2019 VW Polo AW 2G 1.6 TDI DSG Highline EU
iichel
Eindhoven, NB, NL
C?ID=284912
So we have a black VW Polo AW (2G)
Specs
- 1.6 TDI 4-cylinder engine with 95hp
- 7 speed DSG
- Climatronic dual zone with seat heating
- ACC with MFSW
- Halogen headlights with LED DRL
- 8K PDC
- Active Info Display
- Satellite navigation Discover Media
Sunday,24,February,2019,11:50:37:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.9.1.0  HEX-V2 CB: 0.4436.4
VIN: WVWZZZAWZKY031934   License Plate:
Mileage: 1897km-1178mi   Repair Order:
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZAWZKY031934   Mileage: 1897km-1178miles
Address 01: Engine (J623-DGTD)       Labels: None
   Part No SW: 04L 906 056 LJ    HW: 04L 907 445 F
   Component: R4 1.6l TDI   H01 5930
   Revision: 22101001
   Coding: 01254032436415090000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI03004L906056LJ 004013
   ROD: EV_ECM16TDI03004L906056LJ.rod
   VCID: 00597D416A81E6C79ED-8055
Readiness: N/A
   Part No SW: 0CW 300 040 G    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501806296428
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 3829D5A172D16E0766D-806D
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AC    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H34 0323
   Serial number: 08502727180817
   Coding: 0A035364354450AECA05AC1924DE42A649124526446A245848545254452442659248A2642256241A122A4A2AA269C64AFD966352BF
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
   VCID: 6FBB2EFD471FE9BF777-803B
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 2G0 907 044 L    HW: 2G0 907 044 L
   Component: Climatronic   H03 0501
   Coding: 0120100008020100011008000244010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_VW27.rod
   VCID: 2D07F4F58D93DBAF05B-8079
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 53
                    Reset counter: 84
                    Mileage: 282 km
                    Date: 2018.11.20
                    Time: 09:59:15
                    Voltage terminal 30: 13.8 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0926
   Serial number: 00001824001242
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 3039ED819AA1B6472ED-8065
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000024042128
   Coding: 130034
   Subsystem 2 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000024083217
   Coding: 090034
   Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 72269205
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000023484247
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000023761550
   Coding: 1B0000
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 81
                    Mileage: 636 km
                    Date: 2018.11.24
                    Time: 15:18:07
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 33
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.4 V
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018227
   Coding: 0471051011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4CC199711649F2A7325-8019
   Component: ACCCONTIMQB   H03 0233
   Coding: 3200670248FF8748949C8145804087
   VCID: 3E25C3B950F55037AC1-806B
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025D7749648DF4D7889-8057
   Subsystem 1 - Part No SW: -----------    HW: 442 061 209 18
   Serial number: 3577Y20AB2B94883E2FQ
   Subsystem 2 - Part No SW: -----------    HW: 442 061 209 18
   Serial number: 3587Y20A92B9488254AC
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 608 18
   Serial number: 35177809B2D101C092DI
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 508 18
   Serial number: 3527783BB2D09FD3313X
   Subsystem 5 - Part No SW: -----------    HW: 442 132 607 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11B129E7376066R
   Part No SW: 2G0 920 790 A    HW: 2G0 920 790 A
   Component: KOMBI         506 1691
   Coding: 04A4010825800008018862011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 25170CD5D563E3EFCDB-8071
9456433 - Key
          B104B 31 [008] - No Signal
                    Mileage: 883 km
                    Date: 2019.01.14
                    Time: 16:17:04
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008475027
   Coding: 030100044F087300FA0002581C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 3D27C4B55DF34B2FB5B-8069
   Subsystem 2 - Part No SW: 2G0 959 442 H    HW: 2G0 959 442 H
   Component: E221__MFL-DC1  H02 0052
   Serial number: 39180001519100048293
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1009A863
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert ¸berschritten]
                    Reset counter: 84
                    Mileage: 1226 km
                    Date: 2019.02.20
                    Time: 04:45:33
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6041
   Serial number: 00706158CP3J249
   Coding: 010000000000000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0_011.rod
   VCID: 3C21C9B146E94227825-8069
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     H41 0472
   Serial number: VWZAZ2U0994697
   Coding: 02720001BE0000004111000100080A001F0500E401200000CF
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 313FE88591ABBF4F213-8065
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2562634
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [008] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 60
                    Mileage: 12 km
                    Date: 2018.11.03
                    Time: 15:37:01
                    Voltage terminal 30: 12.0 V
End----------(Elapsed Time: 01:03, VBatt start/end: 12.5V/12.5V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
;SW:04L-906-056-LJ   HW:04L-907-445-F ---  Engine
;Component:R4 1.6l TDI   H01 5930	 Coding:01254032436415090000
;EV_ECM16TDI03004L906056LJ	4013	EV_ECM16TDI03004L906056LJ.rod
;Sunday	24	February	2019
;VCDS Version: Release 18.9.1  Data version: 20190114 DS296.0
;VCID: 00597D416A81E6C79ED-8055
IDE00001-Production mode	00 00 00 	3
IDE00263-Injector 1 correction value	2S40XW7LJTGSU7T46S36 	20
IDE00264-Injector 2 correction value	9S40XWPUW2ESURDWU132 	20
IDE00265-Injector 3 correction value	DS40XLPAUAESL7DJAS79 	20
IDE00266-Injector 4 correction value	J900XWPBKBEY3760LX78 	20
IDE01096-Particulate Filter Statistics	0	1
IDE01711-Blocking of particle filter regeneration	not active 	1
IDE01945-Engine run-in oil pressure	not active 	1
IDE02248-Individually adjustable maximum speed limit	300.0 km/h	2
IDE02332-Deactivate production mode	00 00 00 	3
IDE02637-Adaptation for metering quantity measurement	4	1
IDE04158-Activation of start-stop function	active 	1
IDE04617-Protective function	Enabled 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE07903-Adaptation of ash mass	0.43 g	2
IDE08287-Bleeding of coolant circuit	not active 	1
IDE10309-Adaptation of oxidation catalytic converter ageing	29952 s	2
ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping	Not blocked 	1
ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor	Not blocked 	1
Elapsed Time: 00:05
;SW:0CW-300-040-G   HW:0AM-927-769-E ---  Auto Trans
;Component:GSG DQ200G2_M H05 1604	 Coding:0014
;EV_TCMDQ200021	1001	EV_TCMDQ200021_VW27.rod
;Sunday	24	February	2019	11:52:39:11868
;VCID: 3829D5A172D16E0766D-806D
IDE00001-Production mode	not activated 	3
Elapsed Time: 00:01
;SW:2Q0-614-517-AC   HW:2Q0-614-517-M ---  ABS Brakes
;Component:ESC_high_vFGS H34 0323	 Coding:0A035364354450AECA05AC1924DE42A649124526446A245848545254452442659248A2642256241A122A4A2AA269C64AFD966352BF
;EV_Brake1BOSCHESPMQBA0	4032	EV_Brake1BOSCHESPMQBA0_VW27.rod
;Sunday	24	February	2019	11:52:47:11868
;VCID: 6FBB2EFD471FE9BF777-803B
IDE00001-Production mode	not active 	3
IDE00820-ENG155021-Activating and deactivating all development messages-DEV_ESP_Resp_00	not activated 	1
IDE00820-ENG155022-Activating and deactivating all development messages-DEV_ESP_Resp_01	not activated 	1
IDE00820-ENG155023-Activating and deactivating all development messages-DEV_ESP_Resp_02	not activated 	1
IDE00820-ENG155024-Activating and deactivating all development messages-DEV_ESP_Resp_03	not activated 	1
IDE00820-ENG155025-Activating and deactivating all development messages-DEV_ESP_Resp_04	not activated 	1
IDE00820-ENG155026-Activating and deactivating all development messages-DEV_ESP_Resp_05	not activated 	1
IDE02332-Deactivate production mode	Deactivating 	3
IDE03659-Roller test bench mode	Manual activation: possible 	1
IDE04159-Deactivation of start-stop function	not active 	1
IDE04456-Brake disk drying	Medium 	1
IDE04643-Overboost in brake system	activated 	1
IDE04765-Counter steer support	Strong 	1
IDE04939-Tire pressure monitoring display	Default 	1
IDE04949-Engine drag torque control	activated 	1
IDE04952-Braking torque boost for distance regulation	100%	1
IDE05055-Hydraulic brake assistant	normal 	1
IDE05161-Straight ahead brake stabilization	activated 	1
IDE05286-Expanded electronic differential lock	Medium 	1
IDE05337-Starting vibration reduction	Strong 	1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
IDE07292-Brake pre-filling	ended 	1
IDE11623-Emergency brake information	activated 	1
IDE14084-Pump test run	present 	1
MAS01299-Offroad	0	1
MAS02080-XCP calibration protocol	not activated 	1
MAS02138-Hill-start assistant	normal 	1
MAS08145-MAS13354-Hill-start assistant: increase threshold-Gradient threshold engine running	3%	2
MAS08145-MAS13355-Hill-start assistant: increase threshold-Gradient threshold start-stop - engine-stop	0%	2
ENG153789-ENG154895-content_of_developement_message_1-address_of_byte_0	00 00 00 00 	40
ENG153789-ENG154896-content_of_developement_message_1-address_of_byte_1	00 00 00 00 	40
ENG153789-ENG154897-content_of_developement_message_1-address_of_byte_2	00 00 00 00 	40
ENG153789-ENG154898-content_of_developement_message_1-address_of_byte_3	00 00 00 00 	40
ENG153789-ENG154899-content_of_developement_message_1-address_of_byte_4	00 00 00 00 	40
ENG153789-ENG154900-content_of_developement_message_1-address_of_byte_5	00 00 00 00 	40
ENG153789-ENG154901-content_of_developement_message_1-address_of_byte_6	00 00 00 00 	40
ENG153789-ENG154902-content_of_developement_message_1-address_of_byte_7	00 00 00 00 	40
ENG153789-ENG155896-content_of_developement_message_1-Signal_length_byte_0	0	40
ENG153789-ENG155897-content_of_developement_message_1-Signal_length_byte_1	0	40
ENG153789-ENG155898-content_of_developement_message_1-Signal_length_byte_2	0	40
ENG153789-ENG155899-content_of_developement_message_1-Signal_length_byte_3	0	40
ENG153789-ENG155900-content_of_developement_message_1-Signal_length_byte_4	0	40
ENG153789-ENG155901-content_of_developement_message_1-Signal_length_byte_5	0	40
ENG153789-ENG155902-content_of_developement_message_1-Signal_length_byte_6	0	40
ENG153789-ENG155903-content_of_developement_message_1-Signal_length_byte_7	0	40
ENG153790-ENG154895-content_of_developement_message_2-address_of_byte_0	00 00 00 00 	40
ENG153790-ENG154896-content_of_developement_message_2-address_of_byte_1	00 00 00 00 	40
ENG153790-ENG154897-content_of_developement_message_2-address_of_byte_2	00 00 00 00 	40
ENG153790-ENG154898-content_of_developement_message_2-address_of_byte_3	00 00 00 00 	40
ENG153790-ENG154899-content_of_developement_message_2-address_of_byte_4	00 00 00 00 	40
ENG153790-ENG154900-content_of_developement_message_2-address_of_byte_5	00 00 00 00 	40
ENG153790-ENG154901-content_of_developement_message_2-address_of_byte_6	00 00 00 00 	40
ENG153790-ENG154902-content_of_developement_message_2-address_of_byte_7	00 00 00 00 	40
ENG153790-ENG155896-content_of_developement_message_2-Signal_length_byte_0	0	40
ENG153790-ENG155897-content_of_developement_message_2-Signal_length_byte_1	0	40
ENG153790-ENG155898-content_of_developement_message_2-Signal_length_byte_2	0	40
ENG153790-ENG155899-content_of_developement_message_2-Signal_length_byte_3	0	40
ENG153790-ENG155900-content_of_developement_message_2-Signal_length_byte_4	0	40
ENG153790-ENG155901-content_of_developement_message_2-Signal_length_byte_5	0	40
ENG153790-ENG155902-content_of_developement_message_2-Signal_length_byte_6	0	40
ENG153790-ENG155903-content_of_developement_message_2-Signal_length_byte_7	0	40
ENG153791-ENG154895-content_of_developement_message_3-address_of_byte_0	00 00 00 00 	40
ENG153791-ENG154896-content_of_developement_message_3-address_of_byte_1	00 00 00 00 	40
ENG153791-ENG154897-content_of_developement_message_3-address_of_byte_2	00 00 00 00 	40
ENG153791-ENG154898-content_of_developement_message_3-address_of_byte_3	00 00 00 00 	40
ENG153791-ENG154899-content_of_developement_message_3-address_of_byte_4	00 00 00 00 	40
ENG153791-ENG154900-content_of_developement_message_3-address_of_byte_5	00 00 00 00 	40
ENG153791-ENG154901-content_of_developement_message_3-address_of_byte_6	00 00 00 00 	40
ENG153791-ENG154902-content_of_developement_message_3-address_of_byte_7	00 00 00 00 	40
ENG153791-ENG155896-content_of_developement_message_3-Signal_length_byte_0	0	40
ENG153791-ENG155897-content_of_developement_message_3-Signal_length_byte_1	0	40
ENG153791-ENG155898-content_of_developement_message_3-Signal_length_byte_2	0	40
ENG153791-ENG155899-content_of_developement_message_3-Signal_length_byte_3	0	40
ENG153791-ENG155900-content_of_developement_message_3-Signal_length_byte_4	0	40
ENG153791-ENG155901-content_of_developement_message_3-Signal_length_byte_5	0	40
ENG153791-ENG155902-content_of_developement_message_3-Signal_length_byte_6	0	40
ENG153791-ENG155903-content_of_developement_message_3-Signal_length_byte_7	0	40
ENG118148-Developer_Function_1	00 00 	2
ENG122614-Developer_Function_102	activated 	1
ENG122615-Developer_Function_103	activated 	1
ENG122619-Developer_Function_109	not activated 	1
ENG125053-Developer_Function_120	Default 	1
ENG118200-Developer_Function_3	not activated 	1
ENG118201-Developer_Function_4	5	1
Elapsed Time: 00:11
;SW:2G0-907-044-L   HW:2G0-907-044-L ---  Auto HVAC
;Component:Climatronic   H03 0501	 Coding:0120100008020100011008000244010D0000000000000000000000000000
;EV_ACClimaBHBMQBA0	4017	EV_ACClimaBHBMQBA0_VW27.rod
;Sunday	24	February	2019	11:53:02:11868
;VCID: 2D07F4F58D93DBAF05B-8079
IDE00001-Production mode	Deactivating 	3
IDE01067-Retention of driver's seat heater level	active for 10 minutes 	1
IDE01476-Store recirculation air setting for terminal 15 off	Matching coding 	1
IDE01478-Ignore compressor switch-off by Engine Control Module	Do not ignore 	1
IDE01482-After-run of parking heater or parking ventilation	activated 	1
IDE01483-Blower voltage for voice operation	not activated 	1
IDE01495-After-run time of auxiliary heater with A/C off	120 s	1
IDE01503-Runtime for compressor run-in basic setting	120 s	1
IDE01536-Post-heating of parking heater	10 min	1
IDE02155-Reset all counters	not activated 	1
IDE02332-Deactivate production mode	0	3
IDE03176-Duration of compressor run in	0 s	1
IDE03251-Stop release for start-stop function	According to function requirements 	1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed)	1500 /min	1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost	active 	1
IDE07948-Retention of frt.pass. seat heater level	not active 	1
IDE12351-AUTO display for manual recirculation	Matching coding 	1
IDE12352-Fresh air/air recirculation door active during OFF operation	active 	1
Elapsed Time: 00:10
iichel
Eindhoven, NB, NL
C?ID=284912
;SW:2Q0-937-090-A   HW:2Q0-937-090 ---  Cent. Elect.
