Measuring Blocks greyed out and not working
CCV6
C?ID=357809
Hello ,
Just run for the first time and disappointed the measuring block button does not work on my car. Advanced Measuring values button works fine. Probably something basic I am missing. :banghead:
I have a screenshot.
https://imgur.com/a/OpnwoAs
Here is the autoscan
  Monday,11,February,2019,22:11:22:10363
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8K8DA019111   License Plate: KY12TYV
Mileage: 167120km-103843mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K8DA019111   Mileage: 167120km-103843miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KD    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 32194012242601080000
   Shop #: WSC 45123 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KD 003005
   ROD: EV_ECM20TDI01103L906018JG.rod
   VCID: 76B5E47C3845BA07B41-8022
5290 - Throttle Actuator Control Circuit
          P2100 00 [032] - Open Circuit
5305 - Throttle Position Sensor (G69)
          P0123 00 [032] - Signal too High
4891 - EGR Valve (N18)
          P0403 00 [104] - Malfunction
                    Fault Frequency: 41
                    Mileage: 163395 km
                    Date: 2018.09.22
                    Time: 10:54:51
                    Engine speed: 2675.00 /min
                    Normed load value: 7.1 %
                    Vehicle speed: 41 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.620 V
                    Unlearning counter according OBD: 36
                    Air mass: actual value (mg/stroke): 523.9 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 91.31 %
                    EGR valve: offset closed: 0.12 %
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 16
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 7
                    High press EGR actuator: actual unconditioned volt val: 1017.4 mV
4892 - EGR Valve (N18)
                    Fault Frequency: 44
                    Mileage: 161217 km
                    Date: 2018.06.14
                    Time: 07:43:17
                    Engine speed: 2887.50 /min
                    Normed load value: 4.7 %
                    Vehicle speed: 43 km/h
                    Air mass: actual value (mg/stroke): 289.6 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 19.48 %
                    High press EGR actuator: actual unconditioned volt val: 3680.0 mV
Readiness: 0 2 0 0 0
   Part No SW: 8K9 907 379 L    HW: 8K9 907 379 L
   Component: ESP8 quattro  H09 0100
   Coding: 061544
   Shop #: WSC 06334 000 00000
   VCID: 4BC3658813C797EF3BF-801E
   Part No SW: 8K0 907 064 FC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H10 0602
   Coding: 03B20000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 76B5E47C38C5BA07B41-8022
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0812000010987021
   Serial number: 2312000008927005
   Part No SW: 8K2 820 043 AD    HW: 8K2 820 043 AD
   Revision: D1000000    Serial number: 01010220120923
   Coding: 342402E000
   VCID: 6B83C508738777EF5BF-803E
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 AD
   Component: BCM1 1.0      H14 0103
   Revision: 04014001    Serial number: 00000026734701
   Coding: 290000308034A7C00081000300001F1F001D070827080201000008000000030000000024000000
   Shop #: WSC 24550 000 1048576
   VCID: 74B1DE742EB9A8178A5-8020
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 030212  H06 0070
   Serial number: SWF12020030078
   Coding: 00FD11
   Component: G397_RLFS  H06 0001
   Serial number: 20146343
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002601121540
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 71080F06000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD90VJ4S
   Coding: 30534435363030303030554A3052384B3053
   VCID: 48C95A8402317CF716D-801C
   Serial number: 6334MSME6A7043238
   Serial number: 6344MSME6B1405359
   Serial number: 6352QSME446C1848O
   Serial number: 6362QSME3C6C307AV
   Serial number: 63732SME446D0354
   Serial number: 63832SME196C0A667
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120209000335
   Coding: 000017
   VCID: 4FFB7198E7DFABCF577-801A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 B    HW: 8K0 920 982 B
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NTE21312D
   Coding: 3304290202012600010000
   VCID: 33331D686B37EF2F53F-8066
   Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H10 0025
   Revision: 1Y030014    Serial number: 1441Y1213102A5
   Coding: 00CF07FF00
   VCID: 3FDB4158577F3B4FA77-806A
   Serial number: 0285756701
   Serial number: 12021001088011200181
            000 -  -  - Intermittent
                    Reset counter: 109
                    Mileage: 166521 km
