- Mar 17, 2014
- 14
- 2
- Birmingham UK
- C?ID=198143
Could you please assist with a problem I have with settings on the new Golf 7, whereas I am trying to activate the “Closing the windows in the rain” option?
I have set the adaptation coding for channels 15 active-16 permanent-28 active. As this did not work I tried to alter “RLS_Close_Glazing” in the adaptation to active, but this produced “ERROR: Channel Not Available”. I then tried to change the setting in the Long Coding of module 5Q0 937 084Q” sub module “5Q0-955-547” by setting bit 2 in byte 0 “Rain Closing Active” and again this produced an error: “Coding rejected Error 31: Request out of range”.
The attempt was made with only the ignition on and also with the engine running.
This is my autoscan:
Your help would be appreciated.
Thank you
Bill.
Saturday,15,March,2014,11:05:15:11201
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZAUZDP079089 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
Address 01: Engine (J623-CPTA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 AD HW: 04E 907 309 G
Component: 1.4l R4 TSI H02 5532
Revision: WKH02---
Coding: 01250032236405082000
Shop #: WSC 00028 028 00080
ASAM Dataset: EV_ECM14TFS01104E906016AD 002006
ROD: EV_ECM14TFS01104E906016AD.rod
VCID: 64C759686F707E3E1FF-8031
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 D HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 3902
Revision: 00043014 Serial number: CU501303187173
Shop #: WSC 00028 028 00310
ROD: EV_TCMDQ200021_AU37.rod
VCID: 3A7BC710BD7458CE953-806F
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 Q HW: 5Q0 907 379 E
Component: ESC H75 0534
Revision: 00000000 Serial number:
Coding: 01FA8AA1202712750377060801CC2980510448C0608094F3F82A502AC1
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 4A9B97D0ED94C84E053-801F
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120004200100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 3663D320896CBCAE71B-8063
Air quality sensor:
263426 - Air Quality Sensor
B10AF 31 [008] - No Signal
Reset counter: 12
Mileage: 4676 km
Date: 2014.02.25
Time: 07:41:01
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011308601425
Coding: 03001846C24102FB0FA44080B11C0728100A000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 4683A3E0F98C2C2EE1B-8013
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A
Component: WWS 130317 042 0551
Serial number: 130319080559
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M04D09H13M01S36S1
Coding: 00A8DD
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY130520P6C
Serial number: 00000000000056508464
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0029
Revision: -------- Serial number: 61131308700820
Coding: 0131161051
Shop #: WSC 00017 666 00908
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 3D71CC0CAC5A6FF6B01-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-567.clb
Part No SW: 5Q0 907 567 G HW: 5Q0 907 567 G
Component: ACC3 H08 0390
Serial number: 04041375030254
Coding: 001E1300FE0309
ASAM Dataset: EV_ACCBoschMQB 001021
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 3F8DB604A6567DE6A2D-806A
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Component: AirbagVW20 011 0361
Serial number: 003M1R02DGFD
Coding: 98FCC0C0000000005C5400CF00C800000065
Shop #: WSC 00028 028 00057
Seat belt tensioner; left:
Component: BeltPretRevFL H35 0340
Serial number: 34169677A04041350661
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H35 0340
Serial number: 34169676A04041340700
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 803 13
Serial number: 35767000000BB8B0AC05
Subsystem 4 - Part No SW: ----------- HW: 480 002 803 13
Serial number: 35867000000187BCDC07
Subsystem 5 - Part No SW: ----------- HW: 480 400 304 13
Serial number: 35165029B0FAE8A462D
Subsystem 6 - Part No SW: ----------- HW: 480 400 304 13
Serial number: 3526502BF0FEA210C0DU
Subsystem 7 - Part No SW: ----------- HW: 480 402 003 13
Serial number: 3556502B70FAE8A1223N
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Revision: -------- Serial number: 12031308490737
Coding: 0D00
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7BF50214F2CEA1C6CE5-802E
Part No SW: 5G0 920 970 HW: 5G0 920 970
Component: KOMBI 336 0580
Coding: 27A401082790260001886A01040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
VCID: E7DDCE641E469526BAD-80B2
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 125 1109
Revision: -------- Serial number: 0000484847
Coding: 030100042B086400EF00065C1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_AU37.rod
VCID: 3467E9289F10AEBE4FF-8061
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H13 0035
Serial number: 23130000275380040291
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6877660103
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000056235917
Coding: 003B0220D001028000001000
Shop #: WSC 00028 028 00074
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 020B7FF09524D00E8D3-8057
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001117534
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 83
ROD: EV_SteerAssisMQB.rod
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000056849937
Coding: 003B0020DE01028000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 010970FC9022CB16949-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001128000
Coding: 050000
Part No SW: 5G0 035 858 HW: 5G0 035 858
Component: MU-S-ND-ER 039 0170
Serial number: V5F00704130548
Coding: 02730001FF00000021111201002800001F0100160100010045
ASAM Dataset: EV_MUStd4CPASE 002036
ROD: EV_MUStd4CPASE_SE37.rod
VCID: E9D9C85C0852A356AC9-80BC
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H44 0020
Serial number: VWZ8Z9N3401HQ1
Engine Control Module 2:
Subsystem 2 - Part No SW: 5G0 919 866 D HW: -----------
Component: ECE 2013 --- 0021
End ---------------------------------------------------------------------
Thank you
Bill.
