2017 Skoda Octavia RS 2.0 TDI 4x4 CUNA
Ilu
Finland
HN1-008020
Wednesday,13,February,2019,21:02:41:11509
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
VIN: TMBCK7NE3H0******   License Plate: ***-***
Mileage: 76287km-47402mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 42 44 47 52
          55 5F 69 A5 A9
VIN: TMBCK7NE3H0******   Mileage: 76287km-47402miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BT    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H23 1542
   Revision: B5H23---
   Coding: 011D001A047601081000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BT 002003
   ROD: EV_ECM20TDI01104L906026BS_002.rod
   VCID: 7DB21B63ECDD9BA2BE-8028
5456 - Starter Will Not Turn
          P3054 00 [104] - Jammed or Electrical Malfunction
                    Mileage: 71167 km
                    Date: 2018.12.22
                    Time: 10:22:50
                    Engine speed: 0.00 /min
                    Coolant temperature: 49 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 6.760 V
                    Starter control: terminal 50 acknowledgment-Bits 0-7: 32
                    Status of starter activation relay-Bits 0-7: 3
                    Starter control: release conditions-Bits 0-7: 0
                    Starter control: release conditions-Bits 0-7: 98
                    Starter control: shut-off conditions 1-Bits 0-7: 0
                    Number of manual engine starts-Bits 0-7: 0
                    Number of automatic engine starts-Bits 0-7: 0
                    Number of automatic engine starts-Bits 0-7: 19
20359 - Internal Control Module
          P0606 00 [101] - Processor Fault
                    Mileage: 76104 km
                    Date: 2019.02.12
                    Time: 11:31:58
                    Coolant temperature: 88 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 11.780 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 17
                    Engine status: COENG_READY
   Part No SW: 0D9 300 013 A    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4903
   Revision: 06354004    Serial number: TFK01605142262
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 156223C3F4AD63E216-8040
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61616000001073
   Coding: 1A076B913422096F40800705C1C52958D62C9002E083947416615070C02903
   ROD: EV_Brake1UDSContiMK100IPB_035_VW41.rod
   VCID: 7BB6157BF2C9959280-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0406502315
   Coding: 032C0C
   Shop #: WSC 73430 790 00000
   VCID: 3B36D57BB2495592C0-806E
   Part No SW: 5E0 907 044 AH    HW: 5E0 907 044 AH
   Component: Climatronic   H04 1601
   Revision: 00001K07
   Coding: 01010104004111011005000100101002
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 6B96253B82A9051210-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061615501622
   Coding: 0C031B76C24722FB07A04082B11807280C00000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04446E878F37EA6AF1-8050
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160516  041 0570
   Serial number:         160525202646
   Coding: 065DDD
   Component: RLHS  042 0105
   Serial number: S2Y16M06D10H22M23S58
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY16090416C
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035510473
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 227
                    Mileage: 65502 km
                    Date: 2018.09.09
                    Time: 20:04:18
   Revision: --------    Serial number: 39331615907394
   Coding: 0071051151
   Shop #: WSC 73430 790 00063
   VCID: 43C6AD9BCAB92D5288-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 03051603212487
   Coding: 000C1E00FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A38D07FBD736C9ADB-806E
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPBQF90E
   Coding: 98CCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F6E51ABD67199325C-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 003 005 16
   Serial number: 3576U0000005F0C04B1D
   Subsystem 2 - Part No SW: -----------    HW: 454 003 005 16
   Serial number: 3586U000000F26B04B1G
   Subsystem 3 - Part No SW: -----------    HW: 454 802 905 16
   Serial number: 3516RD961980B000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 905 16
   Serial number: 3526RBD4D960B000000O
   Subsystem 5 - Part No SW: -----------    HW: 454 802 805 16
   Serial number: 3556V4FE1520B000000G
   Part No SW: 5Q0 953 507 HK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 04061604400560
   Coding: 6010
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0640748FB90BD87AEF-8052
   Part No SW: 5E0 920 757 C    HW: 5E0 920 757 C
