2013 Golf 7 coding problem
   #21
Yup, file sizes match.
How about the digital signature? Is it intact? Click the Digital Signatures tab...
Uwe: Thanks for your efforts, but it is with more than a degree of embarrassment that I must admit that the problem was indeed at my end. The digital signature for the file was OK (same as the previous beta - with differnet date, of course).
It appears that (for some unknown reason) your software has suddently conflicted with my firewall program. I've been using Symantec Endpoint Protection for some time now without any problems when loading your previous SW versions. Now, the only way that I can make your software load onto my laptop is if I disable Endpoint before I download the file (I have absolutely no idea why - other than perhaps a conflict with the latest Endpoint definition files)!
Anyhow, thanks again for your help - I reckon that you are entitled to ask Dana for half of her petty cash payment (i.e. $25) - as a token of my gratitude. Buy yourself a couple of glasses of Aussie beers!
   #22
Gotta love it when Nannyware messes with your files and doesn't give you an obvious message telling you it has done so.
itavaltalainen
Munich Airport - Germany
C?ID=178722
Seems I got an issue with rain closing, used latest beta (i.e. 14.6.1) and changed rlfs coding to 06885D - which was accepted, also managed to turn rain closing on and show it in the menu but for some reason it will not accept coding to permanent (i.e. it just remains on once - which means it will work only once after you ticking the box in the car setup menu, next time I go in there it's unticked again).
Anyone had the same issue?
Full auto scan below (it's a 11-2013, 2.0 TDI estate, right hand drive):
Sunday,22,June,2014,11:51:10:14667
VCDS Version: 14.6.1.0 (x64)
Data version: 20140601
VIN: WVWZZZAUZEP533xxx   License Plate:
Mileage: 37069km-23033mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 20 2B 42 44 52 55 5F
VIN: WVWZZZAUZEP533xxx   Mileage: 37069km-23033miles
Address 01: Engine (J623-CRBC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 11190012034505083000
   Shop #: WSC 00028 028 00212
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_SK37.rod
   VCID: 79F9E952F8E019F256-802C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Revision: 00000000    Serial number: 628030000009B4
   Coding: 04FA8AA13423096F037E060241C52920512C90C0608294F3F46050F4C002
   Shop #: WSC 00028 028 00076
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7BF5F35AF2DC2BE244-802E
Address 05: Acc/Start Auth. (J518)       Labels: None
   Revision: 00021000    Serial number: 0194434276
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7B365EBD66D2EA1F-806F
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02120104202400011005004100101000
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 66C3B22E995E860A8B-8033
   Air quality sensor:
   Part No SW: 5Q0 937 086 L    HW: 5Q0 937 086 L
   Component: BCM PQ37BOSCH 020 0078
   Revision: --------    Serial number: 86580110130672
   Coding: 03010B66C24122FB0BA44080B11C0728180A000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 011005
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 43854BBACAAC93224C-8016
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    130915  042 0551
   Serial number:         130922235726
   Component: RLFS  024 0042
   Serial number: Y13M10D02H22M53S16S1
   Coding: 06885D
   Serial number: 000000000ZY132462VJY
   Serial number: 00000000000027962890
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231328501165
   Coding: 0071051001
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3B75335AB25CEBE204-806E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 04101376510145
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3561256294783D92F2-8060
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 14091341357197
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E3E26EC9FE768A3B-8023
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR00SUEG
   Shop #: WSC 00028 028 00062
   VCID: 7F0D074AE6C437C268-802A
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B23091350043
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B23091371029
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 609 13
   Serial number: 357670000009837DDD08
   Subsystem 4 - Part No SW: -----------    HW: 480 002 609 13
   Serial number: 358670000008B27DDD0A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 13
   Serial number: 3516502C11171FE1D0BD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 910 13
   Serial number: 3526502B71142C8391D9
   Subsystem 7 - Part No SW: -----------    HW: 480 402 709 13
   Serial number: 3556502C11142C81E1EB
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20131003500341
   Coding: 0C00
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: N/A
   VCID: 73E5DB7ADA8C63A21C-8026
No ASAM data for: "EV_SMLSVALEOMQB" (VW37)
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 27A511103F80260001887A01040000
   VCID: 285FFC1653CA507A79-807D
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 26091310800204
   Coding: 030100040B087300EF00065E880F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_AU37.rod
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H15 0038
   Serial number: 27130001616960113395
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 2883981403
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02028867727261565623393E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B55031A423C7B6294-807E
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000222488004
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB.rod
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000077815352
   Coding: 003B1220D001028000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 020B8EBE95365A2A07-8057
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000003002808
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 418941B2D0B081325E-8014
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000077832409
   Coding: 003B1020DE01028000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 010981B2903041321E-8054
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000003017117
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029602000B000200
   VCID: 3D713D42AC48E5D23A-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0421
   Serial number: V7F00910130129
   Coding: 02730201FF00000011111201002800031F0100860100010045
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 67DDBF2A9E549F02B0-8032
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ901QF7
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
End-------------------------(Elapsed Time: 04:14)--------------------------
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Have you changed the other 2 adaptation channels in 09 as per this post
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/?p=3567802
Just as a heads up, I am having issues with rain closing. It only seems to remain active for approximately 1 hour.
