VW passat in limp mode
vagcom pro
Verified VCDS-User
C?ID=342235
Hi I need help i came across vw passat B7 with plenty of errors car is in limp mode and according to owner it has egr and dpf delete all the work was done by some one else who claims that they know everything but i am not sure about that any help will be appreciated as where to start with the thing i dont understand is if egr is deleted why its still showing the egr error?
	Sunday,17,February,2019,22:23:41:22147
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20181017 DS296.0
VIN: WVWZZZ3CZAP064800   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77 7D
37-Navigation -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0001
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 019 AD    HW: 03L 907 309 F
   Component: R4 2,0L EDC G000SG  5875
   Revision: 22H30---    Serial number: VWZCZ000000000
   Coding: 0001072
   Shop #: WSC 00999 444 64523
   VCID: 6D87CAB64194965F45D-8038
009254 - Exhaust Gas Recirculation Cooling Valve Control Circuit
               P2426 - 000 - Short to Ground - MIL ON
                    Fault Status: 11100000
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:30:29
                    Temperature: 24.3°C
                    Absolute Pres.: 989.4 mbar
                    (no units): 856.8
                    (no units): 3.97
                    Temperature: 49.5°C
000071 - Boost Pressure Control Valve/Solenoid (Bank 1)
               P0047 - 000 - Short to GND - MIL ON
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:00:32
                    Load: 9.8 %
                    Lambda: 13.4 %
                    Temperature: 24.3°C
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:00:32
                    Temperature: 9.9°C
                    Voltage: 12.08 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 23.4°C
009754 - Coolant Pump 2
               P261A - 000 - Open circuit - MIL ON
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:00:34
                    Voltage: 12.08 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011110
                    Count: 1
                    Temperature: 25.2°C
000260 - Mass Air Flow Sensor (G70)
               P0104 - 000 - Intermittent - MIL ON
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:04:59
                    RPM: 667 /min
                    Voltage: 11.70 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 710.0 mg/str
                    Mass Air / Rev.: 1275.0 mg/str
009756 - Coolant Pump 2
               P261C - 000 - Short to GND - Intermittent
                    Mileage: 276592 km
                    Date: 2032.14.21
                    Time: 14:43:02
                    RPM: 943 /min
                    Speed: 5.0 km/h
                    Voltage: 13.91 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Temperature: 52.2°C
Readiness: 1 4 0 0 1
   Part No SW: 3C0 614 109 AH    HW: 3C0 614 109 AH
   Component: J104    C4 440 V2   0024
   Revision: --026---    Serial number: 00000705936964
   Coding: 0036347
   Shop #: WSC 00028 790 00002
   VCID: 6491AF92925ED7171A3-8030
Address 08: Auto HVAC
   Part No SW: 3C8 937 049 AA    HW: 3C8 937 049 AA
   Component: Bordnetz-SG     H57 3204
   Revision: 00H57000    Serial number: 00000004071009
   Coding: 00908F0700041A00470A00000F000000000059435C000100000308000000
   Shop #: WSC 00028 028 00001
   VCID: 70B9D3C256A67BB76EB-8024
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 280710 026  0612
   Coding: 00046997
   Shop #: WSC 00028
                    Fault Status: 01101000
                    Fault Frequency: 9
                    Reset counter: 52
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:31:01
                    Voltage: 12.50 V
00483 - Control Module for Auxiliary Air Heater
                    Reset counter: 52
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:31:01
                    Voltage: 12.50 V
03789 - Terminal 75 Limp Mode Active
            000 -  -
                    Reset counter: 52
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:34:01
                    Voltage: 14.10 V
   Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
   Component: J234__006 VW10 HI   1916
   Revision: 21014000    Serial number: 003GHPEF2X1/
   Coding: 0012342
   VCID: 48C95B220EB6937716B-801C
   Subsystem 1 - Serial number: 6332MTS673951950
   Subsystem 2 - Serial number: 6342MTS618361880
   Subsystem 3 - Serial number: 6351HTS609D4D6KJ
   Subsystem 4 - Serial number: 6361HTS6LMU1D6KR
Address 16: Steering wheel
Address 17: Instruments
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C06522156A
   Coding: 3DFD2C04C21003
   VCID: 211FE686CDCC823FB15-8074
                    Reset counter: 51
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:31:34
                    Reset counter: 51
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:31:35
            000 -  -
                    Reset counter: 51
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:31:38
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 00137 211 56823
   VCID: 7AADF1EA00DA31E7D0F-802E
Address 37: Navigation
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   VCID: 313F16C69D2C32BF215-8064
   Component:    KSG PQ46 ELV 043 0612
   Coding: 01910A0001860E763004941570085FCE107C01
   Shop #: WSC 12345 123 45725
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Component: Neigungssensor  004 0611
            000 -  -
                    Reset counter: 51
                    Mileage: 276590 km
                    Date: 2032.14.21
                    Time: 14:33:47
                    Reset counter: 91
                    Mileage: 276592 km
                    Date: 2032.14.21
                    Time: 14:43:09
00457 - Control Module for Network (J519)
                    Reset counter: 91
                    Mileage: 276598 km
                    Date: 2032.14.21
                    Time: 15:23:03
Address 52: Door Elect, Pass.
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000351227
   Coding: 0000056
   VCID: 2C0107B2BA0E5F57123-8078
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07957351
   Coding: 012120
   VCID: 2A0D01AABCFA4167E0F-807E
Address 7D: Aux. Heat
End----------(Elapsed Time: 03:14, VBatt start/end: 13.9V/13.9V)-----------
grant@gendan
Hi,
From your scan, I would say the EGR valve is still present and faulty. It may be that the car has been flashed to not use the EGR value but it is still physically fitted to the car and looks to have developed a short circuit.
Unless it has been removed and the wiring hacked-up as there seem to be a number of electrical wiring issues here.
_Val
Latvia
C?ID=356659
Could you explain this?
Readiness: 1 [U]4[/U] 0 0 1
dafrazi
Norristown, PA
C?ID=173774
Limp mode likely caused by MAF and boost controller errors.
Check the wiring at the boost controller. The wires like to break under the boot at the connector.
vagcom pro
Verified VCDS-User
C?ID=342235
Thank you for replies I will keep you all updated thanks again
NEtech
Denmark
C?ID=56995
4 Fault codes, 2 Intermittent does not count here.
