Rear camera audi a4 B9
GaRc1a
Spain
C?ID=351945
I bought the original rear camera for the audi a4 B9, someone can help me to make the connection in the CanBus line, the instructions tell me that I have to connect to the Adblue control piece, but I do not know where that piece is.
GaRc1a
Spain
C?ID=351945
hello, someone can tell if the cables indicated in the photo are from the CANBUS line to connect the rear camera. Thank you
darkchina811
ITALY
C?ID=333184
since it's a twister pair, it most probably is the CanBus line you are looking for.
GaRc1a
Spain
C?ID=351945
thank you, I have not found out. Forgive my translation.
Do you think it's the canbus line?
darkchina811
ITALY
C?ID=333184
yes, and I would connect:
- orange/brown with orange/brown;
- orange/gray with gray.
myounus
Northwest UK
C?ID=321059
You can get wiring diagrams from erwin or if you know someone who has elsawin they should be able to check for you.
South Molton, UK
GaRc1a
Spain
C?ID=351945
Hi.
I have already installed the reversing camera. This is the coding that I have been sent but I do not activate the camera and it does not work.
Activate byte 35 bit 4 of module 09, I think it has nothing to do with the camera?
It gives me the error to calibrate the camera but I give it to calibrate and it tells me ERROR: INCORRECT MESSAGE LENGHT OR INVALID FORMAT.
Thank you
https://ibb.co/stJxTBF
https://ibb.co/dD4T6Jb
https://ibb.co/pb4FYdK
https://ibb.co/jHmX1Lw
myounus
Northwest UK
C?ID=321059
Can you please post an autoscan. Thanks
GaRc1a
Spain
C?ID=351945
Sunday,24,February,2019,14:52:55:59327
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4444.4
Workshop Code: 572 10005 015640
VIN: WAUZZZF49JA124773   License Plate:
Chassis Type: F4-AU49 (8W5)
Scan: 01 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6C A5 AC BB
          BC D6 D7
VIN: WAUZZZF49JA124773   Mileage: 22305km-13859miles
Address 01: Engine (J623-DEUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 A    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H35 3332
   Revision: B1H35---
   Coding: 0A194032232405083408
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TDI01104L906026A 004006
   ROD: EV_ECM20TDI01104L906026_004.rod
   VCID: 28080E22427D60B7F6D-807C
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0766
   Coding: 04AA1C9908A40A9A11A5409800805292E4C1D6203810508802004A4927836B
   Shop #: WSC 10005 572 15640
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4DC69FB60D5F659F25B-8018
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 S    HW: 8W0 820 043 S
   Component: Klima Zone 3  H60 0210
   Coding: 141800295544000D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 43D2B98EDB1BA3EFC3F-8016
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002064449
   Serial number: 6212590900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143E17900CD05445118188D80F9110B3108000000000000000020001A810A450132025601
   VCID: 015E7386818771FF913-8054
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 171219  043 0813
   Serial number: 89435300301735301555
   Coding: 5BC7F7
   Serial number: 21028846X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 11 12 2017  01211484
   Serial number: GX1CE102111723810046
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00642528
   Subsystem 6 - Part No SW: 8W0 925 301 AC    HW: 8W0 925 301 AC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000172438002
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00BUEVF
   Coding: AACCF0C00C800000585400F3D04C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4CC092B2F6456C97325-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 062 811 17
   Serial number: 3577Y00C92532140940L
   Subsystem 2 - Part No SW: -----------    HW: 442 062 811 17
   Serial number: 3587Y00C92532141F16W
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 601 18
   Serial number: 3517700BD291FA15330A
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 601 18
   Serial number: 3527700B52914AA19336
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 3557500C92777834F2DS
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 3567500C92777832C1AK
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 2307500B1275CB2473A6
   Subsystem 8 - Part No SW: -----------    HW: 442 430 212 17
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B92532143A25%
   Subsystem 9 - Part No SW: -----------    HW: 442 430 212 17
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00BF25A1C61346J
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B4105AD8494647B41-8022
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0373
   Coding: 05A45090288000080520E9601000400000000000
   Shop #: WSC 28664 003 1048576
   Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
   Component: Gateway       H42 0123
   Revision: 7A000001    Serial number: 0187A589918112
   Coding: 03010001000006404107000000000012C8080007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
   Component: J453 MFL  H04 0002
   Serial number: 20171221051618 20604
   Serial number: 7568336404
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78A81E62D25D3037A6D-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000377593003
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323CEC4A74A11A67589-8066
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        005 0129
