I just updated from a 2012 Audi A7 (C7) to a 2019 Audi A7 (C8) and I am looking for adaptations and coding for the items listed below.
1. Needle Sweep in Virtual Cockpit
2. Display transmission gear for "D" and "S" drive modes
3. Change the Parking Assist shutdown speed threshold
4. Headlights - enable "Off" option. US vehicles have this option for speeds 0-6 mph. Canadian vehicles do not have this option at all
5. DRL (Daytime Running Lights) Off Option when vehicle is in Park with EPB applied (C7 worked this way from the factory)
6. Seat Symmetry + Passenger Seat Control
7. Enable Ability to lock car with Engine running
8. Enable Lap Timer
I had enabled some of these adaptations on my old C7 with my HEX-NET adapter, so obviously I'm looking to tweak the new ride. I've provided my auto-scan for the C8 below.
Has anyone had any success with adaptations and coding on the C8's?
Thanks in advance.
8. Enable Lap Timer
Thanks in advance.
VCDS Mobile 0.4451.0.4
VIN: WAUV2AF21KN024826
Scan: 01 02 03 06 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47 52 5F
61 6D 74 75 81 82 A5 BB BC C4 CA CB CC CD CF D6 D7 DB DC DE
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction
0010 CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK
0000 D7-Light Ctrl Right 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (DLZA J623) Labels: None
Part No SW: 4K0 907 559 A HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0004
Revision: B8H11000
Coding: 1A650012236E010E34286000000400000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0114K0907559A 001004
ROD: EV_ECM30TFS0114K0907559A.rod
VCID: 33298CCF059AE006821057-8066
No fault codes found.
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4K0 927 153 M HW: 0HL 927 156 B
Component: 0HL 30TFSINAR H01 0003
Revision: --H01---
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 3731B8DF11E20C26BE3803-8062
Subsystem 1 - Part No SW: 0CK-927-152-AA
Component: V553 MTFP003 0576
Serial Number: 75145041180198001671
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 4N0 907 379 AC HW: 4N0 907 379 P
Component: ESP9 Premium H06 0850
Coding: 58AA169729A40B9A11A64C933883D1E3F439891A6894D088321C8BC72F9C91
ROD: EV_ESP9BOSCHCMP_004.rod
VCID: 79B57EE76776DA5608AC55-802C
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0042
Coding: 001CB2400001BEA14843010101010000810000070700878700000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU58.rod
VCID: 3D3DAAF733DE26766474C1-8068
Subsystem 1 - Part No SW: 4N0-907-182
Component: N477 VB1 BFSvH04 0011
Serial Number: SJ800120071840258074
Coding: BF2F00
458789 - Databus
U1122 00 [040] - Implausible Message
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Coding: 07001563C0291CDD070E57891CEB9C28131B37110406009781090A001B331601086909028010000000000303004308180802000044010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74AB4FD34014A73E5B9A9C-8021
Subsystem 1 - Part No SW: 4K1-955-119
Component: J400FRWISCH 063 0740
Serial Number: 00000001805230400151
Coding: 7DC727
Subsystem 2 - Part No SW: 81A-955-555-A
Serial Number: 21773316X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1-941-501-A
Component: E1 - LTM H09 0086
Serial Number: 13S23.08.1800300623
Subsystem 4 - Part No SW: 4N0-907-410-A
Component: USHL5 H10 0100
Serial Number: 0000009600350Z011W02
Coding: 250000
Subsystem 5 - Part No SW: 8W0-857-511-B
Component: Y7_InnenspiegH01 0002
Serial Number: GX1CE110051823610073
