A6 issues after MMI unit replaced to add DAB radio support
tihi
Slovenia
C?ID=336726
Originally the A6 had no DAB radio so I managed to get MMI unit with DAB support.
The antenna was installed, unit was replaced and DAB radio now works.
After the unit was replaced at at the workshop it was coded with settings from the old unit.
But there are few issues:
- Car menu doesn't work anymore (It shows message "Car systems not available")
- USB ports don't recognize USB devices (sticks)
- No parking display when parking sensors are activated
The scan shows 10 Faults Found for the unit 5F including "Control Module Incorrectly Coded":
Thursday,21,February,2019,17:50:59:55547
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WAUZZZ4G5JN109158   License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 36 3B 42 44 46 52 53 55 5F
          62 6D 72 8F 90 AC
VIN: WAUZZZ4G5JN109158   Mileage: 15949km-9910miles
Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 4166
   Revision: 8DH20---
   Coding: 0A254012232401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
   ROD: EV_ECM20TDI01104L906021HA_004.rod
   VCID: 6B823046E3087FEF5BF-803E
   Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000001026
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002028
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 2E04F952109ACAC73C1-807A
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180085000604
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DEB2EEB10445BFD13-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01A8700E000000000000
   VCID: 7CA0031A96E6E857C25-8028
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0113
   Serial number: 11041800110852
   Coding: 34010908210000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619E526E11C425BFF13-8034
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001960321702
   Coding: 0105C01440349FE0C1014083A0001800CF9CC3082E08020100000494E101140200400024030000
   VCID: 74B02B3ABEB6A0178A5-8020
   Component: WWS57X 180226  H38 0080
   Serial number:         180305063526
   Coding: 0045F7
   Serial number: 21305132X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 12 03 2018  00001374
   Subsystem 4 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H02 0007
   Serial number: 8F419B1900PAG0FSA002
   Component: Airbag10.43   H83 0098
   Revision: --------    Serial number: 003P100G64W1
   Coding: 30333130313630323637554A304C34473053
   VCID: 3B22C006D3E82F6F8BF-806E
   Serial number: 3575HRB400A5DKL2A8MI
   Serial number: 3585HRB40165DNAKA9OT
   Serial number: 3515JRB40025DPR4EGV/
   Serial number: 3525JRB405D5EP2CDPN+
   Serial number: 3554VRB405V5G08E41GI
   Serial number: 3564VRB40635FQRSNGI0
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560RCJ0001U
   Coding: 000014
   VCID: 3B22C006D3682F6F8BF-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 03 03 2018  C0005465
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 934 R    HW: 4G8 920 934 R
   Component: TDieRdw       H17 0225
   Revision: 18001312    Serial number: 658050418592003
   Coding: 13A60D000B410008010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 40D8B7EABA0E4CB7DED-8014
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002932798
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 002011
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 1877437304
   Voltage stabilizer:
   Serial number: 18012400000000000061
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 678A4C76FF605B8F3F7-8032
   Revision: AA000000    Serial number: 00000311376229
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77AA1C36AFC0CB0FAF7-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820FGF3A
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3634D132E8CAF207741-8062
   Component: TSG FA        H03 0511
   Coding: 011F16015E00628002080002
   VCID: 47CAACF69FA07B8F1F7-8012
   Component: RCevo         H55 0202
   Revision: 00000001    Serial number: 0000583390
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2CC502DCD21667909-806E
   Revision: 00002001    Serial number: 0476962835
   Coding: 011A062080B93080C320088408010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00046752767
   Component: TSG BF        H03 0511
   VCID: 46D4A1F298AA6287E41-8012
   Part No SW: 4H0 907 801 N    HW: 4H0 907 801 M
   Component: EPB-4         H01 0020
   Revision: --------    Serial number: 00000002482501
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3332E826FBB8E72F53F-8066
   Coding: 04FA02102A630200
   VCID: 3430EB3AFEB6E0174A5-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 A    HW: 4G1 035 021
   Component: MU-H-LND-EU   036 0073
   Serial number: A276A0H7530530
   Coding: 01750101FF0A000013110201C00B00002F0006E5F1700100FF
   Shop #: WSC 20440 002 104857
   ROD: EV_MUHig4CGen2HBAS_AU57.rod
   VCID: 18683F8A821E247746D-804C
   Subsystem 1 - Part No SW: V03 959 801 ES    HW: -----------
   Component: ECE 2014/2015  --- 0086
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9JY80AADB
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349RD500081
10 Faults Found:
1586 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for speed shutoff thresholds]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
                    Voltage terminal 30: 12.0 V
1587 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for language]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
1588 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for visible MMI system languages]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
1589 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for power management timer]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
1595 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for audio management HMI constants]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
1591 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for telephone audio parameters]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
1598 - Data Set Implausible
          B2012 00 [009] -  -
          [Control module (data record download) - implausible data record for visible MMI system languages]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
          U1014 00 [009] - -
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
          B201A 00 [009] -  -
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
                    Status_Software_Version_Management-module_name: MKBD_FC7/KBD
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
          [USB - communication error]
                    Reset counter: 203
                    Mileage: 15949 km
                    Date: 2019.02.21
                    Time: 17:37:45
                    Interface for external media: status-Status: OK
   Component: TSG HL        H03 0511
   Coding: 010F14004000628002080002
   VCID: 49CEAACE89B48DFF093-801C
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002003    Serial number: 080802130
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   VCID: 323CED2204A2EE27589-8066
   Component: TSG HR        H03 0511
   Component: RGS-VL        H16 0080
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EE22E01A4D53F213-8064
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 180800336
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3AE4561790C3CF377-807A
End----(Elapsed Time: 01:54, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
What does mean "Control Module Incorrectly Coded"?
With the old unit I also had Smartphone interface option installed (purchased and got codes).
Now those codes can't be entered with the new MMI unit.
How can I now re-install Smartphone interface option?
Any help appreciated.
tihi
Slovenia
C?ID=336726
For those who might have the same issue here is the explanation:
- this head unit is 4G1 035 021 A (for model year 2014)
- not compatible with USB ports/interface I have in the car
- it does not support Smartphone interface (supported in newer unit 4G1 035 021 J).
So I replaced the head unit with the right one and now everything works fine.