Others have also reported that is is messing up the Leaving Home function, which works fine unless the car has been left for a long period (greater than an hour coincidentally) and then Leaving Home stops working. Seems given that this is happening at a round the same time as the rainclosing stopping working, it seems that enabling rain closing in this manner is causing issues. Any feedback appreciated.
http://www.briskoda.net/forums/topic/319677-octavia-iii-vcds-tweaks/
   #25
itavaltalainen
C?ID=178722
Yes have changed the other two channels as well (but channel numbers are not exactly the same, suppose I may have different firmware, car was built in the end of October 2013 - text behind them is the same though):
Address 09-02:5Q0 955 547 recoded (Long Coding) from 00A8EE to 06885D (00028/028/00076)
Address 09:5Q0 937 086 L recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from not active to active
Address 09:5Q0 937 086 L recoded (ADP-(28)-Access control 2-Menuesteuerung Regenschliessen) from not active to active
When I try to change it from once to permanent:
Address 09:5Q0 937 086 L recoded (ADP-(16)-Access control 2-Regenschliessen_art) from once to Permanent
it comes up with 'request out of range' error.
PS: It does work - once (and just 1 min after locking, not tried after say a few hours)
Hello VCDS Gurus!
Tried the rain closing tweak (changed the settings for the three channels).
Coding accepted by the car.
Ticked the dialogue box that said something like "automatic closing in rain".
Thought to myself: that was easy - now let's try it.
Switched wiper (on the stalk) to rain sensing position
Lowered the windows (all of them)
Locked the car doors
Waited a while (about 30 mins)
Poured water over the windshield where the rain sensor is
nothing happened !!
Checked coding again - all OK
Tried above method again
nothing happened!!
What did I do wrong?
Keithuk: many thanks for the links. The information that you have provided is pretty much the way that I had understood rain closing to work on VW cars. The good burghers in Germany appear to located the rain closing facility in the adaptation channels on the mkVII (rather than in the long coding section) and prior to Dana's fix, the SW wouldn't speak at all to the RLFS unit (which it now does). But alas, despite RT's recent improvements, the actual operation of the facility (on my car, at least) is proving illusive. I'm hoping that someone can identify a fault in my process (which entirely likely). Else I will have to seek solace in a couple of glasses (or more) of aged single malt!
   #29
andyvee
C?ID=159389
What coding are you using for the RLFS?
For a Golf VII it should be one of the ones listed below
06885D> motorway light "OFF" / rain light "ON" / Rain Close "ON" for Octavia 3 / Leon 5F
06A8DD> motorway light "OFF" / rain light "ON" / Rain Close "ON" for Golf 7
07C85D> motorway light "ON" / rain light " ON "/ Rain Close" ON "for Octavia 3 / Leon 5F
07E8DD> motorway light "ON" / rain light "ON" / Rain Close "ON" for Golf 7
   #30
Andyvee: Thanks for the advice -I've read some of your stuff on this and other forums (hello).
I first tried implementing the rain closing facility via changes to the three adaptation channels that others have described on this thread:
The changes were duly accepted by the software following the updates that were embedded in the latest Beta SW version.
Whilst still retaining the above adaptation channel changes, I then altered the hex value of the RLFS (# 2-5Q0 955 547 -RLFS) to 06A8DD as you suggested. I chose this option for my car because the previous code for the RLFS was hex 00A8DD. Coding accepted.
But alas, still no rain closing function when I spray water on the windshield (with the doors locked and the wipers on rain sensing position). Guess that it was not meant to be!
PS: On further investigation, I found that an interesting thing happens with the above changes intact: After I've spray the windshield with water and I then momentarily re-click the door locking button on the key fob (i.e. don't hold the key fob button down), the open windows close! Stranger than fiction-huh?
   #31
andyvee
C?ID=159389
Yep, this is the same issue some others are seeing as well, as well as the rain closing working for about an hour then stopping working.
Try deactivating and then reactivating rain closing from the Infotainment unit. Also, you can test by 'tapping' the rain sensor with your finger, you don't need to keep spraying water.
Make sure that the following procedure is followed to test it:
Engine is running and wipers and headlights on auto with drivers door closed.
Turn off engine, exit vehicle and close door
Use the button on the remote fob to lower the windows an inch
Lock the vehicle
Tap on the rainsensor with your fingers
There appears to be an issue on MQB platform cars where for the settings to take effect properly the control unit has to reset after the coding changes. I don't think VCDS does this, but VCP resets the controllers after every change (hence why you can only do one adaptation channel at a time with VCP), and has a manual reset as well. A suggestion to include in future beta versions Dana?????
   #32
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Hello Andy, this function is already on our wish/todo list. We'll see what we can do about this. :)
   #35
bloggo
Birmingham UK
C?ID=198143
Andy,
I carried out the procedure that DV52 posted on the "vwwatercooled" site and all codings were accepted.
