Multiple Oxygen Sensor codes P0131, P0130, P2251
mjwiest
Lehigh Valley, PA
C?ID=282927
Backyard mechanic here.
I have replaced O2 sensor on manifold with a used one from parts bin and get the same codes. (thinking it was the sensor)
Visual inspection show no apparent wire issues at 6 pin connector
Is there any tests with measuring blocks? What am I looking for?
Using a voltmeter what do I test and what outcome am I looking for?
Tuesday,19,February,2019,08:02:54:55382
VCDS Version: Release 18.9.1 (x64) Running on Windows 10 x64
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Control Module Part Number: 07K 906 032 BG HW: 07K 906 032 Q
Component and/or Version: 2,5l R5/4V G 1859
Software Coding: 0000003
Work Shop Code: WSC 00066 000 00000
VCID: 6FEC55C67E455A3234-803A
000305 - Oxygen (Lambda) Sensor B1 S1
P0131 - 002 - Signal too Low - Intermittent - MIL ON
Fault Status: 10100010
Mileage: 180945 km
Time: 17:36:22
RPM: 2576 /min
Load: 89.8 %
Speed: 79.0 km/h
Temperature: 91.0°C
Temperature: 24.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
008785 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
P2251 - 004 - Open Circuit
Mileage: 180949 km
Time: 07:37:46
RPM: 831 /min
Load: 30.2 %
Temperature: 22.0°C
Temperature: 6.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
000304 - Oxygen (Lambda) Sensor B1 S1
P0130 - 001 - Malfunction in Circuit
Fault Status: 01100001
Mileage: 180949 km
Time: 07:37:46
RPM: 831 /min
Load: 30.2 %
Temperature: 22.0°C
Temperature: 6.0°C
Voltage: 14.351 V
Readiness: 0000 1000
mjwiest
Lehigh Valley, PA
C?ID=282927
I have wire diagram but do not know what to test
Gone But Not Forgotten
Component and/or Version: 2,5l R5/4V G 1859<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed!
Please to meet you "backyard mechanic"...... I'm the asshole mechanic! :p
Did you load light wire tracks from G39 connector to ecu T94 connector & at respective pins, if good current is able to be carried by respective tracks & with a quality new oxygen sensor, not some used one, change engine ecu?
Isn't it advised to check and load light plus inspect all tracks of ecu harness and a visual inspection of wiper area or for harness known defects?
JPPSG?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
https://forums.ross-tech.com/showth...ad-wiring-diagrams-the-videos-(final-version)
Post a complete auto-scan with valid vin number to pull PR data.
If you need a controller or OXS or package deal please see us here & with included data transfer.
https://www.ebay.com/itm/330955482482
Did you change entire OXS or did you crimp some POS in?
And remember the worst type of FOD is induced FOD!
Please clear codes and report a fresh complete auto-scan after doing so and additionally with MODE 9 DATA from the OBD2 side too!
WARNING!
This car is an SULEV! ......... & contains 3 OXS sensors & that like to share tracks and fuck around with each other for some undocumented fun outside the scope of the RTFB!
Hey PSSST....... did you know you are reading the wrong WD so go to ERWIN and check yourself?
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Who knows? NostraJackASS knows nothing!
mjwiest
Lehigh Valley, PA
C?ID=282927
Thank you for the quick response.
The used OXS was from a low mileage motor complete with 6-pin connector.
My first task is the cowl area harness inspection and expose the ecu.
