Coming & leaving home MK5 2010
JIMENEZ
Columbia
C?ID=170890
I wonder if you could help me with the coming home activation for a VW MK5 2010, I'm trying to activate coming and leaving with the steps on ross tech
website but I couldn´t do.
Thanks a lot.
Wednesday,05,March,2014,15:20:21:36145
VCDS Version: Release 12.12.2
Address 09: Cent. Elect.
Control Module Part Number: 5K0 937 087 F
Component and/or Version: BCM PQ35 H 011 0029
Software Coding: 2D200BBE982F2AE440080089100009040378008651208D605C8020000000
Work Shop Code: WSC 00066
VCID: 387FE8268BDEBADE637-806D
Advanced Identification
Identification: YNF-GDL
Revision: BK011001
Date: 17.06.10
Manufacturer number: 0001
Test stand number: 0029
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 0000.00.00
Flash Tool Code: 00000 000 00000
Software
BAP: 01.04.00
Misc.
Hardware number: 5K0 937 087 F
Workshop System Name: J519
VCDS Info:
Labels: 1K0-937-08x-09.clb
mtl
Slovenia
C?ID=153305
Does it have light sensor installed?
Andy
Sector 7G
HC424490
Please post a complete autoscan. That should show additional info like slave modules.
killep2
C?ID=214777
Hi,
I see the original owner wont continue with this post So I will post my question related to this,
Is it possible to active this when there is no light sensor ? I have some light under the Mirrors the seems working like Coming home leaving home
I want to active the Front light for this.
Hi,
We need to get that Byte 18 issue sorted first but per the scan here
http://forums.ross-tech.com/showthread.php?535-Lights-issues-after-changing-BCM-(1k0-937-087-J)
.. you have a PQ35 Mk6 Golf based BCM. The Tweaks on this page should apply and you can activate Manual Coming Home lights (not automatic and NO leaving home because of the lack of RLS)
http://wiki.ross-tech.com/wiki/index.php/VW_Golf/Golf_Plus_(5K/52)_Tweaks
If you need any help with that manual activation post the newest scan in this thread after the lighting issues are sorted. I don't want to pile these tweaks onto that major exterior lighting issue.