Saturday,02,May,2015,15:53:39:11201
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
VIN: WVWZZZAUZDP******   License Plate:
Mileage: 10669km-6629mi   Repair Order:
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP******   Mileage: 10669km-6629miles
Address 01: Engine (J623-CPTA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: 1.4l R4 TSI   H02 5532
   Revision: WKH02---
   Coding: 01250032236405082000
   Shop #: WSC 00028 028 00080
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002006
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: 64C759686F707E1843-8031
   Part No SW: 0CW 300 047 T    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5211
   Revision: 00043014    Serial number: CU501303187173
   Shop #: WSC 00028 028 00310
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4C9791C8E7E0D6586B-8019
   Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
   Component: ESC           H75 0537
   Coding: 01FA8AA1202712750377060801CC2980510448C0608094F3F82A502AC1
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   VCID: 7EF30B00E1DCB4C8B5-802B
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00120004200100011005004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 3663D320896CBC882D-8063
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011308601425
   Coding: 03001846C24102FB0FA44080B11C0728100A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 4683A3E0F98C2C08BD-8013
   Slave 1:
   Component: WWS    130317  042 0551
   Serial number:         130319080559
   Coding: 0E4DD5
   Slave 2:
   Serial number: Y13M04D09H13M01S36S1
   Coding: 06A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130520P6C
   Serial number: 00000000000056508464
539925 - Databus
                    Reset counter: 152
                    Mileage: 10112 km
                    Date: 2015.03.27
                    Time: 11:18:53
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0029
   Revision: --------    Serial number: 61131308700820
   Coding: 0131161051
   Shop #: WSC 00017 666 00908
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3D71CC0CAC5A6FD0EC-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 04041375030254
   Coding: 001E1300FE0309
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3F8DB604A6567DC0FE-806A
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R02DGFD
   Coding: 98FCC0C0000000005C5400CF00C800000065
   Shop #: WSC 00028 028 00057
   VCID: 4A9B97D0ED94C86859-801F
   Serial number: 34169677A04041350661
   Coding: 333135
   Serial number: 34169676A04041340700
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 803 13
   Serial number: 35767000000BB8B0AC05
   Subsystem 4 - Part No SW: -----------    HW: 480 002 803 13
   Serial number: 35867000000187BCDC07
   Subsystem 5 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 35165029B0FAE8A462D
   Subsystem 6 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 3526502BF0FEA210C0DU
   Subsystem 7 - Part No SW: -----------    HW: 480 402 003 13
   Serial number: 3556502B70FAE8A1223N
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 12031308490737
   Coding: 0D00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 7BF50214F2CEA1E092-802E
   Part No SW: 5G0 920 970     HW: 5G0 920 970
   Component: KOMBI         336 0580
   Coding: 67A401082790260001886A01040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 67DD4E649E46150066-8032
1048578 - No Basic Setting
          B2010 00 [008] -  -
                    Reset counter: 161
                    Mileage: 9214 km
                    Date: 2015.01.21
                    Time: 09:35:54
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000484847
   Coding: 030100042B086400EF00065C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_VW37.rod
   VCID: 3467E9289F10AE9813-8061
H13 0035
   Serial number: 23130000275380040291
   Coding: 2DFFFF
   Serial number: 6877660103
   Serial number: 0000056235917
   Coding: 003B0220D001028000001000
   Shop #: WSC 00028 028 00074
   VCID: 020B7FF09524D028D1-8057
   Serial number: 00000000000001117534
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 83
   Serial number: 0000056849937
   Coding: 003B0020DE01028000801000
   VCID: 010970FC9022CB30C8-8054
   Serial number: 00000000000001128000
   Coding: 050000
   Part No SW: 5G0 035 858     HW: 5G0 035 858
   Component: MU-S-ND-ER    039 0170
   Serial number: V5F00704130548
   Coding: 02730001FF00000021111201002800001F0100160100010045
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 69D9485C8852237070-803C
   Component: ABT_Std_Nav  H44 0020
   Serial number: VWZ8Z9N3401HQ1
   Subsystem 2 - Part No SW: 5G0 919 866 N    HW: -----------
   Component:  ECE 2014/15  --- 0040
Mods carried out with beta 15.3.0
End-------------------------(Elapsed Time: 03:33)--------------------------
Andy
Sector 7G
HC424490
Excellent! Thanks for the feedback. :thumbs:
   #37
bloggo
Birmingham UK
C?ID=198143
Andy,
Although the coding's were accepted I was still unable to get the rain closing to work.
Bill.
   #39
Bill: I've just had look at Andy's instructions compared to mine. The only difference that I can find is in the In-cabin procedures. Andy suggests that you reset all the car's settings to factory, whereas my instruction are to reset opening and closing settings. Worth trying Andy's way if you still have the adaptation/coding changes made.
Cheers
   #40
bloggo
Birmingham UK
C?ID=198143
Andy/DV52
Ok, I've tried both suggestions with no luck.
I will try starting from scratch when I have time, to see if it works and keep you advised.
Thanks to you both for your assistance.
Bill.