Bentley manual is due to be delivered today. I have been using Haynes and www.repairsurge.com
mjwiest
Lehigh Valley, PA
C?ID=282927
Wednesday,20,February,2019,15:16:34:55382
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWRZ71K48M154951   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K48M154951   Mileage: 180980km-112455miles
Address 01: Engine (CBU)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BG    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1859
   Revision: 1NH03---    Serial number: VWX7Z0H224J02H
   Coding: 0000003
   Shop #: WSC 00066 000 00000
                    Mileage: 180985 km
                    Time: 00:02:47
                    RPM: 782 /min
                    Load: 21.2 %
                    Temperature: 35.0°C
                    Temperature: 15.0°C
                    Voltage: 14.224 V
                    Mileage: 180985 km
                    Time: 00:02:47
                    RPM: 782 /min
                    Load: 21.2 %
                    Temperature: 35.0°C
                    Temperature: 15.0°C
                    Voltage: 14.224 V
Readiness: 0110 1101
   Part No SW: 09G 927 750 HE    HW: 09G 927 750 HE
   Component: AQ 250 6F           1090
   Revision: 00H69000    Serial number:
   Coding: 0000584
   VCID: 7BF471963A3D369288-802E
   Revision: 00H11001
   Coding: 0021122
   VCID: 73E459B6126D7ED2D0-8026
   Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000007834610
   Coding: 14058E234004150007140000001400000008730B5C000100000000000000
   Component: Wischer 190308 021  0501
   Coding: 00038805
   Shop #: WSC 00066
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 44
                    Mileage: 180985 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.70 V
Address 0F: Digital Radio        Labels: None
   Part No SW: 8E0 035 593 Q    HW: 8E0 035 593 Q
   Component: SDAR SIRIUS     H08 0160
   Revision: 00000000    Serial number: AUZ4Z7L0596198
   Coding: 0000000
   VCID: 377CADA64695D2F22C-8062
            000 -  -
                    Reset counter: 4
                    Mileage: 180985 km
                    Time: 00:02:29
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M04NNNT
   Coding: 0013889
   VCID: 6CD642CA4F53A12A11-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME33031253Y
   Subsystem 3 - Serial number: 6342MSME3555617AE
   Subsystem 4 - Serial number: 6351HSME13280B765
   Subsystem 5 - Serial number: 6361HSME131C595BF
   Subsystem 6 - Serial number: 63727SME125B5C534
   Subsystem 7 - Serial number: 63827SME126B405F5
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0100
   Coding: 0010021
   VCID: 77FC6DA6061512F2EC-8022
   Part No SW: 1K0 920 954 Q    HW: 1K0 920 954 Q
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0002000    Serial number: VWX7Z0H224J02H
   Coding: 0023203
   Shop #: WSC 00066 067 57207
   VCID: 3A7AB4927587CF9AD3-806E
   Revision:   H07 01    Serial number: 150208F1001180
   Coding: ED807F070003021002
   VCID: 306E96BAA3FB05CA6D-8064
   Component: IMMO            3HL 1222
   Shop #: WSC 47505 003 1048576
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000548188307
   Coding: 0001205
   VCID: 3B74B1967ABDF692C8-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 3560A7AE5C9920E23E-8060
   Coding: 13980F880186281B0904058FB0880F0488DCA0
   VCID: 04060A6A47C3496AF9-8050
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000572688305
   Coding: 0001204
   VCID: 3C76B28A7FB3F1AAC1-8068
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2190641
   Coding: 0010400
   VCID: 29587BDE80217402AA-807C
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000002832669
   Coding: 0001168
   VCID: 3E72B88269AFE3BAEF-806A
00934 - Electric Window Motor; Rear Left (V26)
                    Fault Status: 01100101
                    Reset counter: 4
                    Mileage: 180985 km
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000002834165
   Coding: 0001168
   VCID: 3F8CC5866EA5EAB2E4-806A
                    Fault Status: 01111000
                    Reset counter: 4
                    Mileage: 180985 km
00935 - Electric Window Motor; Rear Right (V27)
                    Reset counter: 4
                    Mileage: 180985 km
                    Fault Status: 01111100
                    Reset counter: 4
                    Mileage: 180985 km
End-------------------------(Elapsed Time: 02:08)---------------
PR DATA record.
