retrofit cluster, I'll move this to Retrofits.
It would not hurt to post a scan from your car.
vastechnics
C?ID=143747
Have you add most fibre?
CarlightExpress
C?ID=353848
The Fiber Cable has been added yes, but in order to troubleshoot I disconnected the fibre from the Infotainment unit and the two ports are not illuminated
Here's the Scan from the car
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
          BB BC
VIN: WVWZZZ3CZFE465481   Mileage: 9030km-5610miles
08-Auto HVAC -- Status: Malfunction 0000
5F-Information Electr. -- Status: Malfunction 0000
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026     HW: 03N 907 309
   Component: R4 2,0L EDC   X23 1707
   Revision: A1X23---
   Coding: 01250012036705083000
   Shop #: WSC 68107 514 16480
   ASAM Dataset: EV_ECM20BTD01103N906026 001011
   ROD: EV_ECM20BTD01103N906026.rod
   VCID: 6889BAE702F95CA736D-803C
   Part No SW: 0DL 300 011     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 4701
   Revision: 00H10V01
   ROD: EV_TCMDQ500021.rod
   VCID: 6597B3D3F5EB41CF0DB-8030
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60575000000842
   Coding: 0FEC938F54260B71077B070841C469F0C92AD0E0E08296F5186250F8C209
   Shop #: WSC 22255 002 1048576
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 49CF5F63793385AF093-801C
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0524
   Revision: 00023000    Serial number: 0361563484
   Coding: 000F0F0703
   Shop #: WSC 05311 115 00318
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 77ABE99B5F47C35FAF7-8022
   Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
   Revision: 00001K10
   Coding: 12120104202100012015500000101802
   Shop #: WSC 00015 115 08193
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6D87CBF32D1B798F45B-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86581102150587
   Coding: 03051C46C24102FF0B844084B11C07281880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA7FBB37D7BE90FF5B-8028
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150206  043 0607
   Serial number:         150211091834
   Component: RLHS  037 0059
   Serial number: S4Y15M03D04H10M28S35
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 25 12 2014  00000636
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150233L5U
   Serial number: 00000000000061746339
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391503403756
   Coding: 0071051011
   Shop #: WSC 05311 115 00063
   ROD: EV_EPHVA18AU3700000_002_VW48.rod
   VCID: 40D942474A0944E7DED-8014
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 3260678110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 33331D8B0BBFEF7F53F-8066
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 21091441350106
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76B5E49F584DBA57B41-8022
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1P36581-
   Coding: 98FCC0C0008000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015F874301838DEF913-8054
   Belt Pretensioner left:
   Serial number: 3G2857705C0056P00133
   Coding: 80000A
   Belt Pretensioner right:
   Serial number: 3G2857706C0055P00540
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 001 402 15
   Serial number: 3576U00000099A342316
   Subsystem 4 - Part No SW: -----------    HW: 454 001 402 15
   Serial number: 3586U0000002FA342316
   Subsystem 5 - Part No SW: -----------    HW: 454 801 702 15
   Serial number: 3516R9C0B1C060000007
   Subsystem 6 - Part No SW: -----------    HW: 454 801 702 15
   Serial number: 3526R14CBDA05000000D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 502 15
   Serial number: 3556VC3659D05000000H
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150219500294
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D273BB33DFB290FB5B-8068
   Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Component: KOMBI         411 1340
   Coding: 27A50818BF80260001886A001400000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardVDDMQBAB 009048
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 270BF9DBCF6793DFFF7-8072
   Revision: --------    Serial number: 20021510800304
   Coding: 030300044F017300EF00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72BDD88F3425A677989-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000283980025072
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 7094145603
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00012.01.15
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46D5545F682D6AD7E41-8012
   Serial number: 15000017330012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD78331239D6F613-8024
   Serial number: 170215BBG09828
   Coding: 003F0A20D001028000001000
   VCID: 42DD484F440556F7C89-8016
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Shop #: WSC 00015 115 00318
   VCID: 43D34D4B5B1F5FFFC3F-8016
   Serial number: 210215BBK19017
   Coding: 003F0020D001028000001000
   VCID: 41DF474341034DEFD13-8014
   Component: AFS-ECU       H01 0110
   Coding: 03A602000F210200
   Shop #: WSC 21075 002 1048576
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FDB41BB37F73B1FA77-806A
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3G0 035 020 A    HW: 3G0 035 020
   Component: MU-H-ND-EU    H41 0121
   Serial number: A598B0F7500468
   Coding: 02840201FF00000011111201000808001F0106C601200000DE
   VCID: 1577C313650B114F5DB-8040
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9PU300VP4
   Subsystem 2 - Part No SW: V03 959 806 FL    HW: -----------
   Component: ECE 2019  --- 0175
   Compact Disc Database:
   Component: Gracenote2  --- 1008
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 130215BBC19455
   Coding: 000E00200101028000001000
   VCID: 44D14E575E1158C7FA5-8010
   Component: TSG HBFS      020 0028
   Serial number: 130215BBC19459
End----------(Elapsed Time: 02:11, VBatt start/end: 12.2V/12.2V)-----------
^^^ Wow - that's the 1st time that I have seen the error message "5F-Information Electr. -- Status: Malfunction 0000" in the summary part of an auto-scan report and "No fault code found" in the detailed records of the 5F module listing. At face value - it would appear (to me at least) that the VCDS device is deliberately telling "porkies" - but I'm prepared to give the cable the benefit of doubt! :D
Uwe: am I missing something? Or is this a not-surprising outcome in certain conditions? If so, please explain why this happens
vastechnics
C?ID=143747
Is the MOST port activated? Byte 19 bit 5.