Subsystem 6 - Part No SW: 4K0-947-135-E
Component: Dachmodul H42 0413
Serial Number: C00066488
Coding: 0D0104
Subsystem 7 -
Subsystem 8 - Part No SW: 80A-907-705
Component: J866-EVLS-SG H03 0100
Serial Number: WA133233000051953747
Coding: 0A0700
Subsystem 9 - Part No SW: 4N0-963-575
Component: V512 LLR1SLvLH01 0012
Serial Number: L84AI13201828
Subsystem 10 - Part No SW: 4N0-963-575
Component: V514 LLR1SKvLH01 0012
Serial Number: L84AI13201844
Subsystem 11 - Part No SW: 4N0-963-575
Component: V516 LLR1SLvRH01 0012
Serial Number: L84AI13201853
Subsystem 12 - Part No SW: 4N0-963-575
Component: V518 LLR1SKvRH01 0012
Serial Number: L84AI13201819
405507 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 4K0 907 561 A HW: 4K0 907 561
Component: LRR4R H04 0330
Coding: D6659F5478082C00010360E1000000BE4A1246484481009E04
ASAM Dataset: EV_ACCBOSCHAU65X 002022
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 2C1B97B3D8A4BFFEC3AA84-8079
002406 - 002406 - Unknown faultcode
Address 15: Airbags (J234) Labels: None
Part No SW: 4N0 959 655 N HW: 4N0 959 655 N
Component: AirbagVW31 H05 2710
Coding: BFCCFCC000C00000A000003FF20D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_AU58.rod
VCID: 47D1C81F61027CA6CED873-8012
Subsystem 1 - Part No SW: 4N0-980-945-A
Component: BeltPretRevFLH10 0115
Serial Number: 00AI2018221054700000
Coding: 04F001
Subsystem 2 - Part No SW: 4N0-980-946-A
Component: BeltPretRevFRH10 0115
Serial Number: 00AI2018208005900000
Coding: 04F001
Subsystem 3 - Part No SW: 4M0-959-339
Component: BF-Gewichtss.H11 0022
Serial Number: IBH0000J180009V9DR0Y
Coding: 303136
Subsystem 4 - Part No SW: --------------
Component: SideSensor_Df001 0887
Serial Number: 35700000000F53701339
Subsystem 5 - Part No SW: --------------
Component: SideSensor_Pf001 0887
Serial Number: 35800000000D13C4D23O
Subsystem 6 - Part No SW: --------------
Component: SideSensor_Dr002 0149
Serial Number: 351001C14E8A8450FAAP
Subsystem 7 - Part No SW: --------------
Component: SideSensor_Pr002 0149
Serial Number: 352001C14E8A81F0AAAS
Subsystem 8 - Part No SW: --------------
Component: FrontSensor_D002 0149
Serial Number: 355001C1440A4810CD85
Subsystem 9 - Part No SW: --------------
Component: FrontSensor_P002 0149
Serial Number: 356001C1440A88E0BB5H
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4N0 907 129 N HW: 4N0 907 129 N
Component: Lenks.Modul H03 0005
Shop #: WSC 00000 000
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 3C3BA7F328C42F7E534AF4-8069
Address 17: Instruments (J285) Labels: None
Part No SW: 4K0 920 790 C HW: 4K0 920 790 C
Component: FBenRDWACC--- H11 0153
Coding: 898650E3FC8800080293E1609880C80008002000
Shop #: WSC 05745 128 28889
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2D1D9AB7E3BEB6F6D4D491-8078
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4K0 907 468 C HW: 4K0 907 468 C
Component: Gateway H05 0117
Coding: 020100050004064054960000005B0132DCBA004F18000000097D078E10000000
ASAM Dataset: EV_Gatew31xAU65x 003160
ROD: EV_Gatew31xAU65x.rod
VCID: 342B8FD30094E73E9B1A5C-8061
Subsystem 1 - Part No SW: 4K0-951-523-J
Component: E221__MFL H06 0003
Serial Number: 00000000000000000000
Subsystem 2 - Part No SW: 4K0-915-181
Component: J367-BDMContiH03 1050
Serial Number: 7418631100180731067A
66304 - Databus
U1124 00 [008] - Additional Installations Detected
131687 - 131687 - Unknown faultcode
8519683 - Energy Management Active