Thank you OP for posting an auto-scan
[TABLE="class: vinInfoTable, width: 550"]
[TR]
[TH="align: left"]Vehicle Identification No.[/TH]
[TD="colspan: 2"]3VWRZ71K48M154951[/TD]
[/TR]
[TR]
[TH="align: left"]Model[/TH]
[TD="colspan: 2"]Jetta
JEM[/TD]
[/TR]
[TR]
[TH="align: left"]Date of production[/TH]
[TD="colspan: 2"]03.04.2008[/TD]
[/TR]
[TR]
[TH="align: left"]Year[/TH]
[TD="colspan: 2"]2008[/TD]
[/TR]
[TR]
[TH="align: left"]Sales type[/TH]
[TD="colspan: 2"]1K27S3[/TD]
[/TR]
[TR]
[TH="align: left"]Engine Code[/TH]
[TD="colspan: 2"]CBUA[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission Code[/TH]
[TD="colspan: 2"]KBV
[/TD]
[/TR]
[/TABLE]
[TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PC[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0HM[/TD]
[TD]Vehicle class differentiation -1KM-
Build status corresponds to production
in Mexico[/TD]
[/TR]
[TR]
[TH="align: left"]tail pipe[/TH]
[TD="class: prCode"]0P1[/TD]
[TD]Rear side exhaust tailpipe[/TD]
[/TR]
[TR]
[TH="align: left"]drive-off assistance[/TH]
[TD="class: prCode"]UG0[/TD]
[TD]Without hill start assist/hill descent
control/comfort driving assist[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]0GT[/TD]
[TD]Emission standard SULEV[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UM[/TD]
[TD]Driver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E7[/TD]
[TD]Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8ZH[/TD]
[TD]Antenna for AM/FM reception, "diversity"[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SH[/TD]
[TD]Left exterior mirror, flat (US)[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RR[/TD]
[TD]Right exterior mirror, convex (US)[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WL[/TD]
[TD]Jack for external audio source[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8X[/TD]
[TD]US comfort equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KE[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J1L[/TD]
[TD]Battery 280 A (60 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1ZP[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]Components with special surface[/TH]
[TD="class: prCode"]6FF[/TD]
[TD]Exterior mirror housing and various attachments
colour coded to vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0D[/TD]
[TD]Assembly kit, USA corresponding vehicle
version (not California), various parts[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)
[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH="align: left"]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH="align: left"]brake wear indicator[/TH]
[TD="class: prCode"]9U1[/TD]
[TD]brake wear indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T1[/TD]
[TD]Heated washer nozzles in front[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH="align: left"]Chrome package[/TH]
[TD="class: prCode"]QJ1[/TD]
[TD]Chrome package[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C12[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FE[/TD]
[TD]Tilting and sliding glass sunroof with
sunbshade[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in rear[/TH]
[TD="class: prCode"]1JA[/TD]
[TD]Rear shock absorption, basic design 1[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in front[/TH]
[TD="class: prCode"]G46[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH="align: left"]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G7[/TD]
[TD]Filler neck module 1 with insert[/TD]
[/TR]
[TR]
[TH="align: left"]Installation differentiation for components[/TH]
[TD="class: prCode"]0ER[/TD]
[TD]Installation differentiation for
transmission AQ250
-- vehicle components --[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AG[/TD]
[TD]Electronic immobilizer
with anti-theft alarm system (for USA)[/TD]
[/TR]
[TR]
[TH="align: left"]Inserts[/TH]
[TD="class: prCode"]5MA[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Scuff plates[/TH]
[TD="class: prCode"]7M5[/TD]
[TD]Without impact protection film for door sill[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH="align: left"]Electric interface for external use
[/TH]
[TD="class: prCode"]UF0[/TD]
[TD]Without electric interface[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FL[/TD]
[TD]Mexico manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Pedestrian protection[/TH]
[TD="class: prCode"]VL0[/TD]
[TD]Standard pedestrian protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Pedal cluster[/TH]
[TD="class: prCode"]VF0[/TD]
[TD]Standard pedal cluster[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K4[/TD]
[TD]Separate daytime running lights
NAR[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YG[/TD]
[TD]Weight range 7
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]L13[/TD]
[TD]Suspension range 13
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]T8K[/TD]
[TD]5-cylinder SI engine 2.5 l
unit 07K.1[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U5[/TD]
[TD]Luggage pockets on backrest[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment cover[/TH]
[TD="class: prCode"]3U0[/TD]
[TD]Without luggage compartment cover[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)
[/TD]
[/TR]
[TR]
[TH="align: left"]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment trim[/TH]
[TD="class: prCode"]5A7[/TD]
[TD]Comfort luggage compartment trim with
service lid/snap-on cover[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G1A[/TD]
[TD]6-speed automatic transmission[/TD]
[/TR]
