EPS_DSR_Status signal is invalid
CarlightExpress
C?ID=353848
I only have this one fault code showing up (I know it says two but I cleared the other code due to Car/Trailer stabilization being enabled), MIL is not illuminated but cannot find anything even on google as to what is causing this, anyone got any ideas?
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60575000000842
   Coding: 0FEC938F54260B71077B070841C469F0C92AD0E0E08296F5186250F8C209
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 49CF5F63793385AF093-801C
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 210
                    Date: 2019.02.21
                    Time: 21:18:06
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
8277 - Databus
Likely mismatch in Driver Steering Recommendation (DSR) coding between your Electronic Power Steering (EPS) module at address 44, and your ABS/ESR module at address 03.
https://en.wikipedia.org/wiki/Driver_Steering_Recommendation
https://www.continental-automotive....tions/Dynamics/Driver-Steering-Recommendation
+1.
CarlightExpress
C?ID=353848
Full Scan
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
          BB BC
VIN: WVWZZZ3CZFE465481   Mileage: 130473km-81072miles
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026     HW: 03N 907 309
   Component: R4 2,0L EDC   X23 1707
   Revision: A1X23---
   Coding: 01250012036705083000
   Shop #: WSC 68107 514 16480
   ASAM Dataset: EV_ECM20BTD01103N906026 001011
   ROD: EV_ECM20BTD01103N906026.rod
   VCID: 6889BAE702F95CA736D-803C
   Part No SW: 0DL 300 011     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 4701
   Revision: 00H10V01
   ROD: EV_TCMDQ500021.rod
   VCID: 6597B3D3F5EB41CF0DB-8030
8277 - Databus
                    Reset counter: 210
                    Date: 2019.02.21
                    Time: 21:18:06
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0524
   Revision: 00023000    Serial number: 0361563484
   Coding: 000F0F0703
   Shop #: WSC 05311 115 00318
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 77ABE99B5F47C35FAF7-8022
   Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
   Revision: 00001K10
   Coding: 12120104202100012015500000101802
   Shop #: WSC 00015 115 08193
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6D87CBF32D1B798F45B-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86581102150587
   Coding: 03051C46C24102FF0B844084B11C07281880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA7FBB37D7BE90FF5B-8028
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150206  043 0607
   Serial number:         150211091834
   Component: RLHS  037 0059
   Serial number: S4Y15M03D04H10M28S35
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 25 12 2014  00000636
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150233L5U
   Serial number: 00000000000061746339
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391503403756
   Coding: 0071051051
   Shop #: WSC 05311 115 00063
   ROD: EV_EPHVA18AU3700000_002_VW48.rod
   VCID: 40D942474A0944E7DED-8014
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 3260678110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 33331D8B0BBFEF7F53F-8066
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 21091441350106
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76B5E49F584DBA57B41-8022
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1P36581-
   Coding: 98FCC0C0008000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015F874301838DEF913-8054
   Belt Pretensioner left:
   Serial number: 3G2857705C0056P00133
   Coding: 80000A
   Belt Pretensioner right:
   Serial number: 3G2857706C0055P00540
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 001 402 15
   Serial number: 3576U00000099A342316
   Subsystem 4 - Part No SW: -----------    HW: 454 001 402 15
   Serial number: 3586U0000002FA342316
   Subsystem 5 - Part No SW: -----------    HW: 454 801 702 15
   Serial number: 3516R9C0B1C060000007
   Subsystem 6 - Part No SW: -----------    HW: 454 801 702 15
   Serial number: 3526R14CBDA05000000D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 502 15
   Serial number: 3556VC3659D05000000H
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150219500294
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D273BB33DFB290FB5B-8068
   Part No SW: 3G0 920 951     HW: 3G0 920 951
   Component: KOMBI         308 4311
   Coding: 27A50818BF80260001886A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 6491AED7FED138C71A5-8030
   Revision: --------    Serial number: 20021510800304
   Coding: 030300044F017300EF00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72BDD88F3425A677989-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000283980025072
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 7094145603
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00012.01.15
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46D5545F682D6AD7E41-8012
   Serial number: 15000017330012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD78331239D6F613-8024
   Serial number: 170215BBG09828
   Coding: 003F0A20D001028000001000
   VCID: 42DD484F440556F7C89-8016
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 0002
   Shop #: WSC 00015 115 00318
   VCID: 43D34D4B5B1F5FFFC3F-8016
   Serial number: 210215BBK19017
   Coding: 003F0020D001028000001000
   VCID: 41DF474341034DEFD13-8014
   Component: AFS-ECU       H01 0110
   Coding: 03A602000F210200
   Shop #: WSC 21075 002 1048576
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FDB41BB37F73B1FA77-806A
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3G0 035 020 A    HW: 3G0 035 020
   Component: MU-H-ND-EU    H41 0121
   Serial number: A598B0F7500468
   Coding: 02840201FF00000011111201000808001F0106C601200100DE
   VCID: 1577C313650B114F5DB-8040
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9PU300VP4
   Subsystem 2 - Part No SW: V03 959 806 FL    HW: -----------
   Component: ECE 2019  --- 0175
   Compact Disc Database:
   Component: Gracenote2  --- 1008
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 130215BBC19455
   Coding: 000E00200101028000001000
   VCID: 44D14E575E1158C7FA5-8010
   Component: TSG HBFS      020 0028
   Serial number: 130215BBC19459
End----------(Elapsed Time: -2:-47, VBatt start/end: 14.6V/14.6V)----------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Thank you for the complete Auto-Scan. Unfortunately both your ABS and EPS controllers are different enough from mine that I can't directly advise you on coding. Ross-Tech support will have more information available and may be able to comment.
