2007 Jetta FSI, DTC p0123 Help!
HectorT
C?ID=165912
Hello there, need some help here.
2007 Jetta 2.0T FSI.
Getting the code p0123 only when I apply about 50% +/- throttle. Otherwise, if I drive normal the MIL never goes on.
So far I have checked-
1-Fuses
2-Grounds
3-Battery
4-all easily accesible connections
5- TBA
6- new throttle body and redid TBA.
So what's next to try?
Monday,25,February,2019,05:53:47:51312
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWRJ71K28M193657   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRJ71K28M193657   Mileage: 239970km-149110miles
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H52480K5
   Coding: 0403010A1C070160
   Shop #: WSC 00066 000 00000
   VCID: 3663991C418F0DFA37-8062
000291 - Throttle Position Sensor (G69)
               P0123 - 001 - Signal too High
                    Fault Status: 01100001
                    Mileage: 239967 km
                    Time: 05:40:37
                    RPM: 751 /min
                    Load: 18.8 %
                    Temperature: 84.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
Readiness: 0100 0100
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AE
   Component: GSG DSG         082 1410
   Revision: 04708020    Serial number: 00000803061349
   VCID: 193972A0D051C2823A-804C
   Revision: 00H11001
   Coding: 0021122
   VCID: 73E56008127D58D2D0-8026
            013 - Check DTC Memory
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CF74B343F2317AA81-8028
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000913068
   Coding: 14058E234004150007140000001400000008730B5C000100000000000000
   VCID: 6FED6C787E557C3234-803A
   Component: Wischer 100608 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 00101001
                    Reset counter: 86
                    Mileage: 239962 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Fault Status: 00101100
                    Reset counter: 86
                    Mileage: 239962 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0340315
   Coding: 0000100
   VCID: 3365A00852FD18D210-8066
            000 -  -
                    Reset counter: 46
                    Mileage: 239962 km
                    Time: 15:05:05
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M05HS6C
   Coding: 0013889
   VCID: 6CD77B744F43872A11-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME3531475ED
   Subsystem 3 - Serial number: 6342MSME353417768
   Subsystem 4 - Serial number: 6351HSME156C72718
   Subsystem 5 - Serial number: 6361HSME155B19279
   Subsystem 6 - Serial number: 63727SME1458592B5
   Subsystem 7 - Serial number: 63827SME15574119.
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0010021
   VCID: 77FD5418060534F2EC-8022
   Part No SW: 1K0 920 954 P    HW: 1K0 920 954 P
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0002000    Serial number: VWX7Z0H52480K5
   Coding: 0023203
   VCID: 397992207091E282DA-806C
   Revision:   H07 01    Serial number: 250408F1001010
   Coding: ED807F070003021002
   VCID: 306FAF04A3EB23CA6D-8064
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000563388517
   Coding: 0001205
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 01101100
                    Fault Frequency: 17
                    Reset counter: 47
                    Mileage: 239962 km
                    Fault Status: 01101000
                    Reset counter: 47
                    Mileage: 239962 km
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 35619E105C8906E23E-8060
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 040733D447D36F6AF9-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000077088605
   Coding: 0001204
   VCID: 70EF6F04636B63CA2D-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Reset counter: 86
                    Reset counter: 86
                    Mileage: 239962 km
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2208304
   Coding: 0010400
   VCID: 2959426080315202AA-807C
00003 - Control Module
            014 - Defective
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000003168685
   Coding: 0001168
   VCID: 3E73813C69BFC5BAEF-806A
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000003130042
   Coding: 0001168
   VCID: 3F8DFC386EB5CCB2E4-806A
                    Reset counter: 86
                    Mileage: 239962 km
End-------------------------(Elapsed Time: 02:01)--------------------------
You could log the data from the throttle valve sensors in MVB group 062.
This car has ~150,000 miles on it. What kind of shape are the drivetrain mounts in? I wonder of the drivetrain is moving around enough under load to tug something to the point of causing a problem?
HectorT
C?ID=165912
I did log it this morning, values don't add up.
I will need to check the motor mounts.
'061			'062
Engine Speed	Battery Voltage	Throttle Valve Angle	Throttle Valve	Throttle Valve	Accel. Pedal Pos.	Accel. Pedal Pos.