[TR]
[TH="align: left"]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear spoiler[/TH]
[TD="class: prCode"]5J0[/TD]
[TD]Without rear spoiler[/TD]
[/TR]
[TR]
[TH="align: left"]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M0[/TD]
[TD]Without rear window wiper and washer
system[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3NQ[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AP[/TD]
[TD]Climatic air-conditioning system (semi-automatic)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8ES[/TD]
[TD]Twin headlamps for driving on the right,
with integrated high beam (US design)[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH="align: left"]Interior light in footwell[/TH]
[TD="class: prCode"]6T1[/TD]
[TD]Interior light in footwell[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U5C[/TD]
[TD]Instrument cluster, mph speedometer
- USA -[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8B[/TD]
[TD]Notchback[/TD]
[/TR]
[TR]
[TH="align: left"]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH="align: left"]coolbox[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y2[/TD]
[TD]Tropical zones[/TD]
[/TR]
[TR]
[TH="align: left"]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH="align: left"]headrest for seat, rear[/TH]
[TD="class: prCode"]3Q6[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]3J1[/TD]
[TD]Hight-adjustable head restraints for
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel tank treatment[/TH]
[TD="class: prCode"]2LF[/TD]
[TD]Fuel tank with special material
treatment (coextrusion) with changed
protective layer[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z0[/TD]
[TD]Initial standard fuel filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]1A1[/TD]
[TD]Fuel system for fuel-injected SI engine,
injection system without fuel return[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH="align: left"]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear license plate bracket[/TH]
[TD="class: prCode"]6P2[/TD]
[TD]License plate bracket, rear (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]License plate bracket front (small, NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K0[/TD]
[TD]Without surface protection, with
additional transit coating[/TD]
[/TR]
[TR]
[TH="align: left"]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH="align: left"]Rear cargo area[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]Reading lamp[/TH]
[TD="class: prCode"]8S4[/TD]
[TD]Two reading lights front, two rear[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH="align: left"]Backrest release[/TH]
[TD="class: prCode"]3H2[/TD]
[TD]Backrest release for right front seat
[/TD]
[/TR]
[TR]
[TH="align: left"]Air duct, front area[/TH]
[TD="class: prCode"]VK1[/TD]
[TD]Air duct, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Load edge protection[/TH]
[TD="class: prCode"]2P1[/TD]
[TD]Plastic loading edge protection[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P4[/TD]
[TD]Manually adjustable lumbar support in
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]1MH[/TD]
[TD]Leather-wrapped steering wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RW[/TD]
[TD]10 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q0[/TD]
[TD]without beam length regulator[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH="align: left"]Marten repeller[/TH]
[TD="class: prCode"]UM0[/TD]
[TD]Without marten repeller[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q0[/TD]
[TD]Without multi-function display/
trip computer[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D77[/TD]
[TD]5-cylinder SI engine 2.5 l/125 kW (20V)
(R-5)
base engine is T8K[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SH[/TD]
[TD]Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TH[/TD]
[TD]Vanity mirror, right, illuminated, with
extractable[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TA[/TD]
[TD]witout rear fog lamp[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WA[/TD]
[TD]Without fog lights[/TD]
[/TR]
[TR]
[TH="align: left"]Upgrading measures[/TH]
[TD="class: prCode"]GP0[/TD]
[TD]Vehicles w/o special upgrade measures
[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P1[/TD]
[TD]Rear floor panel module, type 2[/TD]
[/TR]
[TR]
[TH="align: left"]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]CJ8[/TD]
[TD]Alloy wheels 6.5J x 16[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8US[/TD]
[TD]Radio "Premium"
(double-size standard radio)[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JF[/TD]
[TD]Non-smoking package (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K4[/TD]
[TD]Tire pressure monitoring system 315 MHz
High[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]H4B[/TD]
[TD]All-season tires 205/55 R16 H (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G4[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]4QQ[/TD]
[TD]3-point seat belts in front with
pretensioner and height adjustment,
US label[/TD]
[/TR]
[TR]
[TH="align: left"] [/TH]
[TD="class: prCode"]PMC[/TD]
[TD]California emission concept[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, left[/TH]
[TD="class: prCode"]3TF[/TD]
[TD]Front left comfort seat[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, right[/TH]
[TD="class: prCode"]3SF[/TD]
[TD]Comfort seat, front right[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplates for sales name[/TH]
[TD="class: prCode"]QD3[/TD]