U140B 00 [008] -
8531970 - Quiescent Current
U1406 00 [000] - Too High
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 C HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0802
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
VCID: 2E1F9DBBEEB8CDEEEDDE9E-807B
Address 22: AWD (J492) Labels: None
Part No SW: 4K0 927 755 HW: 0CJ 927 749 A
Component: C8_DL4_N_SD2
Coding: 170C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: F2A7C9CBBA00290EC9660A-80A7
Component: MEM-FS 009 0042
Coding: 001C9A400001BEA14803010101010000810000070700878700000000004000
ROD: EV_SCMDriveSideCONTIAU736_AU58.rod
Component: N475 VB1 FSv H04 0011
Serial Number: SJ80012007184025837D
Coding: BF2F00
458789 - Databus
Address 3C: Lane Change (J769) Labels: None
Part No SW: 4N0 907 566 E HW: 4N0 907 566 A
Component: MRR_HR H12 0265
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
VCID: 3833BBE31CFC035EB72208-806D
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS
Coding: 005DDB4252001482A009A430
ROD: EV_DCU2DriveSideMAXHKLO_AU58.rod
VCID: 40C3D303442C4B9E0F92A0-8015
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: E1002101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 312586C7FF86D216F0FC7D-8064
Address 46: Central Conv. (J393) Labels: None
Part No SW: 4N0 907 064 BD HW: 4N0 907 064 D
Component: BCM2 MLBevo H14 0145
Coding: 0134000049A100C0650FA0046C01080203004001810422502F0400000F04823F001E0101010F01
ASAM Dataset: EV_BCM2CONTIAU651 008007
ROD: EV_BCM2CONTIAU651_008.rod
VCID: 72A749CB3A00A90E49668A-8027
Subsystem 1 - Coding: 000000
Subsystem 2 -
Subsystem 3 -
Subsystem 4 -
Subsystem 5 - Part No SW: 5Q0-951-605-A
Serial Number: 00000000000045069938
Subsystem 6 - Part No SW: 4K8-945-069-C
Component: Slali1AU583 H03 0404
Serial Number:
Subsystem 7 - Part No SW: 3G0-962-243-C
Component: GEB.F.HeckoefH17 0906
Serial Number: 11165608
Subsystem 8 - Part No SW: 4K8-959-252
Component: J223 HSP 0304H02 0200
Serial Number: WA133582000053337988
Coding: 00FF00
Part No SW: 4N0 035 466 B HW: 4N0 035 466
Component: A2PA-3-AU H01 0029
Revision: --02S---
Coding: 0185030000A2AAAAAAA00A010000
ASAM Dataset: EV_AMPMst24C1Gen2pBAO 001006
ROD: EV_AMPMst24C1Gen2pBAO_AU58.rod
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS
Coding: 005DDB025E001482A009A430
ROD: EV_DCU2PasseSideMAXHKLO_AU58.rod
VCID: 3FC1D0FF39D234667668DB-806A
524378 - Databus
U1200 00 [008] - Defective
Part No SW: 4K0 035 084 A HW: 4K0 035 084 A
Component: MU-H-LNS-US 046 2482
Coding: 0185030200000000C1220002061C00302F0001E401F008048E
ROD: EV_MUHigGen2pALPI.rod
VCID: 240B7F93B07477BE0B7AEC-8071
Subsystem 1 - Part No SW: V03-959-804-CA
Component: MIB2P_NA_Q2180296
Subsystem 2 - Part No SW: 4K0-919-605-A
Component: DU AU58x HighH42 0144
Serial Number: INX00127061800060074
Subsystem 3 -
Subsystem 4 - Part No SW: V03-959-800-EG
Component: Gracenote2 3006
Subsystem 5 - Part No SW: 4K0-919-603-A
Component: DU AU58x Bot H41 0144
Serial Number: INX00119041800080307
Subsystem 6 - Part No SW: 4N0-035-123
Component: DISC PLAYER H06 0006
Serial Number: AUZ8ZCJKJ00ANLR
7219 - Function Restricted due to Missing Message(s)
U1111 00 [008] -
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 29156EA7D756AAD6388CA5-807C
Address 6D: Trunk Elect. (J605) Labels: 8W-6d.clb
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: --------
Coding: 1630
ROD: EV_DeckLidCONTIAU736_AU58.rod
VCID: 4AD7F12B721081CED1F652-801F