;Component:BCM A0 Std+   H98 0926	 Coding:
;EV_BCMA0	204001	EV_BCMA0_204.rod
;Sunday	24	February	2019	11:53:26:11868
;VCID: 3039ED819AA1B6472ED-8065
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not_active 	3
IDE00001-ENG130235-Production mode-Entry_control	not_active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not_active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not_active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not_active 	3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1	not_active 	3
IDE00001-ENG130232-Production mode-Window_reversing_threshold	not_active 	3
IDE00002-Transport mode	active 	4
IDE00820-Activating and deactivating all development messages	not active 	1
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	5
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln	not active 	5
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global	not active 	5
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn	not active 	5
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln	not active 	5
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn	normal 	5
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung	not active 	5
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte	not active 	5
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen	active 	5
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl	not active 	5
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl	not active 	5
IDE02711-ENG149246-Rear Window Wiper-Automatisches_Heckwischen	not active 	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	Keine_Spannungsanforderung 	8
IDE02711-ENG149248-Rear Window Wiper-Heckwischer_Weiterlauf	not active 	8
IDE02711-ENG115850-Rear Window Wiper-Komfortwischen_Heck	active 	8
IDE02711-ENG149251-Rear Window Wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1	5 s	8
IDE02711-ENG149252-Rear Window Wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2	3 s	8
IDE02711-ENG149250-Rear Window Wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik	7 s	8
IDE02711-ENG149249-Rear Window Wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall	7 s	8
IDE02711-ENG149245-Rear Window Wiper-Menuesteuerung_Komfortwischen_HW	active 	8
IDE02711-ENG148996-Rear Window Wiper-rear_window_wiper	DWP_Extraction 	8
IDE02711-ENG149247-Rear Window Wiper-Traenenwischen_Heck	active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front	installed 	8
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI	not active 	8
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	8
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	not active 	8
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel	Enabled 	8
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen	not active 	8
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus	not active 	8
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer	installed 	8
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung	not installed 	8
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung	not installed 	8
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe	Cold white 	8
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum	50%	8
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer	50%	8
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn	50%	8
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil	not installed 	8
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI	not installed 	8
IDE02957-ENG114629-Ambient lighting-Foot well lighting	installed 	8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled 	8
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung	not installed 	8
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung	not installed 	8
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung	not installed 	8
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel	not installed 	8
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel	not installed 	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.0 ∞	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	20.0 %/s	16
IDE03638-ENG149111-static AFS light-bei_Rueckwaertsfahrt	both sides 	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	120.0 ∞C	16
IDE03638-ENG149114-static AFS light-Obere_Geschwindigkeitsschwelle	40.0 km/h	16
IDE03638-ENG149117-static AFS light-obere_Grenztemperatur	100.0 ∞C	16
IDE03638-ENG149116-static AFS light-Oberer_Lenkradwinkel	120 ∞	16
IDE03638-ENG149113-static AFS light-Untere_Geschwindigkeitsschwelle	0.0 km/h	16
IDE03638-ENG149118-static AFS light-untere_Grenztemperatur	80.0 ∞C	16
IDE03638-ENG149115-static AFS light-Unterer_Lenkradwinkel	80 ∞	16
IDE03638-ENG116674-static AFS light-Vorschrift	ECE_R119 	16
IDE03638-ENG149112-static AFS light-Zeitwert_Einschaltzeit_Abbiegelicht	15 min	16
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	9
IDE04927-MAS01535-Window heater-Rear window defogger	installed 	9
IDE04927-MAS01564-Window heater-Windshield defogger	not installed 	9
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung	35.0 ∞C	9
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung	35.0 ∞C	9
IDE04927-ENG126613-Window heater-Aussenspiegelheizung	600 s	9
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert	320 s	9
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH	active 	9
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH	active 	9
IDE05144-Read parameter address	00 00 00 	3
IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 2D 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 2D 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 2D 3A 00 20 14 00 7F 12 00 80 00 00 00 00 00 00 2D 44 00 21 14 00 7F 13 00 80 00 00 00 00 00 00 0B 36 00 1A 0B 1E 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 1E 64 00 00 00 00 00 00 00 00 00 17 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 17 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 	208
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin	0	38
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin	0	38
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin	puddle light 	38
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung	zeitgesteuert 	36
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats	not connected 	36
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	seat_heater_on_LIN 	36
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	36
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1	0%	36
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2	20%	36
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3	0%	36
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4	100%	36
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5	0%	36
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6	100%	36
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.05	36
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit	2 min	36
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	24.00 ∞C	36
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	22.00 ∞C	36
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit	15 min	36
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	32.00 ∞C	36
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	30.00 ∞C	36
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit	15 min	36
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	40.00 ∞C	36
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	38.00 ∞C	36
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	36
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO	Keine_Spannungsanforderung 	36
IDE06096-ENG149157-Interior lighting-Innenlicht_bei_offenem_Heckdeckel_einschalten	active 	8
IDE06096-ENG98648-Interior lighting-Interior light	Keine_Spannungsanforderung 	8
IDE06425-Roller test bench mode: functional	not active 	1
IDE08786-MAS10528-Assistance light functions-Rain/light sensor	brightness_sensor 	9
IDE08786-MAS10545-Assistance light functions-Humidity sensor	installed 	9
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP	not active 	9
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung	0 ms	9
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen	not active 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit	0 ∞	7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC	0 ∞	7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0	not active 	7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1	not active 	7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10	not active 	7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11	not active 	7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12	not active 	7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13	not active 	7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14	not active 	7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15	not active 	7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16	not active 	7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17	not active 	7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18	not active 	7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19	not active 	7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2	not active 	7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20	not active 	7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21	not active 	7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22	not active 	7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23	not active 	7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24	not active 	7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25	not active 	7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26	not active 	7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27	not active 	7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28	not active 	7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29	not active 	7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3	not active 	7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30	not active 	7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31	not active 	7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32	not active 	7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33	not active 	7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34	not active 	7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4	not active 	7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5	not active 	7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6	not active 	7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7	not active 	7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8	not active 	7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9	not active 	7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand	0_Ohm 	7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit	0 ∞	7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC	0 ∞	7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0	not active 	7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1	not active 	7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10	not active 	7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11	not active 	7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12	not active 	7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13	not active 	7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14	not active 	7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15	not active 	7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16	not active 	7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17	not active 	7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18	not active 	7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19	not active 	7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2	not active 	7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20	not active 	7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21	not active 	7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22	not active 	7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23	not active 	7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24	not active 	7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25	not active 	7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26	not active 	7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27	not active 	7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28	not active 	7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29	not active 	7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3	not active 	7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30	not active 	7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31	not active 	7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32	not active 	7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33	not active 	7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34	not active 	7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4	not active 	7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5	not active 	7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6	not active 	7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7	not active 	7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8	not active 	7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9	not active 	7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand	0_Ohm 	7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs	Energiemanagement oder Zeit 	6
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit	30 min	6
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose	not active 	6
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein	active 	6
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	3
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	3
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	3
IDE11944-MAS10510-Keyless access and start authorization-Kessy	not installed 	5
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR	not active 	5
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungs¸berwachung IDGeber	not active 	5
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit	not active 	5
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit	not active 	5
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen	not active 	5
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen	active 	5
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung	not active 	5
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system	not installed 	5
MAS01490-IDE08581-Energy management-Recuperation	active 	5
MAS01490-MAS12921-Energy management-Predictive energy management	not active 	5
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement	active 	5
MAS01490-ENG98636-Energy management-Hybrid	No 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	2000 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 32 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	4000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	NOT-DEFINED 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4300 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	6000 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	1400 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC	First_dtc 	9
ENG148492-MAS01577-Anti-theft device-Parking heater	not installed 	5
ENG148492-ENG149232-Anti-theft device-Akustischer_Alarm_Signalhorn	not active 	5
ENG148492-ENG115864-Anti-theft device-Alarmsignal	frequency_modulated 	5
ENG148492-ENG148991-Anti-theft device-anti_theft_alarm_system	not active 	5
ENG148492-ENG148992-Anti-theft device-anti_theft_alarm_with_simple_horn	not installed 	5
ENG148492-ENG148993-Anti-theft device-anti_theft_alarm_without_Thatcham	No 	5
ENG148492-ENG148990-Anti-theft device-deactivation_button_anti_theft_alarm_sensor	not installed 	5
ENG148492-ENG154590-Anti-theft device-Deaktivierung_DWA_ueber_MMI	not active 	5
ENG148492-ENG123016-Anti-theft device-Diebstahlschutz_mit_Anhaenger	not active 	5
ENG148492-ENG149229-Anti-theft device-DWA_Alarmverzoegerung	immidiat_driver_door_contact_thatcham 	5
ENG148492-ENG149230-Anti-theft device-DWA_Camper_Modus	not active 	5
ENG148492-ENG148994-Anti-theft device-interior_monitoring_sensor	No 	5
ENG148492-ENG149231-Anti-theft device-Sirenen_Alarmzahl	10_Alarme 	5
ENG148492-ENG142008-Anti-theft device-tilt_sensor	No 	5
ENG148492-ENG149228-Anti-theft device-Verzoegerung_Panikalarm	2_sekunden_verzoegerung 	5
ENG141649-ENG133379-Auflenlicht_Blinker-Abbruch Komfortblinken	active 	5
ENG141649-ENG130187-Auflenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger	separte 	5
ENG141649-ENG115774-Auflenlicht_Blinker-Komfortblinken	active 	5
ENG141649-ENG115854-Auflenlicht_Blinker-Komfortblinken_Blinkzyklen	3	5
ENG141647-MAS10529-Auflenlicht_Front-Low beam: bulb type	H7 	9
ENG141647-ENG149099-Auflenlicht_Front-Allwetterlicht_Ausschaltgrenze	350 km/h	9
ENG141647-ENG149098-Auflenlicht_Front-Allwetterlicht_Einschaltgrenze	350 km/h	9
ENG141647-ENG149106-Auflenlicht_Front-Fahrlicht_bei_Tag	Daytime running lights 	9
ENG141647-ENG149097-Auflenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich	active 	9
ENG141647-ENG126567-Auflenlicht_Front-max_scheinwerfer_2limitieren	in_Betrieb_lassen 	9
ENG141647-ENG149100-Auflenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht	not active 	9
ENG141647-ENG149103-Auflenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht	active 	9
ENG141647-ENG149101-Auflenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich	not active 	9
ENG141647-ENG149104-Auflenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten	not active 	9
ENG141647-ENG149107-Auflenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO	not active 	9
ENG141647-ENG149105-Auflenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht	not active 	9
ENG141647-ENG115733-Auflenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG149102-Auflenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge	active 	9
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal	No 	5
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion	not active 	5
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit	255 km/h	5
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA	active 	5
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion	not active 	5
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion	not active 	5
ENG141656-MAS10538-Auflenlicht_uebergreifend-Light rotary sw. connection	Discrete signal current 	16
ENG141656-MAS10541-Auflenlicht_uebergreifend-Light rotary switch with fog light	Yes 	16
ENG141656-MAS10542-Auflenlicht_uebergreifend-Light rotary switch with fog tail light	Yes 	16
ENG141656-MAS10543-Auflenlicht_uebergreifend-Light rotary sw. with AFL	Yes 	16
ENG141656-MAS10544-Auflenlicht_uebergreifend-Light rotary switch with park. light pos.	Yes 	16
ENG141656-ENG248495-Auflenlicht_uebergreifend-ABL_off_ECE48_Rev6	No 	16
ENG141656-ENG133381-Auflenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	Energy management 	16
ENG141656-ENG133380-Auflenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	Energy management 	16
ENG141656-ENG126566-Auflenlicht_uebergreifend-beidseitiges_dauerparklicht	active 	16
ENG141656-ENG149092-Auflenlicht_uebergreifend-Coming_home_Leuchten	Low beam 	16
ENG141656-ENG149089-Auflenlicht_uebergreifend-Coming_Home_Verbaustatus	manual 	16
ENG141656-ENG149093-Auflenlicht_uebergreifend-Coming-home_Einschaltereignis	ignition 	16
ENG141656-ENG248654-Auflenlicht_uebergreifend-ECE48_Rev6_aktiv	not active 	16
ENG141656-ENG126818-Auflenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	in 0 and SL position 	16
ENG141656-ENG137034-Auflenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	16
ENG141656-ENG154619-Auflenlicht_uebergreifend-Fernlicht_LH	Keine_Spannungsanforderung 	16
ENG141656-ENG154177-Auflenlicht_uebergreifend-Fog light	Keine_Spannungsanforderung 	16
ENG141656-ENG149096-Auflenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung	116	16
ENG141656-ENG149094-Auflenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung	72	16
ENG141656-ENG155156-Auflenlicht_uebergreifend-keine_LCM_blinker	false 	16
ENG141656-ENG149086-Auflenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht	integriert_in_Suchbeleuchtung 	16
ENG141656-ENG149095-Auflenlicht_uebergreifend-Leaving-Home_Verbausstatus	Enabled 	16
ENG141656-ENG126569-Auflenlicht_uebergreifend-lho_aktiviert	active 	16
ENG141656-ENG126570-Auflenlicht_uebergreifend-lho_zeit	30 seconds 	16
ENG141656-ENG149005-Auflenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht	Yes 	16
ENG141656-ENG115862-Auflenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	16
ENG141656-ENG142034-Auflenlicht_uebergreifend-Light_Control_Module	not installed 	16
ENG141656-ENG98354-Auflenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	16
ENG141656-ENG149088-Auflenlicht_uebergreifend-Menueeinstellung_CHO_LHO	Menuesteuerung_Zeit_aktivieren 	16
ENG141656-ENG149091-Auflenlicht_uebergreifend-Menueeinstellung_Cominghome	30 seconds 	16
ENG141656-ENG149090-Auflenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung	active 	16
ENG141656-ENG149087-Auflenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert	One-sided 	16
ENG141656-ENG126565-Auflenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt	active 	16
ENG141656-ENG137035-Auflenlicht_uebergreifend-Standlicht-Verfuegbarkeit	24 s	16
ENG141656-ENG248823-Auflenlicht_uebergreifend-TFL_off_ECE48_Rev6	No 	16
ENG141656-ENG154174-Auflenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	16
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1	installed 	5
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2	not installed 	5
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3	not installed 	5
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4	not installed 	5
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control	Halogen 	6
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset	not active 	6
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert	800 ms	6
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent	present 	6
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung	present 	6
ENG141645-IDE05739-HW_Verbau-Footwell light	not installed 	8
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch	installed 	8
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter	Open 	8
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15	active 	8
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN	horn_via_LIN 	8
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0	0 lx	10
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1	8 lx	10
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2	200 lx	10
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3	300 lx	10
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4	500 lx	10
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0	16	10
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1	16	10
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2	100	10
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3	100	10
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4	100	10
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0	0 lx	10
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1	8 lx	10
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2	220 lx	10
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3	300 lx	10
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4	500 lx	10
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0	6	10
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1	6	10
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2	100	10
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3	100	10
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4	100	10
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0	0	12
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1	10	12
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2	50	12
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3	100	12
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4	220	12
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5	253	12
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0	2.00%	12
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1	2.00%	12
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2	6.00%	12
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3	10.00%	12
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4	80.00%	12
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5	100.00%	12
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0	0 lx	8
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1	8 lx	8
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2	50 lx	8
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3	500 lx	8
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0	100	8
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1	100	8
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2	100	8
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3	100	8
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0	0.00%	6
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1	50.00%	6
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2	100.00%	6
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0	0.00%	6
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1	50.00%	6
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2	100.00%	6
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0	0 lx	8
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1	8 lx	8
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2	50 lx	8
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3	500 lx	8
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0	100	8
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1	100	8
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2	100	8
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3	100	8