[TD]Lettering for sales name[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P7[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact in buckle[/TD]
[/TR]
[TR]
[TH="align: left"]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZD[/TD]
[TD]3-point seat belts, outer rear with US
label[/TD]
[/TR]
[TR]
[TH="align: left"]Center rear seat belts[/TH]
[TD="class: prCode"]3C8[/TD]
[TD]3-point seat belt, center rear with US
label[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N0C[/TD]
[TD]Seat trim covers in leatherette[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3PD[/TD]
[TD]Manual height adjustment for front
seats, electric backrest adjustment for
left front seat[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH="align: left"]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH="align: left"]Side lights[/TH]
[TD="class: prCode"]7R4[/TD]
[TD]Side marker lamps and turn signal
repeaters (turn signals with white lens)[/TD]
[/TR]
[TR]
[TH="align: left"]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH="align: left"]Control number (no PR family)[/TH]
[TD="class: prCode"]SL9[/TD]
[TD]Control (in-plant)[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH="align: left"]Protective side molding[/TH]
[TD="class: prCode"]4B0[/TD]
[TD]with no protective side strip[/TD]
[/TR]
[TR]
[TH="align: left"]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH="align: left"]Supertone system and tone sequence
control[/TH]
[TD="class: prCode"]9J0[/TD]
[TD]Without supertone system and tone
sequence control[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JC[/TD]
[TD]Comfort bumpers[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer[/TH]
[TD="class: prCode"]0BG[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AG[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Drawers under front seats[/TH]
[TD="class: prCode"]QN0[/TD]
[TD]Without drawers under front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Heavy-duty/sports version[/TH]
[TD="class: prCode"]2UA[/TD]
[TD]Standard design[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH="align: left"]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]0NV[/TD]
[TD]Nameplate set "2.5"[/TD]
[/TR]
[TR]
[TH="align: left"]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH="align: left"]Door storage compartments in front[/TH]
[TD="class: prCode"]3YR[/TD]
[TD]Door pockets with insert mats[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5Hz[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K0[/TD]
[TD]Central locking w/ radio remote control
and interior controls[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B38[/TD]
[TD]Legal requirements California[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]3LJ[/TD]
[TD]Door and side trim panel in foam film,
insert in leatherette[/TD]
[/TR]
[TR]
[TH="align: left"]doors[/TH]
[TD="class: prCode"]0A2[/TD]
[TD]4 doors[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV8[/TD]
[TD]Satellite radio reception NAR[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EB[/TD]
[TD]without identification plate[/TD]
[/TR]
[TR]
[TH="align: left"]Delivery equipment[/TH]
[TD="class: prCode"]2A8[/TD]
[TD]Delivery equipment, water border[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH="align: left"]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH="align: left"]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG0[/TD]
[TD]without service interval extension[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH="align: left"]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W1[/TD]
[TD]Washer fluid level indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Additional body panels,
side[/TH]
[TD="class: prCode"]6EA[/TD]
[TD]Without additional side body covers
(stone guard)[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B7[/TD]
[TD]Child seat anchors as per Canadian
requirements a. ISOFIX child seat system
[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
mjwiest
Lehigh Valley, PA
C?ID=282927
This is the correct WD for the oxs for this car. EWD-57 # 38/14 with 121 pin.
My T6 connector is wired differently than on this WD.
T6w5 is black T6w2 is green/white (similar to the previous WD I posted earlier 94 pin)
The car is new to me and this is the first I'm working on it. I don't understand the schematics of the G39 on the WD. Would this effect the OXS?
Wire and check tracks pin location to pin location and omit color or WD racism.
He doubts me?
latest
mjwiest
Lehigh Valley, PA
C?ID=282927
Car was purchased at salvage auction without a key. Battery was disconnected. I towed and dropped at local VW dealership to have keys made. Towed car from dealership to my home as the thief damaged the shift cable. Here is the initial scan done after fixing the shift linkage / without the plastic cover on and prior to driving. I cleared the fault ( MAF). I forced Readiness and had 7 of the 8. CEL came on later.
Friday,15,February,2019,17:05:30:55382
VCDS Version: 18.9.0.2 (x64)
VIN: 3VWRZ71K48M154951   Mileage: 180930km-112424miles
   Coding: 0000003
   VCID: 6FEC55C67E455A323C-803A
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - MIL ON
                    Fault Status: 11100010
                    Mileage: 180939 km
                    RPM: 252 /min
                    Load: 81.9 %
                    Temperature: 72.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.303 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High - MIL ON
