Polo 6R Window Problem
Chr15
C?ID=207693
Hi all, hoping for a bit of advice.
Ive got a 2014 Vw Polo 6R with a fault on the drivers door control module/window motor/ switch assembly.
Its had a new genuine motor and switch assembly for what im told was a different fault and has now been broought to me.
The window switch assembly will not operate any other window but all windows will operate from there individual switch except the drivers side. (Front and rear electric windows)
All wiring checked and ok.
Feel like im missing a basic setting or some adaptation maybe needed.
Any help or suggestions much appreciated and TIA
Friday,22,February,2019,13:24:01:28060
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
Dealer/Shop Name: V.A.G Car Clinic
VIN: WVWZZZ6RZFU043022   License Plate: POLO WINDOW
Mileage: 60023km-37296mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFU043022   Mileage: 60023km-37296miles
Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057     HW: 04C 907 309 J
   Component: R3 1.0l MPI   H23 8071
   Revision: 31H23000
   Coding: 01110052020401080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM10MPI01104C906057 001012
   ROD: EV_ECM10MPI01104C906057A.rod
   VCID: E288D53FF522AD5A2B-80B6
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0002
   Serial number: 08500952140913
   Coding: 23DD2485492733C30914106B0053C42492CC90080005C7090C00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: EC94BB0707E6EB2A91-80B8
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1409011B-0377
   Coding: 200000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 9D72A6C38CDCD2A256-80C8
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009458014968
   Coding: 03000840425300530BA44080B10703880000580257010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   VCID: AE10710FF17A593AFF-80FA
   Subsystem 1 - Part No: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU026091442698417
   Coding: 0200A0
   Subsystem 2 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY142021PMA
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000030222076
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU007101442804908
   Coding: 1400A0
   Subsystem 5 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU029091442723783
   Coding: 0400A0
593924 - Motor for Window Regulator; Front Drivers Side
          B14D3 02 [009] - Signal Failure
                    Reset counter: 46
                    Mileage: 60023 km
                    Date: 2019.02.22
                    Time: 13:20:34
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag011 001 0330
   Revision: --------    Serial number: 003LM0051DU9
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: B12A6A73E04446C2E2-80E4
   Subsystem 1 - Part No SW: -----------    HW: 410 820 708 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009B15C41F1E01P
   Subsystem 2 - Part No SW: -----------    HW: 410 820 708 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H009915C41F302CP
   Subsystem 3 - Part No SW: -----------    HW: 442 151 408 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AD1519FB2B42O
   Subsystem 4 - Part No SW: -----------    HW: 442 150 309 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C516C1CE20107
   Part No SW: 6C0 920 940 A    HW: 6C0 920 940 A
   Component: KOMBI         211 0290
   Coding: 272409002180260001082A001000000000000000
   VCID: A208953FB5A2ED5A6B-80F6
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009458014968
   Coding: 030100046F0A640071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: E582CE23E40CDA62CE-80B0
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2391406391300765AB1B
   Coding: 240000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61262201132821786770
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CE8S0262
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: B326607B1A5874D290-80E6
   Part No SW: 3Q0 035 820     HW: 3Q0 035 820
   Component: MU-S-D-ER     H11 0133
   Serial number: VWZAZ2P4562168
   Coding: 02620000BE00000011111201000808001F0100C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: E680C92F190AD17AC7-80B2
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H41 1015
   Serial number: VWZ8Z9PH000XEY
          B201A 00 [009] -  -
                    Reset counter: 45
                    Mileage: 60023 km
                    Date: 2019.02.22
                    Time: 11:50:06
                    Voltage terminal 30: 12.1 V
End----(Elapsed Time: 00:48, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
09: Cent. Elect. (J519) doesn't seem to be able to talk to the door control module in the front driver's door at all. That's not something that can be fixed with a basic setting or adaptation.
Power and ground good to the door control module?
Gone But Not Forgotten
How was wiring authenticated?
Were the terminals from end to end load light tested and isolated using the WD?
Were the parts changed the correct part number, beware of FOD?
JPPSG
Radiosolutions
C?ID=178437
Check wiring in rubber boot between drivers door and car. Also if drivers door module is faulty will cause this fault.
iichel
Eindhoven, NB, NL
C?ID=284912
Occasionally the wiring will fail in these cars. Check the wiring to the switch and motor for corrosion or breaks in the driver door. Like jack suggested, load test the wire. Power, ground, data. Those are your friends. If one of them is missing, it's not going to work. All fingers now point at driver's door wiring loom.
Power and ground will be easy to find. Thick wires to the door motor. Data is LIN and is a thin white/purple wire.