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0	0 lx	8
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1	8 lx	8
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2	50 lx	8
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3	500 lx	8
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0	6	8
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1	6	8
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2	100	8
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3	100	8
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0	0.00%	6
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1	50.00%	6
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2	100.00%	6
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0	0.00%	6
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1	50.00%	6
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2	100.00%	6
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx	8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx	8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx	8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx	8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6	8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6	8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100	8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100	8
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0	0 ms	22
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1	100 ms	22
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10	1000 ms	22
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2	200 ms	22
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3	300 ms	22
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4	400 ms	22
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5	500 ms	22
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6	600 ms	22
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7	700 ms	22
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8	800 ms	22
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9	900 ms	22
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0	100.00%	22
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1	100.00%	22
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10	0.00%	22
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2	95.00%	22
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3	80.00%	22
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4	40.00%	22
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5	20.00%	22
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6	10.00%	22
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7	5.00%	22
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8	3.00%	22
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9	1.00%	22
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0	0	22
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1	50	22
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2	100	22
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3	200	22
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4	253	22
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0	0 lx	22
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1	50 lx	22
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2	100 lx	22
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3	200	22
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4	500	22
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0	0 ms	22
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1	100 ms	22
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10	1000 ms	22
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2	200 ms	22
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3	300 ms	22
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4	400 ms	22
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5	500 ms	22
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6	600 ms	22
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7	700 ms	22
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8	800 ms	22
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9	900 ms	22
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0	0.00%	22
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10	100.00%	22
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7	80.00%	22
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8	95.00%	22
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9	100.00%	22
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0	0.00%	12
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1	6.00%	12
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2	16.00%	12
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3	30.00%	12
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4	60.00%	12
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5	100.00%	12
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0	10	12
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1	10	12
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2	100	12
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3	150	12
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4	220	12
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5	253	12
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0	0 ms	10
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1	2000 ms	10
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2	3000 ms	10
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3	4000 ms	10
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4	5100 ms	10
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0	1.00%	10
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1	5	10
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2	15	10
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3	40	10
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4	100	10
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters	LSS ohne Elektronik 	5
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal	LIN-Signal 	5
ENG148608-ENG155105-Lenkradhebel-FAS-Taster	not installed 	5
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung	FL tastend 	5
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung	MFL-Bedienung 	5
ENG148608-ENG149001-Lenkradhebel-heated_mirror	installed with mirror switch 	5
ENG148608-ENG149004-Lenkradhebel-speed_limiter	installed 	5
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL	Direct 	5
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter	CAN 	5
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30	installed 	5
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0	100	16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0	0	16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0	maximize 	16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0	maximize 	16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0	maximize 	16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0	0	16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0	0	16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0	14	16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0	34	16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0	Always 	16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0	Blinken links Hellphase 	16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0	not active 	16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0	not active 	16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0	not active 	16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0	not active 	16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0	not active 	16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0	not active 	16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0	not active 	16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0	Blinkleuchten 	16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10	0	16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10	0	16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10	maximize 	16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10	maximize 	16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10	maximize 	16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10	0	16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10	0	16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10	0	16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10	0	16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10	Always 	16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10	not active 	16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10	not active 	16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10	not active 	16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10	not active 	16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10	not active 	16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10	not active 	16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10	not active 	16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10	not active 	16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10	not active 	16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11	100	16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11	0	16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11	maximize 	16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11	maximize 	16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11	maximize 	16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11	0	16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11	0	16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11	0	16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11	0	16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11	Always 	16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11	Warnblinktaster 	16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11	not active 	16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11	not active 	16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11	not active 	16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11	not active 	16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11	not active 	16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11	not active 	16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11	not active 	16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12	100	16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12	0	16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12	maximize 	16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12	maximize 	16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12	maximize 	16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12	0	16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12	0	16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12	22	16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12	38	16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12	Always 	16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12	Nebellicht links 	16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12	Abbiegelicht links 	16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12	not active 	16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12	not active 	16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12	not active 	16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12	not active 	16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12	not active 	16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12	not active 	16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12	allgemeine Scheinwerfer 	16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13	100	16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13	0	16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13	maximize 	16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13	maximize 	16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13	maximize 	16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13	0	16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13	0	16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13	23	16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13	42	16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13	Always 	16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13	Nebellicht rechts 	16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13	Abbiegelicht rechts 	16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13	not active 	16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13	not active 	16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13	not active 	16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13	not active 	16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13	not active 	16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13	not active 	16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13	allgemeine Scheinwerfer 	16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15	127	16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15	0	16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15	maximize 	16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15	maximize 	16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15	maximize 	16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15	0	16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15	0	16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15	0	16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15	0	16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15	Always 	16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15	SafeLED 	16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15	not active 	16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15	not active 	16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15	not active 	16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15	not active 	16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15	not active 	16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15	not active 	16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15	not active 	16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16	100	16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16	0	16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16	maximize 	16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16	maximize 	16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16	maximize 	16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16	0	16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16	0	16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16	0	16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16	0	16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16	Always 	16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16	Blinken links Hellphase 	16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16	not active 	16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16	not active 	16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16	not active 	16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16	not active 	16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16	not active 	16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16	not active 	16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16	not active 	16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17	100	16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17	0	16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17	maximize 	16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17	maximize 	16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17	maximize 	16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17	0	16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17	0	16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17	0	16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17	0	16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17	Always 	16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17	Blinken rechts Hellphase 	16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17	not active 	16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17	not active 	16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17	not active 	16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17	not active 	16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17	not active 	16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17	not active 	16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17	not active 	16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18	100	16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18	0	16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18	maximize 	16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18	maximize 	16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18	maximize 	16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18	0	16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18	0	16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18	16	16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18	8	16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18	Always 	16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18	Blinken links Hellphase 	16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18	not active 	16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18	not active 	16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18	not active 	16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18	not active 	16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18	not active 	16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18	not active 	16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18	not active 	16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18	Blinkleuchten 	16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19	100	16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19	0	16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19	maximize 	16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19	maximize 	16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19	maximize 	16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19	0	16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19	0	16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19	18	16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19	18	16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19	Always 	16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19	Blinken rechts Hellphase 	16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19	not active 	16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19	not active 	16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19	not active 	16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19	not active 	16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19	not active 	16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19	not active 	16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19	not active 	16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19	Blinkleuchten 	16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1	100	16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1	0	16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1	maximize 	16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1	maximize 	16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1	maximize 	16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1	0	16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1	0	16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1	15	16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1	3E 	16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1	Always 	16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1	Blinken rechts Hellphase 	16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1	not active 	16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1	not active 	16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1	not active 	16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1	not active 	16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1	not active 	16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1	not active 	16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1	not active 	16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1	Blinkleuchten 	16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20	100	16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20	15	16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20	maximize 	16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20	maximize 	16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20	maximize 	16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20	0	16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20	0	16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20	39	16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20	10	16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20	Always 	16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20	Brake light 	16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20	not active 	16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20	Parking light 	16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20	Parking light left 	16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20	not active 	16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20	not active 	16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20	not active 	16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20	not active 	16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20	Bremsleuchten 	16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21	100	16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21	15	16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21	maximize 	16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21	maximize 	16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21	maximize 	16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21	0	16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21	0	16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21	3A 	16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21	20	16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21	Always 	16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21	Brake light 	16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21	not active 	16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21	Parking light 	16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21	Parking light right 	16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21	not active 	16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21	not active 	16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21	not active 	16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21	not active 	16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21	Bremsleuchten 	16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22	100	16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22	0	16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22	maximize 	16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22	maximize 	16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22	maximize 	16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22	0	16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22	0	16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22	2C 	16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22	29	16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22	Always 	16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22	Brake light 	16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22	not active 	16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22	not active 	16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22	not active 	16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22	not active 	16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22	not active 	16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22	not active 	16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22	not active 	16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22	LEDdritteBremsleuchte 	16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23	55	16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23	0	16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23	maximize 	16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23	maximize 	16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23	maximize 	16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23	0	16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23	0	16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23	29	16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23	0A 	16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23	Always 	16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23	Parking light 	16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23	Parking light left 	16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23	not active 	16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23	not active 	16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23	not active 	16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23	not active 	16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23	not active 	16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23	not active 	16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23	allgemeineGluehlampe27W:auchH15-TFL 	16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24	55	16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24	0	16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24	maximize 	16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24	maximize 	16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24	maximize 	16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24	0	