                    Mileage: 180939 km
                    Time: 02:47:05
                    RPM: 692 /min
                    Load: 27.4 %
                    Temperature: 72.0°C
                    Voltage: 13.716 V
   Coding: 0000584
   VCID: 7BF471963A3D369280-802E
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -  - Intermittent
   Revision: 00H11001
   Coding: 0021122
   VCID: 73E459B6126D7ED2D8-8026
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 00111010
                    Reset counter: 42
                    Mileage: 179157 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.35 V
   Coding: 0000000
   VCID: 377CADA64695D2F224-8062
            000 -  -
                    Fault Frequency: 31
                    Reset counter: 2
                    Mileage: 180772 km
                    Time: 11:37:12
   Coding: 0013889
   VCID: 6CD642CA4F53A12A19-8038
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Coding: 0010021
   VCID: 77FC6DA6061512F2E4-8022
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
02413 - Switch for Selector Lever Position P Lock (F319)
   Coding: 0023203
   VCID: 3A7AB4927587CF9ADB-806E
   VCID: 306E96BAA3FB05CA65-8064
01176 - Key
                    Fault Frequency: 18
                    Mileage: 46916 km
                    Time: 08:19:57
   Coding: 0001205
   VCID: 3B74B1967ABDF692C0-806E
   VCID: 3560A7AE5C9920E236-8060
   VCID: 04060A6A47C3496AF1-8050
   Coding: 0001204
   VCID: 3C76B28A7FB3F1AAC9-8068
   Coding: 0010400
   VCID: 29587BDE80217402A2-807C
00003 - Control Module
            014 - Defective
   Coding: 0001168
   VCID: 3E72B88269AFE3BAE7-806A
   Coding: 0100101
   Coding: 0001168
   VCID: 3F8CC5866EA5EAB2EC-806A
                    Fault Status: 00111000
                    Reset counter: 42
                    Mileage: 96517 km
                    Fault Frequency: 63
                    Reset counter: 2
                    Mileage: 96517 km
End-------------------------(Elapsed Time: 01:54)--------------------------
Doesn't it sound like you have a bad MAF or IAT maybe a SAI or the combined MAP/IAT sensor or a bad wire that is rouge and maybe past the Omega A power circuit for the Lance Lot Link BUS that shares the tracks of all in WD you don't have?
Post the MODE 9 Data of the controller please in OBD2
112424miles
Did you know that an SULEV carries an emissions warranty for 15 years or 150K on SMOG components which this car seems to be covered under?
I wonder what vicarious mystery things could be covered Modda?
With a salvage title? I'm even more skeptical than I normally would be.
Not all salvage auctions sell only salvage title or cars and theft recovery isn't always a salvage vehicle either & depending on the state isn't it?
Now a total loss that is a clear different story now isn't it?
Yeah, but a quick web search of the VIN reveals that this one was indeed sold with "Documents: Pa - Certificate Of Salvage"
Yes but I don't believe salvage means what you might think when consulting DMV there in PA in comparison with reconstructed, each state has different criteria for what the definitions mean I think, no?
I know I had heard a run in with this question once before, & was right about it in end, when arguing on behalf of someone at DMV from PA to NY with a car they purchased in PA coming to NY was being branded salvage when it wasn't due to being labeled reconstructed?
A simple reading of the definitions from state to state comparison proved the point?
Now if title is branded Salvage it maybe not under warranty but it doesn't hurt to ask or check what might be covered & can be verified fast, right?
According to the Pennsylvania Department of Transportation, a salvage vehicle is one that is inoperable, or that is unable to pass a state safety inspection without the owner needing to spend more on repairs than the fair market value of the vehicle.Oct 29, 2015
https://law.justia.com/codes/pennsylvania/2010/title-75/chapter-11/1161/
2010 Pennsylvania Code
Title 75 - VEHICLES
Chapter 11 - Certificate of Title and Security Interests
1161 - Certificate of salvage required.
                               SUBCHAPTER D
             SALVAGE VEHICLES, THEFT VEHICLES, RECONSTRUCTED
                       VEHICLES AND FLOOD VEHICLES
     Sec.
     1161.  Certificate of salvage required.
     1162.  Transfer to vehicle salvage dealer.
     1163.  Transfer to scrap metal processor.
     1164.  Theft vehicles.
     1165.  Reconstructed vehicles.
     1165.1. Inspection of reconstructed, modified and specially
     1165.2. Specialized Vehicle Compliance Inspection Advisory
            Panel.
     1166.  Flood vehicles.
     1167.  Penalty.
        Enactment.  Subchapter D was added December 9, 2002,
     P.L.1278, No.152, effective in 60 days.
        Cross References.  Subchapter D is referred to in sections
     4729, 7309 of this title.
     § 1161.  Certificate of salvage required.
        (a)  General rule.--Except as provided in sections 1162
     (relating to transfer to vehicle salvage dealer) and 1163
     (relating to transfer to scrap metal processor), a person,
     including an insurer or self-insurer as defined in section 1702
     (relating to definitions), who owns, possesses or transfers a
     vehicle located or registered in this Commonwealth which
     qualifies as a salvage vehicle shall make application to the
     department for a certificate of salvage for that vehicle.
