ABS woes after engine,ecu and tranny swap
Fredrick Awuor
Kenya
C?ID=309834
Hello guys,this formely 1.4 GT has chewed pistons like khat ,that has necessitated engine ''rebuilds almost yearly for the past four years,which has been expensive and inconvenient to client...,so we took a drastic step of swapping 2.0l 147kw BWA engine complete with ecu,harnesses and shafts,so while everything else works well,ABS control has refused to recognise the new ECU,I know Jack is going to scold me for this induced FOD,but our options were few'and i think the end here justifies the means....Im politely asking if there is any coding that can be done to appease ABS control.....i must add that ABS light goes off as car accumulates speed,but beeps and comes on when car is stationary
Monday,25,February,2019,07:46:15:21182
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
Dealer/Shop Name: VAG AUTO-XRAY
VIN: WVWZZZ1KZ9U000060   License Plate: 777 2ND SCAN
Mileage: 123410km-76683mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9U000060   Mileage: 123410km-76683miles
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H10---    Serial number: VWZ7Z0E2981735
   Coding: 040300031C070160
   Shop #: WSC 12336 923 402982
   VCID: 2D070B314114158F05B-8078
Readiness: 0110 0001
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000603250243
   Shop #: WSC 44551 111 44551
   VCID: 1471BED5C27EA4472A5-8040
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 133B600D212200FAC80B06EA84190080B100
   Shop #: WSC 00046 412 00000
   VCID: 75B7E351E5C41D4FBDB-8020
                    Reset counter: 190
                    Mileage: 123412 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 8194
                    Count: 50944
                    Count: 55040
                    Count: 53
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6C81C635BA8EDC87525-8038
            009 - Open or Short to Ground
   Revision: 00H54000    Serial number: 00000008425893
   Coding: 038F0F2700041500471400001400000000097F075C000100000000000000
   VCID: 33331D49A730437F53F-8066
   Component: Wischer 110708 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Component: 15 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0B5JM4
   Coding: 0012597
   Subsystem 1 - Serial number: 6332MSME2720611B1
   Subsystem 2 - Serial number: 6342MSME3811603C6
   Subsystem 3 - Serial number: 6352QSME6336355BJ
   Subsystem 4 - Serial number: 6362QSME6572383DP
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           752 0101
   Coding: 0012142
   VCID: 04518E95B21E34C7BA5-8050
   Part No SW: 1K0 920 864 G    HW: 1K0 920 864 G
   Revision: V0002000    Serial number: VWX7Z0H53N27VF
   Coding: 0007503
   Shop #: WSC 84327 981 93645
   VCID: 30391245562678672ED-8064
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 190508F1001997
   Coding: ED817F060002020003
   VCID: 35372351A9445D4F7DB-8060
                    Reset counter: 190
                    Mileage: 123412 km
                    Time: 07:42:27
   Component: IMMO            VDD 1212
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1210
   Coding: 0000694
   Shop #: WSC 00046 000 00000
   VCID: 392F2F61855CB92F993-806C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A0D002D70FA02B7E09-807E
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 809002005103087F2D0484056008DF03E0FCA0
   VCID: 71BFD7419DAC316F613-8024
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000950
   VCID: 3A2D306D805AB237909-806E
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DE55E2BE04478A5-8020
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 000 1012544
   VCID: 38292A65BE56A02766D-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----------(Elapsed Time: 01:06, VBatt start/end: 14.0V/14.0V)-----------
Code before swap
Moving this to Retrofits.