Address 74: Chassis Control (J775) Labels: None
Part No SW: 4K0 907 777 AS HW: 4K0 907 777 A
Component: Fahrwerk-SG H51 2016
Coding: 745D383BDA40
ASAM Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 88538B23AC9C33DE8742B8-80DD
Address 75: Telematics (J949) Labels: None
Part No SW: 4K1 035 283 HW: 4K1 035 283
Component: ConBox H07 0100
Coding: 01C020FF4040800000
ASAM Dataset: EV_ConBoxAU651 001004
ROD: EV_ConBoxAU651_001_AU58.rod
VCID: E58DA2977BCECEB65CE4B9-80B0
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0050
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 28136BA3CC5C93DE2782D8-807D
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 4K8 919 617 B HW: 4K8 919 617 B
Component: HeadupDisplay H13 1815
Coding: 4700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_AU58.rod
VCID: 3A37A1EB22F0114E4156E2-806F
Address A5: Frt Sens. Drv. Assist (J1121) Labels: None
Part No SW: 4KE 907 107 C HW: 4N0 907 107 H
Component: zFAS Var C H09 0290
Coding: 020184000000000000FFD60000F0D54C139F760000000000000000000096D401019BB8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_AU58.rod
2117692 - Control unit for information electronics 1
U1054 00 [008] - No Communication
233479 - Parking Sensor(s); Rear
U8E3550 F0 [008] - Function Limitation due to External Factors
233523 - Parking Sensor(s); Front
U8EB650 F0 [008] - Function Limitation due to External Factors
081922 - 081922 - Unknown faultcode
081924 - 081924 - Unknown faultcode
065537 - 065537 - Unknown faultcode
Address BB: Door Rear Drv Side (J388) Labels: None
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS
Coding: 004DDB0200001482E008A020
VCID: 42C7D90B4A20598E1986BA-8017
Address BC: Door Rear Pass Side (J389) Labels: None
Component: TSG HBFS
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
Address CA: Sunroof (J245) Labels: 4M0-907-594.clb
Part No SW: 4M0 907 594 BG HW: 4M0 907 594
Component: SAD_STG_1 014 0007
Coding: 268040058301
ASAM Dataset: EV_SunRoofCONTIAU736 008010
ROD: EV_SunRoofCONTIAU736_008.rod
VCID: 7CBB67F36844EF7E13CA34-8029
Address CB: Rear Axle Steering (J1019) Labels: None
Part No SW: 4N0 909 145 K HW: 4N0 909 145 C
Component: HAL_MLBevo
Revision: --------
Coding: 42244200
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
VCID: 3935BEE727F61A56482C15-806C
Address CC: Starter-Generator (----) Labels: None
Part No SW: 4N0 903 028 N HW: 4N0 903 028 N
Component: BSG-HP1-65 H17 0523
Coding: 20000400000000
ASAM Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
VCID: 362FB5DB16E8F52EA50E36-8063
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0201
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 352DB2D70BEEFE36AC0429-8060
11567105 - 11567105 - Unknown faultcode
Address CF: Lane Chge Asst 2 (J770) Labels: None
Component: MRR_HL H12 0265
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0030
ROD: EV_LMSLeftHELLAAU58X.rod
Address D7: Light Ctrl Right 2 (A27) Labels: None
Address DB: Frt Corner Rdar 1 (J1089) Labels: None
Part No SW: 4N0 907 669 E HW: 4N0 907 669 A
Component: MRR_VR H12 0265
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels: None
Component: MRR_VL H12 0265
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DE: Charger 1 for mobile dev (J1146) Labels: None
Part No SW: 4K0 035 502 A HW: 4K0 035 502 A
Component: WLC Front H10 0057
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_AU58.rod
VCID: 1F01707F9912546656283B-804A