   Serial number: 0000298349693
   Coding: 001D0B205000000000001080
   Shop #: WSC 06325 790 00001
   VCID: 4FFA85BE0753578F577-801A
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000300008000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DCBC8AC401AAE7C89-8016
   Part No SW: 8W0 907 064 EB    HW: 8W0 907 064 DB
   Component: BCM2 MLBevo   025 0387
   Coding: 012C0000002000A06309A0000600000231020000804306500F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 005876828A8D78F79ED-8054
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Fault Frequency: 8
                    Reset counter: 248
                    Mileage: 22276 km
                    Date: 2019.02.23
                    Time: 20:16:08
                    Supply voltages-Supply voltage: Terminal 30: 12.799 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.785 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.772 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 18 02 80
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       005 0129
   Serial number: 0000298675599
   Coding: 001D0B205C00000000001080
   VCID: 4EC498BA00595E875C1-801A
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 036 B    HW: 8W5 035 036
   Component: MU-P-LN-EU    034 1177
   Serial number: A795A0JB075359
   Coding: 01940101FF00000053110001000A00102F0001E5017001009E
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   VCID: 372ADD5E9FC3FF4F6F7-8062
   Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
   Component: ECE 2019  --- 0175
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9HBJ04BWT
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 R    HW: 8W0 919 614 R
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK115091700020240
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Component: RVC Compact   H12 0250
   Coding: 0294000102002007000040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 3332E94E8BBB136F53F-8066
10489856 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 209
                    Mileage: 22305 km
                    Date: 2019.02.24
                    Time: 14:32:58
                    active: waiting for return message
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H17 0050
   Coding: 0404090100000401022023A0A40000FC10F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736.rod
   VCID: 3C20C272A6E5DC17825-8068
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       005 0129
   Serial number: 0000297716478
   Coding: 000D09200000000000001080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 51FE83C61167417F413-8004
   Component: TSG HBFS      005 0129
   Serial number: 0000297716480
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 167430DAF809E647541-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.2V)-----------
myounus
Northwest UK
C?ID=321059
The answer is there "RearView system not calibrated".
GaRc1a
Spain
C?ID=351945
Thanks for answering.
I try to calibrate the camera and it marks me the error: incorrect message lenght or invalid format.
Any idea how I have to do it?
Thank
https://ibb.co/kM5B6pD
GaRc1a
Spain
C?ID=351945
Could it be that It mark that error because I have to put the calibration template?
When I turn the reverse gear does not activate the camera.
https://ibb.co/K0njNKy
myounus
Northwest UK
C?ID=321059
Where did you get that camera from? The part number 4m0980556a is a camera that's normally parameterised for an Audi A5. Can you check the back of the camera (trunk release) for the part number. Thanks.
GaRc1a
Spain
C?ID=351945
Hi.
I bought it at K-electronic.
It is nº 4M0 980 556 A.
But the screen does not show image.
GaRc1a
Spain
C?ID=351945
This is the configuration that K-electronic has sent me:
Changes are made in ADDRESS 19 "Diagnostic Interface".
- Connect address 19 "Diagnostic interface"
- Select installation list
o Activate address 6C "Rear view camera" and confirm
Save it and leave the control unit
Changes are made in ADDRESS 09 "Zentralelektrik"
- Connect address 09 "Central electrics"
- Select coding
o Select byte 35
 Set bit 4 from 0 to 1
Changes are made in ADDRESS 6C "rear view camera".
- Connect address 6C "Rear view camera"
- Select coding
Code this controller as described in your VCP / VCDS diagnostic system, depending on vehicle equipment.
We deliver this control unit already pre-parameterized as well as pre-coded.
Complete this already existing "standard coding" with the respective vehicle equipment.
Example codes:
Byte 04 - Bit 0 blocked to 1 = AHK
Byte 04 - Bit 1 to 1 = Parking aid front + rear installed
Byte 04 - Bit 1 to 0 = Rear parking aid installed
Byte 04 - Bit 2 to 1 = Parking Assist installed
Byte 07 - Bit 0 to 1 = Guides across
Byte 07 - Bit 1 to 1 = Guides parallel
Byte 07 - Bit 2 on 1 = Guides Trailer
Byte 07 - Bit 3 on 1 = Guides cross
Byte 07 - Bit 4 on 1 = Guides park steering assist installed
Changes are made in DIRECTION 5F "Information Electronics".
Connect address 5F "Information electronics"
Select adjustment
Change the following adjustment values:
Car_Funktion_List_BAP_Gen2_VPS: set to "activated" Car_Funktion_List_BAP_Gen2_VPS: to set MSG-bus "terminal 15"
Save and click on "Restart control unit". With the "Restart control unit" or "ECU reset" function of your VCDS / VCP diagnostic system, the multimedia system reboots - the changes take effect only after this restart