(G28)	(Terminal 30)		Sensor 1 (G187)	Sensor 2 (G188)	Sensor 1 (G79)	Sensor 2 (G185)
 /min	 V	 %	 %	 %	 %	 %
1200	13.63	2.7	13.3	86.7	14.8	7.4
1200	13.63	3.1	12.9	87.1	14.8	7.4
1200	13.63	3.1	12.9	87.1	16.4	8.2
1200	13.536	3.5	12.9	87.1	17.2	8.6
1160	13.536	5.5	13.7	86.3	18.4	9
1160	13.348	7.1	16	84	27	13.3
1160	13.536	9.8	16.8	83.6	33.6	16.8
1360	13.63	11	18.8	81.3	34	16.8
1520	13.536	13.7	20.3	79.7	35.9	18
1800	13.536	18	21.9	78.1	36.7	18
1840	13.724	20.4	25.8	74.2	40.2	19.9
2080	13.724	23.1	27.3	72.7	40.6	19.9
2080	13.818	25.1	28.9	71.1	42.2	20.7
2040	13.724	26.7	31.3	68.8	43.4	21.5
1760	13.724	29.8	32	68	44.5	21.9
1640	13.63	73.7	42.6	57	49.2	24.2
1680	13.724	94.5	81.3	18.4	53.1	26.2
1760	13.724	97.6	85.5	14.1	57	28.5
1840	13.724	99.6	88.3	11.3	57.4	28.5
1920	13.724	99.6	88.3	11.3	60.9	30.5
2040	13.63	99.6	88.3	11.3	62.1	30.9
2120	13.724	99.6	88.3	11.3	64.1	32
2240	13.724	99.6	88.3	11.3	66	32.8
2320	13.818	99.6	88.3	11.3	66.4	33.2
2440	13.912	99.6	88.3	11.3	67.6	33.6
2520	13.912	99.6	88.3	11.3	68.4	34.4
2640	13.724	99.6	88.3	11.3	69.5	34.8
2760	13.818	99.6	88.3	11.3	69.5	34.8
2920	13.818	99.6	88.3	11.3	69.5	34.8
3040	13.818	99.6	88.3	11.3	69.5	34.8
3160	13.818	99.6	88.3	11.3	69.1	34.8
3320	13.818	99.6	88.3	11.3	67.2	33.6
3440	13.818	99.2	87.9	11.7	66	33.2
3560	13.724	99.6	87.9	11.7	63.3	31.6
3720	13.724	99.6	88.3	11.3	62.1	31.3
3840	13.818	99.6	88.3	11.3	62.1	30.9
3920	13.818	99.6	88.3	11.3	62.1	30.9
4040	13.63	99.6	88.3	11.3	62.1	30.9
3280	13.63	99.6	88.3	11.3	57	28.1
3160	13.63	34.9	87.9	11.7	49.2	24.2
3160	13.63	25.1	35.9	64.1	44.1	21.9
3200	13.63	18.8	26.2	73.8	37.9	18.8
3120	13.724	12.9	22.7	77.3	31.6	15.6
2720	13.724	7.1	19.1	80.9	27.7	13.7
2520	13.724	7.1	16.4	84	18.4	9
2440	13.536	6.7	16	84	14.8	7.4
2480	13.536	7.1	16	84	14.8	7.4
2280	13.63	6.3	16	84	14.8	7.4
2280	13.536	6.3	15.6	84.4	14.8	7.4
2200	13.63	6.3	15.6	84.4	14.8	7.4
2080	13.63	5.9	15.2	84.8	14.8	7.4
2040	13.63	5.5	15.2	84.8	14.8	7.4
1960	13.536	5.1	14.8	85.2	14.8	7.4
2000	13.724	5.1	14.8	85.2	14.8	7.4
1920	13.63	5.1	14.8	85.2	14.8	7.4
1920	13.536	5.1	14.8	85.2	14.8	7.4
1840	13.536	5.1	14.8	85.5	14.8	7.4
1840	13.442	4.7	14.5	85.5	14.8	7.4
1720	13.536	4.7	14.5	85.5	14.8	7.4
1760	13.536	4.7	14.1	85.9	14.8	7.4
1680	13.536	4.7	14.5	85.9	14.8	7.4
1640	13.63	4.3	14.5	85.9	14.8	7.4
1600	13.536	4.3	14.1	85.9	14.8	7.4
1560	13.536	3.9	14.1	85.9	14.8	7.4
1480	13.536	3.9	14.1	85.9	14.8	7.4
1400	13.536	3.9	13.7	86.3	14.8	7.4
1400	13.536	3.5	13.7	86.3	14.8	7.4
1360	13.442	3.5	13.7	86.3	14.8	7.4
1320	13.536	3.5	13.7	86.3	14.8	7.4
1320	13.442	3.5	13.3	86.7	14.8	7.4