   Component: KOMBI         305 8311
   Coding: 07AD0018ED840008018A6A031000000000000000
   VCID: 2B16E53B4229C51250-807E
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
   Component: STH-MQB       008 0075
   Coding: 9309
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000050997
0036 - Fuel Level too Low
          P1250 00 [009] - -
                    Reset counter: 147
                    Mileage: 75656 km
                    Date: 2019.02.08
                    Time: 22:11:54
                    Operating condition of parking heater: OFF
                    71
                    Coolant temperature of parking heater: 81 °C
                    Coolant temperature: 86 °C
                    Engine running status: detected
                    Fuel level: 8 l
                    Heater output: 0 W
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0004961328
   Coding: 030100345F087300EB00027A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7CB41667F7C792AA89-8028
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A2371250516
   Serial number: 75410803001605300569
66565 - Diagnostic Databus
          U1202 00 [008] - Malfunction
          [Bus defekt CAN-Diagnose]
                    Reset counter: 163
                    Mileage: 74787 km
                    Date: 2019.02.02
                    Time: 18:33:24
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 184
                    Mileage: 76077 km
                    Date: 2019.02.12
                    Time: 00:00:13
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Serial number: HA1-00021.05.16
   Coding: 0001
   VCID: 4AD880BFED93FC1A4B-801E
   Revision: 00000000    Serial number: 16000092378004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424FE479F179AEA01-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PF311755
   Coding: 0010000000000500018480808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3C34D667B74752AAC9-8068
   Component: TSG FS        010 0031
   Serial number: 0000203948568
   Coding: 001D0020DE00040000001100
   VCID: 47DEB98BFE81017254-8012
   Serial number: 00000000000010387125
   Coding: 010200
65639 - Motor for Window Regulator
          B1487 29 [008] - Signal Implausible
                    Mileage: 69148 km
                    Date: 2018.11.11
                    Time: 13:26:54
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 A    HW: 3Q0 035 466 A
   Component: MIB2_amp_P_SK H02 0250
   Revision: 00000001    Serial number: SKZ8Z1GAS01STH+
   Coding: 0373010000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 2D12EB237C3DCB224E-8078
   Component: TSG BFS       010 0031
   Serial number: 0000203991234
   VCID: 46C0B48FF98B187AAF-8012
   Serial number: 00000000000010371828
   Coding: 190200
   Coding: 03EA00003F000000
   VCID: 40CCA297DBAF364A95-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5Q0 035 864 B    HW: 5Q0 035 864 B
   Component: MU-S-N-ER     H30 0353
   Serial number: SKZAZ2S5091845
   Coding: 037351010000000011110002000800002F0101E4012081008E
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 3228F85F650394DA13-8066
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H43 1031
   Serial number: SKZ8Z9SLH00VS0
   Subsystem 2 - Part No SW: 5L0 051 236 H    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0407322247
   Coding: 0100000202000000
   VCID: 3E30DC6FA15B40BAE7-806A
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000573221
   Coding: 0101010001030306000400000100000101
   ROD: EV_MFKBoschAU370.rod
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Fault Frequency: 65
                    Reset counter: 188
                    Mileage: 61122 km
                    Date: 2018.07.09
                    Time: 18:09:58
                    Control Module temperature: 44 °C
                    Outside air temperature: 29.0 °C
                    Vehicle speed: 16.64 km/h
                    Voltage terminal 15: 13.3 V
                    Terminal 15 on: 72.3 s
1123601 - predictive route data
                    Fault Frequency: 16
                    Reset counter: 184
                    Mileage: 67914 km
                    Date: 2018.10.24
                    Time: 21:12:54
                    Control Module temperature: 35 °C
                    Outside air temperature: 1.0 °C
                    Vehicle speed: 10.56 km/h
                    Voltage terminal 15: 14.8 V
                    Terminal 15 on: 2866.9 s
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 160504200692
   VCID: 699A5F338855170262-803C
End----------(Elapsed Time: 01:57, VBatt start/end: 12.4V/12.4V)-----------