16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24	0	16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24	2A 	16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24	1A 	16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24	Always 	16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24	Parking light 	16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24	Parking light right 	16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24	not active 	16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24	not active 	16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24	not active 	16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24	not active 	16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24	not active 	16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24	not active 	16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24	allgemeineGluehlampe27W:auchH15-TFL 	16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25	100	16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25	0	16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25	maximize 	16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25	maximize 	16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25	maximize 	16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25	0	16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25	0	16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25	30	16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25	28	16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25	Always 	16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25	Parking light 	16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25	not active 	16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25	not active 	16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25	not active 	16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25	not active 	16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25	not active 	16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25	not active 	16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25	not active 	16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose 	16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26	100	16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26	0	16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26	maximize 	16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26	maximize 	16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26	maximize 	16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26	0	16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26	0	16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26	33	16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26	0C 	16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26	Always 	16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26	NebelschlusslichtwennkeinAnhaengergesteckt 	16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26	not active 	16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26	not active 	16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26	not active 	16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26	not active 	16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26	not active 	16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26	not active 	16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26	not active 	16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL 	16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27	100	16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27	0	16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27	maximize 	16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27	maximize 	16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27	maximize 	16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27	0	16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27	0	16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27	8	16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27	0	16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27	Always 	16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27	Terminal 58xs dimmer 	16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27	not active 	16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27	not active 	16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27	not active 	16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27	not active 	16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27	not active 	16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27	not active 	16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27	not active 	16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28	100	16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28	0	16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28	maximize 	16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28	maximize 	16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28	maximize 	16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28	0	16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28	0	16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28	32	16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28	1B 	16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28	Always 	16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28	Rueckfahrlicht 	16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28	not active 	16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28	not active 	16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28	not active 	16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28	not active 	16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28	not active 	16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28	not active 	16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28	not active 	16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL 	16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29	100	16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29	0	16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29	maximize 	16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29	maximize 	16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29	maximize 	16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29	0	16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29	0	16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29	1	16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29	0	16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29	Always 	16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29	Klemme 30G 	16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29	not active 	16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29	not active 	16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29	not active 	16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29	not active 	16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29	not active 	16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29	not active 	16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29	not active 	16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29	allgemeineGluehlampe12W 	16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2	127	16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2	0	16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2	maximize 	16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2	maximize 	16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2	maximize 	16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2	0	16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2	0	16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2	26	16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2	35	16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2	Always 	16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2	Parking light 	16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2	Parking light left 	16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2	not active 	16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2	not active 	16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2	not active 	16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2	not active 	16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2	not active 	16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2	not active 	16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2	allgemeineLEDmitOpenLoadDiagnose 	16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30	126	16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30	0	16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30	maximize 	16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30	maximize 	16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30	maximize 	16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30	0	16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30	0	16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30	7	16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30	0	16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30	Always 	16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30	Interior light 	16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30	not active 	16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30	not active 	16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30	not active 	16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30	not active 	16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30	not active 	16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30	not active 	16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30	not active 	16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30	allgemeineGluehlampe12W 	16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31	96	16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31	0	16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31	maximize 	16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31	maximize 	16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31	maximize 	16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31	0	16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31	0	16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31	0	16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31	0	16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31	Always 	16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31	Ambientelicht 1 	16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31	not active 	16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31	not active 	16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31	not active 	16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31	not active 	16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31	not active 	16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31	not active 	16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31	not active 	16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32	96	16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32	0	16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32	maximize 	16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32	maximize 	16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32	maximize 	16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32	0	16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32	0	16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32	0	16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32	0	16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32	Always 	16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32	Footwell light 	16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32	not active 	16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32	not active 	16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32	not active 	16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32	not active 	16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32	not active 	16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32	not active 	16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32	not active 	16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32	LED Kleinleistung ohne Open Load Diagnose 	16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33	0	16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33	0	16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33	maximize 	16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33	maximize 	16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33	maximize 	16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33	0	16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33	0	16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33	0	16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33	0	16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33	Always 	16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33	not active 	16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33	not active 	16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33	not active 	16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33	not active 	16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33	not active 	16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33	not active 	16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33	not active 	16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33	not active 	16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33	not active 	16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34	0	16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34	0	16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34	maximize 	16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34	maximize 	16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34	maximize 	16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34	0	16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34	0	16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34	0	16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34	0	16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34	Always 	16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34	not active 	16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34	not active 	16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34	not active 	16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34	not active 	16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34	not active 	16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34	not active 	16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34	not active 	16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34	not active 	16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34	not active 	16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3	127	16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3	0	16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3	maximize 	16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3	maximize 	16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3	maximize 	16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3	0	16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3	0	16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3	27	16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3	3F 	16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3	Always 	16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3	Parking light 	16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3	Parking light right 	16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3	not active 	16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3	not active 	16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3	not active 	16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3	not active 	16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3	not active 	16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3	not active 	16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3	allgemeineLEDmitOpenLoadDiagnose 	16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4	127	16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4	0	16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4	minimize 	16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4	maximize 	16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4	maximize 	16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4	0	16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4	0	16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4	20	16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4	3A 	16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4	Always 	16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4	Daytime running lights 	16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4	not active 	16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4	Nebellicht links 	16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4	not active 	16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4	not active 	16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4	not active 	16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4	not active 	16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4	not active 	16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose 	16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5	127	16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5	0	16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5	minimize 	16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5	maximize 	16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5	maximize 	16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5	0	16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5	0	16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5	21	16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5	44	16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5	Always 	16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5	Daytime running lights 	16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5	not active 	16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5	Nebellicht rechts 	16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5	not active 	16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5	not active 	16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5	not active 	16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5	not active 	16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5	not active 	16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose 	16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6	100	16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6	0	16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6	maximize 	16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6	maximize 	16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6	maximize 	16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6	0	16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6	0	16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6	1A 	16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6	36	16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6	Always 	16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6	Abblendlicht links 	16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6	ComingHome LeavingHome 	16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6	not active 	16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6	not active 	16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6	not active 	16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6	not active 	16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6	not active 	16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6	not active 	16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6	Low beam 	16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7	100	16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7	0	16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7	maximize 	16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7	maximize 	16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7	maximize 	16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7	0	16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7	0	16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7	1B 	16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7	40	16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7	Always 	16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7	Abblendlicht rechts 	16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7	ComingHome LeavingHome 	16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7	not active 	16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7	not active 	16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7	not active 	16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7	not active 	16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7	not active 	16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7	not active 	16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7	Low beam 	16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8	100	16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8	0	16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8	maximize 	16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8	maximize 	16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7	maximize 	16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8	0	16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8	0	16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8	1C 	16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8	37	16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8	Always 	16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8	Left high beam 	16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8	Headlamp flasher 	16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8	not active 	16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8	not active 	16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8	not active 	16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8	not active 	16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8	not active 	16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8	not active 	16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8	allgemeineScheinwerferohneAbschaltung 	16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9	100	16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9	0	16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9	maximize 	16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9	maximize 	16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9	maximize 	16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9	0	16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9	0	16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9	1D 	16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9	41	16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9	Always 	16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9	Right high beam 	16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9	Headlamp flasher 	16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9	not active 	16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9	not active 	16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9	not active 	16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9	not active 	16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9	not active 	16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9	not active 	16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9	allgemeineScheinwerferohneAbschaltung 	16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14	100	16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14	0	16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14	maximize 	16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14	maximize 	16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14	maximize 	16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14	0	16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14	0	16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14	0	16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14	0	16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14	Always 	16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14	LockUnlockLED 	16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14	not active 	16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14	not active 	16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14	not active 	16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14	not active 	16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14	not active 	16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14	not active 	16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14	not active 	16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14	LED Kleinleistung ohne Open Load Diagnose 	16
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck)	0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 0D 10 00 39 18 00 64 08 09 0F 00 00 00 00 00 00 0D 20 00 3A 18 00 64 08 0A 0F 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 09 0A 00 29 08 09 37 00 00 00 00 00 00 00 00 00 09 1A 00 2A 08 0A 37 00 00 00 00 00 00 00 00 00 20 28 00 30 08 00 64 00 00 00 00 00 00 00 00 00 09 0C 00 33 1A 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 	160
ENG148594-Leuchtenkonfiguration (Sonstiges)	24 00 00 00 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 40 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 00 02 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 08 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 08 00 00 07 29 00 7E 00 00 00 00 00 00 00 00 00 24 00 00 00 2D 00 60 00 00 00 00 00 00 00 00 00 24 00 00 00 2B 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	192
