Polo 2G AW Park assist retrofit
vastechnics
C?ID=143747
I have this Polo 2G. I have retrofit PLA. Module sees all the sensors but in 44 Steering Assist coding don't work. Need the Security Access. Someone knows what the code is? It's not the same like Polo 6C 17580. It's different.
Monday,11,February,2019,14:55:31:43540
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WVWZZZAWZJY089258   License Plate: SOUPOLOAW
Mileage: 10916km-6782mi   Repair Order:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 47 55 5F
VIN: WVWZZZAWZJY089258   Mileage: 10916km-6782miles
Address 01: Engine (J623-CHZL)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BD    HW: 04C 907 309 AT
   Component: R3 1.0l TFS   H21 5150
   Revision: WXH21---
   Coding: 01110032234415080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
   ROD: EV_ECM10TFS01104C906026BF.rod
   VCID: 64905A358ED11E671A5-8030
   CAN Converter 01:
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0222
   Serial number: 08506534180108
   Coding: 09034B64154990B6D2FEA81B24E242A649124D26224A242444541254452442659248B26444522424222A482AA249D64A7D926B52BE
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
   VCID: 6D863F115D1B5F2F45B-8038
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 2G0 907 044 L    HW: 2G0 907 044 L
   Component: Climatronic   H03 0501
   Coding: 0120000008000100011008000244010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_VW27.rod
   VCID: 2D06FF119D9B9F2F05B-8078
459015 - Databus
          [Feuchtesensor innen - kein Signal/Kommunikation]
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.09
                    Time: 15:14:26
262402 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.09
                    Time: 15:14:26
                    Outside air temperature: 10.0 °C
                    Voltage terminal 30: 11.1 V
262404 - Sunlight Photo Sensor
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.09
                    Time: 15:14:26
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0915
   Serial number: 07001801900082
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77AA1D792F47E5FFAF7-8022
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S7Y18M01D17H12M54S43
   Coding: 0038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000011893674
   Coding: 130037
   Subsystem 3 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000018440967
   Coding: 090000
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000018581187
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000018594417
   Coding: 1B0000
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [009] - Open or Short to Plus
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.11
                    Time: 11:42:32
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 33
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.5 V
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418917353
   Coding: 0471151001
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4BC29189034FB11F3BF-801E
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00600240FF8748949C8145604087
   VCID: 3E24C85D40FD14B7AC1-806A
   Part No SW: 2Q0 959 655 AH    HW: 2Q0 959 655 AH
   Component: VW22Airbag    010 0349
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 035279A96B9FB95F83F-8056
   Belt Pretensioner left:
   Serial number: 2G4857705B0353R00776
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 2G4857706B0292R00513
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 442 061 612 17
   Serial number: 3577Y219F25777D3E18L
   Subsystem 4 - Part No SW: -----------    HW: 442 061 612 17
   Serial number: 3587Y21A325777D44261
   Subsystem 5 - Part No SW: -----------    HW: 442 0B1 401 18
   Serial number: 3517784BD292F3F4E03/
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 401 18
   Serial number: 3527784C1292F3F323CT
   Subsystem 7 - Part No SW: -----------    HW: 442 131 601 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11B52888612051C
   Part No SW: 2G0 920 740 A    HW: 2G0 920 740 A
   Component: KOMBI         309 0460
   Coding: 04A401002D800008018862011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 20181625DA494247BED-8074
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0915
   Coding: 030100046F085600F800005C080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0.rod
   VCID: 6FBA25195717AD3F777-803A
   Subsystem 2 - Part No SW: 2G0 959 442 H    HW: 2G0 959 442 H
   Component: E221__MFL-DC1  H02 0052
   Serial number: 29170002379040117421
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 10035645
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 00307858CP3J025
   Coding: 00000000000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 392EDB4159D3338F993-806C
   Part No SW: 5Q6 035 456     HW: 5Q6 035 456
   Component: KonzernAmp 8K H01 2427
   Revision: --------    Serial number: A1117A00022493
   Coding: 0202000000AAAA00000000000000
   ASAM Dataset: EV_AMPCAN8C1PASE 001015
   ROD: EV_AMPCAN8C1PASE_VW27.rod
   VCID: 73B229693B3F89DF93F-8026
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 178A000009200003
   Shop #: WSC 17651 003 1048576
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DEB3A131036B4FD13-8014
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    H41 0468
   Serial number: VWZAZ2U0215506
   Coding: 02720001BE0000004111010100880A001F0500D401200100CE
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 323CEC6D84A5C0D7589-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJV0051158
   Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
   Component: ECE1 2017/18  --- 0820
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.11
                    Time: 11:44:52
                    Voltage terminal 30: 12.7 V
0518 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.11
                    Time: 11:44:52
0522 - Front Left Bass Speaker
          B105F 13 [008] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
                    Reset counter: 141
                    Mileage: 10917 km
                    Date: 2019.02.11
                    Time: 11:44:52
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.11
                    Time: 11:44:52
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                    Reset counter: 101
                    Mileage: 10917 km
                    Date: 2019.02.11
                    Time: 11:44:52
End----(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
myounus
Northwest UK
C?ID=321059
What do you need a security code for steering assist?
vastechnics
C?ID=143747
Yes because if you want to provide coding. It says need security acces.
myounus
Northwest UK
C?ID=321059
Try 19249 28183 or 44595
vastechnics
C?ID=143747
Ok I will try and report here thanks!
vastechnics
C?ID=143747
19249 worked for me thanks!