        (b)  Application for certificate of salvage.--An owner who
     transfers a vehicle to be destroyed or dismantled, salvaged or
     recycled shall assign the certificate of title to the person to
     whom the vehicle is transferred. Except as provided in section
     1163, the transferee shall immediately present the assigned
     certificate of title to the department or an authorized agent of
     the department with an application for a certificate of salvage
     upon a form furnished and prescribed by the department. An
     insurer as defined in section 1702 to which title to a vehicle
     is assigned upon payment to the insured or claimant of the
     replacement value of a vehicle shall be regarded as a transferee
     under this subsection. If an owner retains possession of a
     vehicle which is damaged to the extent that it qualifies for
     vehicle replacement payment, the owner shall apply for a
     certificate of salvage immediately. In this case, an insurer
     shall not pay vehicle replacement value until the owner produces
     evidence to the insurer that the certificate of salvage has been
     issued. A self-insurer as defined in section 1702 shall apply
     for a certificate of salvage when a vehicle is damaged to the
     extent that the cost of repairs would exceed the replacement
     value of the vehicle as certified by a licensed motor vehicle
     physical damage appraiser.
        (c)  Issuance and effect of certificate of salvage.--Upon
     proper application for a certificate of salvage, the department
     or agent of the department shall issue to the transferee a
     certificate of salvage which shall authorize the holder to
     possess or by endorsement transfer ownership of the salvage
     vehicle. A certificate of title or registration shall not again
     be issued or renewed for the vehicle except upon application
     containing the information the department requires, accompanied
     by any necessary documents required under section 1165 (relating
     to reconstructed vehicles).
        (d)  Out-of-State salvage vehicles.--The owner of a salvage
     vehicle possessing a valid certificate of title or certificate
     of salvage from a state or jurisdiction other than this
     Commonwealth does not need to apply for a certificate under
     subsection (a). If the owner wishes to transfer the salvage
     vehicle, the owner shall make application to the department and
     attach the out-of-State certificate of title or certificate of
     salvage along with any other information and documents the
     department reasonably requires to establish the ownership of the
     vehicle and the existence or nonexistence of security interests
     in the vehicle. The person identified on the application must be
     located or the owner or lienholder must be domiciled in this
     Commonwealth to qualify for issuance of a certificate of salvage
     by the department.
        (e)  Certificate not to be assigned in blank.--No person
     shall make application for or assign or physically possess a
     certificate of salvage or direct or allow another person in his
     employ or control to make application for or assign or
     physically possess a certificate of salvage unless the name and
     address of the transferee is placed on the assignment of the
     certificate of salvage simultaneously with the name of the
     transferor.
        (f)  Repairs to personal vehicle.--Nothing herein shall
     require a vehicle owner to obtain a certificate of salvage to
     repair or replace parts or component parts which malfunction or
     wear out as a result of normal use and operation which has
     occurred after the vehicle was transferred to the owner.
        Cross References.  Section 1161 is referred to in section
     1162 of this title.
And research pays off............ :p
Oh I'm going to have a fucking field day with this .........
SUBJECT: Emissions Warranty and Manufacturer Responsibilities under the Clean Air Act Dear Manufacturer:
Dear Manufacturer:
Over the past several months EPA has received numerous inquiries from the public regarding emissions warranty claims which have been denied. This letter is not intended to establish or alter any legal requirements, but to remind manufacturers of their responsibilities under the Clean Air Act and EPA regulations to honor emissions warranties and of the limited circumstances under which warranty claims may be denied.We would also like to update the EPA contact information which is required to be included in the owner’s manual/warranty booklet per 40 CFR §85.2109(a) (6). The following provisions apply to light duty vehicles and light duty trucks.
State Warranty Requirements Which Differ from the Federal Emissions Warranty EPA has received several reports from vehicle owners stating that their warranty claims have been denied based on the age or mileage of their vehicle exceeding the California year/70,000 mile warranty period.State motor vehicle emissions warranty provisions are in addition to, and do not void or eliminate, the federal emissions warranties under §207 of the Act. A vehicle that is within the federal warranty period and subject to regulations issued under §202 is the reforecovered by the federal emission warranties, notwithstanding valid adoption by a state of separate warranties. Under this situation, the Federal and California warranty provisions are concurrent, and all vehicles, even those sold in California, are subject to Federal warranty provisions. Therefore the Federal 8 year or 80,000 mile warranty period for the specified major emission control components applies to all vehicles, including those sold in California.