1400	13.63	3.5	13.3	86.7	14.8	7.4
1440	13.536	3.9	13.7	86.3	14.8	7.4
1360	13.536	3.5	13.7	86.3	14.8	7.4
1320	13.442	3.5	13.7	86.3	14.8	7.4
1240	13.536	3.1	13.3	86.7	14.8	7.4
1200	13.442	3.1	13.3	86.7	14.8	7.4
1160	13.442	3.5	13.3	87.1	14.8	7.4
1200	13.442	3.5	13.7	86.3	14.8	7.4
1280	13.442	3.5	13.7	86.3	14.8	7.4
1280	13.536	3.9	13.7	86.3	14.8	7.4
1200	13.536	3.5	13.7	86.3	14.8	7.4
1160	13.442	3.5	13.7	86.3	14.8	7.4
1040	13.536	3.5	13.7	86.3	14.8	7.4
960	13.442	3.5	13.7	86.3	14.8	7.4
1080	13.536	3.5	13.7	86.3	14.8	7.4
1120	13.348	2.7	12.9	87.1	14.8	7.4
1000	13.442	3.1	12.9	87.1	14.8	7.4
920	13.442	3.1	13.3	86.7	14.8	7.4
840	13.442	3.1	13.3	86.7	14.8	7.4
800	13.536	3.1	13.3	86.7	14.8	7.4
800	13.442	3.5	13.3	86.7	14.8	7.4
800	13.63	3.5	13.7	86.3	14.8	7.4
760	13.442	3.1	13.3	86.7	14.8	7.4
680	13.442	3.9	13.3	86.7	14.8	7.4
720	13.536	4.7	14.5	85.9	14.8	7.4
880	13.63	3.5	14.1	85.9	14.8	7.4
920	13.63	3.5	13.3	86.7	14.8	7.4
920	13.536	3.5	13.7	86.3	14.8	7.4
840	13.536	3.5	13.7	86.3	14.8	7.4
840	13.536	3.5	13.3	86.7	14.8	7.4
840	13.442	3.5	13.3	86.7	14.8	7.4
800	13.442	3.1	13.3	86.7	14.8	7.4
840	13.536	3.1	13.3	86.7	14.8	7.4
800	13.63	3.1	13.3	86.7	14.8	7.4
800	13.63	3.5	13.3	86.7	14.8	7.4
840	13.63	3.5	13.7	86.7	14.8	7.4
800	13.348	3.5	13.3	86.7	14.8	7.4
800	13.536	3.5	13.3	86.7	14.8	7.4
840	13.348	3.5	13.3	86.7	14.8	7.4
840	13.442	3.5	13.7	86.7	14.8	7.4
800	13.254	3.5	13.3	86.7	14.8	7.4
840	13.63	3.5	13.7	86.3	14.8	7.4
840	13.254	3.5	13.3	86.7	14.8	7.4
840	13.63	3.5	13.3	86.7	14.8	7.4
840	13.254	3.1	13.3	86.7	14.8	7.4
800	13.348	3.1	13.3	86.7	14.8	7.4
840	13.348	3.1	13.3	86.7	14.8	7.4
840	13.442	3.1	12.9	87.1	14.8	7.4
800	13.348	3.1	13.3	87.1	14.8	7.4
800	13.536	3.1	13.3	87.1	14.8	7.4
800	13.442	3.1	13.3	87.1	14.8	7.4
800	13.536	3.1	12.9	87.1	14.8	7.4
840	13.442	3.1	13.3	87.1	14.8	7.4
840	13.348	3.1	13.3	87.1	14.8	7.4
800	13.348	3.1	12.9	87.1	14.8	7.4
880	13.63	3.5	13.7	86.3	14.8	7.4
880	13.63	3.9	13.7	86.3	14.8	7.4
800	13.442	4.3	13.7	86.3	14.8	7.4
720	13.63	5.1	14.1	85.9	14.8	7.4
720	13.536	5.9	14.8	85.2	14.8	7.4
920	13.536	4.3	15.2	84.8	14.8	7.4
880	13.63	3.1	13.7	86.3	16	7.8
960	13.63	4.3	14.1	85.9	21.5	10.5
1000	13.63	4.7	14.1	85.9	23	11.3
1000	13.724	4.7	14.5	85.5	23.8	11.7
1000	13.63	4.7	14.5	85.5	23.8	11.7
1080	13.724	5.5	14.5	85.5	25	12.1
1160	13.724	7.1	15.6	84.4	27.7	13.7
1280	13.724	8.6	16.8	83.2	29.7	14.8
1160	13.724	8.6	17.6	82.4	29.7	14.8
1360	13.724	9.8	18	82	32	16
1400	13.724	11	19.1	80.9	32.4	16
1400	13.724	11	19.1	80.9	32.8	16
1520	13.724	11.8	19.5	80.5	32.8	16.4
1600	13.63	12.5	20.3	79.7	33.6	16.8
1760	13.63	14.9	21.5	78.5	36.7	18.4
