Hill hold
ALAutodiagnose
C?ID=107046
Hello, my first post here. i want to deactivate the hill hold function in a Ibiza '14. Anyone any experience with it?
I don't think there are a whole lot of 2014 Ibiza owners here. I can't make any promises of a solution, but if you want people to look at it, please post an Auto-Scan so we can all see what this car is made of.
Eddie-NL
C?ID=41179
an ibiza is not the same platform as the mk6 golf
Keithuk
Stoke on Trent, England
C?ID=122432
I know that but there is no harm in checking if the same settings are available.
Eddie-NL
C?ID=41179
it is not the same
NEtech
Denmark
C?ID=56995
I would not do that.
Post an Autoscan, as Uwe asked for.
ALAutodiagnose
C?ID=107046
VIN: VSSZZZ5FZER068395
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 6322300000036D
Coding: 20EE629224260974007A060941C8240446249000608224F200410070C002
Shop #: WSC 00049 770 00104
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 4B91105CE2D9F1463EF-801E
With this the information of the car.
Tried several things tiday but nothing works.
The unit doesn't accept any recoding.
The car is a Leon by the way :-)
That's not a complete Auto-Scan.
Seriously, as complicated as these cars are now, it is not at very useful just to see one module. Also, your software is out-of-date.
ALAutodiagnose
C?ID=107046
 Monday,01,December,2014,13:55:38:07393
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: VSSZZZ5FZER068395   License Plate:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
Address 01: Engine (J623-CRKB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FD    HW: 04L 907 309 E
   Component: R4 1,6L EDC   H22 6544
   Revision: 86H22---
   Coding: 01190012032401090000
   Shop #: WSC 00049 770 00127
   ASAM Dataset: EV_ECM16TDI01104L906021FD 002004
   ROD: EV_ECM16TDI01104L906021FD_SE37.rod
   VCID: 6CD3B3C08797167E575-8039
17158 - Databus
                    Fault Frequency: 27
                    Reset counter: 32
          U0428 00 [032] - -
                    Fault Frequency: 27
                    Reset counter: 32
   Part No SW: 5F0 907 044 E    HW: 5F0 907 044 E
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 00000104200100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 285B8FD053EFFA5EF3D-807D
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011333200096
   Coding: 08000A46424102FB4BE44080401407081000000000000000000000000000
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 7BF1809CF2F981C6CEF-802E
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119
   Component: WWS370 131118  041 0574
   Serial number:         131120071854
   Coding: 0BC5FD
   Component: RLFS  024 0042
   Serial number: Y13M11D28H17M22S25S6
   Coding: 00885D
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231334002005
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 3B71409CB27941C68EF-806E
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PRFTUM8
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SE37.rod
   VCID: 7F09748CE6E19DE6E27-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 211 13
   Serial number: 3576U0000003AC585E0M
   Subsystem 2 - Part No SW: -----------    HW: 454 002 211 13
   Serial number: 3586U000000997415E0F
   Subsystem 3 - Part No SW: -----------    HW: 454 802 411 13
   Serial number: 3516R788A81020000000
   Subsystem 4 - Part No SW: -----------    HW: 454 802 311 13
   Serial number: 3526RE1EE6C02000000K
   Subsystem 5 - Part No SW: -----------    HW: 454 802 610 13
   Serial number: 3556VC6B81B02000000F
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 04121304221414
   Coding: 1400
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 77F99CACCED1A5A6AA7-8022
   Part No SW: 5F0 920 871 A    HW: 5F0 920 871 A
   Component: KOMBI         303 2210
   Coding: 07A402002980000800086A00000000
   ROD: EV_DashBoardVDDMQBAB_SE37.rod
   VCID: 27598CEC5EF1F526FA7-8072
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 29111310800489
   Coding: 030100F40B087300EF000648080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_SE37.rod
   VCID: 3F89348CA6615DE6A27-806A
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0120
   Serial number: 000000000A0235161013
   Coding: 002000
   Serial number: 2359171803
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000083218898
   Coding: 00100320DE00040000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 44833B60CF873E3EFF5-8011
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001121075
   Coding: 310000
65601 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 52
                    Mileage: 3490 km
                    Date: 2014.10.02
                    Time: 18:19:03
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 01
   ROD: EV_SteerAssisMQB.rod
   VCID: 3D754E84AC6D4FF6B0B-8068
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000083433883
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 4381387CCA893906C6F-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001108777
   Coding: 290000
Address 55: Xenon Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 048A000009000000
   VCID: F5E516A454DD57B638B-80A0
   Part No SW: 5F0 035 846 A    HW: 5F0 035 846 A
   Component: MU-S-N-ER     040 0425
   Serial number: E1F00612130012
   Coding: 04730001D70A000021110001000800002F0103040100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE.rod
   VCID: 264781E859FBEC2EC11-8073
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H51 0022
   Serial number: SEZ8Z9NL400L14
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5F0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
ALAutodiagnose
C?ID=107046
   Revision: 86H22---
17158 - Databus
                    Fault Frequency: 27
                    Reset counter: 32
          U0428 00 [032] - -
                    Fault Frequency: 27
                    Reset counter: 32
   Revision: 00001K07
   Air quality sensor:
   Coding: 0BC5FD
   Coding: 00885D
   Coding: 0031051001
   Coding: 1400
   Coding: 002000
   Coding: 310000
                    Reset counter: 52
                    Mileage: 3490 km
                    Date: 2014.10.02
                    Time: 18:19:03
   Coding: 01
   Coding: 290000