ENG126648-MAS02526-LIN-Mirrormode-Activation	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-ENG149044-LIN-Mirrormode-LIN4	not active 	1
ENG126648-ENG149045-LIN-Mirrormode-LIN5	not active 	1
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0	0.00%	12
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1	0.00%	12
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2	0.00%	12
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3	0.00%	12
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4	0.00%	12
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5	0.00%	12
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0	0.00%	12
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1	0.00%	12
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2	0.00%	12
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3	0.00%	12
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4	0.00%	12
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5	0.00%	12
ENG122979-MAS00075-Networking-Brake control module	installed 	8
ENG122979-MAS00798-Networking-Transmission Control Module (TCM)	installed 	8
ENG122979-MAS01374-Networking-Trailer	not installed 	8
ENG122979-MAS03175-Networking-Databus extended	not installed 	8
ENG122979-MAS09880-Networking-Interval potentiometer	installed 	8
ENG122979-MAS09882-Networking-MFA button on BCM	installed 	8
ENG122979-MAS10518-Networking-A/C electronics	installed 	8
ENG122979-MAS10570-Networking-Window lift type	MQB_window_regulator 	8
ENG122979-ENG149007-Networking-Door LIN	installed 	8
ENG122979-ENG149008-Networking-Roof LIN	installed 	8
ENG122979-ENG149009-Networking-Sounder LIN	not installed 	8
ENG124714-ENG142044-OCU-DWA_push	active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	active 	8
ENG124714-OCU-	not installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0	15 s	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2	15 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4	15 s	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	Via ZV-Absicherung Light 	8
ENG124714-ENG154722-OCU-RHF_Panikalarm	not active 	8
ENG148614-ENG148862-Patch_code_driver-Parameter_1	FF 08 00 FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	128
ENG148614-ENG148865-Patch_code_driver-Parameter_2	FF FF 	128
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1	00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2	FF FF 	128
ENG148615-ENG148862-Patch_code_passenger-Parameter_1	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 08 00 FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	128
ENG148615-ENG148865-Patch_code_passenger-Parameter_2	FF FF 	128
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1	00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2	FF FF 	128
ENG141646-MAS00481-Querschnitts_funktionen-BAP	active 	5
ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
ENG141646-MAS04194-Querschnitts_funktionen-Driver side	Left 	5
ENG141646-MAS10509-Querschnitts_funktionen-Traffic	Right 	5
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer	installed 	5
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung	not active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben	not active 	5
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv	not active 	5
ENG141646-ENG148952-Querschnitts_funktionen-P_locked	installed 	5
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3	not installed 	5
ENG117297-Reversing_Threshold_Driver_Side_Front	90%	1
ENG117299-Reversing_Threshold_Driver_Side_Rear	90%	1
ENG117298-Reversing_Threshold_Passenger_Side_Front	90%	1
ENG117300-Reversing_Threshold_Passenger_Side_Rear	90%	1
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system	not installed 	10
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA	active 	10
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung	10	10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel	active 	10
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit	2000 ms	10
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit	800 ms	10
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit	10000 ms	10
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit	0 ms	10
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit	800 ms	10
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system	installed 	10
ENG148494-MAS10534-Search lights-Input medium: search illumination	HMI 	21
ENG148494-ENG142240-Search lights-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG148494-ENG154582-Search lights-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
ENG148494-ENG154583-Search lights-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
ENG148494-ENG154584-Search lights-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
ENG148494-ENG154585-Search lights-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
ENG148494-ENG179120-Search lights-Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
ENG148494-ENG142242-Search lights-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
ENG148494-ENG142241-Search lights-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
ENG148494-ENG149159-Search lights-KL58_Einschalten_mit_Rampe	not active 	21
ENG148494-ENG149160-Search lights-KL58_Verriegelungsausschalten	not_active 	21
ENG148494-ENG149161-Search lights-Lichtsensor_wirkt_auf_Suchbeleuchtung	active 	21
ENG148494-ENG149162-Search lights-Suchbeleuchtung_Festwert	100%	21
ENG148494-ENG142234-Search lights-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG148494-ENG130188-Search lights-Warnblinktastersuchbeleuchtung_Aktivierung	always_active 	21
ENG148494-ENG130190-Search lights-Warnblinktastersuchbeleuchtung_Faktor	0.1	21
ENG148494-ENG130189-Search lights-Warnblinktastersuchbeleuchtung_Grundwert	6.00%	21
ENG116588-MAS10520-Sonderfunktionen-Special function 1	not installed 	4
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker	SMLS 	4
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2	not enabled 	4
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen	not active 	5
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus	by_convenience_operation_via_remote_control_key 	5
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung	not active 	5
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen	not active 	5
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side	not installed 	5
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel	active 	5
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf	not active 	5
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt	not active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig	not active 	5
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress	getauscht 	5
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0	0.0 lx	10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1	8.0 lx	10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2	50.0 lx	10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3	80.0 lx	10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4	100.0 lx	10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0	6	10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1	6	10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2	20	10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3	50	10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4	100	10
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0	6	10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1	6	10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2	20	10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3	50	10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4	100	10
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	86	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141632-MAS10512-Sunroof-Sunroof module MD1	not installed 	4
ENG141632-MAS10513-Sunroof-Sunroof module MD shade	not installed 	4
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen	not active 	4
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen	not active 	4
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen	tilting 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	CAN 	4
ENG148611-MAS10548-Verbau Personalisierung-Profile function	Key profile 	8
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	8
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten	4	8
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung	not active 	8
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	8
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv	not active 	8
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	8
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante	Schluessel 	8
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0	not active 	8
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1	active 	8
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2	active 	8
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3	not active 	8
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4	not active 	8
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5	not active 	8
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6	not active 	8
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7	not active 	8
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1	00 00 	20
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2	00 00 	20
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3	00 00 	20
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4	00 00 	20
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1	00 00 	20
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2	00 00 	20
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3	00 00 	20
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4	00 00 	20
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5	00 00 	20
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6	00 00 	20
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1	04 06 90 19 02 00 00 08 FF BE F7 07 D0 10 10 F6 00 C8 32 0B 0F 03 84 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 07 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 02 98 10 00 02 51 C0 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 EF 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00 	128
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2	EB 76 	128
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1	03 84 02 8A 14 1E EC 01 0B 02 08 00 00 00 00 05 32 02 1E 19 0A 00 0A F4 32 1E 10 00 03 FD 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 32 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 06 37 11 10 0C 32 C8 F6 E7 F6 FB 19 14 05 0E 14 01 5E 02 34 10 10 0E 32 64 D8 D8 F1 F6 28 1E 05 0F 0C 19 19 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	128
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2	B8 CA 	128
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1	29 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 01 90 01 90 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	128
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2	19 34 	128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1	00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 0F FF DF FF 00 00 00 0A 01 00 00 00 	128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2	FF CE 	128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1	03 20 02 26 14 EC 04 02 02 0A 02 02 00 0A 05 28 04 14 19 0F 00 05 EC 19 1E 14 00 05 FB 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 20 1E FA E2 CE F1 F6 28 1E 32 08 1E 00 00 32 02 16 0E 14 12 C8 EC D8 F1 F6 1E 14 32 00 0C 14 01 2C 02 19 0E 14 12 FA E2 CE F1 F6 28 1E 32 00 0E 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2	8C 1F 	128
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1	04 06 90 19 02 00 00 08 FF BE F7 07 D0 10 10 F6 00 C8 32 0B 0F 03 84 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 07 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 02 98 10 00 02 51 C0 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 8F 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00 	128
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2	AF 70 	128
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1	03 84 02 8A 14 1E EC 01 0B 02 08 00 00 00 00 05 32 02 1E 19 0A 00 0A F4 32 1E 10 00 03 FD 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 32 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 06 37 11 10 0C 32 C8 F6 E7 F6 FB 19 14 05 0E 14 01 5E 02 34 10 10 0E 32 64 D8 D8 F1 F6 28 1E 05 0F 0C 19 19 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	128
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2	B8 CA 	128
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1	29 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 0E 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	128
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2	78 6E 	128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1	00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 0F FF DF FF 00 00 00 0A 01 00 00 00 	128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2	AC 46 	128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1	03 20 02 26 14 EC 04 02 02 0A 02 02 00 0A 05 28 04 14 19 0F 00 05 EC 19 1E 14 00 05 FB 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 20 1E FA E2 CE F1 F6 28 1E 32 08 1E 00 00 32 02 16 0E 14 12 C8 EC D8 F1 F6 1E 14 32 00 0C 14 01 2C 02 19 0E 14 12 FA E2 CE F1 F6 28 1E 32 00 0E 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2	8C 1F 	128
ENG124895-Window_Regulator_VW_Settings_Driver_Side	F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 28 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 96 96 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 1E 3C 50 00 64 55 3A 06 00 B4 01 00 0A 00 14 00 00 	128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear	F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 A0 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 41 30 39 01 00 00 00 00 00 00 00 00 00 AD 84 	88
ENG130137-Window_Regulator_VW_Settings_Passenger_Side	F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 28 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 32 32 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 1E 3C 50 00 64 55 3A 06 01 E1 01 00 0A 00 14 00 00 	128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear	F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 A0 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 41 30 39 01 00 00 00 00 00 00 00 00 00 A0 02 	88
ENG148493-ENG115721-Windshield wiper-Frontwischer	Sollspannungsanforderung 13.5 	6
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition	keine_Abtaupostition 	6
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf	active 	6
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition	active 	6
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung	active 	6
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer	not active 	6
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer	0 ms	6
ENG148493-ENG149042-Windshield wiper-rain_sensor_function	not installed 	6
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren	not active 	6
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status	not active 	6
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	active 	6
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ	Direct 	6
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube	not active 	6
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus	not active 	6
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart	immer_Wischerstopp 	6
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube	active 	6
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button	Rocker sw. 	5
ENG141651-MAS10546-ZV allgemein-Radio freq.	434.42MHz 	5
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function	installed 	5
ENG141651-ZV allgemein-	not active 	5
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen	not active 	5
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm	not active 	5
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf	not active 	5
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	5
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein	not active 	5
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Auflenhaut	not active 	5
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung	active 	5
ENG141651-ENG115755-ZV allgemein-Notschlieflfunktion	active 	5
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung	all_doors_connected_directly 	5
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung	Yes 	5
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung	Globale_Entriegelung 	5
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck	active 	5
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln	active 	5
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit	not active 	5
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR	not active 	5
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock	adjustable 	5
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren	active 	4
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen	active 	4
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash	not active 	4
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button	not installed 	5
ENG141653-MAS10551-ZV Heck-Rear lid lock control	Contact control 	5
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type	1 or 2 notch rear actuator 	5
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch	Yes 	5
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels	active 	5
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster	not active 	5
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	5
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	5
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung	digitale_Logik 	5
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel	active 	5
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen	not active 	5
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing	active 	7
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening	not active 	7
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front	active 	7
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear	Yes 	7
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschlieflen	not active 	7
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf	not active 	7
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen	active 	7
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen	active 	7
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit	600 s	7
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus	active 	7
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen	active 	7
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen	active 	7
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen	active 	7
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster	not active 	7
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global	active 	7
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer	not active 	7
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien	not active 	7
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung	not active 	7
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar	adjustable 	7
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen	active 	7
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen	active 	7
ENG141652-MAS01914-ZV T¸rkonfiguration-Type of lock	1 Motor locks without Safe (NAR locks) 	5
ENG141652-MAS06443-ZV T¸rkonfiguration-Lock cylinder passenger door	not installed 	5
ENG141652-MAS10567-ZV T¸rkonfiguration-Four-door	Yes 	5
Elapsed Time: 01:33
iichel
Eindhoven, NB, NL
C?ID=284912
;SW:5QA-919-294-C   HW:5QA-919-294 ---  Park/Steer Assist
;Component:PDC 8 KanalH07 0050	 Coding:0471051011
;EV_EPHVA18AU3700000	9039	EV_EPHVA18AU3700000_009_VW27.rod
;Sunday	24	February	2019	11:55:11:11868
;VCDS Version: Release 18.9.1  Data version: 20190114 DS296.0
;VCID: 4CC199711649F2A7325-8019
IDE00001-Production mode	Deactivating 	3
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble	not activated 	1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble	not activated 	1
IDE00845-Wheel circ.	1920 mm	2
IDE01165-Park assist activation tone	On 	1
IDE01167-Convertible offset for volume level 1	255	1
IDE01168-Increment for convertible volume levels	255	1
IDE01169-Audio reduction request	On 	1
IDE02328-Distance to curb	15 cm	1
IDE02332-Deactivate production mode	0	3
IDE03782-Switch-off speed for parking assist	15 km/h	1
IDE05274-Acoustic warning for rear lid assistant	not active 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE11215-Automatic Activation	activated 	1
IDE14666-Parking aid: personalization	not activated 	1
MAS01426-Speaker volume for rear park assist	Stage 4 	1
MAS01427-Speaker frequency for rear park assist	Stage 1 	1
MAS01428-Speaker volume for front park assist	Stage 4 	1
MAS01429-Speaker frequency for front park assist	Stage 7 	1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners	0.180 1/m	6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners	1.308 1/m	6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang	0.689 m	6
MAS12129-Customer-oriented off-road trip	not activated 	1
MAS12843-Maneuvering brake function	activated 	1
Elapsed Time: 00:10
;SW:2Q0-907-572-M   HW:2Q0-907-572-B ---  Auto Dist. Reg
;Component:ACCCONTIMQB   H03 0233	 Coding:3200670248FF8748949C8145804087
;EV_ACCMRRCONTIVW376	2012	EV_ACCMRRCONTIVW376_002.rod
;Sunday	24	February	2019	11:55:25:11868
;VCID: 3E25C3B950F55037AC1-806B
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific	OFF 	1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100	OFF 	1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101	OFF 	1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102	OFF 	1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay	OFF 	1
IDE01795-Heated lens	OFF 	1
IDE01949-Distance basic setting option	On 	1
IDE03642-Presentation mode	not active 	1
IDE05815-Sail function	Deactivating 	1
IDE08935-Expanded restart function	On 	1
IDE09564-Distance change via speed adjustment	On 	1
IDE09565-Prioritized target object display	OFF 	1
IDE10280-Constant delay after transfer request	No 	1
IDE13334-Reduced radar performance	38	1
Elapsed Time: 00:05
;SW:2Q0-959-655-AG   HW:2Q0-959-655-AG ---  Airbags
;Component:VW22Airbag    010 0248	 Coding:88CCC0C0000000005C5400CF000800000065
;EV_AirbaVW22BPAVW27X	1010	EV_AirbaVW22BPAVW27X.rod
;Sunday	24	February	2019	11:55:36:11868
;VCID: 025D7749648DF4D7889-8057
IDE05178-Conclude start of operation	locked 	1
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction air bag: driver side	not defined 	8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side	not defined 	8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor	activated 	8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit	not defined 	8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection	not defined 	8
IDE12055-MAS00478-Adaptation airbag 2-Reserved	2	8
MAS00975-IDE00947-Airbag adaptations-driver side rear curtain airbag igniter	not defined 	8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter	not defined 	8
MAS00975-IDE01755-Airbag adaptations-Rollover protection system	not defined 	8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery	not defined 	8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery	not defined 	8
MAS00975-IDE07192-Airbag adaptations-Igniter for window airbag	not defined 	8
MAS00975-IDE08436-Airbag adaptations-Driver side seat belt tensioner igniter 3	not defined 	8
MAS00975-IDE08437-Airbag adaptations-Frt.pass. side seat belt tensioner igniter 3	not defined 	8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1	not defined 	8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2	not defined 	8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter	activated 	8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter	activated 	8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter	activated 	8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter	activated 	8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter	not defined 	8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter	not defined 	8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter	activated 	8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter	activated 	8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter	not defined 	8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter	not defined 	8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter	activated 	8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter	activated 	8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter	activated 	8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter	activated 	8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter	not defined 	8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt	not defined 	8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter	not defined 	8
MAS00975-MAS00024-Airbag adaptations-Igniter for active head restraint on frt. passenger side	not defined 	8
MAS00975-MAS00079-Airbag adaptations-Key switch	Airbag deactivation key switch installed 	8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection: front passenger side	activated 	8
MAS00975-MAS00478-Airbag adaptations-Reserved	2	8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood	not defined 	8
Elapsed Time: 00:06
;SW:2G0-920-790-A   HW:2G0-920-790-A ---  Instruments
;Component:KOMBI         506 1691	 Coding:04A4010825800008018862011001000000000000
;EV_DashBoardVDDMQBA0	1026	EV_DashBoardVDDMQBA0_VW27.rod
;Sunday	24	February	2019	11:55:45:11868
;VCID: 25170CD5D563E3EFCDB-8071
IDE00001-Production mode	not active 	3
IDE00295-Oil temperature display	On 	1
IDE00342-ESI: Resetting ESI	no warning 	1