Instrumentel Cluster graphics needs to be unchecked.
Import is also the 5F coding. post adaption map of that
^^^^ good points!!!
here's OP's code-string values for his/her? 5F module:
Byte	Hex	Binary
0	02	00000010
1	84	10000100
2	02	00000010
3	01	00000001
4	FF	11111111
5	00	00000000
6	00	00000000
7	00	00000000
8	11	00010001
9	11	00010001
10	12	00010010
11	01	00000001
12	00	00000000
13	08	00001000
14	08	00001000
15	00	00000000
16	1F	00011111
17	01	00000001
18	06	00000110
19	C6	11000110
20	01	00000001
21	20	00100000
22	00	00000000
23	00	00000000
24	DE	11011110
25		00000000
26		00000000
27		00000000
28		00000000
29		00000000
30		00000000
So, Byte 19, Bit 5 =0 (MOST=OFF) & Byte 22, Bit 0 =0 (Dashboard Graphics variant = MOST)
vastechnics
C?ID=143747
Thanks DV52. So MOST is off. Needs to be ON.
That is rather strange, isn't it?
I'm sure VCDS isn't deliberately misstating that. But IIRC, some of these cars have multiple entries in the GVL for 5F, which VCDS combines somehow, and I could see this internalizing some confusion. :eek:
CarlightExpress
C?ID=353848
Awesome, It's alive :))))))
Many thanks guys, you guys are awesome :)
Simon
vastechnics
C?ID=143747
Hehe no problem. I do retrofit a lot for this. Done on MK7 Polo 2G Passat Tiguan etc
CarlightExpress
C?ID=353848
May I ask as you clearly use ODIS also, I have been informed that ODIS can correct the mileage but only Upwards, would that be correct?
Both ODIS and VCDS can correct mileage upward on a brand-new instrument cluster; one that has never been "corrected" before, and that has less than 100 km on the odometer.
CarlightExpress
C?ID=353848
Yes but I got a used cluster with significantly less mileage than my own car for a third of the price of a new cluster :) , but I am lead to believe ODIS can correct but only upwards
I don't think so.
IWMTom
C?ID=313572
It can't - I have the same problem after retrofitting a used AID.
Currently, I only know of one company which claims to have managed it, but I doubt the validity of their claims.
I've just printed a little sticker that I've attached to the cluster trim with the date of the swap, the old mileage, the mileage on the cluster when it was installed, and the number that needs to be added to the current displayed odometer reading to get the true mileage of the car.
vastechnics
C?ID=143747
Hello mileage is not changeable. Only new cluster or less 100 km. But can also do once or twice dont know exatly.
People who claim they do mileage corection on AiD just crap. Nobody can yet. AID introduced since Passat B8. Still no solution so.
CarlightExpress
C?ID=353848
I have just located a cluster with 34km on the clock (So can have mileage corrected since it is below the 100km), but the part number ends in a C as opposed to the one I have ending in A, notibly the Immobiliser code on the sticker is a GEKOWSF2, I presume this cluster will still work in my car?
My current cluster retrofitted cluster: 3G0920791A
Alternative cluster with <100km : 3G0920791C
I presume it will still work, but anyone know for sure?