In the meantime, you may want to look yourself at coding on address 44, while connected to your car so you can see coding information. Also look at adaptation values. The way you enable and disable things like DSR changed over time with different EPS rack generations, so I can't tell you for sure where it's located. It may require a login/security access value to change, which should be documented if needed.
It also might be helpful to know any tweaks or retrofits you've been working on. The car didn't get into this state by itself. It also won't have thrown a Car/Trailer stabilization enabled fault when you don't have a trailer control module. Can you disclose any other changes you've been making? We're not judgmental here ;) but it helps to know how you got broken in order to get you fixed.
CarlightExpress
C?ID=353848
Basically, I removed the Instrument cluster so that I could route the Fibre Cable in preparation for the AID going in next week, after this it had lost the ABS coding, however I had done a scan a few days before on the car for a High Fuel Rail Pressure issue which had triggered Limp Mode, so I had a full scan with all the codings to put the ABS coding back and performed the steering angle sensor calibration and end stops again.
Prior the cluster being removed the error was not shown
I am currently going through the previous auto scan and checking the codings that are shown now versus what they were previously, there's a few differences like in Park / Steer Assist (Address 10) and Address 44 has a different coding than prior, I'll go through them all now and see what other changes
CarlightExpress
C?ID=353848
Only two that are different are
Address 10 Park/Steer Assist:
Current Coding: 0071051051
Previous Coding: 0071051011
Address 44 Steering Assist:
Current Coding: 0002
Previous Coding: 8103
CarlightExpress
C?ID=353848
Just applied correct coding to 44 First, no difference, same error in ABS, applied the correct coding to Address 10, Error gone away, car is back to being fault free :)
Thanks for all your help on this
CarlightExpress
C?ID=353848
          BB BC
VIN: WVWZZZ3CZFE465481   Mileage: 130496km-81086miles
   Revision: A1X23---
   Revision: 00H10V01
   Coding: 000F0F0703
   Revision: 00001K10
   Air quality sensor:
   Coding: 90A8DD
   Coding: 0071051011
   Coding: 80000A
   Coding: 80000A
   Coding: 0410
   Coding: 2DFFFF
   Analog clock:
   Coding: 0301
   Coding: 8103
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
End----(Elapsed Time: 02:12, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Assem Ehab
Egypt
C?ID=443031
لدي رمز خطأ واحد فقط يظهر (أعلم أنه يقول اثنين ولكني قمت بمسح الرمز الآخر بسبب تمكين تثبيت السيارة / المقطورة) ، MIL غير مضاء ولكن لا يمكن العثور على أي شيء حتى على google فيما يتعلق بما يسبب هذا ، أي شخص عندك اي افكار؟
[كود] العنوان 03: ABS Brakes (J104) الملصقات: 5Q0-907-379-IPB-V1.clb
الجزء رقم SW: 3Q0 907379 R HW: 3Q0 907379 G
المكون: ESC H42 0711
مراجعة: 00000000 الرقم المسلسل: 60575000000842
الترميز: 0FEC938F54260B71077B070841C469F0C92AD0E0E08296F5186250F8C209
المحل رقم: WSC 00015115 00001
مجموعة بيانات ASAM: EV_Brake1UDSContiMK100IPB 034036
قضيب: EV_Brake1UDSContiMK100IPB_034_VW37.rod
2 تم العثور على عيوب:
8277 - قاعدة البيانات
U1122 00 [009] - رسالة غير معقولة
[FCAN: إشارة EPS_DSR_Status غير صالحة]
مؤكد - تم اختباره منذ مسح الذاكرة
تجميد الإطار:
حالة الخطأ: 00000001
أولوية الخطأ: 3
تردد الخطأ: 1
عداد إعادة الضبط: 210
التاريخ: 2019.02.21
الوقت: 21:18:06 [/ CODE]
