Polo 6R MY2011 G250 issue
MartinsX
Riga, Latvia
C?ID=268515
The car was crashed and repaired before it came to my workshop. Together with a lot of other issues, mainly already solved, I got G250 sensor faulty DTC.
Wiring from PS pump/control module to G250 was damaged in crash and badly repaired. I redid repair and DTC changed from
00816 - Power Steering Sensor (G250)
            30-00 - Open or Short to Plus
to
            37-00 - Faulty
Another (used) sensor gives the same fault. Both sensors are Hella made, 6Q0 423 445
Ok, there are couple of simple possibilities: another used sensor is faulty, too; signal input of control module is faulty; etc.
But couple things get me puzzled:
1) GW list in autoscan shows 44-Steering Assist -- Status: OK 0000, but DTC in module 44 is permanent;
2) according WD cable 6Q1 901 129 pinout is #1 to #1, #2 to #2 and #3 to #3. In reality pin #1 goes to pin #3 and vice versa. Cable was damaged in the middle and connected back by colors of wires. The only WD showing pin numbers in both ends is for Polo 6R, all other WD's of models using the same 6Q1 901 129 cable shows numbering only in one end. Do anyone have that type of car or separate cable handy and is willing to help me with pinout?
Autoscan:
Tuesday,26,February,2019,01:29:26:32442
VCDS Version: 18.9.1.0
VIN: WVWZZZ6RZBY233699   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY233699   Mileage: 178630km-110995miles
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C1DBAB641F7C624E-8030
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AE    HW: 6R0 907 379 AC
   Component: ABS8.2 front  H04 0001
   Revision: --------
   Coding: 200224E3017000B5042B24EB80DA00000200
   Shop #: WSC 00788 648 00255
   VCID: 0109EF3B9C77B042D2-8054
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 31
                    Reset counter: 84
                    Mileage: 178614 km
                    Date: 2013.07.15
                    Time: 13:45:41
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x3203
                    Hex Value: 0x1997
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 31697FFB6857E0C262-8064
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 038111723
   Coding: 3CB029BF08A10000002008003D2B0CD00088410F60060000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 428B2037DDF16B5A8B-8016
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  007 1621
   Serial number: KU0-KU024.01.1114910
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  007 1621
   Serial number: KU0-KU026.01.1115823
   Coding: 08BC30
                    Fault Status: 00101011
                    Reset counter: 124
                    Mileage: 178602 km
                    Date: 2013.07.14
                    Time: 10:16:53
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag01K H09 0020
   Revision: --------    Serial number: 003GX00F6RR+
   Coding: 00314B
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9B0817EDC1B31A43-801E
   Serial number: 3575HRB40630ATOCBP3U
   Serial number: 3585HRB405P0DGESFH86
   Serial number: 3515RRB405V0DD2AB0UQ
   Serial number: 3525RRB405T0DD2A4H05
   Part No SW: 6R0 920 861 E    HW: 6R0 920 861 E
   Component: KOMBI         H05 0114
   Serial number: 00000004569723
   Coding: 140800
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01013
   ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
   VCID: 377D41E38E333EF22C-8062
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
                    Mileage: 117658 km
                    Date: 2017.01.11
                    Time: 11:45:14
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002000
   VCID: 70EFBAFFA3DDA9CA2D-8024
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H05 0012
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25.rod
   Part No: 6Q0 423 156 G
   Component: Lenkhilfe           0004
   Coding: 00110
   Shop #: WSC 12345
   VCID: 336575F3064BD2D210-8066
            37-00 - Faulty
   Part No SW: 5M0 035 156 C    HW: 5M0 035 156 C
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1L0550340
   Coding: 0000020002
   VCID: 2959979B40879802AA-807C
End-------------------------(Elapsed Time: 01:58)--------------------------
BTW label file 6Q0-423-156.clb in coding help pop-up has x??xx descriptions/values interchanged.
iichel
Eindhoven, NB, NL
C?ID=284912
Are you sure the power steering pump itself is ok? Perhaps coding 01210 for the power steering pump. But I doubt this as soon as I wrote it.