1920	13.63	17.3	23.8	76.2	37.9	18.8
1880	13.724	19.2	24.6	75.4	39.1	19.1
1600	13.724	19.2	25.8	74.2	39.5	19.5
1600	13.63	18.8	25.4	74.6	39.8	19.5
1680	13.63	18.8	25.4	74.6	39.8	19.5
1800	13.63	19.2	25.4	74.6	40.2	19.9
1920	13.724	19.6	25.8	74.2	40.2	19.9
2040	13.724	20	26.2	73.8	40.2	19.9
2120	13.63	20	26.2	73.8	40.2	19.9
1960	13.63	19.6	26.6	73.4	40.2	19.9
1800	13.63	23.5	27.3	72.7	43.4	21.5
1720	13.63	28.2	31.3	68.8	45.7	22.3
1720	13.63	28.2	32.8	67.2	45.7	22.3
1800	13.63	29.4	32.8	67.2	46.1	22.7
1880	13.724	58.8	43.4	56.6	48	23.8
1960	13.724	67.5	62.1	37.5	48.4	23.8
2040	13.63	58	59.4	40.2	48.4	23.8
1920	13.63	47.5	50.4	49.2	48.4	23.8
1680	13.63	57.6	59.8	39.8	48.4	23.8
1680	13.442	43.1	46.5	53.1	48.4	23.8
1720	13.63	23.9	49.2	50.8	42.2	20.7
1720	13.536	18.4	27.7	72.3	37.5	18.8
1760	13.63	13.7	22.7	77.3	34.8	17.2
1880	13.63	13.3	21.1	78.9	34.4	17.2
1800	13.536	13.7	21.5	78.5	34.4	17.2
1800	13.63	13.7	21.5	78.5	34.4	17.2
1640	13.724	13.3	21.5	78.5	34.4	17.2
1600	13.63	13.3	21.1	78.9	34.4	17.2
1560	13.63	13.3	21.1	78.9	34.4	17.2
1520	13.63	12.9	21.1	78.9	34.4	17.2
1480	13.724	12.9	20.7	79.3	34.4	17.2
1480	13.63	12.9	20.7	79.3	34.4	17.2
1520	13.536	12.9	20.7	79.3	34.8	17.2
1520	13.63	12.9	20.7	79.3	34.8	17.2
1520	13.724	12.5	20.7	79.3	34.8	17.2
1560	13.724	12.5	20.7	79.3	34.8	17.2
1560	13.63	12.5	20.7	79.3	34.8	17.2
1560	13.536	11.4	20.3	79.7	33.6	16.8
1560	13.63	7.1	17.6	82.4	26.2	12.9
1600	13.63	7.1	16	84	27.3	13.7
1600	13.63	7.5	16.4	83.6	27.3	13.7
1560	13.536	7.5	16.4	83.6	27.3	13.7
1560	13.63	9	16.8	83.6	27.3	13.7
1640	13.442	9.4	18	82	29.7	14.8
1560	13.536	9	18	82	29.7	14.8
1560	13.63	9	18	82	29.7	14.8
1600	13.63	9	18	82	29.7	14.8
1600	13.63	10.2	18.4	81.6	31.3	15.6
1600	13.536	10.2	18.8	81.3	31.3	15.6
1600	13.63	10.2	18.8	81.3	31.3	15.6
1600	13.442	10.2	18.8	81.3	31.3	15.6
1640	13.63	10.2	18.8	81.3	31.3	15.6
1640	13.536	10.2	18.8	81.3	31.3	15.6
1640	13.442	10.2	18.8	81.3	31.3	15.6
1640	13.63	11	18.8	81.3	31.3	15.6
1720	13.724	14.1	21.1	78.9	37.9	18.8
1680	13.63	16.1	23	77.3	38.3	19.1
1680	13.63	16.9	23.4	76.6	39.1	19.1
1680	13.63	17.3	23.8	76.2	39.1	19.5
1720	13.536	17.6	24.2	75.8	39.1	19.5
1720	13.63	17.6	24.6	75.4	39.5	19.5
1760	13.63	17.6	24.6	75.4	39.5	19.5
1760	13.63	18	24.6	75.4	39.5	19.5
1800	13.442	18.4	25	75	39.5	19.5
1840	13.63	18.8	25.4	75	39.5	19.5
1840	13.724	18.8	25.4	74.6	39.5	19.5
1840	13.63	18.4	25.4	74.6	39.1	19.5
1760	13.63	16.5	24.2	75.8	37.5	18.8
1680	13.63	15.7	23.4	76.6	37.5	18.4
1640	13.536	15.7	23	77	37.1	18.4
1640	13.63	15.7	23	77	37.1	18.4
1600	13.63	12.5	22.7	77.7	34.8	17.2
1600	13.63	11	19.5	80.5	32	16