                    Date: 2019.01.31
                    Time: 20:20:24
                    Bin. Bits:    10111
                    Voltage: 11.30 V
                    Count: 6
   Part No SW: 8K0 959 793 Q    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000022583491
   Coding: 011002204001410001
   VCID: 4EC56C9CE0D5A2C75C1-801A
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0028339006
   Coding: 100000000001
   Shop #: WSC 24552 000 1048576
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311E746EB9E8174A5-8060
   Revision: 00002001    Serial number: 0168122851
   Coding: 013B062220B900408020023680000000
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 39
                    Reset counter: 78
                    Mileage: 163076 km
                    Date: 2018.09.01
                    Time: 18:07:53
02615 - Fuel Tank Cap; Lock
                    Fault Frequency: 13
                    Reset counter: 78
                    Mileage: 166153 km
                    Date: 2019.01.04
                    Time: 18:25:55
   Part No SW: 8K0 959 792 Q    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000023538209
   VCID: 4DC76B90EDD399DF25B-8018
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 10000000015760
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3635247C78C5FA07741-8062
   Part No SW: 4G0 035 056 D    HW: 4G0 035 056
   Component: Radio U STD   H60 0094
   Revision: AB001007    Serial number: 229B-0C7553067
   Coding: 010003020100000001
   VCID: 221DE82CC4CD76A7A89-8076
   Part No SW: 8R2 035 652 A    HW: 8R2 035 652
   Component: B-BN-EU       H62 0175
   Revision: --------    Serial number: 147BP0C7506005
   Coding: 01010101000681ED01800B4E000000030000
   VCID: 323D186C942DE627589-8066
   Subsystem 1 - Part No: 4G0 919 884 K
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0098
   Serial number: 9465AU0C2504754
   Subsystem 3 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001062793
02244 - Button in Control Head is Stuck
            000 -  -
                    Reset counter: 79
                    Mileage: 167129 km
                    Date: 2019.02.11
                    Time: 22:06:11
                    Voltage: 12.10 V
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000023308328
   Coding: 010002204001210001
   VCID: 43D34DA83B975FAFC3F-8016
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000023308409
End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
CCV6
C?ID=357809
Ahh ... Thanks.. Funny how you read post pointing out the differences in "UDS" and not really absorbing what the post is saying...
The advanced measuring values appear to have what I need so should get there to diagnose the problem (low fuel consumption and EGR issue). Only time consuming bit is running down the list to find the things you want to monitor every time you take a log. VAG dont appear to have grouped them in any logical sequence other than numerical order.
Is there a way to save the selected and save the advanced measuring blocks so you can repeat log day after day?
I know... I will use the forum search function.
Thanks again.
Eric
HC800000
Notice that even [Meas. Blocks - 08] is no longer an option for UDS modules. This isn't because we, Ross-Tech, though that would be fun, but rather, this is what the Germans have done.
I guess people get upset when we point out they are missing something basic? ;)
See third picture and accompanying text here:
http://www.ross-tech.com/vcds/tour/adv-meas-blocks.php
FandaTDI
Czech Republic
C?ID=204559
Eric: Yes and to be precise, filtering will lower the values in the list (so many times are even 2, better 3 letters enough) ... And isn´t it more likely 2nd picture? ;-)
In accordance to this page, I would like to ask about the sample rate of logging (more values) and diffencies between interfaces (/units/probability of communication problems...) e.g. when I am on one PC using both (HEX-CAN and HEX-NET) interfaces. Talking about this:
"When using a HEX-NET or HEX-V2 interface, you can select a value by which to split Grouped UDS requests. You should select the highest value that allows data to be displayed for all of the checked items (instead of "N/A")."
Is this significant difference in the sample rate? (what about turbo vs Grouped UDS requests?) And what sample rate is it if both are off/ N/A? Set up or depends on concrete unit or just the (CAN-)BUS type?
Is the highest value the same as (always) "turbo" on? What if I would have it with HEX-CAN?
The place number of values that are grouped into a single UDS request has nothing to do with "turbo" mode.
Turbo mode changes the timing in the underlying, low-level protocol.