IDE00343-Language version	Dutch 	1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	11 H	1
IDE00501-Minute	55 min	1
IDE00502-Year	2019 yr	2
IDE00503-Month	2 mon	1
IDE00504-Day	24 d	1
IDE00510-ESI: distance driven from inspection	1886 km	3
IDE00511-ESI: time from inspection	113 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	good oil quality 	1
IDE00517-ESI: soot entry	1700 km	2
IDE00518-ESI: thermal load	1100 km	2
IDE00819-Day counter	152 d	2
IDE00827-ESI: minimum value of time between inspections	365 d	2
IDE01153-SIA: maximum value of distance to service	15000 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02489-Display depiction	Version 1 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
IDE03329-Driving profiled for range remaining	4.7 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
IDE03346-MAS01230-Units adjusted-Date	dd_mm_yy 	3
IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	∞C 	3
IDE03346-MAS02957-Units adjusted-Time	24h 	3
IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
IDE03348-MAS01456-Speed warning-Speed	0	2
IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	1800 km	2
IDE03352-FIX: Time since last time-dependent inspection	113 d	2
IDE03372-Source for synchronization of time	GPS 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE05930-Service notification in days	30 d	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	365 d	2
IDE06588-Ignition active message: actuator	Driver door 	1
IDE06922-No-voltage display	Not available 	1
IDE07221-Cylinder shut-off	Display 	1
IDE11086-Service notification	30 d	1
IDE11932-MAS01877-Display of colour adjustment-Red	0	3
IDE11932-MAS01878-Display of colour adjustment-Green	0	3
IDE11932-MAS01879-Display of colour adjustment-Blue	0	3
IDE12211-China variant	No 	1
IDE12467-Tubes illustration	Version 5 	1
IDE12722-Driving profile display	No 	1
IDE13094-Tachometer end value	Version 0 	1
IDE13607-MAS16698-Lock display contents-Lock infotainment list	No 	9
IDE13607-MAS16699-Lock display contents-Lock function lists	No 	9
IDE13607-MAS16700-Lock display contents-Lock MFA displays	No 	9
IDE13607-MAS16701-Lock display contents-Dynamic image lock	No 	9
IDE13607-MAS16702-Lock display contents-Lock functional animation	No 	9
IDE13607-MAS16703-Lock display contents-lock	No 	9
IDE13607-MAS16704-Lock display contents-Lock system status animation	No 	9
IDE13607-MAS16705-Lock display contents-Lock operating support animation	No 	9
IDE13607-MAS16706-Lock display contents-List time out	0 s	9
IDE13607-MAS17250-Lock display contents-Map locked	No 	9
IDE13607-MAS17251-Lock display contents-Piloted driving locked	No 	9
IDE13607-MAS17283-Lock display contents-Vehicle model locked	No 	9
IDE13607-MAS17284-Lock display contents-Cover intensity locked	100%	9
IDE13607-MAS17285-Lock display contents-Number of list entries blocked	0	9
IDE14184-Active participant personalization	No 	1
IDE14220-Vehicle speed warning for India-	No 	1
IDE14220-Vehicle speed warning for India-	0 s	1
MAS01299-Offroad	No display 	1
ENG114742-Activation of Development Messages	not active 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
ENG119875-defuel_threshold	8 l	1
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1	0	12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2	14	12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3	32	12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4	64	12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5	96	12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6	FD 	12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1	1	12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2	1	12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3	2	12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4	4	12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5	32	12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6	64	12
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	0A 	12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	32	12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	64	12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	96	12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	1	12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	1	12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	3	12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	6	12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	28	12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	1	12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	1	12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	3	12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	6	12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	28	12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1	00 00 	24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2	00 0A 	24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3	00 32 	24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4	00 64 	24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5	00 96 	24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6	00 FD 	24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1	00 32 	24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2	00 32 	24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3	00 78 	24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4	00 E6 	24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5	01 F4 	24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6	03 E8 	24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1	00 00 	24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2	00 0A 	24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3	00 32 	24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4	00 64 	24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5	00 96 	24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6	00 FD 	24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1	00 0C 	24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2	00 0C 	24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3	00 23 	24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4	00 46 	24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5	01 F4 	24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6	03 E8 	24
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 FA 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 28 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 50 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 96 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG153720-MAS03686-Display_longitudinal_coordinator-Automatic distance regulation	not active 	1
ENG153720-MAS05203-Display_longitudinal_coordinator-CCS	not active 	1
ENG153720-MAS10720-Display_longitudinal_coordinator-Speed limiter	not active 	1
ENG119833-Display_Save_CP	Yes 	1
ENG119874-Gas_functionality	not active 	1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	auto_lowbeam_foglight 	1
ENG119882-init_fuel_algorithm	Yes 	1
ENG130585-Leaving_warning_delay	1.6 s	1
ENG103063-Mileage	1897 km	3
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 ∞C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 ∞C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 ∞C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 ∞C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG119825-Picture_Upload_Download	not active 	1
ENG153765-Second_digital_speed	No display 	1
ENG119876-Service_Key_Clear_All_Counter	Yes 	1
ENG98918-Sport	No display 	1
ENG130584-Statistic_phev_mileage	5 km	1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.40 s	18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.3	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	not active 	4
Elapsed Time: 00:31
;SW:3Q0-907-530-Q   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   439 4344	 Coding:030100044F087300FA0002581C0F00010001070000000000000000000000
;EV_GatewNF	13044	EV_GatewNF_VW27.rod
;Sunday	24	February	2019	11:56:44:11868
;VCID: 3D27C4B55DF34B2FB5B-8069
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys	Deactivating 	3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation	Deactivating 	3
IDE00002-Transport mode	not active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01211-Static current measuring mode	not activated 	1
IDE01457-Energy management deactivation stage	Mode not active 	1
IDE01459-Energy management heat output control status	Mode not active 	1
IDE01844-Increase idle speed request	Mode not active 	1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time	-- 	3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation	Mode not active 	3
IDE01860-Generator specified voltage value variable	10.6 V	1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1	coded 	32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module	coded 	32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1	coded 	32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side	Not coded 	32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning	coded 	32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics	coded 	32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater	Not coded 	32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1	Not coded 	32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control	coded 	32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics	Not coded 	32
IDE01996-SFT00021-Installation list: specified installations-Airbag	coded 	32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics	Not coded 	32
IDE01996-SFT00023-Installation list: specified installations-Dash Board	coded 	32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater	Not coded 	32
IDE01996-SFT00025-Installation list: specified installations-Gateway	1	32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection	Not coded 	32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance	Not coded 	32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2	Not coded 	32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control	Not coded 	32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost	Not coded 	32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control	Not coded 	32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking	Not coded 	32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2	Not coded 	32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics	Not coded 	32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side	Not coded 	32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant	Not coded 	32
IDE01996-SFT00061-Installation list: specified installations-Special Function	Not coded 	32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor	Not coded 	32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side	Not coded 	32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance	coded 	32
IDE01996-SFT00071-Installation list: specified installations-Sound System	Not coded 	32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module	Not coded 	32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module	Not coded 	32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side	Not coded 	32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation	Not coded 	32
IDE01996-SFT00086-Installation list: specified installations-Radio	Not coded 	32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner	Not coded 	32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1	coded 	32
IDE01996-SFT00096-Installation list: specified installations-Tachograph	Not coded 	32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1	Not coded 	32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function	Not coded 	32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View	Not coded 	32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit	Not coded 	32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit	Not coded 	32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance	coded 	32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1	Not coded 	32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display	Not coded 	32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module	Not coded 	32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System	Not coded 	32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit	Not coded 	32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound	Not coded 	32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface	Not coded 	32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side	Not coded 	32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side	Not coded 	32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management	Not coded 	32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left	Not coded 	32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right	Not coded 	32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise	Not coded 	32
IDE01996-SFT00197-Installation list: specified installations-Thermal management	Not coded 	32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module	Not coded 	32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof	Not coded 	32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module	Not coded 	32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2	Not coded 	32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01	Not coded 	32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02	Not coded 	32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03	Not coded 	32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04	Not coded 	32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05	Not coded 	32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06	Not coded 	32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07	Not coded 	32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08	Not coded 	32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D	Not coded 	32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11	Not coded 	32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16	Not coded 	32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17	Not coded 	32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A	Not coded 	32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D	Not coded 	32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F	Not coded 	32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20	Not coded 	32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21	Not coded 	32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22	Not coded 	32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24	Not coded 	32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25	Not coded 	32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26	Not coded 	32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27	Not coded 	32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28	Not coded 	32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29	Not coded 	32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A	Not coded 	32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E	Not coded 	32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F	Not coded 	32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35	Not coded 	32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36	Not coded 	32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37	Not coded 	32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38	Not coded 	32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39	Not coded 	32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A	Not coded 	32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C	Not coded 	32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D	Not coded 	32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40	Not coded 	32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41	Not coded 	32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43	Not coded 	32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45	Not coded 	32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48	Not coded 	32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49	Not coded 	32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51	Not coded 	32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52	Not coded 	32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53	Not coded 	32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55	Not coded 	32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56	Not coded 	32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58	Not coded 	32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59	Not coded 	32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A	Not coded 	32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B	Not coded 	32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C	Not coded 	32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D	Not coded 	32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E	Not coded 	32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F	Not coded 	32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60	Not coded 	32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61	Not coded 	32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62	Not coded 	32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66	Not coded 	32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68	Not coded 	32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B	Not coded 	32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C	Not coded 	32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E	Not coded 	32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74	Not coded 	32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75	Not coded 	32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78	Not coded 	32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79	Not coded 	32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A	Not coded 	32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D	Not coded 	32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E	Not coded 	32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F	Not coded 	32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80	Not coded 	32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81	Not coded 	32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82	Not coded 	32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83	Not coded 	32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86	Not coded 	32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87	Not coded 	32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88	Not coded 	32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89	Not coded 	32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B	Not coded 	32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C	Not coded 	32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D	Not coded 	32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E	Not coded 	32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F	Not coded 	32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90	Not coded 	32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91	Not coded 	32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92	Not coded 	32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93	Not coded 	32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94	Not coded 	32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95	Not coded 	32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96	Not coded 	32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97	Not coded 	32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98	Not coded 	32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99	Not coded 	32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A	Not coded 	32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B	Not coded 	32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D	Not coded 	32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E	Not coded 	32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F	Not coded 	32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0	Not coded 	32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1	Not coded 	32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2	Not coded 	32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3	Not coded 	32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5	Not coded 	32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6	Not coded 	32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7	Not coded 	32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8	Not coded 	32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA	Not coded 	32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB	Not coded 	32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC	Not coded 	32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD	Not coded 	32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF	Not coded 	32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0	Not coded 	32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1	Not coded 	32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2	Not coded 	32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3	Not coded 	32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4	Not coded 	32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5	Not coded 	32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6	Not coded 	32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7	Not coded 	32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8	Not coded 	32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9	Not coded 	32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA	Not coded 	32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB	Not coded 	32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC	Not coded 	32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD	Not coded 	32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE	Not coded 	32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF	Not coded 	32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0	Not coded 	32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1	Not coded 	32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2	Not coded 	32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3	Not coded 	32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4	Not coded 	32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5	Not coded 	32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6	Not coded 	32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7	Not coded 	32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8	Not coded 	32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9	Not coded 	32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA	Not coded 	32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB	Not coded 	32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC	Not coded 	32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD	Not coded 	32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE	Not coded 	32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF	Not coded 	32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0	Not coded 	32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1	Not coded 	32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2	Not coded 	32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3	Not coded 	32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4	Not coded 	32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5	Not coded 	32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6	Not coded 	32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7	Not coded 	32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8	Not coded 	32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9	Not coded 	32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA	Not coded 	32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB	Not coded 	32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC	Not coded 	32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD	Not coded 	32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE	Not coded 	32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF	Not coded 	32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0	Not coded 	32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1	Not coded 	32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2	Not coded 	32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3	Not coded 	32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4	Not coded 	32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5	Not coded 	32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6	Not coded 	32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7	Not coded 	32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8	Not coded 	32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9	Not coded 	32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA	Not coded 	32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB	Not coded 	32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC	Not coded 	32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED	Not coded 	32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE	Not coded 	32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF	Not coded 	32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0	Not coded 	32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1	Not coded 	32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2	Not coded 	32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3	Not coded 	32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4	Not coded 	32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5	Not coded 	32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6	Not coded 	32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7	Not coded 	32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8	Not coded 	32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9	Not coded 	32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA	Not coded 	32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB	Not coded 	32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC	Not coded 	32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD	Not coded 	32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE	Not coded 	32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF	Not coded 	32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity	70 Ah	15