Fredrick Awuor
Kenya
C?ID=309834
Oh my,I kind of forgot....this is code after swap....will post autoscan before swap
Fredrick Awuor
Kenya
C?ID=309834
Code before Swapping BWA for BLG
Saturday,01,December,2018,17:01:17:48669
VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZ1KZ9U000060   Mileage: 118180km-73433miles
Address 01: Engine        Labels: 03C-906-032-BLG.lbl
   Part No SW: 03C 906 032 AK    HW: 03C 906 032 C
   Component: MED17.5.1       G   6457
   Revision: 96H07---    Serial number: VWX7Z0H53N27VF
   Coding: 0000075
   Shop #: WSC 84320 981 60675
   VCID: 6696BF75B46C2CE704A-8032
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open
                    Mileage: 116709 km
                    Time: 11:45:24
                    RPM: 876 /min
                    Load: 12.2 %
                    Temperature: 86.0°C
                    Temperature: 47.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 13.462 V
001056 - Catalyst System; Bank 1
               P0420 - 000 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11110000
                    Mileage: 116972 km
                    Time: 19:40:53
                    RPM: 1870 /min
                    Load: 43.5 %
                    Speed: 77.0 km/h
                    Temperature: 84.0°C
                    Temperature: 27.0°C
                    Voltage: 13.589 V
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed
                    Mileage: 118086 km
                    Time: 17:01:44
                    RPM: 1722 /min
                    Load: 62.3 %
                    Speed: 33.0 km/h
                    Temperature: 86.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 820.0 mbar
                    Voltage: 13.462 V
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 74
                    Mileage: 118153 km
                    Time: 13:52:03
                    RPM: 855 /min
                    Load: 15.7 %
                    Speed: 1.0 km/h
                    Temperature: 87.0°C
                    Temperature: 47.0°C
                    Voltage: 13.208 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 118160 km
                    Time: 14:20:53
                    RPM: 1930 /min
                    Load: 11.8 %
                    Speed: 80.0 km/h
                    Temperature: 86.0°C
                    Temperature: 40.0°C
                    Voltage: 13.716 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 118160 km
                    Time: 14:20:53
                    RPM: 1930 /min
                    Load: 11.8 %
                    Speed: 80.0 km/h
                    Temperature: 86.0°C
                    Temperature: 40.0°C
                    Voltage: 13.716 V
Readiness: 0000 0001
   Part No SW: 02E 300 050 M    HW: 02E 927 770 AE
   Component: GSG DSG         081 1402
   Revision: 09908010    Serial number: 00000710250209
   Shop #: WSC 04940 001 00001
   VCID: 1C62DD9D3AA0263762E-8048
   Revision: 00H35001
   VCID: 75B4E839F5CAD77FBD0-8020
   VCID: 6C82CD5DAA8016B752E-8038
   VCID: 33301621B73E894F534-8066
   Coding: 00049109
   Shop #: WSC 00046
                    Fault Status: 01101100
                    Fault Frequency: 17
                    Reset counter: 247
                    Mileage: 116703 km
                    Voltage: 12.35 V
   Coding: 0012597
   Coding: 0012142
   VCID: 045285FDA210FEF7BAE-8050
   Coding: 0007503
   VCID: 303A192D4628B2572E6-8064
   VCID: 35342839B94A977F7D0-8060
                    Reset counter: 247
                    Mileage: 110027 km
                    Time: 00:14:54
   Coding: 0000694
   VCID: 392C24099552731F998-806C
   Revision: 00H15000
   VCID: 2A0E0B4560F4C887E02-807E
   VCID: 71BCDC298DA2FB5F618-8024
   Coding: 0000950
   VCID: 3A2E3B0590547807902-806E
   Coding: 0000003
   VCID: 74B2D53DF2B0CE778AE-8020
Address 56: Radio
   Coding: 0000144
   VCID: 382A210DAE586A17666-806C
   Coding: 0000144
End----------(Elapsed Time: 01:10, VBatt start/end: 13.5V/13.3V)-----------
What model year car is that engine/ECU out of? Do you know what type of ABS the donor car had?
Fredrick Awuor
Kenya
C?ID=309834
No,I'll check Partslink24 and report back
Fredrick Awuor
Kenya
C?ID=309834
Hello Uwe,according to ETKA....donor car had ABS/ESP control.... 1K0 614 517 BK,BEF.....on this BWA ECU VIN...WVWZZZ1KZ6U021988
iichel
Eindhoven, NB, NL
C?ID=284912
Having a quick look on the net, " Part No SW: 1K0 907 115 J HW: 1K0 907 115 F" does not show any cars (except this one) with an MK60EC1. Doubting compatibility here.