Vehicles with Salvage or Branded Titles EPA has received several reports from vehicle owners stating that their warranty claims have been denied solely based on the fact that the vehicle has a salvage title.While EPA acknowledges that a manufacturer is not responsible for damage to an emissions related component caused by improper use or maintenance, EPA’s regulations prohibit a manufacturer from denying an emissions performance warranty claim based on improper use or maintenance which is not relevant to the reason the vehicle failed (40CFR 85.2104(h)(3)). Additionally, as stated in EPA’s guidance on allowable maintenance (CD-85-11), EPA’s long-standing policy is that a manufacturer may only deny a defect warranty claim if it can show that the part failure was due to improper or neglected maintenance and not due to a defect. This principle applies to improper use(e.g. an accident or flood damage) as well.
The fact that a vehicle has a salvage title, by itself, is not evidence that a defect or emissions failure was caused by previous damage outside the responsibility of the manufacturer. Therefore a manufacturer may not deny an emissions warranty claim based solely on the fact that a vehicle has a salvage title. The following restrictions apply to all light duty vehicles/trucks whether or not they have a salvage or branded title.a) Defect Warranty A manufacturer may not deny an emissions defect warranty claim because of previous damage (e.g. an accident or flood damage), unless the manufacturer is able to show that part failure was due to the previous damage and not due to a defect.b) Performance Warranty A manufacturer may not deny an emission performance warranty claim because of previous damage (e.g. an accident or flood damage) which is not relevant to the reason the vehicle failed. In other words, a manufacturer must show a direct causative effect between the previous damage to the vehicle and the failure of the vehicle to comply with emission standards.
Cost of Diagnostics EPA has received several reports from vehicle owners stating that they were charged for the cost of diagnostics for a warranty claim.The regulations of 40 CFR §85.2106(g) state: “The vehicle manufacturer shall incur "all costs" associated with a determination that an emission performance warranty claim is valid.” This means the owner cannot be charged a diagnostic fee related to a valid warranty claim.
Warranty Enforcement:
EPA would like to remind manufacturers that failing or refusing to comply with the terms and conditions of the emissions warranties is a prohibited act under §203(a)(4)(D) of the Clean Air Act and may be subject to a civil penalty of to up $37,500 for each offense.Acts constituting such a failure or refusal shall include, but are not limited to, the following:(1) Failure to honor a valid warranty claim,(2) Performance of a warranty repair in a manner which cannot reasonably be expected to allow the vehicle to meet applicable emission standards for the remainder of its useful life(3) Failure of a manufacturer to reimburse a dealer or other designated agent for performance of a warranty repair(4) Charging the vehicle owner for any portion of a valid warranty claim including any related diagnostic fee.(5) Failure of a manufacturer to supply a part necessary to perform a warranty repair within a reasonable period, unless such failure is for a reason not attributable to the vehicle manufacturer or the warranty repair facility (for a performance warranty claim, a manufacturer generally must supply a part necessary to performs warranty repair within 30 days (40 CFR §85.2111(b)(4)).EPA would also like to remind manufacturers that if a warranty claim is denied, an owner can request a written explanation of the basis upon which the claim is being denied. For a performance warranty claim, failure to notify an owner within 30 days (unless the delays attributable to the vehicle owner or events which are beyond the control of the vehicle manufacturer or the repair facility) shall result in the vehicle manufacturer being responsible for repairing the warranted items free of charge to the vehicle owner.
EPA Contact Information:
Please include in each vehicle’s owner’s manual or warranty booklet an explanation thatan owner may obtain further information concerning emission warranties or that anowner may report violations of the terms of the emission warranties by contacting:
U.S. Environmental Protection AgencyOffice of Transportation and Air QualityCompliance Division, Light-Duty Vehicle Group
Attn: Warranty Complaints2000
Traverwood DriveAnn
Arbor, MI 48105
Email: complianceinfo@epa.gov
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=35121&flag=1
mjwiest
Lehigh Valley, PA
C?ID=282927
On the ECM connector, how do I know pin number/location?
I have tested continuity and load from T6 to ECM. All good. New OXS will be going in as soon as I get it.
mjwiest
Lehigh Valley, PA
C?ID=282927
I'll call the local VW dealership regarding Emissions Warranty. GOOD STUFF!
My inspection station that does the Enhanced Inspection here in PA says that NY is brutal regarding the process of restoring Salvage to Reconstructed.
mjwiest
Lehigh Valley, PA
C?ID=282927
Currently a PA Salvage title. I am preparing it for the Enhanced Inspection (failed Rediness) Once it passes the Enhanced Inspection, it will be a PA Reconstructed (branded) Title.