IDE03256-MAS06106-Battery adaptation-Battery technology	EFB+ 	15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer	JCB 	15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number	1111111111	15
IDE03903-Production process data 1	C0 00 	2
IDE04159-Deactivation of start-stop function	Mode not active 	1
IDE04186-Battery terminal recognition	connected 	1
IDE04330-Transfer of release code for a SWaP function	0	1
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE06530-Distance left for deactivation of static current measuring mode	2	1
IDE06541-Distance left for deactivation of transport mode	50	1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof	activated 	4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM	activated 	4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start	activated 	4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)	activated 	4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system	activated 	4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system	activated 	4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof	activated 	4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D	activated 	4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill	activated 	4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)	activated 	4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill	activated 	4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C	activated 	4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater	activated 	4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater	activated 	4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater	activated 	4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation	activated 	4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater	activated 	4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light	activated 	4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light	not activated 	4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission	activated 	4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater	activated 	4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater	activated 	4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater	activated 	4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater	activated 	4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation	activated 	4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection	ECO tips independent of driver profile selection 	4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption	activated 	4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency	Separate from exterior temperature without switch 	4
IDE07838-Counter for inconsistent states	0	2
IDE08348-Start/stop start voltage limit	7.8 V	1
IDE08624-MKE Check box	activated 	1
IDE10735-Number requests autonomous recharging	3	1
IDE10736-Cyclization limitation request battery service	0	1
IDE10748-MAS11262-Range gain-Range gain AC system	not activated 	3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater	activated 	3
IDE10748-MAS11264-Range gain-Range gain window defogger	activated 	3
IDE10748-MAS11265-Range gain-Range gain seat heater front	activated 	3
IDE10748-MAS11266-Range gain-Range gain front set ventilation	activated 	3
IDE10748-MAS11267-Range gain-Range gain rear heater	activated 	3
IDE10748-MAS11268-Range gain-Range gain fog light	activated 	3
IDE10748-MAS11269-Range gain-Range gain rear fog light	not activated 	3
IDE10748-MAS11270-Range gain-Range gain windshield heating	activated 	3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater	activated 	3
IDE10748-MAS11272-Range gain-Range gain mirror heater	activated 	3
IDE10748-MAS11273-Range gain-Range gain rear seat heater	activated 	3
IDE10748-MAS11274-Range gain-Range gain rear seat heater	activated 	3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system	not activated 	3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system	not activated 	3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption	not activated 	3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain	not activated 	3
IDE10748-MAS11279-Range gain-List at engine still stand	activated 	3
IDE10748-MAS12689-Range gain-Catalogue range display	activated 	3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display	activated 	3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting	activated 	3
IDE10748-MAS19099-Range gain-Convenience consumption socket	activated 	3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption	not activated 	3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating	not activated 	3
MAS16372-Security version number	2	2
SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch	installed 	3
SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage	Unknown (3)	3
SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version	ACC 	3
SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor	not installed 	3
SFT271921-MAS19102-Multi Function Steering Wheel Control Module-Dimming after-run	active 	3
SFT271921-MAS19103-Multi Function Steering Wheel Control Module-Local data bus: wake-up function	not active 	3
SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function	active 	3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset	active 	12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation	100	12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation	60000 ms	12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation	10000 ms	12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption	3000 ms	12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption	0 ms	12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation	255000 ms	12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation	1500 ms	12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation	500 ms	12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption	2500 ms	12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen	Mode not active 	4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level	Mode not active 	4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen	Mode not active 	4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen	Mode not active 	4
ENG137075-EM_heating_power_quota_adjustment	1000 W	1
ENG137061-EM_nominal_voltage_limitation_low_beams	12.1 V	1
ENG137064-EM_requirement_cyclic_time_voltage_measurement	0 s	1
ENG137063-EM_requirement_reduction_air_blowers	Mode not active 	1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1	Enabled 	32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module	Enabled 	32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1	not enabled 	32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side	Enabled 	32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning	Enabled 	32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics	Enabled 	32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater	Enabled 	32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1	Enabled 	32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control	Enabled 	32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics	Enabled 	32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag	not enabled 	32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics	Enabled 	32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board	Enabled 	32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater	Enabled 	32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway	Enabled 	32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection	Enabled 	32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance	Enabled 	32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2	Enabled 	32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control	Enabled 	32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost	Enabled 	32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control	Enabled 	32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking	Enabled 	32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2	Enabled 	32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics	Enabled 	32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side	Enabled 	32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant	Enabled 	32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function	Enabled 	32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor	Enabled 	32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side	Enabled 	32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance	Enabled 	32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System	Enabled 	32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module	Enabled 	32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module	Enabled 	32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side	Enabled 	32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation	Enabled 	32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio	Enabled 	32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner	Enabled 	32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1	Enabled 	32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph	Enabled 	32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1	Enabled 	32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function	Enabled 	32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View	Enabled 	32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit	Enabled 	32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit	Enabled 	32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance	Enabled 	32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1	Enabled 	32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display	Enabled 	32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module	Enabled 	32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System	Enabled 	32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit	Enabled 	32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound	Enabled 	32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface	Enabled 	32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side	Enabled 	32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side	Enabled 	32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management	Enabled 	32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left	Enabled 	32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right	Enabled 	32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise	Enabled 	32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management	Enabled 	32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module	Enabled 	32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof	Enabled 	32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module	Enabled 	32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2	Enabled 	32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00	Enabled 	32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01	Enabled 	32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02	Enabled 	32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03	Enabled 	32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04	Enabled 	32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05	Enabled 	32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06	Enabled 	32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07	Enabled 	32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08	Enabled 	32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D	Enabled 	32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11	Enabled 	32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16	Enabled 	32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17	Enabled 	32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A	Enabled 	32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D	Enabled 	32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F	Enabled 	32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20	Enabled 	32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21	Enabled 	32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22	Enabled 	32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24	Enabled 	32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25	Enabled 	32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26	Enabled 	32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27	Enabled 	32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28	Enabled 	32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29	Enabled 	32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A	Enabled 	32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E	Enabled 	32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F	Enabled 	32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35	Enabled 	32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36	Enabled 	32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37	Enabled 	32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38	Enabled 	32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39	Enabled 	32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A	Enabled 	32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C	Enabled 	32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D	Enabled 	32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40	Enabled 	32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41	Enabled 	32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43	Enabled 	32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45	Enabled 	32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48	Enabled 	32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49	Enabled 	32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51	Enabled 	32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52	Enabled 	32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53	Enabled 	32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55	Enabled 	32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56	Enabled 	32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58	Enabled 	32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59	Enabled 	32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A	Enabled 	32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B	Enabled 	32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C	Enabled 	32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D	Enabled 	32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E	Enabled 	32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F	Enabled 	32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60	Enabled 	32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61	Enabled 	32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62	Enabled 	32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66	Enabled 	32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68	Enabled 	32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B	Enabled 	32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C	Enabled 	32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E	Enabled 	32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74	Enabled 	32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75	Enabled 	32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78	Enabled 	32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79	Enabled 	32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A	Enabled 	32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D	Enabled 	32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E	Enabled 	32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F	Enabled 	32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80	Enabled 	32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81	Enabled 	32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82	Enabled 	32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83	Enabled 	32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86	Enabled 	32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87	Enabled 	32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88	Enabled 	32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89	Enabled 	32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B	Enabled 	32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C	Enabled 	32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D	Enabled 	32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E	Enabled 	32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F	Enabled 	32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90	Enabled 	32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91	Enabled 	32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92	Enabled 	32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93	Enabled 	32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94	Enabled 	32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95	Enabled 	32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96	Enabled 	32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97	Enabled 	32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98	Enabled 	32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99	Enabled 	32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A	Enabled 	32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B	Enabled 	32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D	Enabled 	32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E	Enabled 	32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F	Enabled 	32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0	Enabled 	32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1	Enabled 	32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2	Enabled 	32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3	Enabled 	32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5	Enabled 	32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6	Enabled 	32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7	Enabled 	32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8	Enabled 	32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA	Enabled 	32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB	Enabled 	32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC	Enabled 	32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD	Enabled 	32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF	Enabled 	32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0	Enabled 	32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1	Enabled 	32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2	Enabled 	32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3	Enabled 	32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4	Enabled 	32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5	Enabled 	32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6	Enabled 	32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7	Enabled 	32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8	Enabled 	32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9	Enabled 	32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA	Enabled 	32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB	Enabled 	32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC	Enabled 	32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD	Enabled 	32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE	Enabled 	32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF	Enabled 	32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0	Enabled 	32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1	Enabled 	32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2	Enabled 	32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3	Enabled 	32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4	Enabled 	32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5	Enabled 	32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6	Enabled 	32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7	Enabled 	32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8	Enabled 	32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9	Enabled 	32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA	Enabled 	32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB	Enabled 	32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC	Enabled 	32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD	Enabled 	32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE	Enabled 	32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF	Enabled 	32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0	Enabled 	32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1	Enabled 	32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2	Enabled 	32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3	Enabled 	32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4	Enabled 	32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5	Enabled 	32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6	Enabled 	32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7	Enabled 	32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8	Enabled 	32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9	Enabled 	32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA	Enabled 	32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB	Enabled 	32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC	Enabled 	32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD	Enabled 	32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE	Enabled 	32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF	Enabled 	32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0	Enabled 	32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1	Enabled 	32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2	Enabled 	32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3	Enabled 	32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4	Enabled 	32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5	Enabled 	32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6	Enabled 	32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7	Enabled 	32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8	Enabled 	32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9	Enabled 	32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA	Enabled 	32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB	Enabled 	32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC	Enabled 	32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED	Enabled 	32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE	Enabled 	32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF	Enabled 	32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0	Enabled 	32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1	Enabled 	32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2	Enabled 	32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3	Enabled 	32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4	Enabled 	32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5	Enabled 	32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6	Enabled 	32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7	Enabled 	32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8	Enabled 	32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9	Enabled 	32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA	Enabled 	32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB	Enabled 	32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC	Enabled 	32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD	Enabled 	32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE	Enabled 	32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF	Enabled 	32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus	Databus drivetrain 	2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ	not active 	2
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation	activated 	1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate	activated 	1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events	100	8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events	20	8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events	10	8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time	30 min	8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events	12 s	8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay	0 s	8
Elapsed Time: 00:27
iichel
Eindhoven, NB, NL
C?ID=284912
;SW:2Q1-909-144-M   HW:2Q1-909-144-F ---  Steering Assist
;Component:TRW_G4L_MQBA0 611 6041	 Coding:010000000000000001010201010001000000010101
;EV_SteerAssisTRWG4LMQBA0	11016	EV_SteerAssisTRWG4LMQBA0_011.rod
;Sunday	24	February	2019	11:57:20:11868
;VCDS Version: Release 18.9.1  Data version: 20190114 DS296.0
;VCID: 3C21C9B146E94227825-8069
IDE03724-Straight line running	Active: with learned value 	1
IDE03734-Support power	100%	1
IDE04130-Characteristic curve of steering assistance	Driving profile selection button 	1
IDE04555-Activation of pwr steering asst without engine running	not active 	1
IDE05162-Software end stop	active 	1
IDE06419-Driving profile switchover	Incremental: controlled over time 	1
IDE06657-Steering angle: calculated	not active 	1
IDE06678-Pull compensation	Active: with learned value 	1
IDE07540-Download without rest bus	not active 	1
MAS02080-XCP calibration protocol	active 	1
MAS09008-Plausibility check	not active 	1
MAS13709-Engine variant	Medium 	1
Elapsed Time: 00:03
;SW:3Q0-035-864-C   HW:3Q0-035-864-C ---  Information Electr.
