H i all i have the above vehicle, the car has intermitted fault where the car smokes, and when it does smoke it revs about 400 rpm
above its normal idle..
here is scan for the car anyone point me in the direction as to whats causing the problem or what components i should be checking
thanks..
thanks..
Monday,24,November,2014,20:09:04:29062
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WVWZZZ1KZ9U015454 License Plate: TIE 24.11.14
Mileage: 139880km-86917mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9U015454 Mileage: 139880km-86917miles
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 KF HW: 03L 906 022 G
Component: R4 2,0L EDC 0000SG 2997
Revision: 13H01--- Serial number: VWX7Z0H63N17YM
Coding: 0000072
Shop #: WSC 00692 210 81791
VCID: 73E0536F12C4AEB9629-8026
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 000 - Signal too High (Rich) - MIL ON
Fault Status: 11100000
Mileage: 139785 km
Time: 23:54:34
RPM: 1265 /min
Speed: 49.0 km/h
Lambda: 38.7 %
Mass Air / Rev.: 480.0 mg/str
Voltage: 0.600 V
(no units): 16.0
Voltage: 0.975 V
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 133B400D092300FFC80F02E9901D00823000
Shop #: WSC 00046 412 00000
VCID: 74E25073D7CAA9817B3-8021
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 76E66A7B01B6BB91457-8023
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008345816
Coding: E5810F2700041500470A00000F00000000085D035C000100000000000000
VCID: 71EC596768D89CA9905-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 100908 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 150708 046 0204
Coding: 00208933
Shop #: WSC 00046
Component: 2K AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD244DF1
Coding: 0012875
VCID: 3D74B557640028C944D-8068
Subsystem 1 - Serial number: 6332MSME3D742F4EX
Subsystem 2 - Serial number: 6342MSME3B322D129
Subsystem 3 - Serial number: 6351HSME16610E140
Subsystem 4 - Serial number: 6361HSME16730D244
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 752 0101
Coding: 0000011
VCID: 030003AF42649E39729-8056
Part No SW: 1K0 920 964 B HW: 1K0 920 964 B
Revision: V0002000 Serial number: VWX7Z0H63N17YM
Coding: 0019403
Shop #: WSC 65536 645 577705
VCID: 2C5288138F7AB141E33-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 020708F1001134
Coding: E9807F064002021003
VCID: 3564AD775C30F0898CD-8060
Component: IMMO VDD 1212
Shop #: WSC 00137 211 56823
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 B
Component: Navigation 0001
Coding: 0000101
VCID: 387AA4434B220DE197B-806D
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1134
Revision: 32008001 Serial number: 00000549188407
Coding: 0000692
Shop #: WSC 00046 000 00000
VCID: 3B70BB4F7A1426F97A9-806E
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Fault Status: 00101100
Fault Frequency: 63
Reset counter: 236
Mileage: 139258 km
Fault Status: 00111000
Fault Frequency: 26
Reset counter: 235
Mileage: 139260 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A5E8E0B858EAF7111F-807F
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 89900A0001060C7F2D04840570085FC690FCA0
Subsystem 2 - Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1134
Revision: 32008001 Serial number: 00000012188405
Coding: 0000692
VCID: 3C72B8537F1A21C1733-8069
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095
Component: Radio 0001
Coding: 0010400
VCID: 62CE262BBD3E373119F-8037
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000003023883
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000003006484
Coding: 0000144
VCID: 3E76B25B690633D15D7-806B