MartinsX
Riga, Latvia
C?ID=268515
As I noted just after autoscan there is error in label file coding helper pop-up. x??xx value 12 is for external g85, signal via CAN, value 01 is for integrated G250. Descriptions for those values are interchanged.
Mainly I am asking just for someone to check pin numbering for cable 6Q1 901 129, both ends.
iichel
Eindhoven, NB, NL
C?ID=284912
Steering sensor to pump
1 to 1 (black)
2 to 2 (brown)
3 to 3 (green)
MartinsX
Riga, Latvia
C?ID=268515
Is this from elsa or measured from real cable?
iichel
Eindhoven, NB, NL
C?ID=284912
It's from Elsa
MartinsX
Riga, Latvia
C?ID=268515
I have the same WD but on real cable are 1 to 3 and 3 to 1. I'd like to compare with another cable with the same partnumber.
iichel
Eindhoven, NB, NL
C?ID=284912
Why not switch 1 and 3? See if it solves the problem?
MartinsX
Riga, Latvia
C?ID=268515
I tried it with original pump and G250. When connected according wire colors from damaged cable, fault is
            37-00 - Faulty
When connected according WD, fault is
just like when wires was broken. I'm not sure if interchanging +12 supply to G250 with PWM signal from G250 is a good idea. Don't know do the input/output circuits inside G250 and J500 have any kind of protection... I already have one possibly bad pump/J500 module and two possibly bad G250 sensors. Don't want more bad ones and will not try swap pins before receiving info what are connections of real undamaged/unrepaired original cable.
P.S. Last couple years I work for a dealer (unfortunately not for a VAG dealer) and I have seen a lot of errors in original wiring diagrams and other technical documentation, so I don't trust WD just because it is from ERWIN or ELSA.
I don't have hands-on experience with those systems to offer but I can discuss the label descriptions with a larger group next week. At a quick glance we have:
German lbl:
01 = Geber für Lenkwinkel ist Teil der Bremsenelektronik (für ALLE Bosch 5.7)
01 = Geber für Lenkwinkel NICHT verbaut (für ABS Bosch 8.0/8.2i)
12 = Geber für Lenkwinkel ist Teil der Lenkhilfe (für ASR bzw. ASR/ESP Bosch 8.0/8.2i)
English VCDS lbl:
01 = Steering Angle Sensor is Part of the ABS/ESP (for Bosch 5.7 Brake Electronics)
12 = Steering Angle Sensor is Part of the Steering Aid (for Bosch 8.0/8.2i Brake Electronics)
Do you feel as though adding the 2nd possibility for 01 to English VCDS would resolve the noted conflict -or- am I off track here?
P.S. I agree with incorrect wiring diagrams. I encountered that yesterday with a G40 wire to the ECM on a 2013 GLI 2.0T gas and had to use an incorrect diagram (from a 2010 GTI) to sort it.
Gone But Not Forgotten
Fake out LIN with resistance value or sensor and PSI sensor with variable value to see if you get a wake to vacate the DTC for testing.
MartinsX
Riga, Latvia
C?ID=268515
Solved. Another pump/J500 module fitted, coded and fault is gone.
BTW there is error in Elsa/ErWin diagram.
MartinsX
Riga, Latvia
C?ID=268515
German lbl:
English VCDS lbl:
I haven't tested changing coding for car with electric steering pump in combination with Bosch 5.7 just for investigation, so I can't comment it at this time. I didn't pay attention to coding descriptions before, mainly just copy/paste coding from old unit, when replacing one.
I think, label file should be:
12 = Steering Angle Sensor is Part of the ABS/ESP (for Bosch 5.7 Brake Electronics)
01 = Steering Angle Sensor is Part of the Steering Aid (for Bosch 8.0/8.2i Brake Electronics)
golfi_vend
Tartu, Estonia
C?ID=195131
I haven't checked this case, but on older Fabia and Polo there are 2 manufactures for power steering pump. Isn't that between those wiring may be different?
iichel
Eindhoven, NB, NL
C?ID=284912
In the Polo 6R, all pumps are made by TRW. In the 6Q (9N/3) generation, manufacturers were indeed TRW or KOYO.