1600	13.63	10.6	19.1	80.9	31.3	15.6
1640	13.724	10.2	18.8	81.3	30.5	15.2
1640	13.63	9	18.8	81.3	29.3	14.5
1640	13.63	9	17.6	82.4	28.9	14.5
1640	13.724	9	17.6	82.4	28.9	14.5
1680	13.63	9	17.6	82.4	28.9	14.5
1640	13.63	9	17.6	82.4	29.3	14.5
1600	13.63	6.7	16	84	25.8	12.9
1600	13.536	6.7	16	84	25.8	12.9
1600	13.536	6.7	16	84	26.2	12.9
1640	13.536	6.7	16	84	26.2	12.9
1640	13.536	6.7	16.4	83.6	28.5	14.1
1640	13.536	8.6	17.6	82.4	28.9	14.5
1680	13.63	8.6	17.6	82.4	28.9	14.5
1640	13.536	8.6	17.6	82.4	28.5	14.1
1640	13.536	9	19.1	80.9	32.4	16
1720	13.536	11	19.9	80.1	34	16.8
1760	13.63	12.5	20.7	79.3	34.4	17.2
1720	13.63	12.5	21.1	78.9	34.8	17.2
1760	13.63	12.9	21.1	78.9	34.8	17.2
1800	13.536	13.3	21.1	78.9	35.2	17.6
1840	13.442	14.1	21.9	78.1	35.9	18
1960	13.536	14.5	22.3	77.7	36.3	18
1920	13.724	15.7	23	77	38.3	18.8
1960	13.63	18	26.6	73.4	42.2	20.7
1800	13.63	23.5	30.5	69.5	44.5	21.9
1800	13.536	27.5	33.2	66.8	47.3	23.4
1640	13.63	38.4	64.1	35.5	50.4	24.6
1560	13.442	85.9	80.9	18.8	50.4	24.6
1680	13.63	92.9	84.8	14.8	51.6	25.4
1680	13.63	96.9	85.9	13.7	57.8	28.5
1720	13.63	97.3	87.9	11.7	59	29.3
1800	13.536	99.6	88.3	11.3	59	29.3
1880	13.63	99.6	88.3	11.3	59	29.3
1920	13.536	99.6	88.3	11.3	59	29.3
1960	13.724	99.6	88.3	11.3	59	29.3
2040	13.63	99.6	88.3	11.3	57.8	28.5
2080	13.63	99.6	88.3	11.3	57	28.1
2120	13.63	99.6	88.3	11.3	54.3	26.6
2200	13.63	99.6	88.3	11.3	52.7	26.2
2240	13.63	99.6	88.3	11.3	52.7	25.8
2320	13.63	99.6	88.3	11.3	52.7	25.8
2360	13.63	99.6	88.3	11.3	52.7	25.8
2440	13.63	99.6	88.3	11.3	57.4	28.5
2480	13.63	99.6	88.3	11.3	61.7	30.9
2560	13.536	99.6	88.3	11.3	63.3	31.6
2600	13.63	99.6	88.3	11.3	66.8	33.6
2680	13.63	99.6	88.3	11.3	69.9	35.2
2720	13.724	99.6	99.2	11.7	69.1	34.4
2800	13.63	99.6	99.2	11.3	57.8	28.5
2880	13.724	27.5	99.2	67.6	42.2	20.7
2920	13.536	20	99.2	77.7	28.5	14.1
2920	13.442	12.5	99.2	80.5	21.9	10.5
2960	13.536	8.2	99.2	83.6	14.8	7.4
2600	13.536	6.7	99.2	84	14.8	7.4
2280	13.442	5.5	99.2	84.8	14.8	7.4
2280	13.536	5.5	99.2	84.8	14.8	7.4
2240	13.536	5.5	99.2	84.8	14.8	7.4
2200	13.536	5.5	99.2	84.8	14.8	7.4
NostraJackAss
Vehicle Identification No.3VWRJ71K28M193657
ModelJetta
JEM
Date of production17.06.2008
Year2008
Sales type1K27V3
Engine CodeBPY
Transmission CodeKNC
ULEV2
Doesn't the warranty range from 120 to 150K depending on AECD component for free repairs and or reimbursement for these known defects?
Isn't there a TSB or recall of record on the TV wiring harness for stretch and sporadic connectivity issue?
Component: 2.0l R4/4V TFSI 0020 <<<<<<<<<<<<<<<<<<<<<<<<<<<< Update firmware required!