;Component:MU-S-N-ER     H41 0472	 Coding:02720001BE0000004111000100080A001F0500E401200000CF
;EV_MUStd4CTSAT	1022	EV_MUStd4CTSAT_VW27.rod
;Sunday	24	February	2019	11:57:30:11868
;VCID: 313FE88591ABBF4F213-8065
IDE00001-Production mode	00 00 00 	3
IDE00346-Summertime-automatic	Europe 	1
IDE00758-Base volume of telephone	50%	1
IDE00759-Base volume of speech output	50%	1
IDE00760-Microphone sensitivity	0 dB	1
IDE00769-Number 1 for Info call	5E 07 A1 80 00 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00770-Number 1 for roadside assistance	5E 07 A1 80 00 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
IDE00845-Wheel circ.	0 mm	2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module	Yes 	3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner	No 	3
IDE01996-MAS00844-Installation list: specified installations-Radio	No 	3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module	No 	3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1	Yes 	3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2	No 	3
IDE01996-MAS04300-Installation list: specified installations-DVD changer	No 	3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module	No 	3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit	No 	3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8	No 	3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1	No 	3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2	No 	3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1	No 	3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2	No 	3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1	No 	3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2	No 	3
IDE02121-CD eject button	Enabled 	1
IDE02122-Developer mode	not activated 	1
IDE02330-Number 2 for Info call	5E 08 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02331-Number 2 for roadside assistance	5E 06 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02332-Deactivate production mode	0	3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	36	49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	36	49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	36	49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	36	49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	36	49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	36	49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	36	49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	36	49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	36	49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	36	49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	36	49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	36	49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	36	49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	36	49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	36	49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	36	49
IDE02502-Confirmation of installation change	59 D0 	2
IDE02607-Wheel pulse	0	2
IDE02699-Number 1 for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02701-Number 1 (roaming) for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE03902-Automatic ring break diagnostic	No automatic start 	1
IDE04521-Sporadic ring break detection	Visual 	1
IDE04522-Awakening ability on optical databus	OFF 	1
IDE04550-Bluetooth: Sniff mode	OFF 	1
IDE05111-Fee-based traffic information (TMC)	32768	2
IDE05113-Infotainment Recorder	activated 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	OFF 	1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 	1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	OFF 	1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	OFF 	1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	OFF 	1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 	1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 	1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	5	40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-3	40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	6	40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated 	4
IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
IDE10604-Menu entries for mobile online services	activated 	1
IDE11122-Country identification: country of sale HMI	DE 	2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0	non_blocked 	21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked 	21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked 	21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11	non_blocked 	21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12	non_blocked 	21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked 	21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked 	21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked 	21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked 	21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked 	21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked 	21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked 	21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2	non_blocked 	21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked 	21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked 	21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked 	21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked 	21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3	non_blocked 	21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked 	21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked 	21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked 	21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7	non_blocked 	21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked 	21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked 	21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked 	21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	non_blocked 	21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	non_blocked 	21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	non_blocked 	21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	non_blocked 	21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	non_blocked 	21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked 	21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	non_blocked 	21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked 	21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked 	21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked 	21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked 	21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked 	21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked 	21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked 	21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked 	21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked 	21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	non_blocked 	21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	non_blocked 	21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	non_blocked 	21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked 	21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	non_blocked 	21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	non_blocked 	21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	non_blocked 	21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0	non_blocked 	21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked 	21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10	non_blocked 	21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11	non_blocked 	21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12	non_blocked 	21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13	non_blocked 	21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14	non_blocked 	21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked 	21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked 	21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked 	21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18	non_blocked 	21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19	non_blocked 	21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2	non_blocked 	21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20	non_blocked 	21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked 	21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22	non_blocked 	21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked 	21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked 	21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked 	21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked 	21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked 	21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked 	21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked 	21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked 	21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30	non_blocked 	21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked 	21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked 	21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked 	21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked 	21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked 	21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked 	21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked 	21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked 	21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked 	21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked 	21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked 	21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked 	21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked 	21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked 	21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44	non_blocked 	21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45	non_blocked 	21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46	non_blocked 	21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47	non_blocked 	21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5	non_blocked 	21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked 	21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked 	21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked 	21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9	non_blocked 	21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0	non_blocked 	21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked 	21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked 	21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked 	21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked 	21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked 	21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked 	21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked 	21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked 	21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked 	21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked 	21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked 	21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked 	21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked 	21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21	non_blocked 	21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked 	21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked 	21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked 	21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked 	21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked 	21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked 	21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked 	21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked 	21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked 	21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked 	21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked 	21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked 	21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked 	21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked 	21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked 	21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked 	21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked 	21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked 	21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked 	21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4	non_blocked 	21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked 	21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6	non_blocked 	21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked 	21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked 	21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9	non_blocked 	21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	non_blocked 	21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked 	21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked 	21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked 	21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked 	21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked 	21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked 	21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked 	21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked 	21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked 	21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	non_blocked 	21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	non_blocked 	21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	non_blocked 	21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	non_blocked 	21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked 	21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked 	21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked 	21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked 	21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked 	21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked 	21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked 	21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked 	21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked 	21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked 	21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked 	21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	non_blocked 	21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	non_blocked 	21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	non_blocked 	21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	non_blocked 	21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	non_blocked 	21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked 	21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked 	21
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42	not activated 	192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus	not activated 	192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47	not activated 	192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus	not activated 	192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51	not activated 	192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus	not activated 	192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45	activated 	192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus	Comfort data bus 	192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D	not activated 	192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus	not activated 	192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D	not activated 	192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus	not activated 	192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41	not activated 	192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus	not activated 	192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50	not activated 	192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus	not activated 	192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83	not activated 	192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus	not activated 	192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E	not activated 	192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus	not activated 	192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44	not activated 	192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus	not activated 	192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40	not activated 	192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus	not activated 	192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A	not activated 	192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus	not activated 	192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B	not activated 	192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus	not activated 	192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C	not activated 	192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus	not activated 	192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54	not activated 	192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus	not activated 	192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48	not activated 	192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus	not activated 	192
IDE13183-Deactivation/activation of the pop-up for active tracking services	00 00 00 00 	4
MAS00951-Bluetooth	On 	1
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
MAS03782-WLAN	On 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG104140-Bluetooth_Phonebook_Access_Profile	PBAP 	1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	activated 	60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	activated 	60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated 	60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated 	60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated 	60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated 	60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	activated 	60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	activated 	60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	activated 	60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	activated 	60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 	60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated 	60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	activated 	60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	activated 	60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	activated 	60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	activated 	60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 	60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 	60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 	60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated 	60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	not activated 	60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	not activated 	60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	not activated 	60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 	60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 	60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	activated 	60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	activated 	60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated 	60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated 	60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 	60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 	60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated 	60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated 	60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 	60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated 	60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 	60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 	60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated 	60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 	60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 	60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated 	60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	not activated 	60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	not activated 	60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 	60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 	60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated 	60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated 	60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated 	60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	activated 	60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 	60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated 	60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated 	60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 	60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated 	60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated 	60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 	60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 	60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 	60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 	60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	activated 	60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	activated 	60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated 	60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated 	60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 	60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 	60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	activated 	60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	activated 	60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	activated 	60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated 	60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 	60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 	60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	activated 	64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended 	64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus 	64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 	64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	Databus Infotainment 	64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus 	64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	activated 	64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15 	64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain 	64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	activated 	64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment 	64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	activated 	64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus 	64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 	64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus 	64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	not activated 	64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment 	64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus 	64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	not activated 	64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus 	64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 	64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus 	64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 	64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus 	64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus 	64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	not activated 	64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus 	64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	not activated 	64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 	64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	not activated 	64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus 	64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	Comfort data bus 	64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 	64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus 	64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 	64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus 	64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain 	64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated 	64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus 	64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	not activated 	64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended 	64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 	64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus 	64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 	64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment 	64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	activated 	64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus 	64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated 	64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus 	64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended 	64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment 	64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus 	64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 	64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain 	64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus 	64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	Comfort data bus 	64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	Comfort data bus 	64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 	64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus 	64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 	64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 	64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus 	64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	activated 	64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment 	64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated 	64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended 	64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Databus drivetrain 	64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated 	64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended 	64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus 	64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus 	64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15 	64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 	64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus 	64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated 	64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	not activated 	64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	activated 	64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment 	64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 	64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus 	64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available 	8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus 	8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment 	8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available 	8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 	8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available 	8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain 	8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available 	8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus 	8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Comfort data bus 	8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Comfort data bus 	8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available 	8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus 	8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps	On 	10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture	On 	10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart	On 	10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode	RLE 	10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution	resolution_1 	10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode	OFF 	10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon	0	10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most	OFF 	10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode	H264 	10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution	resolution_3 	10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode	MOST_streaming 	10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart	On 	10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1	0	6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2	50	6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3	100	6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1	0	6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2	50	6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3	100	6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	50	12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	100	12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	150	12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	1%	12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	3%	12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	6%	12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	44%	12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07	FF 	32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F	FF 	32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17	FF 	32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F	FF 	32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27	FF 	32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F	FF 	32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37	FF 	32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F	FF 	32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47	FF 	32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F	FF 	32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57	FF 	32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F	FF 	32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67	FF 	32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F	FF 	32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77	FF 	32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F	FF 	32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87	FF 	32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F	FF 	32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97	FF 	32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F	FF 	32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7	FF 	32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF	FF 	32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7	FF 	32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF	FF 	32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7	FF 	32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF	FF 	32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7	FF 	32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF	FF 	32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7	FF 	32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF	FF 	32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7	FF 	32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF	FF 	32
ENG167428-ENG167502-nhtsa_properties-limitation_dependency	gear_selection 	5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length	not activated 	5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration	not activated 	5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input	not activated 	5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback	not activated 	5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input	not activated 	5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists	not activated 	5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists	not activated 	5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps	not activated 	5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard	not activated 	5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad	not activated 	5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation	01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C 	40
ENG117809-p_damping_Display	5 ms	1
ENG117808-p_HMI_Display	13%	1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
ENG117919-Startup_Screen_Sticker_HMI	00 00 	2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display	OFF 	30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing	OFF 	30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO	On 	30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless	OFF 	30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life	OFF 	30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios	OFF 	30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless	OFF 	30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless	OFF 	30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb	blocked 	30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant	0	30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call	On 	30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support	OFF 	30
ENG109862-ENG185778-Vehicle_configuration-FoD	SWaP 	30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL	On 	30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless	OFF 	30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts	OFF 	30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other	OFF 	30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts	OFF 	30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other	OFF 	30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data	not activated 	30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1	Not Present 	30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2	Not Present 	30
ENG109862-ENG127492-Vehicle_configuration-LGI	OFF 	30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul	activated 	30
ENG109862-ENG142142-Vehicle_configuration-map_email_support	OFF 	30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support	OFF 	30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support	OFF 	30
ENG109862-ENG142152-Vehicle_configuration-Map_Style	0	30
ENG109862-ENG152537-Vehicle_configuration-media_control	not activated 	30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link	On 	30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code	MIB_EU 	30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference	RGB565 	30
ENG109862-ENG117843-Vehicle_configuration-my_audi	OFF 	30
ENG109862-ENG117845-Vehicle_configuration-online_dictation	OFF 	30
ENG109862-ENG127495-Vehicle_configuration-online_media	OFF 	30
ENG109862-ENG117840-Vehicle_configuration-online_navigation	OFF 	30
ENG109862-ENG117837-Vehicle_configuration-online_POI	OFF 	30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice	OFF 	30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services	OFF 	30
ENG109862-ENG152553-Vehicle_configuration-online_radio	Deactivated 	30
ENG109862-ENG117841-Vehicle_configuration-online_street_view	OFF 	30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit	OFF 	30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold	0	30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis	0	30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy	0	30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode	Data & language service active 	30
ENG109862-ENG117844-Vehicle_configuration-picture_navi	On 	30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking	not activated 	30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use	not activated 	30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest	0	30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi	OFF 	30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo	OFF 	30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version	PSD_1.5 	30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI	OFF 	30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component	activated 	30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open	not activated 	30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold	not activated 	30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe	not activated 	30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input	FBAS 	30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony	not activated 	30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation	no restriction 	30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag	no_region 	30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch	not activated 	30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch	Not Present 	30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support	OFF 	30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi	activated 	30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode	1	30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold	OFF 	30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling	OFF 	30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone	On 	30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location	OFF 	30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability	OFF 	30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving	blocked 	30
ENG109862-ENG137647-Vehicle_configuration-UOTA	OFF 	30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2	OFF 	30
ENG109862-ENG117852-Vehicle_configuration-UPnP	On 	30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound	not activated 	30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound	not activated 	30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte	not activated 	30
ENG109862-ENG117836-Vehicle_configuration-VZAPro	OFF 	30
ENG109862-ENG127494-Vehicle_configuration-VZO	OFF 	30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI	OFF 	30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot	On 	30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch	not activated 	30
Elapsed Time: 00:41
Reactions: Ilu