HectorT
C?ID=165912
Jack, that was a good read. It's definitely worth a try.
But in the mean time, any other suggestions on what I could try?
My next step is checking the harness at the plug and at the ecm.
Also verifying the motor mounts for excessive movement.
I want to try to replicate the issue while not having to drive it.
Any thoughts?
NostraJackAss
I think that checking the harness is a grand idea but FYI that firmware update I aforementioned is also for this described condition you have too & if you read the TSB on the update and the harness issue, its under warranty but be advised the scan data you posted is proof of that time and mileage stamp to prove your reimbursement request later?
May the data record and the fact you are using a genuine RT device set your freedom and bring you the benefits of a secure method to authenticate your possible needed paper trail of documentation?
This is why pirate tools lose! & yours could win.
HectorT
C?ID=165912
Jack, do you have a minute to show me where that TSB is located?
HectorT
C?ID=165912
This is todays scan, different DTC came up. P0122
Leaving work cold engine. About 20% throttle.
VIN: 3VWRJ71K28M193657   Mileage: 240030km-149147miles
000290 - Throttle Position Sensor (G69)
               P0122 - 002 - Signal too Low
                    Fault Status: 01100010
                    Mileage: 240037 km
                    Time: 15:31:40
                    Temperature: 93.0°C
                    Temperature: 45.0°C
                    Voltage: 12.319 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0000100
            000 -  -
                    Reset counter: 48
                    Mileage: 239987 km
                    Time: 18:07:06
   Coding: 0013889
   Coding: 0010021
   Coding: 0023203
   Coding: 0001205
                    Fault Frequency: 63
                    Reset counter: 92
                    Mileage: 239987 km
                    Fault Frequency: 12
                    Reset counter: 92
                    Mileage: 239987 km
   Coding: 0001204
                    Fault Frequency: 13
                    Reset counter: 52
                    Mileage: 239987 km
                    Reset counter: 52
                    Mileage: 239987 km
   Coding: 0010400
            014 - Defective
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
                    Reset counter: 92
                    Mileage: 239999 km
                    Reset counter: 91
                    Mileage: 240012 km
End-------------------------(Elapsed Time: 02:04)--------------------------
